[PATCH v4 00/11] dra7: bring up and support IPU load/start
This patchset enables support for loading and starting IPU firmware, the following have been implemented: - Enable fs_loader compilation at SPL Level, that is necessary in order to load IPU firmware from /boot partition. - Define necessary related IPU dts nodes. - Add necessary drivers and helpers to bring up, load and start IPU firmware.
The underlying patches are interdependent, therefore should be applied in the order they are numbered in this patchset.
Tests: - Please find SPL, u-boot and kernel console logs in here [1] - At SPL stage, debug logs have been enabled to make sure that IPU1 and IPU2 are loaded and started properly. In fact, these two log messages are only displayed when the firmware has been loaded, and if no errors appear afterwards, it means that firmware started successfully as well: - Starting IPU1... - Starting IPU2...
At U-boot stage, "rproc" command-line tool was used for the testing. In the logs [1], "rproc list" was run before and after IPU1 and IPU2 are initialized by "rproc init". The before run gave an empty list, while the after run listed successfully the two IPUs with their correct addresses: - 0 - Name:'ipu@58820000' type:'internal memory mapped' - 1 - Name:'ipu@55020000' type:'internal memory mapped'
"rproc start" and "rproc stop" were also used for both IPU1 and IPU2, both were successful as no error logs were displayed.
[0]: https://pastebin.com/QGUYSPRt
These U-boot/SPL flags have been purposely enabled during tests to ensure IPU load/start work properly: - CONFIG_DM_RESET=y - CONFIG_RESET_DRA7=y - CONFIG_SPL_DM_RESET=y - CONFIG_FS_LOADER=y - CONFIG_SPL_FS_LOADER=y - CONFIG_SPL_DRIVERS_MISC_SUPPORT=y - CONFIG_REMOTEPROC_TI_IPU=y - CONFIG_SPL_REMOTEPROC=y - CONFIG_CMD_REMOTEPROC=y
Changes in v4: - Enable SPL fs_loader for j7200_evm_r5 and socfpga_arria10.
Changes in v3: - Add a new patch for dra7xx_evm to expand SPL_MULTI_DTB_FIT
Changes in v2: - Add useful checks and remove redundant code.
Amjad Ouled-Ameur (1): configs: dra7xx_evm: Increase the size of SPL_MULTI_DTB_FIT
Keerthy (10): reset: dra7: Add a reset driver arm: mach-omap2: load/start remoteproc IPU1/IPU2 drivers: misc: Makefile: Enable fs_loader compilation at SPL Level linux: bitmap.h: Add find_next_zero_area function remoteproc: uclass: Add remoteproc resource handling helpers remoteproc: ipu: Add driver to bring up ipu dts: dra7-ipu-common-early-boot.dtsi: Add all the ipu early boot related nodes arm: dts: dra7: Add ipu and related nodes arm: dts: dra7*/am57xx-idk-evm-u-boot: Add ipu early boot DT changes dts: am57xx*: Add ipu early boot DT changes
MAINTAINERS | 4 + .../dts/am57xx-beagle-x15-revb1-u-boot.dtsi | 7 + .../dts/am57xx-beagle-x15-revc-u-boot.dtsi | 7 + arch/arm/dts/am57xx-beagle-x15-u-boot.dtsi | 7 + arch/arm/dts/am57xx-cl-som-am57x-u-boot.dtsi | 7 + arch/arm/dts/am57xx-idk-common-u-boot.dtsi | 1 + arch/arm/dts/am57xx-sbc-am57x-u-boot.dtsi | 7 + arch/arm/dts/dra7-evm-u-boot.dtsi | 1 + arch/arm/dts/dra7-ipu-common-early-boot.dtsi | 113 +++ arch/arm/dts/dra7.dtsi | 45 +- arch/arm/dts/dra71-evm-u-boot.dtsi | 1 + arch/arm/dts/dra72-evm-revc-u-boot.dtsi | 1 + arch/arm/dts/dra76-evm-u-boot.dtsi | 1 + arch/arm/include/asm/arch-omap5/clock.h | 3 + arch/arm/include/asm/omap_common.h | 10 + arch/arm/mach-k3/common.c | 10 +- arch/arm/mach-omap2/boot-common.c | 95 +++ arch/arm/mach-omap2/clocks-common.c | 33 + arch/arm/mach-omap2/omap5/hw_data.c | 92 ++- arch/arm/mach-omap2/omap5/prcm-regs.c | 9 +- configs/dra7xx_evm_defconfig | 2 +- configs/j7200_evm_r5_defconfig | 1 + configs/j721e_evm_r5_defconfig | 1 + configs/j721e_hs_evm_r5_defconfig | 1 + configs/socfpga_arria10_defconfig | 1 + drivers/misc/Kconfig | 9 + drivers/misc/Makefile | 2 +- drivers/remoteproc/Kconfig | 10 + drivers/remoteproc/Makefile | 1 + drivers/remoteproc/ipu_rproc.c | 759 ++++++++++++++++++ drivers/remoteproc/rproc-uclass.c | 534 ++++++++++++ drivers/reset/Kconfig | 6 + drivers/reset/Makefile | 1 + drivers/reset/reset-dra7.c | 97 +++ include/linux/bitmap.h | 26 + include/remoteproc.h | 384 ++++++++- 36 files changed, 2271 insertions(+), 18 deletions(-) create mode 100644 arch/arm/dts/am57xx-beagle-x15-revb1-u-boot.dtsi create mode 100644 arch/arm/dts/am57xx-beagle-x15-revc-u-boot.dtsi create mode 100644 arch/arm/dts/am57xx-beagle-x15-u-boot.dtsi create mode 100644 arch/arm/dts/am57xx-cl-som-am57x-u-boot.dtsi create mode 100644 arch/arm/dts/am57xx-sbc-am57x-u-boot.dtsi create mode 100644 arch/arm/dts/dra7-ipu-common-early-boot.dtsi create mode 100644 drivers/remoteproc/ipu_rproc.c create mode 100644 drivers/reset/reset-dra7.c
Expand SPL_MULTI_DTB_FIT to accommodate new SPL IPU nodes.
Signed-off-by: Amjad Ouled-Ameur aouledameur@baylibre.com ---
(no changes since v1)
configs/dra7xx_evm_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index d1aa91d676e1..d3a1d3e4d334 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -52,7 +52,7 @@ CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIST="dra7-evm dra72-evm dra72-evm-revc dra71-evm dra76-evm" CONFIG_SPL_MULTI_DTB_FIT=y -CONFIG_SPL_MULTI_DTB_FIT_UNCOMPRESS_SZ=0xA000 +CONFIG_SPL_MULTI_DTB_FIT_UNCOMPRESS_SZ=0x10000 CONFIG_OF_SPL_REMOVE_PROPS="clocks clock-names interrupt-parent" CONFIG_ENV_OVERWRITE=y # CONFIG_ENV_IS_IN_FAT is not set
Add a reset driver to bring IPs out of reset.
Signed-off-by: Keerthy j-keerthy@ti.com [Amjad: reset_ops structure member "free" has been renamed to "rfree", use the latter instead] Signed-off-by: Amjad Ouled-Ameur aouledameur@baylibre.com ---
MAINTAINERS | 1 + drivers/reset/Kconfig | 6 +++ drivers/reset/Makefile | 1 + drivers/reset/reset-dra7.c | 97 ++++++++++++++++++++++++++++++++++++++ 4 files changed, 105 insertions(+) create mode 100644 drivers/reset/reset-dra7.c
diff --git a/MAINTAINERS b/MAINTAINERS index 38c68ee87d41..bd9cc4107cbe 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -536,6 +536,7 @@ F: drivers/ram/k3* F: drivers/remoteproc/k3_system_controller.c F: drivers/remoteproc/pruc_rpoc.c F: drivers/remoteproc/ti* +F: drivers/reset/reset-dra7.c F: drivers/reset/reset-ti-sci.c F: drivers/rtc/davinci.c F: drivers/serial/serial_omap.c diff --git a/drivers/reset/Kconfig b/drivers/reset/Kconfig index d73daf5e3189..b57714111b5a 100644 --- a/drivers/reset/Kconfig +++ b/drivers/reset/Kconfig @@ -206,4 +206,10 @@ config RESET_ZYNQMP passing request via Xilinx firmware interface to TF-A and PMU firmware.
+config RESET_DRA7 + bool "Support for TI's DRA7 Reset driver" + depends on DM_RESET + help + Support for TI DRA7-RESET subsystem. Basic Assert/Deassert + is supported. endmenu diff --git a/drivers/reset/Makefile b/drivers/reset/Makefile index d69486bdeb9e..97e3a782c0d8 100644 --- a/drivers/reset/Makefile +++ b/drivers/reset/Makefile @@ -30,3 +30,4 @@ obj-$(CONFIG_RESET_SYSCON) += reset-syscon.o obj-$(CONFIG_RESET_RASPBERRYPI) += reset-raspberrypi.o obj-$(CONFIG_RESET_SCMI) += reset-scmi.o obj-$(CONFIG_RESET_ZYNQMP) += reset-zynqmp.o +obj-$(CONFIG_RESET_DRA7) += reset-dra7.o diff --git a/drivers/reset/reset-dra7.c b/drivers/reset/reset-dra7.c new file mode 100644 index 000000000000..585f8323c52e --- /dev/null +++ b/drivers/reset/reset-dra7.c @@ -0,0 +1,97 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Texas Instruments DRA7 reset driver + * + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + * Author: Keerthy j-keerthy@ti.com + */ + +#include <asm/io.h> +#include <common.h> +#include <dm.h> +#include <reset-uclass.h> +#include <dm/device_compat.h> + +struct dra7_reset_priv { + u32 rstctrl; + u32 rstst; + u8 nreset; +}; + +static int dra7_reset_request(struct reset_ctl *reset_ctl) +{ + return 0; +} + +static int dra7_reset_free(struct reset_ctl *reset_ctl) +{ + return 0; +} + +static inline void dra7_reset_rmw(u32 addr, u32 value, u32 mask) +{ + writel(((readl(addr) & (~mask)) | (value & mask)), addr); +} + +static int dra7_reset_deassert(struct reset_ctl *reset_ctl) +{ + struct dra7_reset_priv *priv = dev_get_priv(reset_ctl->dev); + int mask = 1 << reset_ctl->id; + + if (reset_ctl->id < 0 || reset_ctl->id >= priv->nreset) + return -EINVAL; + + dra7_reset_rmw(priv->rstctrl, 0x0, mask); + + while ((readl(priv->rstst) & mask) != mask) + ; + + return 0; +} + +static int dra7_reset_assert(struct reset_ctl *reset_ctl) +{ + struct dra7_reset_priv *priv = dev_get_priv(reset_ctl->dev); + int mask = 1 << reset_ctl->id; + + if (reset_ctl->id < 0 || reset_ctl->id >= priv->nreset) + return -EINVAL; + + dra7_reset_rmw(priv->rstctrl, mask, 0x0); + + return 0; +} + +struct reset_ops dra7_reset_ops = { + .request = dra7_reset_request, + .rfree = dra7_reset_free, + .rst_assert = dra7_reset_assert, + .rst_deassert = dra7_reset_deassert, +}; + +static const struct udevice_id dra7_reset_ids[] = { + { .compatible = "ti,dra7-reset" }, + { } +}; + +static int dra7_reset_probe(struct udevice *dev) +{ + struct dra7_reset_priv *priv = dev_get_priv(dev); + + priv->rstctrl = dev_read_addr(dev); + priv->rstst = priv->rstctrl + 0x4; + priv->nreset = dev_read_u32_default(dev, "ti,nresets", 1); + + dev_info(dev, "dra7-reset successfully probed %s\n", dev->name); + + return 0; +} + +U_BOOT_DRIVER(dra7_reset) = { + .name = "dra7_reset", + .id = UCLASS_RESET, + .of_match = dra7_reset_ids, + .probe = dra7_reset_probe, + .ops = &dra7_reset_ops, + .priv_auto = sizeof(struct dra7_reset_priv), +};
First check the presence of the ipu firmware in the boot partition. If present enable the ipu and the related clocks & then move on to load the firmware and eventually start remoteproc IPU1/IPU2.
do_enable_clocks by default puts the clock domains into auto which does not work well with reset. Hence adding do_enable_ipu_clocks function.
