[U-Boot-Users] [PATCH 1/2] fsl_elbc_nand: workaround for hangs during nand write
Using current driver elbc sometimes hangs during nand write. Reading back last byte helps though (thanks to Scott Wood for the idea).
Signed-off-by: Anton Vorontsov avorontsov@ru.mvista.com Signed-off-by: Scott Wood scottwood@freescale.com --- drivers/mtd/nand/fsl_elbc_nand.c | 11 ++++++++++- 1 files changed, 10 insertions(+), 1 deletions(-)
diff --git a/drivers/mtd/nand/fsl_elbc_nand.c b/drivers/mtd/nand/fsl_elbc_nand.c index c1644c0..ab3e0fd 100644 --- a/drivers/mtd/nand/fsl_elbc_nand.c +++ b/drivers/mtd/nand/fsl_elbc_nand.c @@ -489,7 +489,7 @@ static void fsl_elbc_write_buf(struct mtd_info *mtd, const u8 *buf, int len) struct fsl_elbc_ctrl *ctrl = priv->ctrl; unsigned int bufsize = mtd->writesize + mtd->oobsize;
- if (len < 0) { + if (len <= 0) { printf("write_buf of %d bytes", len); ctrl->status = 0; return; @@ -503,6 +503,15 @@ static void fsl_elbc_write_buf(struct mtd_info *mtd, const u8 *buf, int len) }
memcpy_toio(&ctrl->addr[ctrl->index], buf, len); + /* + * This is workaround for the weird elbc hangs during nand write, + * Scott Wood says: "...perhaps difference in how long it takes a + * write to make it through the localbus compared to a write to IMMR + * is causing problems, and sync isn't helping for some reason." + * Reading back the last byte helps though. + */ + in_8(&ctrl->addr[ctrl->index] + len - 1); + ctrl->index += len; }
I guess (and I don't like having to guess) that this patch is intended for the new NAND code, as we don't even have a file "fsl_elbc_nand.c" in mainline yet?
It would be really helpful if you could be explicit and make clear what the target of such patches is.
Thanks.
Yes, it's for the NAND testing branch.
OK, I'll prefix such patches with "NAND testing:" in the future.
-Scott
Scott Wood
