[PATCH] linker_lists: set LINKER_LIST_ALIGN to 8 if 64BIT
CPU_MIPS64 needs 8-byte alignment on the linker lists, otherwise an exception may occur. In fact all 64BIT architectures should default to 8; that's what this patch does. Fixes an issue found on malta64 with QEMU:
Breakpoint 1, lists_driver_lookup_name (name=0xffffffffbe043578 "root_driver") at /home/uboot/u-boot/drivers/core/lists.c:31 31 if (!strcmp(name, entry->name)) [...] ld a1,0(s0)
(gdb) p/x &entry->name 0xffffffffbe04b0d4 (gdb) p/x $s0 0xffffffffbe04b0d4
$ grep __u_boot_list /tmp/malta64/u-boot.objdump 4 __u_boot_list 000018e0 ffffffffbe04a4d4 ffffffffbe04a4d4 0004a584 2**2
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org --- arch/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/Kconfig b/arch/Kconfig index 8f1f4667012..72bf4029251 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -45,7 +45,7 @@ config SYS_CACHELINE_SIZE config LINKER_LIST_ALIGN int default 32 if SANDBOX - default 8 if ARM64 || X86 + default 8 if 64BIT default 4 help Force the each linker list to be aligned to this boundary. This
On Mon, 7 Oct 2024 at 12:42, Jerome Forissier jerome.forissier@linaro.org wrote:
-- 2.40.1
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
- default 8 if 64BIT default 4 help Force the each linker list to be aligned to this boundary. This
Superseded by https://patchwork.ozlabs.org/project/uboot/patch/20241007094206.2928071-1-je...
Thanks,
It seems you are pointing to this very patch. You probably wanted to respond to an earlier version.
Best regards
Heinrich
Sorry about that. I wanted to reply to [1] indeed. And I wondering why my reply wouldn't show up on patchwork... :o
[1] http://patchwork.ozlabs.org/project/uboot/patch/20241003142030.1610222-1-jer...
Thanks.
Ilias Apalodimas
Jerome Forissier