Signed-off-by: Keerthy j-keerthy@ti.com [Amjad: fix IPU1_LOAD_ADDR and compile warnings] Signed-off-by: Amjad Ouled-Ameur aouledameur@baylibre.com ---
arch/arm/include/asm/arch-omap5/clock.h | 3 + arch/arm/include/asm/omap_common.h | 10 +++ arch/arm/mach-omap2/boot-common.c | 95 +++++++++++++++++++++++++ arch/arm/mach-omap2/clocks-common.c | 33 +++++++++ arch/arm/mach-omap2/omap5/hw_data.c | 92 ++++++++++++++++++++++-- arch/arm/mach-omap2/omap5/prcm-regs.c | 9 ++- 6 files changed, 235 insertions(+), 7 deletions(-)
diff --git a/arch/arm/include/asm/arch-omap5/clock.h b/arch/arm/include/asm/arch-omap5/clock.h index 87eb3f335ab0..a00626e357c9 100644 --- a/arch/arm/include/asm/arch-omap5/clock.h +++ b/arch/arm/include/asm/arch-omap5/clock.h @@ -135,6 +135,9 @@ #define HSMMC_CLKCTRL_CLKSEL_MASK (1 << 24) #define HSMMC_CLKCTRL_CLKSEL_DIV_MASK (3 << 25)
+/* CM_IPU1_IPU1_CLKCTRL CLKSEL MASK */ +#define IPU1_CLKCTRL_CLKSEL_MASK BIT(24) + /* CM_L3INIT_SATA_CLKCTRL */ #define SATA_CLKCTRL_OPTFCLKEN_MASK (1 << 8)
diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index de8fc99d0478..264a2e717a70 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -362,6 +362,10 @@ struct prcm_regs { /* IPU */ u32 cm_ipu_clkstctrl; u32 cm_ipu_i2c5_clkctrl; + u32 cm_ipu1_clkstctrl; + u32 cm_ipu1_ipu1_clkctrl; + u32 cm_ipu2_clkstctrl; + u32 cm_ipu2_ipu2_clkctrl;
/*l3main1 edma*/ u32 cm_l3main1_tptc1_clkctrl; @@ -632,6 +636,12 @@ void do_disable_clocks(u32 const *clk_domains, u8 wait_for_disable); #endif /* CONFIG_OMAP44XX || CONFIG_OMAP54XX */
+void do_enable_ipu_clocks(u32 const *clk_domains, + u32 const *clk_modules_hw_auto, + u32 const *clk_modules_explicit_en, + u8 wait_for_enable); +void enable_ipu1_clocks(void); +void enable_ipu2_clocks(void); void setup_post_dividers(u32 const base, const struct dpll_params *params); u32 omap_ddr_clk(void); diff --git a/arch/arm/mach-omap2/boot-common.c b/arch/arm/mach-omap2/boot-common.c index fdb8b479ea01..afc358564191 100644 --- a/arch/arm/mach-omap2/boot-common.c +++ b/arch/arm/mach-omap2/boot-common.c @@ -10,6 +10,8 @@ #include <common.h> #include <ahci.h> #include <log.h> +#include <dm/uclass.h> +#include <fs_loader.h> #include <spl.h> #include <asm/global_data.h> #include <asm/omap_common.h> @@ -19,9 +21,14 @@ #include <watchdog.h> #include <scsi.h> #include <i2c.h> +#include <remoteproc.h>
DECLARE_GLOBAL_DATA_PTR;
+#define IPU1_LOAD_ADDR (0xa17ff000) +#define MAX_REMOTECORE_BIN_SIZE (8 * 0x100000) +#define IPU2_LOAD_ADDR (IPU1_LOAD_ADDR + MAX_REMOTECORE_BIN_SIZE) + __weak u32 omap_sys_boot_device(void) { return BOOT_DEVICE_NONE; @@ -194,6 +201,91 @@ u32 spl_mmc_boot_mode(const u32 boot_device) return gd->arch.omap_boot_mode; }
+int load_firmware(char *name_fw, u32 *loadaddr) +{ + struct udevice *fsdev; + int size = 0; + + if (!IS_ENABLED(CONFIG_FS_LOADER)) + return 0; + + if (!*loadaddr) + return 0; + + if (!uclass_get_device(UCLASS_FS_FIRMWARE_LOADER, 0, &fsdev)) { + size = request_firmware_into_buf(fsdev, name_fw, + (void *)*loadaddr, 0, 0); + } + + return size; +} + +void spl_boot_ipu(void) +{ + int ret, size; + u32 loadaddr = IPU1_LOAD_ADDR; + + if (!IS_ENABLED(CONFIG_SPL_BUILD) || + !IS_ENABLED(CONFIG_REMOTEPROC_TI_IPU)) + return; + + size = load_firmware("dra7-ipu1-fw.xem4", &loadaddr); + if (size <= 0) { + pr_err("Firmware loading failed\n"); + goto skip_ipu1; + } + + enable_ipu1_clocks(); + ret = rproc_dev_init(0); + if (ret) { + debug("%s: IPU1 failed to initialize on rproc (%d)\n", + __func__, ret); + goto skip_ipu1; + } + + ret = rproc_load(0, IPU1_LOAD_ADDR, 0x2000000); + if (ret) { + debug("%s: IPU1 failed to load on rproc (%d)\n", __func__, + ret); + goto skip_ipu1; + } + + debug("Starting IPU1...\n"); + + ret = rproc_start(0); + if (ret) + debug("%s: IPU1 failed to start (%d)\n", __func__, ret); + +skip_ipu1: + loadaddr = IPU2_LOAD_ADDR; + size = load_firmware("dra7-ipu2-fw.xem4", &loadaddr); + if (size <= 0) { + pr_err("Firmware loading failed for ipu2\n"); + return; + } + + enable_ipu2_clocks(); + ret = rproc_dev_init(1); + if (ret) { + debug("%s: IPU2 failed to initialize on rproc (%d)\n", __func__, + ret); + return; + } + + ret = rproc_load(1, IPU2_LOAD_ADDR, 0x2000000); + if (ret) { + debug("%s: IPU2 failed to load on rproc (%d)\n", __func__, + ret); + return; + } + + debug("Starting IPU2...\n"); + + ret = rproc_start(1); + if (ret) + debug("%s: IPU2 failed to start (%d)\n", __func__, ret); +} + void spl_board_init(void) { /* Prepare console output */ @@ -214,6 +306,9 @@ void spl_board_init(void) #ifdef CONFIG_AM33XX am33xx_spl_board_init(); #endif + if (IS_ENABLED(CONFIG_SPL_BUILD) && + IS_ENABLED(CONFIG_REMOTEPROC_TI_IPU)) + spl_boot_ipu(); }
void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) diff --git a/arch/arm/mach-omap2/clocks-common.c b/arch/arm/mach-omap2/clocks-common.c index 1d8eab2dab50..390d1f2a649b 100644 --- a/arch/arm/mach-omap2/clocks-common.c +++ b/arch/arm/mach-omap2/clocks-common.c @@ -858,6 +858,39 @@ void do_enable_clocks(u32 const *clk_domains, } }
+void do_enable_ipu_clocks(u32 const *clk_domains, + u32 const *clk_modules_hw_auto, + u32 const *clk_modules_explicit_en, + u8 wait_for_enable) +{ + u32 i, max = 10; + + if (!IS_ENABLED(CONFIG_REMOTEPROC_TI_IPU)) + return; + + /* Put the clock domains in SW_WKUP mode */ + for (i = 0; (i < max) && clk_domains && clk_domains[i]; i++) { + enable_clock_domain(clk_domains[i], + CD_CLKCTRL_CLKTRCTRL_SW_WKUP); + } + + /* Clock modules that need to be put in HW_AUTO */ + for (i = 0; (i < max) && clk_modules_hw_auto && + clk_modules_hw_auto[i]; i++) { + enable_clock_module(clk_modules_hw_auto[i], + MODULE_CLKCTRL_MODULEMODE_HW_AUTO, + wait_for_enable); + }; + + /* Clock modules that need to be put in SW_EXPLICIT_EN mode */ + for (i = 0; (i < max) && clk_modules_explicit_en && + clk_modules_explicit_en[i]; i++) { + enable_clock_module(clk_modules_explicit_en[i], + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN, + wait_for_enable); + }; +} + void do_disable_clocks(u32 const *clk_domains, u32 const *clk_modules_disable, u8 wait_for_disable) diff --git a/arch/arm/mach-omap2/omap5/hw_data.c b/arch/arm/mach-omap2/omap5/hw_data.c index fa4e27063c53..e6bee48dfcb3 100644 --- a/arch/arm/mach-omap2/omap5/hw_data.c +++ b/arch/arm/mach-omap2/omap5/hw_data.c @@ -376,6 +376,85 @@ struct vcores_data omap5430_volts_es2 = { .mm.efuse.reg_bits = OMAP5_ES2_PROD_REGBITS, };
+/* + * Enable IPU1 clock domains, modules and + * do some additional special settings needed + */ +void enable_ipu1_clocks(void) +{ + if (!IS_ENABLED(CONFIG_DRA7XX) || + !IS_ENABLED(CONFIG_REMOTEPROC_TI_IPU)) + return; + + u32 const clk_domains[] = { + (*prcm)->cm_ipu_clkstctrl, + (*prcm)->cm_ipu1_clkstctrl, + 0 + }; + + u32 const clk_modules_hw_auto_essential[] = { + (*prcm)->cm_ipu1_ipu1_clkctrl, + 0 + }; + + u32 const clk_modules_explicit_en_essential[] = { + (*prcm)->cm_l4per_gptimer11_clkctrl, + (*prcm)->cm1_abe_timer7_clkctrl, + (*prcm)->cm1_abe_timer8_clkctrl, + 0 + }; + do_enable_ipu_clocks(clk_domains, clk_modules_hw_auto_essential, + clk_modules_explicit_en_essential, 0); + + /* Enable optional additional functional clock for IPU1 */ + setbits_le32((*prcm)->cm_ipu1_ipu1_clkctrl, + IPU1_CLKCTRL_CLKSEL_MASK); + /* Enable optional additional functional clock for IPU1 */ + setbits_le32((*prcm)->cm1_abe_timer7_clkctrl, + IPU1_CLKCTRL_CLKSEL_MASK); + /* Enable optional additional functional clock for IPU1 */ + setbits_le32((*prcm)->cm1_abe_timer8_clkctrl, + IPU1_CLKCTRL_CLKSEL_MASK); +} + +/* + * Enable IPU2 clock domains, modules and + * do some additional special settings needed + */ +void enable_ipu2_clocks(void) +{ + if (!IS_ENABLED(CONFIG_DRA7XX) || + !IS_ENABLED(CONFIG_REMOTEPROC_TI_IPU)) + return; + + u32 const clk_domains[] = { + (*prcm)->cm_ipu_clkstctrl, + (*prcm)->cm_ipu2_clkstctrl, + 0 + }; + + u32 const clk_modules_hw_auto_essential[] = { + (*prcm)->cm_ipu2_ipu2_clkctrl, + 0 + }; + + u32 const clk_modules_explicit_en_essential[] = { + (*prcm)->cm_l4per_gptimer3_clkctrl, + (*prcm)->cm_l4per_gptimer4_clkctrl, + (*prcm)->cm_l4per_gptimer9_clkctrl, + 0 + }; + do_enable_ipu_clocks(clk_domains, clk_modules_hw_auto_essential, + clk_modules_explicit_en_essential, 0); + + /* Enable optional additional functional clock for IPU2 */ + setbits_le32((*prcm)->cm_l4per_gptimer4_clkctrl, + IPU1_CLKCTRL_CLKSEL_MASK); + /* Enable optional additional functional clock for IPU2 */ + setbits_le32((*prcm)->cm_l4per_gptimer9_clkctrl, + IPU1_CLKCTRL_CLKSEL_MASK); +} + /* * Enable essential clock domains, modules and * do some additional special settings needed @@ -478,12 +557,13 @@ void enable_basic_clocks(void)
void enable_basic_uboot_clocks(void) { - u32 const clk_domains_essential[] = { -#if defined(CONFIG_DRA7XX) - (*prcm)->cm_ipu_clkstctrl, -#endif - 0 - }; + u32 cm_ipu_clkstctrl = 0; + + if (IS_ENABLED(CONFIG_DRA7XX) && + !IS_ENABLED(CONFIG_REMOTEPROC_TI_IPU)) + cm_ipu_clkstctrl = (*prcm)->cm_ipu_clkstctrl; + + u32 const clk_domains_essential[] = {cm_ipu_clkstctrl, 0};
u32 const clk_modules_hw_auto_essential[] = { (*prcm)->cm_l3init_hsusbtll_clkctrl, diff --git a/arch/arm/mach-omap2/omap5/prcm-regs.c b/arch/arm/mach-omap2/omap5/prcm-regs.c index 28c4f4f73749..d7196a3156c9 100644 --- a/arch/arm/mach-omap2/omap5/prcm-regs.c +++ b/arch/arm/mach-omap2/omap5/prcm-regs.c @@ -832,7 +832,10 @@ struct prcm_regs const dra7xx_prcm = { /* cm IPU */ .cm_ipu_clkstctrl = 0x4a005540, .cm_ipu_i2c5_clkctrl = 0x4a005578, - + .cm_ipu1_clkstctrl = 0x4a005500, + .cm_ipu1_ipu1_clkctrl = 0x4a005520, + .cm_ipu2_clkstctrl = 0x4a008900, + .cm_ipu2_ipu2_clkctrl = 0x4a008920, /* prm irqstatus regs */ .prm_irqstatus_mpu = 0x4ae06010, .prm_irqstatus_mpu_2 = 0x4ae06014, @@ -1013,6 +1016,10 @@ struct prcm_regs const dra7xx_prcm = { /*l3main1 edma*/ .cm_l3main1_tptc1_clkctrl = 0x4a008778, .cm_l3main1_tptc2_clkctrl = 0x4a008780, + + /* cm1.abe */ + .cm1_abe_timer7_clkctrl = 0x4a005568, + .cm1_abe_timer8_clkctrl = 0x4a005570, };
void clrset_spare_register(u8 spare_type, u32 clear_bits, u32 set_bits)
Enable fs_loader compilation at SPL Level.
Signed-off-by: Keerthy j-keerthy@ti.com [Amjad: fix compilation failures for J721e platform] Signed-off-by: Amjad Ouled-Ameur aouledameur@baylibre.com
arch/arm/mach-k3/common.c | 10 +++------- configs/j7200_evm_r5_defconfig | 1 + configs/j721e_evm_r5_defconfig | 1 + configs/j721e_hs_evm_r5_defconfig | 1 + configs/socfpga_arria10_defconfig | 1 + drivers/misc/Kconfig | 9 +++++++++ drivers/misc/Makefile | 2 +- 7 files changed, 17 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-k3/common.c b/arch/arm/mach-k3/common.c index 39d00270b7fa..b4b75f4e6c86 100644 --- a/arch/arm/mach-k3/common.c +++ b/arch/arm/mach-k3/common.c @@ -156,13 +156,15 @@ void init_env(void) #endif }
-#ifdef CONFIG_FS_LOADER int load_firmware(char *name_fw, char *name_loadaddr, u32 *loadaddr) { struct udevice *fsdev; char *name = NULL; int size = 0;
+ if (!IS_ENABLED(CONFIG_FS_LOADER)) + return 0; + *loadaddr = 0; #ifdef CONFIG_SPL_ENV_SUPPORT switch (spl_boot_device()) { @@ -186,12 +188,6 @@ int load_firmware(char *name_fw, char *name_loadaddr, u32 *loadaddr)
return size; } -#else -int load_firmware(char *name_fw, char *name_loadaddr, u32 *loadaddr) -{ - return 0; -} -#endif
__weak void release_resources_for_core_shutdown(void) { diff --git a/configs/j7200_evm_r5_defconfig b/configs/j7200_evm_r5_defconfig index aeb76e8023f1..f5a8f325c0f1 100644 --- a/configs/j7200_evm_r5_defconfig +++ b/configs/j7200_evm_r5_defconfig @@ -91,6 +91,7 @@ CONFIG_SYS_I2C_OMAP24XX=y CONFIG_DM_MAILBOX=y CONFIG_K3_SEC_PROXY=y CONFIG_FS_LOADER=y +CONFIG_SPL_FS_LOADER=y CONFIG_K3_AVS0=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_SPL_MMC_HS400_SUPPORT=y diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index b0759d1f305d..1fb13a8a707d 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -88,6 +88,7 @@ CONFIG_SYS_I2C_OMAP24XX=y CONFIG_DM_MAILBOX=y CONFIG_K3_SEC_PROXY=y CONFIG_FS_LOADER=y +CONFIG_SPL_FS_LOADER=y CONFIG_ESM_K3=y CONFIG_K3_AVS0=y CONFIG_ESM_PMIC=y diff --git a/configs/j721e_hs_evm_r5_defconfig b/configs/j721e_hs_evm_r5_defconfig index 3d2bbb4844e8..1e4a93ff53fe 100644 --- a/configs/j721e_hs_evm_r5_defconfig +++ b/configs/j721e_hs_evm_r5_defconfig @@ -82,6 +82,7 @@ CONFIG_SYS_I2C_OMAP24XX=y CONFIG_DM_MAILBOX=y CONFIG_K3_SEC_PROXY=y CONFIG_FS_LOADER=y +CONFIG_SPL_FS_LOADER=y CONFIG_K3_AVS0=y CONFIG_MMC_SDHCI=y CONFIG_SPL_MMC_SDHCI_ADMA=y diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig index d6b744475039..63284cb0eb54 100644 --- a/configs/socfpga_arria10_defconfig +++ b/configs/socfpga_arria10_defconfig @@ -40,6 +40,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DWAPB_GPIO=y CONFIG_FS_LOADER=y +CONFIG_SPL_FS_LOADER=y CONFIG_MMC_DW=y CONFIG_MTD=y CONFIG_PHY_MICREL=y diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index a8baaeaf5cfe..0ade3e32b0ef 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -453,6 +453,15 @@ config FS_LOADER The consumer driver would then use this loader to program whatever, ie. the FPGA device.
+config SPL_FS_LOADER + bool "Enable loader driver for file system" + help + This is file system generic loader which can be used to load + the file image from the storage into target such as memory. + + The consumer driver would then use this loader to program whatever, + ie. the FPGA device. + config GDSYS_SOC bool "Enable gdsys SOC driver" depends on MISC diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index f9826d2462d1..bca7b24e99ad 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -37,7 +37,7 @@ obj-$(CONFIG_FSL_IFC) += fsl_ifc.o obj-$(CONFIG_FSL_IIM) += fsl_iim.o obj-$(CONFIG_FSL_MC9SDZ60) += mc9sdz60.o obj-$(CONFIG_FSL_SEC_MON) += fsl_sec_mon.o -obj-$(CONFIG_FS_LOADER) += fs_loader.o +obj-$(CONFIG_$(SPL_)FS_LOADER) += fs_loader.o obj-$(CONFIG_GDSYS_IOEP) += gdsys_ioep.o obj-$(CONFIG_GDSYS_RXAUI_CTRL) += gdsys_rxaui_ctrl.o obj-$(CONFIG_GDSYS_SOC) += gdsys_soc.o
Add find_next_zero_area to fetch the next zero area in the map.
Signed-off-by: Keerthy j-keerthy@ti.com Signed-off-by: Amjad Ouled-Ameur aouledameur@baylibre.com ---
include/linux/bitmap.h | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/include/linux/bitmap.h b/include/linux/bitmap.h index dae4225be549..0a8503af9f14 100644 --- a/include/linux/bitmap.h +++ b/include/linux/bitmap.h @@ -159,6 +159,32 @@ static inline unsigned long find_first_bit(const unsigned long *addr, unsigned l (bit) < (size); \ (bit) = find_next_bit((addr), (size), (bit) + 1))
+static inline unsigned long +bitmap_find_next_zero_area(unsigned long *map, + unsigned long size, + unsigned long start, + unsigned int nr, unsigned long align_mask) +{ + unsigned long index, end, i; +again: + index = find_next_zero_bit(map, size, start); + + /* + * Align allocation + */ + index = (index + align_mask) & ~align_mask; + + end = index + nr; + if (end > size) + return end; + i = find_next_bit(map, end, index); + if (i < end) { + start = i + 1; + goto again; + } + return index; +} + static inline void bitmap_fill(unsigned long *dst, unsigned int nbits) { if (small_const_nbits(nbits)) {
Add remoteproc resource handling helpers. These functions are primarily to parse the resource table and to handle different types of resources. Carveout, devmem, trace & vring resources are handled.
Signed-off-by: Keerthy j-keerthy@ti.com [Amjad: fix redefinition of "struct resource_table" and compile warnings ] Signed-off-by: Amjad Ouled-Ameur aouledameur@baylibre.com
(no changes since v2)
drivers/remoteproc/rproc-uclass.c | 534 ++++++++++++++++++++++++++++++ include/remoteproc.h | 384 ++++++++++++++++++++- 2 files changed, 917 insertions(+), 1 deletion(-)
diff --git a/drivers/remoteproc/rproc-uclass.c b/drivers/remoteproc/rproc-uclass.c index 87e1ec7ad7f0..50bcc9030e98 100644 --- a/drivers/remoteproc/rproc-uclass.c +++ b/drivers/remoteproc/rproc-uclass.c @@ -8,15 +8,31 @@
#define pr_fmt(fmt) "%s: " fmt, __func__ #include <common.h> +#include <elf.h> #include <errno.h> #include <log.h> #include <malloc.h> +#include <virtio_ring.h> #include <remoteproc.h> #include <asm/io.h> #include <dm/device-internal.h> #include <dm.h> #include <dm/uclass.h> #include <dm/uclass-internal.h> +#include <linux/compat.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct resource_table { + u32 ver; + u32 num; + u32 reserved[2]; + u32 offset[0]; +} __packed; + +typedef int (*handle_resource_t) (struct udevice *, void *, int offset, int avail); + +static struct resource_table *rsc_table;
/** * for_each_remoteproc_device() - iterate through the list of rproc devices @@ -196,6 +212,80 @@ static int rproc_post_probe(struct udevice *dev) return 0; }
+/** + * rproc_add_res() - After parsing the resource table add the mappings + * @dev: device we finished probing + * @mapping: rproc_mem_entry for the resource + * + * Return: if the remote proc driver has a add_res routine, invokes it and + * hands over the return value. overall, 0 if all went well, else appropriate + * error value. + */ +static int rproc_add_res(struct udevice *dev, struct rproc_mem_entry *mapping) +{ + const struct dm_rproc_ops *ops = rproc_get_ops(dev); + + if (!ops->add_res) + return -ENOSYS; + + return ops->add_res(dev, mapping); +} + +/** + * rproc_alloc_mem() - After parsing the resource table allocat mem + * @dev: device we finished probing + * @len: rproc_mem_entry for the resource + * @align: alignment for the resource + * + * Return: if the remote proc driver has a add_res routine, invokes it and + * hands over the return value. overall, 0 if all went well, else appropriate + * error value. + */ +static void *rproc_alloc_mem(struct udevice *dev, unsigned long len, + unsigned long align) +{ + const struct dm_rproc_ops *ops; + + ops = rproc_get_ops(dev); + if (!ops) { + debug("%s driver has no ops?\n", dev->name); + return NULL; + } + + if (ops->alloc_mem) + return ops->alloc_mem(dev, len, align); + + return NULL; +} + +/** + * rproc_config_pagetable() - Configure page table for remote processor + * @dev: device we finished probing + * @virt: Virtual address of the resource + * @phys: Physical address the resource + * @len: length the resource + * + * Return: if the remote proc driver has a add_res routine, invokes it and + * hands over the return value. overall, 0 if all went well, else appropriate + * error value. + */ +static int rproc_config_pagetable(struct udevice *dev, unsigned int virt, + unsigned int phys, unsigned int len) +{ + const struct dm_rproc_ops *ops; + + ops = rproc_get_ops(dev); + if (!ops) { + debug("%s driver has no ops?\n", dev->name); + return -EINVAL; + } + + if (ops->config_pagetable) + return ops->config_pagetable(dev, virt, phys, len); + + return 0; +} + UCLASS_DRIVER(rproc) = { .id = UCLASS_REMOTEPROC, .name = "remoteproc", @@ -426,3 +516,447 @@ int rproc_is_running(int id) { return _rproc_ops_wrapper(id, RPROC_RUNNING); }; + + +static int handle_trace(struct udevice *dev, struct fw_rsc_trace *rsc, + int offset, int avail) +{ + if (sizeof(*rsc) > avail) { + debug("trace rsc is truncated\n"); + return -EINVAL; + } + + /* + * make sure reserved bytes are zeroes + */ + if (rsc->reserved) { + debug("trace rsc has non zero reserved bytes\n"); + return -EINVAL; + } + + debug("trace rsc: da 0x%x, len 0x%x\n", rsc->da, rsc->len); + + return 0; +} + +static int handle_devmem(struct udevice *dev, struct fw_rsc_devmem *rsc, + int offset, int avail) +{ + struct rproc_mem_entry *mapping; + + if (sizeof(*rsc) > avail) { + debug("devmem rsc is truncated\n"); + return -EINVAL; + } + + /* + * make sure reserved bytes are zeroes + */ + if (rsc->reserved) { + debug("devmem rsc has non zero reserved bytes\n"); + return -EINVAL; + } + + debug("devmem rsc: pa 0x%x, da 0x%x, len 0x%x\n", + rsc->pa, rsc->da, rsc->len); + + rproc_config_pagetable(dev, rsc->da, rsc->pa, rsc->len); + + mapping = kzalloc(sizeof(*mapping), GFP_KERNEL); + if (!mapping) + return -ENOMEM; + + /* + * We'll need this info later when we'll want to unmap everything + * (e.g. on shutdown). + * + * We can't trust the remote processor not to change the resource + * table, so we must maintain this info independently. + */ + mapping->dma = rsc->pa; + mapping->da = rsc->da; + mapping->len = rsc->len; + rproc_add_res(dev, mapping); + + debug("mapped devmem pa 0x%x, da 0x%x, len 0x%x\n", + rsc->pa, rsc->da, rsc->len); + + return 0; +} + +static int handle_carveout(struct udevice *dev, struct fw_rsc_carveout *rsc, + int offset, int avail) +{ + struct rproc_mem_entry *mapping; + + if (sizeof(*rsc) > avail) { + debug("carveout rsc is truncated\n"); + return -EINVAL; + } + + /* + * make sure reserved bytes are zeroes + */ + if (rsc->reserved) { + debug("carveout rsc has non zero reserved bytes\n"); + return -EINVAL; + } + + debug("carveout rsc: da %x, pa %x, len %x, flags %x\n", + rsc->da, rsc->pa, rsc->len, rsc->flags); + + rsc->pa = (uintptr_t)rproc_alloc_mem(dev, rsc->len, 8); + if (!rsc->pa) { + debug + ("failed to allocate carveout rsc: da %x, pa %x, len %x, flags %x\n", + rsc->da, rsc->pa, rsc->len, rsc->flags); + return -ENOMEM; + } + rproc_config_pagetable(dev, rsc->da, rsc->pa, rsc->len); + + /* + * Ok, this is non-standard. + * + * Sometimes we can't rely on the generic iommu-based DMA API + * to dynamically allocate the device address and then set the IOMMU + * tables accordingly, because some remote processors might + * _require_ us to use hard coded device addresses that their + * firmware was compiled with. + * + * In this case, we must use the IOMMU API directly and map + * the memory to the device address as expected by the remote + * processor. + * + * Obviously such remote processor devices should not be configured + * to use the iommu-based DMA API: we expect 'dma' to contain the + * physical address in this case. + */ + mapping = kzalloc(sizeof(*mapping), GFP_KERNEL); + if (!mapping) + return -ENOMEM; + + /* + * We'll need this info later when we'll want to unmap + * everything (e.g. on shutdown). + * + * We can't trust the remote processor not to change the + * resource table, so we must maintain this info independently. + */ + mapping->dma = rsc->pa; + mapping->da = rsc->da; + mapping->len = rsc->len; + rproc_add_res(dev, mapping); + + debug("carveout mapped 0x%x to 0x%x\n", rsc->da, rsc->pa); + + return 0; +} + +#define RPROC_PAGE_SHIFT 12 +#define RPROC_PAGE_SIZE BIT(RPROC_PAGE_SHIFT) +#define RPROC_PAGE_ALIGN(x) (((x) + (RPROC_PAGE_SIZE - 1)) & ~(RPROC_PAGE_SIZE - 1)) + +static int alloc_vring(struct udevice *dev, struct fw_rsc_vdev *rsc, int i) +{ + struct fw_rsc_vdev_vring *vring = &rsc->vring[i]; + int size; + int order; + void *pa; + + debug("vdev rsc: vring%d: da %x, qsz %d, align %d\n", + i, vring->da, vring->num, vring->align); + + /* + * verify queue size and vring alignment are sane + */ + if (!vring->num || !vring->align) { + debug("invalid qsz (%d) or alignment (%d)\n", vring->num, + vring->align); + return -EINVAL; + } + + /* + * actual size of vring (in bytes) + */ + size = RPROC_PAGE_ALIGN(vring_size(vring->num, vring->align)); + order = vring->align >> RPROC_PAGE_SHIFT; + + pa = rproc_alloc_mem(dev, size, order); + if (!pa) { + debug("failed to allocate vring rsc\n"); + return -ENOMEM; + } + debug("alloc_mem(%#x, %d): %p\n", size, order, pa); + vring->da = (uintptr_t)pa; + + return !pa; +} + +static int handle_vdev(struct udevice *dev, struct fw_rsc_vdev *rsc, + int offset, int avail) +{ + int i, ret; + void *pa; + + /* + * make sure resource isn't truncated + */ + if (sizeof(*rsc) + rsc->num_of_vrings * sizeof(struct fw_rsc_vdev_vring) + + rsc->config_len > avail) { + debug("vdev rsc is truncated\n"); + return -EINVAL; + } + + /* + * make sure reserved bytes are zeroes + */ + if (rsc->reserved[0] || rsc->reserved[1]) { + debug("vdev rsc has non zero reserved bytes\n"); + return -EINVAL; + } + + debug("vdev rsc: id %d, dfeatures %x, cfg len %d, %d vrings\n", + rsc->id, rsc->dfeatures, rsc->config_len, rsc->num_of_vrings); + + /* + * we currently support only two vrings per rvdev + */ + if (rsc->num_of_vrings > 2) { + debug("too many vrings: %d\n", rsc->num_of_vrings); + return -EINVAL; + } + + /* + * allocate the vrings + */ + for (i = 0; i < rsc->num_of_vrings; i++) { + ret = alloc_vring(dev, rsc, i); + if (ret) + goto alloc_error; + } + + pa = rproc_alloc_mem(dev, RPMSG_TOTAL_BUF_SPACE, 6); + if (!pa) { + debug("failed to allocate vdev rsc\n"); + return -ENOMEM; + } + debug("vring buffer alloc_mem(%#x, 6): %p\n", RPMSG_TOTAL_BUF_SPACE, + pa); + + return 0; + + alloc_error: + return ret; +} + +/* + * A lookup table for resource handlers. The indices are defined in + * enum fw_resource_type. + */ +static handle_resource_t loading_handlers[RSC_LAST] = { + [RSC_CARVEOUT] = (handle_resource_t)handle_carveout, + [RSC_DEVMEM] = (handle_resource_t)handle_devmem, + [RSC_TRACE] = (handle_resource_t)handle_trace, + [RSC_VDEV] = (handle_resource_t)handle_vdev, +}; + +/* + * handle firmware resource entries before booting the remote processor + */ +static int handle_resources(struct udevice *dev, int len, + handle_resource_t handlers[RSC_LAST]) +{ + handle_resource_t handler; + int ret = 0, i; + + for (i = 0; i < rsc_table->num; i++) { + int offset = rsc_table->offset[i]; + struct fw_rsc_hdr *hdr = (void *)rsc_table + offset; + int avail = len - offset - sizeof(*hdr); + void *rsc = (void *)hdr + sizeof(*hdr); + + /* + * make sure table isn't truncated + */ + if (avail < 0) { + debug("rsc table is truncated\n"); + return -EINVAL; + } + + debug("rsc: type %d\n", hdr->type); + + if (hdr->type >= RSC_LAST) { + debug("unsupported resource %d\n", hdr->type); + continue; + } + + handler = handlers[hdr->type]; + if (!handler) + continue; + + ret = handler(dev, rsc, offset + sizeof(*hdr), avail); + if (ret) + break; + } + + return ret; +} + +static int +handle_intmem_to_l3_mapping(struct udevice *dev, + struct rproc_intmem_to_l3_mapping *l3_mapping) +{ + u32 i = 0; + + for (i = 0; i < l3_mapping->num_entries; i++) { + struct l3_map *curr_map = &l3_mapping->mappings[i]; + struct rproc_mem_entry *mapping; + + mapping = kzalloc(sizeof(*mapping), GFP_KERNEL); + if (!mapping) + return -ENOMEM; + + mapping->dma = curr_map->l3_addr; + mapping->da = curr_map->priv_addr; + mapping->len = curr_map->len; + rproc_add_res(dev, mapping); + } + + return 0; +} + +static Elf32_Shdr *rproc_find_table(unsigned int addr) +{ + Elf32_Ehdr *ehdr; /* Elf header structure pointer */ + Elf32_Shdr *shdr; /* Section header structure pointer */ + Elf32_Shdr sectionheader; + int i; + u8 *elf_data; + char *name_table; + struct resource_table *ptable; + + ehdr = (Elf32_Ehdr *)(uintptr_t)addr; + elf_data = (u8 *)ehdr; + shdr = (Elf32_Shdr *)(elf_data + ehdr->e_shoff); + memcpy(§ionheader, &shdr[ehdr->e_shstrndx], sizeof(sectionheader)); + name_table = (char *)(elf_data + sectionheader.sh_offset); + + for (i = 0; i < ehdr->e_shnum; i++, shdr++) { + memcpy(§ionheader, shdr, sizeof(sectionheader)); + u32 size = sectionheader.sh_size; + u32 offset = sectionheader.sh_offset; + + if (strcmp + (name_table + sectionheader.sh_name, ".resource_table")) + continue; + + ptable = (struct resource_table *)(elf_data + offset); + + /* + * make sure table has at least the header + */ + if (sizeof(struct resource_table) > size) { + debug("header-less resource table\n"); + return NULL; + } + + /* + * we don't support any version beyond the first + */ + if (ptable->ver != 1) { + debug("unsupported fw ver: %d\n", ptable->ver); + return NULL; + } + + /* + * make sure reserved bytes are zeroes + */ + if (ptable->reserved[0] || ptable->reserved[1]) { + debug("non zero reserved bytes\n"); + return NULL; + } + + /* + * make sure the offsets array isn't truncated + */ + if (ptable->num * sizeof(ptable->offset[0]) + + sizeof(struct resource_table) > size) { + debug("resource table incomplete\n"); + return NULL; + } + + return shdr; + } + + return NULL; +} + +struct resource_table *rproc_find_resource_table(struct udevice *dev, + unsigned int addr, + int *tablesz) +{ + Elf32_Shdr *shdr; + Elf32_Shdr sectionheader; + struct resource_table *ptable; + u8 *elf_data = (u8 *)(uintptr_t)addr; + + shdr = rproc_find_table(addr); + if (!shdr) { + debug("%s: failed to get resource section header\n", __func__); + return NULL; + } + + memcpy(§ionheader, shdr, sizeof(sectionheader)); + ptable = (struct resource_table *)(elf_data + sectionheader.sh_offset); + if (tablesz) + *tablesz = sectionheader.sh_size; + + return ptable; +} + +unsigned long rproc_parse_resource_table(struct udevice *dev, struct rproc *cfg) +{ + struct resource_table *ptable = NULL; + int tablesz; + int ret; + unsigned long addr; + + addr = cfg->load_addr; + + ptable = rproc_find_resource_table(dev, addr, &tablesz); + if (!ptable) { + debug("%s : failed to find resource table\n", __func__); + return 0; + } + + debug("%s : found resource table\n", __func__); + rsc_table = kzalloc(tablesz, GFP_KERNEL); + if (!rsc_table) { + debug("resource table alloc failed!\n"); + return 0; + } + + /* + * Copy the resource table into a local buffer before handling the + * resource table. + */ + memcpy(rsc_table, ptable, tablesz); + if (cfg->intmem_to_l3_mapping) + handle_intmem_to_l3_mapping(dev, cfg->intmem_to_l3_mapping); + ret = handle_resources(dev, tablesz, loading_handlers); + if (ret) { + debug("handle_resources failed: %d\n", ret); + return 0; + } + + /* + * Instead of trying to mimic the kernel flow of copying the + * processed resource table into its post ELF load location in DDR + * copying it into its original location. + */ + memcpy(ptable, rsc_table, tablesz); + free(rsc_table); + rsc_table = NULL; + + return 1; +} diff --git a/include/remoteproc.h b/include/remoteproc.h index 089131f65fde..1a970bc23c52 100644 --- a/include/remoteproc.h +++ b/include/remoteproc.h @@ -1,4 +1,4 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ +/* SPDX-License-Identifier: GPL-2.0 */ /* * (C) Copyright 2015 * Texas Instruments Incorporated - http://www.ti.com/ @@ -15,6 +15,375 @@ */ #include <dm/platdata.h> /* For platform data support - non dt world */
+/** + * struct fw_rsc_hdr - firmware resource entry header + * @type: resource type + * @data: resource data + * + * Every resource entry begins with a 'struct fw_rsc_hdr' header providing + * its @type. The content of the entry itself will immediately follow + * this header, and it should be parsed according to the resource type. + */ +struct fw_rsc_hdr { + u32 type; + u8 data[0]; +}; + +/** + * enum fw_resource_type - types of resource entries + * + * @RSC_CARVEOUT: request for allocation of a physically contiguous + * memory region. + * @RSC_DEVMEM: request to iommu_map a memory-based peripheral. + * @RSC_TRACE: announces the availability of a trace buffer into which + * the remote processor will be writing logs. + * @RSC_VDEV: declare support for a virtio device, and serve as its + * virtio header. + * @RSC_PRELOAD_VENDOR: a vendor resource type that needs to be handled by + * remoteproc implementations before loading + * @RSC_POSTLOAD_VENDOR: a vendor resource type that needs to be handled by + * remoteproc implementations after loading + * @RSC_LAST: just keep this one at the end + * + * For more details regarding a specific resource type, please see its + * dedicated structure below. + * + * Please note that these values are used as indices to the rproc_handle_rsc + * lookup table, so please keep them sane. Moreover, @RSC_LAST is used to + * check the validity of an index before the lookup table is accessed, so + * please update it as needed. + */ +enum fw_resource_type { + RSC_CARVEOUT = 0, + RSC_DEVMEM = 1, + RSC_TRACE = 2, + RSC_VDEV = 3, + RSC_PRELOAD_VENDOR = 4, + RSC_POSTLOAD_VENDOR = 5, + RSC_LAST = 6, +}; + +#define FW_RSC_ADDR_ANY (-1) + +/** + * struct fw_rsc_carveout - physically contiguous memory request + * @da: device address + * @pa: physical address + * @len: length (in bytes) + * @flags: iommu protection flags + * @reserved: reserved (must be zero) + * @name: human-readable name of the requested memory region + * + * This resource entry requests the host to allocate a physically contiguous + * memory region. + * + * These request entries should precede other firmware resource entries, + * as other entries might request placing other data objects inside + * these memory regions (e.g. data/code segments, trace resource entries, ...). + * + * Allocating memory this way helps utilizing the reserved physical memory + * (e.g. CMA) more efficiently, and also minimizes the number of TLB entries + * needed to map it (in case @rproc is using an IOMMU). Reducing the TLB + * pressure is important; it may have a substantial impact on performance. + * + * If the firmware is compiled with static addresses, then @da should specify + * the expected device address of this memory region. If @da is set to + * FW_RSC_ADDR_ANY, then the host will dynamically allocate it, and then + * overwrite @da with the dynamically allocated address. + * + * We will always use @da to negotiate the device addresses, even if it + * isn't using an iommu. In that case, though, it will obviously contain + * physical addresses. + * + * Some remote processors needs to know the allocated physical address + * even if they do use an iommu. This is needed, e.g., if they control + * hardware accelerators which access the physical memory directly (this + * is the case with OMAP4 for instance). In that case, the host will + * overwrite @pa with the dynamically allocated physical address. + * Generally we don't want to expose physical addresses if we don't have to + * (remote processors are generally _not_ trusted), so we might want to + * change this to happen _only_ when explicitly required by the hardware. + * + * @flags is used to provide IOMMU protection flags, and @name should + * (optionally) contain a human readable name of this carveout region + * (mainly for debugging purposes). + */ +struct fw_rsc_carveout { + u32 da; + u32 pa; + u32 len; + u32 flags; + u32 reserved; + u8 name[32]; +}; + +/** + * struct fw_rsc_devmem - iommu mapping request + * @da: device address + * @pa: physical address + * @len: length (in bytes) + * @flags: iommu protection flags + * @reserved: reserved (must be zero) + * @name: human-readable name of the requested region to be mapped + * + * This resource entry requests the host to iommu map a physically contiguous + * memory region. This is needed in case the remote processor requires + * access to certain memory-based peripherals; _never_ use it to access + * regular memory. + * + * This is obviously only needed if the remote processor is accessing memory + * via an iommu. + * + * @da should specify the required device address, @pa should specify + * the physical address we want to map, @len should specify the size of + * the mapping and @flags is the IOMMU protection flags. As always, @name may + * (optionally) contain a human readable name of this mapping (mainly for + * debugging purposes). + * + * Note: at this point we just "trust" those devmem entries to contain valid + * physical addresses, but this isn't safe and will be changed: eventually we + * want remoteproc implementations to provide us ranges of physical addresses + * the firmware is allowed to request, and not allow firmwares to request + * access to physical addresses that are outside those ranges. + */ +struct fw_rsc_devmem { + u32 da; + u32 pa; + u32 len; + u32 flags; + u32 reserved; + u8 name[32]; +}; + +/** + * struct fw_rsc_trace - trace buffer declaration + * @da: device address + * @len: length (in bytes) + * @reserved: reserved (must be zero) + * @name: human-readable name of the trace buffer + * + * This resource entry provides the host information about a trace buffer + * into which the remote processor will write log messages. + * + * @da specifies the device address of the buffer, @len specifies + * its size, and @name may contain a human readable name of the trace buffer. + * + * After booting the remote processor, the trace buffers are exposed to the + * user via debugfs entries (called trace0, trace1, etc..). + */ +struct fw_rsc_trace { + u32 da; + u32 len; + u32 reserved; + u8 name[32]; +}; + +/** + * struct fw_rsc_vdev_vring - vring descriptor entry + * @da: device address + * @align: the alignment between the consumer and producer parts of the vring + * @num: num of buffers supported by this vring (must be power of two) + * @notifyid is a unique rproc-wide notify index for this vring. This notify + * index is used when kicking a remote processor, to let it know that this + * vring is triggered. + * @pa: physical address + * + * This descriptor is not a resource entry by itself; it is part of the + * vdev resource type (see below). + * + * Note that @da should either contain the device address where + * the remote processor is expecting the vring, or indicate that + * dynamically allocation of the vring's device address is supported. + */ +struct fw_rsc_vdev_vring { + u32 da; + u32 align; + u32 num; + u32 notifyid; + u32 pa; +}; + +/** + * struct fw_rsc_vdev - virtio device header + * @id: virtio device id (as in virtio_ids.h) + * @notifyid is a unique rproc-wide notify index for this vdev. This notify + * index is used when kicking a remote processor, to let it know that the + * status/features of this vdev have changes. + * @dfeatures specifies the virtio device features supported by the firmware + * @gfeatures is a place holder used by the host to write back the + * negotiated features that are supported by both sides. + * @config_len is the size of the virtio config space of this vdev. The config + * space lies in the resource table immediate after this vdev header. + * @status is a place holder where the host will indicate its virtio progress. + * @num_of_vrings indicates how many vrings are described in this vdev header + * @reserved: reserved (must be zero) + * @vring is an array of @num_of_vrings entries of 'struct fw_rsc_vdev_vring'. + * + * This resource is a virtio device header: it provides information about + * the vdev, and is then used by the host and its peer remote processors + * to negotiate and share certain virtio properties. + * + * By providing this resource entry, the firmware essentially asks remoteproc + * to statically allocate a vdev upon registration of the rproc (dynamic vdev + * allocation is not yet supported). + * + * Note: unlike virtualization systems, the term 'host' here means + * the Linux side which is running remoteproc to control the remote + * processors. We use the name 'gfeatures' to comply with virtio's terms, + * though there isn't really any virtualized guest OS here: it's the host + * which is responsible for negotiating the final features. + * Yeah, it's a bit confusing. + * + * Note: immediately following this structure is the virtio config space for + * this vdev (which is specific to the vdev; for more info, read the virtio + * spec). the size of the config space is specified by @config_len. + */ +struct fw_rsc_vdev { + u32 id; + u32 notifyid; + u32 dfeatures; + u32 gfeatures; + u32 config_len; + u8 status; + u8 num_of_vrings; + u8 reserved[2]; + struct fw_rsc_vdev_vring vring[0]; +}; + +/** + * struct rproc_mem_entry - memory entry descriptor + * @va: virtual address + * @dma: dma address + * @len: length, in bytes + * @da: device address + * @priv: associated data + * @name: associated memory region name (optional) + * @node: list node + */ +struct rproc_mem_entry { + void *va; + dma_addr_t dma; + int len; + u32 da; + void *priv; + char name[32]; + struct list_head node; +}; + +struct rproc; + +typedef u32(*init_func_proto) (u32 core_id, struct rproc *cfg); + +struct l3_map { + u32 priv_addr; + u32 l3_addr; + u32 len; +}; + +struct rproc_intmem_to_l3_mapping { + u32 num_entries; + struct l3_map mappings[16]; +}; + +/** + * enum rproc_crash_type - remote processor crash types + * @RPROC_MMUFAULT: iommu fault + * @RPROC_WATCHDOG: watchdog bite + * @RPROC_FATAL_ERROR fatal error + * + * Each element of the enum is used as an array index. So that, the value of + * the elements should be always something sane. + * + * Feel free to add more types when needed. + */ +enum rproc_crash_type { + RPROC_MMUFAULT, + RPROC_WATCHDOG, + RPROC_FATAL_ERROR, +}; + +/* we currently support only two vrings per rvdev */ +#define RVDEV_NUM_VRINGS 2 + +#define RPMSG_NUM_BUFS (512) +#define RPMSG_BUF_SIZE (512) +#define RPMSG_TOTAL_BUF_SPACE (RPMSG_NUM_BUFS * RPMSG_BUF_SIZE) + +/** + * struct rproc_vring - remoteproc vring state + * @va: virtual address + * @dma: dma address + * @len: length, in bytes + * @da: device address + * @align: vring alignment + * @notifyid: rproc-specific unique vring index + * @rvdev: remote vdev + * @vq: the virtqueue of this vring + */ +struct rproc_vring { + void *va; + dma_addr_t dma; + int len; + u32 da; + u32 align; + int notifyid; + struct rproc_vdev *rvdev; + struct virtqueue *vq; +}; + +/** struct rproc - structure with all processor specific information for + * loading remotecore from boot loader. + * + * @num_iommus: Number of IOMMUs for this remote core. Zero indicates that the + * processor does not have an IOMMU. + * + * @cma_base: Base address of the carveout for this remotecore. + * + * @cma_size: Length of the carveout in bytes. + * + * @page_table_addr: array with the physical address of the page table. We are + * using the same page table for both IOMMU's. There is currently no strong + * usecase for maintaining different page tables for different MMU's servicing + * the same CPU. + * + * @mmu_base_addr: base address of the MMU + * + * @entry_point: address that is the entry point for the remote core. This + * address is in the memory view of the remotecore. + * + * @load_addr: Address to which the bootloader loads the firmware from + * persistent storage before invoking the ELF loader. Keeping this address + * configurable allows future optimizations such as loading the firmware from + * storage for remotecore2 via EDMA while the CPU is processing the ELF image + * of remotecore1. This address is in the memory view of the A15. + * + * @firmware_name: Name of the file that is expected to contain the ELF image. + * + * @has_rsc_table: Flag populated after parsing the ELF binary on target. + */ + +struct rproc { + u32 num_iommus; + unsigned long cma_base; + u32 cma_size; + unsigned long page_table_addr; + unsigned long mmu_base_addr[2]; + unsigned long load_addr; + unsigned long entry_point; + char *core_name; + char *firmware_name; + char *ptn; + init_func_proto start_clocks; + init_func_proto config_mmu; + init_func_proto config_peripherals; + init_func_proto start_core; + u32 has_rsc_table; + struct rproc_intmem_to_l3_mapping *intmem_to_l3_mapping; + u32 trace_pa; + u32 trace_len; +}; + +extern struct rproc *rproc_cfg_arr[2]; /** * enum rproc_mem_type - What type of memory model does the rproc use * @RPROC_INTERNAL_MEMORY_MAPPED: Remote processor uses own memory and is memory @@ -126,6 +495,12 @@ struct dm_rproc_ops { * @return virtual address. */ void * (*device_to_virt)(struct udevice *dev, ulong da, ulong size); + int (*add_res)(struct udevice *dev, + struct rproc_mem_entry *mapping); + void * (*alloc_mem)(struct udevice *dev, unsigned long len, + unsigned long align); + unsigned int (*config_pagetable)(struct udevice *dev, unsigned int virt, + unsigned int phys, unsigned int len); };
/* Accessor */ @@ -322,6 +697,13 @@ int rproc_elf64_load_rsc_table(struct udevice *dev, ulong fw_addr, */ int rproc_elf_load_rsc_table(struct udevice *dev, ulong fw_addr, ulong fw_size, ulong *rsc_addr, ulong *rsc_size); + +unsigned long rproc_parse_resource_table(struct udevice *dev, + struct rproc *cfg); + +struct resource_table *rproc_find_resource_table(struct udevice *dev, + unsigned int addr, + int *tablesz); #else static inline int rproc_init(void) { return -ENOSYS; } static inline int rproc_dev_init(int id) { return -ENOSYS; }
Hi Amjad,
On Thu, 27 Jan 2022 at 05:17, Amjad Ouled-Ameur aouledameur@baylibre.com wrote:
Changes in v2:
Sorry my comments are a bit late - I sent them on v3.
Hi Simon,
Thank you for your feedback.
Since the patchset has already been applied, I will address your comments
in follow-up patches.
Kindly,
Amjad
On 27/01/2022 16:43, Simon Glass wrote:
Hi Amjad,
Changes in v2:
The driver enables IPU support. Basically enables the clocks, timers, watchdog timers and bare minimal MMU and supports loading the firmware from mmc.
Signed-off-by: Keerthy j-keerthy@ti.com [Amjad: fix compile warnings] Signed-off-by: Amjad Ouled-Ameur aouledameur@baylibre.com ---
MAINTAINERS | 1 + drivers/remoteproc/Kconfig | 10 + drivers/remoteproc/Makefile | 1 + drivers/remoteproc/ipu_rproc.c | 759 +++++++++++++++++++++++++++++++++ 4 files changed, 771 insertions(+) create mode 100644 drivers/remoteproc/ipu_rproc.c
diff --git a/MAINTAINERS b/MAINTAINERS index bd9cc4107cbe..311397137b27 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -533,6 +533,7 @@ F: drivers/phy/omap-usb2-phy.c F: drivers/phy/phy-ti-am654.c F: drivers/phy/ti-pipe3-phy.c F: drivers/ram/k3* +F: drivers/remoteproc/ipu_rproc.c F: drivers/remoteproc/k3_system_controller.c F: drivers/remoteproc/pruc_rpoc.c F: drivers/remoteproc/ti* diff --git a/drivers/remoteproc/Kconfig b/drivers/remoteproc/Kconfig index 24e536463bbd..27e4a60ff5b1 100644 --- a/drivers/remoteproc/Kconfig +++ b/drivers/remoteproc/Kconfig @@ -92,4 +92,14 @@ config REMOTEPROC_TI_PRU help Say 'y' here to add support for TI' K3 remoteproc driver.
+config REMOTEPROC_TI_IPU + bool "Support for TI's K3 based IPU remoteproc driver" + select REMOTEPROC + depends on DM + depends on SPL_DRIVERS_MISC + depends on SPL_FS_LOADER + depends on OF_CONTROL + help + Say 'y' here to add support for TI' K3 remoteproc driver. + endmenu diff --git a/drivers/remoteproc/Makefile b/drivers/remoteproc/Makefile index f0e83451d66f..fbe9c172bc04 100644 --- a/drivers/remoteproc/Makefile +++ b/drivers/remoteproc/Makefile @@ -15,3 +15,4 @@ obj-$(CONFIG_REMOTEPROC_TI_K3_DSP) += ti_k3_dsp_rproc.o obj-$(CONFIG_REMOTEPROC_TI_K3_R5F) += ti_k3_r5f_rproc.o obj-$(CONFIG_REMOTEPROC_TI_POWER) += ti_power_proc.o obj-$(CONFIG_REMOTEPROC_TI_PRU) += pru_rproc.o +obj-$(CONFIG_REMOTEPROC_TI_IPU) += ipu_rproc.o diff --git a/drivers/remoteproc/ipu_rproc.c b/drivers/remoteproc/ipu_rproc.c new file mode 100644 index 000000000000..b4a06bc955a9 --- /dev/null +++ b/drivers/remoteproc/ipu_rproc.c @@ -0,0 +1,759 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * IPU remoteproc driver for various SoCs + * + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + * Angela Stegmaier angelabaker@ti.com + * Venkateswara Rao Mandela venkat.mandela@ti.com + * Keerthy j-keerthy@ti.com + */ + +#include <common.h> +#include <hang.h> +#include <cpu_func.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <elf.h> +#include <env.h> +#include <dm/of_access.h> +#include <fs_loader.h> +#include <remoteproc.h> +#include <errno.h> +#include <clk.h> +#include <reset.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/io.h> +#include <misc.h> +#include <power-domain.h> +#include <timer.h> +#include <fs.h> +#include <spl.h> +#include <timer.h> +#include <reset.h> +#include <linux/bitmap.h> + +#define IPU1_LOAD_ADDR (0xa17ff000) +#define MAX_REMOTECORE_BIN_SIZE (8 * 0x100000) + +enum ipu_num { + IPU1 = 0, + IPU2, + RPROC_END_ENUMS, +}; + +#define IPU2_LOAD_ADDR (IPU1_LOAD_ADDR + MAX_REMOTECORE_BIN_SIZE) + +#define PAGE_SHIFT 12 +#define PAGESIZE_1M 0x0 +#define PAGESIZE_64K 0x1 +#define PAGESIZE_4K 0x2 +#define PAGESIZE_16M 0x3 +#define LE 0 +#define BE 1 +#define ELEMSIZE_8 0x0 +#define ELEMSIZE_16 0x1 +#define ELEMSIZE_32 0x2 +#define MIXED_TLB 0x0 +#define MIXED_CPU 0x1 + +#define PGT_SMALLPAGE_SIZE 0x00001000 +#define PGT_LARGEPAGE_SIZE 0x00010000 +#define PGT_SECTION_SIZE 0x00100000 +#define PGT_SUPERSECTION_SIZE 0x01000000 + +#define PGT_L1_DESC_PAGE 0x00001 +#define PGT_L1_DESC_SECTION 0x00002 +#define PGT_L1_DESC_SUPERSECTION 0x40002 + +#define PGT_L1_DESC_PAGE_MASK 0xfffffC00 +#define PGT_L1_DESC_SECTION_MASK 0xfff00000 +#define PGT_L1_DESC_SUPERSECTION_MASK 0xff000000 + +#define PGT_L1_DESC_SMALLPAGE_INDEX_SHIFT 12 +#define PGT_L1_DESC_LARGEPAGE_INDEX_SHIFT 16 +#define PGT_L1_DESC_SECTION_INDEX_SHIFT 20 +#define PGT_L1_DESC_SUPERSECTION_INDEX_SHIFT 24 + +#define PGT_L2_DESC_SMALLPAGE 0x02 +#define PGT_L2_DESC_LARGEPAGE 0x01 + +#define PGT_L2_DESC_SMALLPAGE_MASK 0xfffff000 +#define PGT_L2_DESC_LARGEPAGE_MASK 0xffff0000 + +/* + * The memory for the page tables (256 KB per IPU) is placed just before + * the carveout memories for the remote processors. 16 KB of memory is + * needed for the L1 page table (4096 entries * 4 bytes per 1 MB section). + * Any smaller page (64 KB or 4 KB) entries are supported through L2 page + * tables (1 KB per table). The remaining 240 KB can provide support for + * 240 L2 page tables. Any remoteproc firmware image requiring more than + * 240 L2 page table entries would need more memory to be reserved. + */ +#define PAGE_TABLE_SIZE_L1 (0x00004000) +#define PAGE_TABLE_SIZE_L2 (0x400) +#define MAX_NUM_L2_PAGE_TABLES (240) +#define PAGE_TABLE_SIZE_L2_TOTAL (MAX_NUM_L2_PAGE_TABLES * PAGE_TABLE_SIZE_L2) +#define PAGE_TABLE_SIZE (PAGE_TABLE_SIZE_L1 + (PAGE_TABLE_SIZE_L2_TOTAL)) + +/** + * struct omap_rproc_mem - internal memory structure + * @cpu_addr: MPU virtual address of the memory region + * @bus_addr: bus address used to access the memory region + * @dev_addr: device address of the memory region from DSP view + * @size: size of the memory region + */ +struct omap_rproc_mem { + void __iomem *cpu_addr; + phys_addr_t bus_addr; + u32 dev_addr; + size_t size; +}; + +struct ipu_privdata { + struct omap_rproc_mem mem; + struct list_head mappings; + const char *fw_name; + u32 bootaddr; + int id; + struct udevice *rdev; +}; + +typedef int (*handle_resource_t) (void *, int offset, int avail); + +unsigned int *page_table_l1 = (unsigned int *)0x0; +unsigned int *page_table_l2 = (unsigned int *)0x0; + +/* + * Set maximum carveout size to 96 MB + */ +#define DRA7_RPROC_MAX_CO_SIZE (96 * 0x100000) + +/* + * These global variables are used for deriving the MMU page tables. They + * are initialized for each core with the appropriate values. The length + * of the array mem_bitmap is set as per a 96 MB carveout which the + * maximum set aside in the current memory map. + */ +unsigned long mem_base; +unsigned long mem_size; +unsigned long + +mem_bitmap[BITS_TO_LONGS(DRA7_RPROC_MAX_CO_SIZE >> PAGE_SHIFT)]; +unsigned long mem_count; + +unsigned int pgtable_l2_map[MAX_NUM_L2_PAGE_TABLES]; +unsigned int pgtable_l2_cnt; + +void *ipu_alloc_mem(struct udevice *dev, unsigned long len, unsigned long align) +{ + unsigned long mask; + unsigned long pageno; + int count; + + count = ((len + (PAGE_SIZE - 1)) & ~(PAGE_SIZE - 1)) >> PAGE_SHIFT; + mask = (1 << align) - 1; + pageno = + bitmap_find_next_zero_area(mem_bitmap, mem_count, 0, count, mask); + debug("%s: count %d mask %#lx pageno %#lx\n", __func__, count, mask, + pageno); + + if (pageno >= mem_count) { + debug("%s: %s Error allocating memory; " + "Please check carveout size\n", __FILE__, __func__); + return NULL; + } + + bitmap_set(mem_bitmap, pageno, count); + return (void *)(mem_base + (pageno << PAGE_SHIFT)); +} + +int find_pagesz(unsigned int virt, unsigned int phys, unsigned int len) +{ + int pg_sz_ind = -1; + unsigned int min_align = __ffs(virt); + + if (min_align > __ffs(phys)) + min_align = __ffs(phys); + + if (min_align >= PGT_L1_DESC_SUPERSECTION_INDEX_SHIFT && + len >= 0x1000000) { + pg_sz_ind = PAGESIZE_16M; + goto ret_block; + } + if (min_align >= PGT_L1_DESC_SECTION_INDEX_SHIFT && + len >= 0x100000) { + pg_sz_ind = PAGESIZE_1M; + goto ret_block; + } + if (min_align >= PGT_L1_DESC_LARGEPAGE_INDEX_SHIFT && + len >= 0x10000) { + pg_sz_ind = PAGESIZE_64K; + goto ret_block; + } + if (min_align >= PGT_L1_DESC_SMALLPAGE_INDEX_SHIFT && + len >= 0x1000) { + pg_sz_ind = PAGESIZE_4K; + goto ret_block; + } + + ret_block: + return pg_sz_ind; +} + +int get_l2_pg_tbl_addr(unsigned int virt, unsigned int *pg_tbl_addr) +{ + int ret = -1; + int i = 0; + int match_found = 0; + unsigned int tag = (virt & PGT_L1_DESC_SECTION_MASK); + + *pg_tbl_addr = 0; + for (i = 0; (i < pgtable_l2_cnt) && (match_found == 0); i++) { + if (tag == pgtable_l2_map[i]) { + *pg_tbl_addr = + ((unsigned int)page_table_l2) + + (i * PAGE_TABLE_SIZE_L2); + match_found = 1; + ret = 0; + } + } + + if (match_found == 0 && i < MAX_NUM_L2_PAGE_TABLES) { + pgtable_l2_map[i] = tag; + pgtable_l2_cnt++; + *pg_tbl_addr = + ((unsigned int)page_table_l2) + (i * PAGE_TABLE_SIZE_L2); + ret = 0; + } + + return ret; +} + +int +config_l2_pagetable(unsigned int virt, unsigned int phys, + unsigned int pg_sz, unsigned int pg_tbl_addr) +{ + int ret = -1; + unsigned int desc = 0; + int i = 0; + unsigned int *pg_tbl = (unsigned int *)pg_tbl_addr; + + /* + * Pick bit 19:12 of the virtual address as index + */ + unsigned int index = (virt & (~PGT_L1_DESC_SECTION_MASK)) >> PAGE_SHIFT; + + switch (pg_sz) { + case PAGESIZE_64K: + desc = + (phys & PGT_L2_DESC_LARGEPAGE_MASK) | PGT_L2_DESC_LARGEPAGE; + for (i = 0; i < 16; i++) + pg_tbl[index + i] = desc; + ret = 0; + break; + case PAGESIZE_4K: + desc = + (phys & PGT_L2_DESC_SMALLPAGE_MASK) | PGT_L2_DESC_SMALLPAGE; + pg_tbl[index] = desc; + ret = 0; + break; + default: + break; + } + + return ret; +} + +unsigned int +ipu_config_pagetable(struct udevice *dev, unsigned int virt, unsigned int phys, + unsigned int len) +{ + unsigned int index; + unsigned int l = len; + unsigned int desc; + int pg_sz = 0; + int i = 0, err = 0; + unsigned int pg_tbl_l2_addr = 0; + unsigned int tmp_pgsz; + + if ((len & 0x0FFF) != 0) + return 0; + + while (l > 0) { + pg_sz = find_pagesz(virt, phys, l); + index = virt >> PGT_L1_DESC_SECTION_INDEX_SHIFT; + switch (pg_sz) { + /* + * 16 MB super section + */ + case PAGESIZE_16M: + /* + * Program the next 16 descriptors + */ + desc = + (phys & PGT_L1_DESC_SUPERSECTION_MASK) | + PGT_L1_DESC_SUPERSECTION; + for (i = 0; i < 16; i++) + page_table_l1[index + i] = desc; + l -= PGT_SUPERSECTION_SIZE; + phys += PGT_SUPERSECTION_SIZE; + virt += PGT_SUPERSECTION_SIZE; + break; + /* + * 1 MB section + */ + case PAGESIZE_1M: + desc = + (phys & PGT_L1_DESC_SECTION_MASK) | + PGT_L1_DESC_SECTION; + page_table_l1[index] = desc; + l -= PGT_SECTION_SIZE; + phys += PGT_SECTION_SIZE; + virt += PGT_SECTION_SIZE; + break; + /* + * 64 KB large page + */ + case PAGESIZE_64K: + case PAGESIZE_4K: + if (pg_sz == PAGESIZE_64K) + tmp_pgsz = 0x10000; + else + tmp_pgsz = 0x1000; + + err = get_l2_pg_tbl_addr(virt, &pg_tbl_l2_addr); + if (err != 0) { + debug + ("Unable to get level 2 PT address\n"); + hang(); + } + err = + config_l2_pagetable(virt, phys, pg_sz, + pg_tbl_l2_addr); + desc = + (pg_tbl_l2_addr & PGT_L1_DESC_PAGE_MASK) | + PGT_L1_DESC_PAGE; + page_table_l1[index] = desc; + l -= tmp_pgsz; + phys += tmp_pgsz; + virt += tmp_pgsz; + break; + case -1: + default: + return 0; + } + } + + return len; +} + +int da_to_pa(struct udevice *dev, int da) +{ + struct rproc_mem_entry *maps = NULL; + struct ipu_privdata *priv = dev_get_priv(dev); + + list_for_each_entry(maps, &priv->mappings, node) { + if (da >= maps->da && da < (maps->da + maps->len)) + return maps->dma + (da - maps->da); + } + + return 0; +} + +u32 ipu_config_mmu(u32 core_id, struct rproc *cfg) +{ + u32 i = 0; + u32 reg = 0; + + /* + * Clear the entire pagetable location before programming the + * address into the MMU + */ + memset((void *)cfg->page_table_addr, 0x00, PAGE_TABLE_SIZE); + + for (i = 0; i < cfg->num_iommus; i++) { + u32 mmu_base = cfg->mmu_base_addr[i]; + + __raw_writel((int)cfg->page_table_addr, mmu_base + 0x4c); + reg = __raw_readl(mmu_base + 0x88); + + /* + * enable bus-error back + */ + __raw_writel(reg | 0x1, mmu_base + 0x88); + + /* + * Enable the MMU IRQs during MMU programming for the + * late attachcase. This is to allow the MMU fault to be + * detected by the kernel. + * + * MULTIHITFAULT|EMMUMISS|TRANSLATIONFAULT|TABLEWALKFAULT + */ + __raw_writel(0x1E, mmu_base + 0x1c); + + /* + * emutlbupdate|TWLENABLE|MMUENABLE + */ + __raw_writel(0x6, mmu_base + 0x44); + } + + return 0; +} + +/** + * enum ipu_mem - PRU core memory range identifiers + */ +enum ipu_mem { + PRU_MEM_IRAM = 0, + PRU_MEM_CTRL, + PRU_MEM_DEBUG, + PRU_MEM_MAX, +}; + +static int ipu_start(struct udevice *dev) +{ + struct ipu_privdata *priv; + struct reset_ctl reset; + struct rproc *cfg = NULL; + int ret; + + priv = dev_get_priv(dev); + + cfg = rproc_cfg_arr[priv->id]; + if (cfg->config_peripherals) + cfg->config_peripherals(priv->id, cfg); + + /* + * Start running the remote core + */ + ret = reset_get_by_index(dev, 0, &reset); + if (ret < 0) { + dev_err(dev, "%s: error getting reset index %d\n", __func__, 0); + return ret; + } + + ret = reset_deassert(&reset); + if (ret < 0) { + dev_err(dev, "%s: error deasserting reset %d\n", __func__, 0); + return ret; + } + + ret = reset_get_by_index(dev, 1, &reset); + if (ret < 0) { + dev_err(dev, "%s: error getting reset index %d\n", __func__, 1); + return ret; + } + + ret = reset_deassert(&reset); + if (ret < 0) { + dev_err(dev, "%s: error deasserting reset %d\n", __func__, 1); + return ret; + } + + return 0; +} + +static int ipu_stop(struct udevice *dev) +{ + return 0; +} + +/** + * ipu_init() - Initialize the remote processor + * @dev: rproc device pointer + * + * Return: 0 if all went ok, else return appropriate error + */ +static int ipu_init(struct udevice *dev) +{ + return 0; +} + +static int ipu_add_res(struct udevice *dev, struct rproc_mem_entry *mapping) +{ + struct ipu_privdata *priv = dev_get_priv(dev); + + list_add_tail(&mapping->node, &priv->mappings); + return 0; +} + +static int ipu_load(struct udevice *dev, ulong addr, ulong size) +{ + Elf32_Ehdr *ehdr; /* Elf header structure pointer */ + Elf32_Phdr *phdr; /* Program header structure pointer */ + Elf32_Phdr proghdr; + int va; + int pa; + int i; + + ehdr = (Elf32_Ehdr *)addr; + phdr = (Elf32_Phdr *)(addr + ehdr->e_phoff); + /* + * Load each program header + */ + for (i = 0; i < ehdr->e_phnum; ++i) { + memcpy(&proghdr, phdr, sizeof(Elf32_Phdr)); + + if (proghdr.p_type != PT_LOAD) { + ++phdr; + continue; + } + + va = proghdr.p_paddr; + pa = da_to_pa(dev, va); + if (pa) + proghdr.p_paddr = pa; + + void *dst = (void *)(uintptr_t)proghdr.p_paddr; + void *src = (void *)addr + proghdr.p_offset; + + debug("Loading phdr %i to 0x%p (%i bytes)\n", i, dst, + proghdr.p_filesz); + if (proghdr.p_filesz) + memcpy(dst, src, proghdr.p_filesz); + + flush_cache((unsigned long)dst, proghdr.p_memsz); + + ++phdr; + } + + return 0; +} + +static const struct dm_rproc_ops ipu_ops = { + .init = ipu_init, + .start = ipu_start, + .stop = ipu_stop, + .load = ipu_load, + .add_res = ipu_add_res, + .config_pagetable = ipu_config_pagetable, + .alloc_mem = ipu_alloc_mem, +}; + +/* + * If the remotecore binary expects any peripherals to be setup before it has + * booted, configure them here. + * + * These functions are left empty by default as their operation is usecase + * specific. + */ + +u32 ipu1_config_peripherals(u32 core_id, struct rproc *cfg) +{ + return 0; +} + +u32 ipu2_config_peripherals(u32 core_id, struct rproc *cfg) +{ + return 0; +} + +struct rproc_intmem_to_l3_mapping ipu1_intmem_to_l3_mapping = { + .num_entries = 1, + .mappings = { + /* + * L2 SRAM + */ + { + .priv_addr = 0x55020000, + .l3_addr = 0x58820000, + .len = (64 * 1024)}, + } +}; + +struct rproc_intmem_to_l3_mapping ipu2_intmem_to_l3_mapping = { + .num_entries = 1, + .mappings = { + /* + * L2 SRAM + */ + { + .priv_addr = 0x55020000, + .l3_addr = 0x55020000, + .len = (64 * 1024)}, + } +}; + +struct rproc ipu1_config = { + .num_iommus = 1, + .mmu_base_addr = {0x58882000, 0}, + .load_addr = IPU1_LOAD_ADDR, + .core_name = "IPU1", + .firmware_name = "dra7-ipu1-fw.xem4", + .config_mmu = ipu_config_mmu, + .config_peripherals = ipu1_config_peripherals, + .intmem_to_l3_mapping = &ipu1_intmem_to_l3_mapping +}; + +struct rproc ipu2_config = { + .num_iommus = 1, + .mmu_base_addr = {0x55082000, 0}, + .load_addr = IPU2_LOAD_ADDR, + .core_name = "IPU2", + .firmware_name = "dra7-ipu2-fw.xem4", + .config_mmu = ipu_config_mmu, + .config_peripherals = ipu2_config_peripherals, + .intmem_to_l3_mapping = &ipu2_intmem_to_l3_mapping +}; + +struct rproc *rproc_cfg_arr[2] = { + [IPU2] = &ipu2_config, + [IPU1] = &ipu1_config, +}; + +u32 spl_pre_boot_core(struct udevice *dev, u32 core_id) +{ + struct rproc *cfg = NULL; + unsigned long load_elf_status = 0; + int tablesz; + + cfg = rproc_cfg_arr[core_id]; + /* + * Check for valid elf image + */ + if (!valid_elf_image(cfg->load_addr)) + return 1; + + if (rproc_find_resource_table(dev, cfg->load_addr, &tablesz)) + cfg->has_rsc_table = 1; + else + cfg->has_rsc_table = 0; + + /* + * Configure the MMU + */ + if (cfg->config_mmu && cfg->has_rsc_table) + cfg->config_mmu(core_id, cfg); + + /* + * Load the remote core. Fill the page table of the first(possibly + * only) IOMMU during ELF loading. Copy the page table to the second + * IOMMU before running the remote core. + */ + + page_table_l1 = (unsigned int *)cfg->page_table_addr; + page_table_l2 = + (unsigned int *)(cfg->page_table_addr + PAGE_TABLE_SIZE_L1); + mem_base = cfg->cma_base; + mem_size = cfg->cma_size; + memset(mem_bitmap, 0x00, sizeof(mem_bitmap)); + mem_count = (cfg->cma_size >> PAGE_SHIFT); + + /* + * Clear variables used for level 2 page table allocation + */ + memset(pgtable_l2_map, 0x00, sizeof(pgtable_l2_map)); + pgtable_l2_cnt = 0; + + load_elf_status = rproc_parse_resource_table(dev, cfg); + if (load_elf_status == 0) { + debug("load_elf_image_phdr returned error for core %s\n", + cfg->core_name); + return 1; + } + + flush_cache(cfg->page_table_addr, PAGE_TABLE_SIZE); + + return 0; +} + +static fdt_addr_t ipu_parse_mem_nodes(struct udevice *dev, char *name, + int privid, fdt_size_t *sizep) +{ + int ret; + u32 sp; + ofnode mem_node; + + ret = ofnode_read_u32(dev_ofnode(dev), name, &sp); + if (ret) { + dev_err(dev, "memory-region node fetch failed %d\n", ret); + return ret; + } + + mem_node = ofnode_get_by_phandle(sp); + if (!ofnode_valid(mem_node)) + return -EINVAL; + + return ofnode_get_addr_size_index(mem_node, 0, sizep); +} + +/** + * ipu_probe() - Basic probe + * @dev: corresponding k3 remote processor device + * + * Return: 0 if all goes good, else appropriate error message. + */ +static int ipu_probe(struct udevice *dev) +{ + struct ipu_privdata *priv; + struct rproc *cfg = NULL; + struct reset_ctl reset; + static const char *const ipu_mem_names[] = { "l2ram" }; + int ret; + fdt_size_t sizep; + + priv = dev_get_priv(dev); + + priv->mem.bus_addr = + devfdt_get_addr_size_name(dev, + ipu_mem_names[0], + (fdt_addr_t *)&priv->mem.size); + + ret = reset_get_by_index(dev, 2, &reset); + if (ret < 0) { + dev_err(dev, "%s: error getting reset index %d\n", __func__, 2); + return ret; + } + + ret = reset_deassert(&reset); + if (ret < 0) { + dev_err(dev, "%s: error deasserting reset %d\n", __func__, 2); + return ret; + } + + if (priv->mem.bus_addr == FDT_ADDR_T_NONE) { + dev_err(dev, "%s bus address not found\n", ipu_mem_names[0]); + return -EINVAL; + } + priv->mem.cpu_addr = map_physmem(priv->mem.bus_addr, + priv->mem.size, MAP_NOCACHE); + + if (devfdt_get_addr(dev) == 0x58820000) + priv->id = 0; + else + priv->id = 1; + + cfg = rproc_cfg_arr[priv->id]; + cfg->cma_base = ipu_parse_mem_nodes(dev, "memory-region", priv->id, + &sizep); + cfg->cma_size = sizep; + + cfg->page_table_addr = ipu_parse_mem_nodes(dev, "pg-tbl", priv->id, + &sizep); + + dev_info(dev, + "ID %d memory %8s: bus addr %pa size 0x%zx va %p da 0x%x\n", + priv->id, ipu_mem_names[0], &priv->mem.bus_addr, + priv->mem.size, priv->mem.cpu_addr, priv->mem.dev_addr); + + INIT_LIST_HEAD(&priv->mappings); + if (spl_pre_boot_core(dev, priv->id)) + return -EINVAL; + + return 0; +} + +static const struct udevice_id ipu_ids[] = { + {.compatible = "ti,dra7-ipu"}, + {} +}; + +U_BOOT_DRIVER(ipu) = { + .name = "ipu", + .of_match = ipu_ids, + .id = UCLASS_REMOTEPROC, + .ops = &ipu_ops, + .probe = ipu_probe, + .priv_auto = sizeof(struct ipu_privdata), +};
Add all the ipu early boot related nodes
(no changes since v1)
MAINTAINERS | 1 + arch/arm/dts/dra7-ipu-common-early-boot.dtsi | 113 +++++++++++++++++++ 2 files changed, 114 insertions(+) create mode 100644 arch/arm/dts/dra7-ipu-common-early-boot.dtsi
diff --git a/MAINTAINERS b/MAINTAINERS index 311397137b27..7adc28dbfd87 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -514,6 +514,7 @@ ARM TI M: Tom Rini trini@konsulko.com S: Maintained T: git https://source.denx.de/u-boot/custodians/u-boot-ti.git +F: arch/arm/dts/dra7* F: arch/arm/mach-davinci/ F: arch/arm/mach-k3/ F: arch/arm/mach-keystone/ diff --git a/arch/arm/dts/dra7-ipu-common-early-boot.dtsi b/arch/arm/dts/dra7-ipu-common-early-boot.dtsi new file mode 100644 index 000000000000..ec6040ff93eb --- /dev/null +++ b/arch/arm/dts/dra7-ipu-common-early-boot.dtsi @@ -0,0 +1,113 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + */ + +/ { + chosen { + firmware-loader = &fs_loader0; + }; + + fs_loader0: fs_loader@0 { + u-boot,dm-pre-reloc; + compatible = "u-boot,fs-loader"; + phandlepart = <&mmc1 1>; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + u-boot,dm-spl; + + ipu2_memory_region: ipu2-memory@95800000 { + compatible = "shared-dma-pool"; + reg = <0x0 0x95800000 0x0 0x3800000>; + reusable; + status = "okay"; + u-boot,dm-spl; + }; + + ipu1_memory_region: ipu1-memory@9d000000 { + compatible = "shared-dma-pool"; + reg = <0x0 0x9d000000 0x0 0x2000000>; + reusable; + status = "okay"; + u-boot,dm-spl; + }; + + ipu1_pgtbl: ipu1-pgtbl@95700000 { + reg = <0x0 0x95700000 0x0 0x40000>; + no-map; + u-boot,dm-spl; + }; + + ipu2_pgtbl: ipu2-pgtbl@95740000 { + reg = <0x0 0x95740000 0x0 0x40000>; + no-map; + u-boot,dm-spl; + }; + }; +}; + +&timer3 { + u-boot,dm-spl; +}; + +&timer4 { + u-boot,dm-spl; +}; + +&timer7 { + u-boot,dm-spl; +}; + +&timer8 { + u-boot,dm-spl; +}; + +&timer9 { + u-boot,dm-spl; +}; + +&timer11 { + u-boot,dm-spl; +}; + +&mmu_ipu1 { + u-boot,dm-spl; +}; + +&mmu_ipu2 { + u-boot,dm-spl; +}; + +&ipu1 { + status = "okay"; + memory-region = <&ipu1_memory_region>; + pg-tbl = <&ipu1_pgtbl>; + u-boot,dm-spl; +}; + +&ipu2 { + status = "okay"; + memory-region = <&ipu2_memory_region>; + pg-tbl = <&ipu2_pgtbl>; + u-boot,dm-spl; +}; + +&l4_wkup { + u-boot,dm-spl; +}; + +&prm { + u-boot,dm-spl; +}; + +&ipu1_rst { + u-boot,dm-spl; +}; + +&ipu2_rst { + u-boot,dm-spl; +};
Add ipu and the associated nodes.
arch/arm/dts/dra7.dtsi | 45 +++++++++++++++++++++++++++++++++++++++++- 1 file changed, 44 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/dra7.dtsi b/arch/arm/dts/dra7.dtsi index fd1aea0b1b16..e2e958b36626 100644 --- a/arch/arm/dts/dra7.dtsi +++ b/arch/arm/dts/dra7.dtsi @@ -41,6 +41,8 @@ d_can0 = &dcan1; d_can1 = &dcan2; spi0 = &qspi; + remoteproc0 = &ipu1; + remoteproc1 = &ipu2; };
timer { @@ -263,9 +265,12 @@ };
prm: prm@6000 { - compatible = "ti,dra7-prm"; + compatible = "ti,dra7-prm", "simple-bus"; reg = <0x6000 0x3000>; interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x6000 0x3000>;
prm_clocks: clocks { #address-cells = <1>; @@ -274,6 +279,20 @@
prm_clockdomains: clockdomains { }; + + ipu1_rst: ipu1_rst@510 { + compatible = "ti,dra7-reset"; + reg = <0x510 0x8>; + ti,nresets = <3>; + #reset-cells = <1>; + }; + + ipu2_rst: ipu2_rst@910 { + compatible = "ti,dra7-reset"; + reg = <0x910 0x8>; + ti,nresets = <3>; + #reset-cells = <1>; + }; };
scm_wkup: scm_conf@c000 { @@ -2032,6 +2051,30 @@ clocks = <&l3_iclk_div>; clock-names = "fck"; }; + + ipu1: ipu@58820000 { + compatible = "ti,dra7-ipu"; + reg = <0x58820000 0x10000>; + reg-names = "l2ram"; + ti,hwmods = "ipu1"; + resets = <&ipu1_rst 0>, <&ipu1_rst 1>, <&ipu1_rst 2>; + iommus = <&mmu_ipu1>; + ti,rproc-standby-info = <0x4a005520>; + timers = <&timer11>; + watchdog-timers = <&timer7>, <&timer8>; + }; + + ipu2: ipu@55020000 { + compatible = "ti,dra7-ipu"; + reg = <0x55020000 0x10000>; + reg-names = "l2ram"; + ti,hwmods = "ipu2"; + resets = <&ipu2_rst 0>, <&ipu2_rst 1>, <&ipu2_rst 2>; + iommus = <&mmu_ipu2>; + ti,rproc-standby-info = <0x4a008920>; + timers = <&timer3>; + watchdog-timers = <&timer4>, <&timer9>; + }; };
thermal_zones: thermal-zones {
Add support for ipu early boot.
arch/arm/dts/am57xx-idk-common-u-boot.dtsi | 1 + arch/arm/dts/dra7-evm-u-boot.dtsi | 1 + arch/arm/dts/dra71-evm-u-boot.dtsi | 1 + arch/arm/dts/dra72-evm-revc-u-boot.dtsi | 1 + arch/arm/dts/dra76-evm-u-boot.dtsi | 1 + 5 files changed, 5 insertions(+)
diff --git a/arch/arm/dts/am57xx-idk-common-u-boot.dtsi b/arch/arm/dts/am57xx-idk-common-u-boot.dtsi index b07aea0048d5..d0ce469f9189 100644 --- a/arch/arm/dts/am57xx-idk-common-u-boot.dtsi +++ b/arch/arm/dts/am57xx-idk-common-u-boot.dtsi @@ -3,6 +3,7 @@ * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ */ #include "omap5-u-boot.dtsi" +#include "dra7-ipu-common-early-boot.dtsi"
/ { xtal25mhz: xtal25mhz { diff --git a/arch/arm/dts/dra7-evm-u-boot.dtsi b/arch/arm/dts/dra7-evm-u-boot.dtsi index f06c701dbd1f..5622512b2401 100644 --- a/arch/arm/dts/dra7-evm-u-boot.dtsi +++ b/arch/arm/dts/dra7-evm-u-boot.dtsi @@ -4,6 +4,7 @@ */
&pcf_gpio_21{ u-boot,i2c-offset-len = <0>; diff --git a/arch/arm/dts/dra71-evm-u-boot.dtsi b/arch/arm/dts/dra71-evm-u-boot.dtsi index b56d4fc9d896..40443da5c855 100644 --- a/arch/arm/dts/dra71-evm-u-boot.dtsi +++ b/arch/arm/dts/dra71-evm-u-boot.dtsi @@ -4,6 +4,7 @@ */
&pcf_gpio_21{ u-boot,i2c-offset-len = <0>; diff --git a/arch/arm/dts/dra72-evm-revc-u-boot.dtsi b/arch/arm/dts/dra72-evm-revc-u-boot.dtsi index b56d4fc9d896..40443da5c855 100644 --- a/arch/arm/dts/dra72-evm-revc-u-boot.dtsi +++ b/arch/arm/dts/dra72-evm-revc-u-boot.dtsi @@ -4,6 +4,7 @@ */
&pcf_gpio_21{ u-boot,i2c-offset-len = <0>; diff --git a/arch/arm/dts/dra76-evm-u-boot.dtsi b/arch/arm/dts/dra76-evm-u-boot.dtsi index a4dfbe7e601a..5fae6ba91936 100644 --- a/arch/arm/dts/dra76-evm-u-boot.dtsi +++ b/arch/arm/dts/dra76-evm-u-boot.dtsi @@ -4,6 +4,7 @@ */
&cpsw_emac0 { phy-handle = <&dp83867_0>;
MAINTAINERS | 1 + arch/arm/dts/am57xx-beagle-x15-revb1-u-boot.dtsi | 7 +++++++ arch/arm/dts/am57xx-beagle-x15-revc-u-boot.dtsi | 7 +++++++ arch/arm/dts/am57xx-beagle-x15-u-boot.dtsi | 7 +++++++ arch/arm/dts/am57xx-cl-som-am57x-u-boot.dtsi | 7 +++++++ arch/arm/dts/am57xx-sbc-am57x-u-boot.dtsi | 7 +++++++ 6 files changed, 36 insertions(+) create mode 100644 arch/arm/dts/am57xx-beagle-x15-revb1-u-boot.dtsi create mode 100644 arch/arm/dts/am57xx-beagle-x15-revc-u-boot.dtsi create mode 100644 arch/arm/dts/am57xx-beagle-x15-u-boot.dtsi create mode 100644 arch/arm/dts/am57xx-cl-som-am57x-u-boot.dtsi create mode 100644 arch/arm/dts/am57xx-sbc-am57x-u-boot.dtsi
diff --git a/MAINTAINERS b/MAINTAINERS index 7adc28dbfd87..c73739a15a4b 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -514,6 +514,7 @@ ARM TI M: Tom Rini trini@konsulko.com S: Maintained T: git https://source.denx.de/u-boot/custodians/u-boot-ti.git +F: arch/arm/dts/am57xx* F: arch/arm/dts/dra7* F: arch/arm/mach-davinci/ F: arch/arm/mach-k3/ diff --git a/arch/arm/dts/am57xx-beagle-x15-revb1-u-boot.dtsi b/arch/arm/dts/am57xx-beagle-x15-revb1-u-boot.dtsi new file mode 100644 index 000000000000..49b16215e528 --- /dev/null +++ b/arch/arm/dts/am57xx-beagle-x15-revb1-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + */ + +#include "omap5-u-boot.dtsi" +#include "dra7-ipu-common-early-boot.dtsi" diff --git a/arch/arm/dts/am57xx-beagle-x15-revc-u-boot.dtsi b/arch/arm/dts/am57xx-beagle-x15-revc-u-boot.dtsi new file mode 100644 index 000000000000..49b16215e528 --- /dev/null +++ b/arch/arm/dts/am57xx-beagle-x15-revc-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + */ + +#include "omap5-u-boot.dtsi" +#include "dra7-ipu-common-early-boot.dtsi" diff --git a/arch/arm/dts/am57xx-beagle-x15-u-boot.dtsi b/arch/arm/dts/am57xx-beagle-x15-u-boot.dtsi new file mode 100644 index 000000000000..49b16215e528 --- /dev/null +++ b/arch/arm/dts/am57xx-beagle-x15-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + */ + +#include "omap5-u-boot.dtsi" +#include "dra7-ipu-common-early-boot.dtsi" diff --git a/arch/arm/dts/am57xx-cl-som-am57x-u-boot.dtsi b/arch/arm/dts/am57xx-cl-som-am57x-u-boot.dtsi new file mode 100644 index 000000000000..49b16215e528 --- /dev/null +++ b/arch/arm/dts/am57xx-cl-som-am57x-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + */ + +#include "omap5-u-boot.dtsi" +#include "dra7-ipu-common-early-boot.dtsi" diff --git a/arch/arm/dts/am57xx-sbc-am57x-u-boot.dtsi b/arch/arm/dts/am57xx-sbc-am57x-u-boot.dtsi new file mode 100644 index 000000000000..49b16215e528 --- /dev/null +++ b/arch/arm/dts/am57xx-sbc-am57x-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + */ + +#include "omap5-u-boot.dtsi" +#include "dra7-ipu-common-early-boot.dtsi"
Amjad Ouled-Ameur
