[PATCH 1/2 v2] board: starfive: support Pine64 Star64 board
Similar to the Milk-V Mars, The Star64 board contains few differences to the VisionFive 2 boards, so can be part of the same U-boot build.
Signed-off-by: Henry Bell dmoo_dv@protonmail.com Cc: ycliang@andestech.com Cc: heinrich.schuchardt@canonical.com ---
Changes since v1
- Fix typos on naming - Create pine64_star64 struct to be populated with PHY values once confirmed --- board/starfive/visionfive2/spl.c | 85 +++++++++++++++++++ .../visionfive2/starfive_visionfive2.c | 4 + 2 files changed, 89 insertions(+)
diff --git a/board/starfive/visionfive2/spl.c b/board/starfive/visionfive2/spl.c index ca61b5be22..248c6ba01d 100644 --- a/board/starfive/visionfive2/spl.c +++ b/board/starfive/visionfive2/spl.c @@ -86,6 +86,39 @@ static const struct starfive_vf2_pro starfive_verb[] = { "tx-internal-delay-ps", "0"}, };
+static const struct starfive_vf2_pro star64_pine64[] = { + {"/soc/ethernet@16030000", "starfive,tx-use-rgmii-clk", NULL}, + {"/soc/ethernet@16040000", "starfive,tx-use-rgmii-clk", NULL}, + + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "motorcomm,tx-clk-adj-enabled", NULL}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "motorcomm,tx-clk-100-inverted", NULL}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "motorcomm,tx-clk-1000-inverted", NULL}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "motorcomm,rx-clk-drv-microamp", "3970"}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "motorcomm,rx-data-drv-microamp", "2910"}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "rx-internal-delay-ps", "1900"}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "tx-internal-delay-ps", "1500"}, + + {"/soc/ethernet@16040000/mdio/ethernet-phy@1", + "motorcomm,tx-clk-adj-enabled", NULL}, + { "/soc/ethernet@16040000/mdio/ethernet-phy@1", + "motorcomm,tx-clk-100-inverted", NULL}, + {"/soc/ethernet@16040000/mdio/ethernet-phy@1", + "motorcomm,rx-clk-drv-microamp", "3970"}, + {"/soc/ethernet@16040000/mdio/ethernet-phy@1", + "motorcomm,rx-data-drv-microamp", "2910"}, + {"/soc/ethernet@16040000/mdio/ethernet-phy@1", + "rx-internal-delay-ps", "0"}, + {"/soc/ethernet@16040000/mdio/ethernet-phy@1", + "tx-internal-delay-ps", "0"}, +}; + void spl_fdt_fixup_mars(void *fdt) { static const char compat[] = "milkv,mars\0starfive,jh7110"; @@ -226,6 +259,56 @@ void spl_fdt_fixup_version_b(void *fdt) } }
+void spl_fdt_fixup_star64(void *fdt) +{ + static const char compat[] = "pine64,star64\0starfive,jh7110"; + u32 phandle; + u8 i; + int offset; + int ret; + + fdt_setprop(fdt, fdt_path_offset(fdt, "/"), "compatible", compat, sizeof(compat)); + fdt_setprop_string(fdt, fdt_path_offset(fdt, "/"), "model", + "Pine64 Star64"); + + /* gmac0 */ + offset = fdt_path_offset(fdt, "/soc/clock-controller@17000000"); + phandle = fdt_get_phandle(fdt, offset); + offset = fdt_path_offset(fdt, "/soc/ethernet@16030000"); + + fdt_setprop_u32(fdt, offset, "assigned-clocks", phandle); + fdt_appendprop_u32(fdt, offset, "assigned-clocks", JH7110_AONCLK_GMAC0_TX); + fdt_setprop_u32(fdt, offset, "assigned-clock-parents", phandle); + fdt_appendprop_u32(fdt, offset, "assigned-clock-parents", + JH7110_AONCLK_GMAC0_RMII_RTX); + + /* gmac1 */ + offset = fdt_path_offset(fdt, "/soc/clock-controller@13020000"); + phandle = fdt_get_phandle(fdt, offset); + offset = fdt_path_offset(fdt, "/soc/ethernet@16040000"); + + fdt_setprop_u32(fdt, offset, "assigned-clocks", phandle); + fdt_appendprop_u32(fdt, offset, "assigned-clocks", JH7110_SYSCLK_GMAC1_TX); + fdt_setprop_u32(fdt, offset, "assigned-clock-parents", phandle); + fdt_appendprop_u32(fdt, offset, "assigned-clock-parents", + JH7110_SYSCLK_GMAC1_RMII_RTX); + + for (i = 0; i < ARRAY_SIZE(star64_pine64); i++) { + offset = fdt_path_offset(fdt, star64_pine64[i].path); + + if (star64_pine64[i].value) + ret = fdt_setprop_u32(fdt, offset, star64_pine64[i].name, + dectoul(star64_pine64[i].value, NULL)); + else + ret = fdt_setprop_empty(fdt, offset, star64_pine64[i].name); + + if (ret) { + pr_err("%s set prop %s fail.\n", __func__, star64_pine64[i].name); + break; + } + } +} + void spl_perform_fixups(struct spl_image_info *spl_image) { u8 version; @@ -252,6 +335,8 @@ void spl_perform_fixups(struct spl_image_info *spl_image) spl_fdt_fixup_version_b(spl_image->fdt_addr); break; }; + } else if (!strncmp(product_id, "STAR64", 6)) { + spl_fdt_fixup_star64(spl_image->fdt_addr); } else { pr_err("Unknown product %s\n", product_id); }; diff --git a/board/starfive/visionfive2/starfive_visionfive2.c b/board/starfive/visionfive2/starfive_visionfive2.c index a86bca533b..1e7c41f01b 100644 --- a/board/starfive/visionfive2/starfive_visionfive2.c +++ b/board/starfive/visionfive2/starfive_visionfive2.c @@ -23,6 +23,8 @@ DECLARE_GLOBAL_DATA_PTR; "starfive/jh7110-starfive-visionfive-2-v1.2a.dtb" #define FDTFILE_VISIONFIVE2_1_3B \ "starfive/jh7110-starfive-visionfive-2-v1.3b.dtb" +#define FDTFILE_PINE64_STAR64 \ + "starfive/jh7110-pine64-star64.dtb"
/* enable U74-mc hart1~hart4 prefetcher */ static void enable_prefetcher(void) @@ -78,6 +80,8 @@ static void set_fdtfile(void) fdtfile = FDTFILE_VISIONFIVE2_1_3B; break; } + } else if (!strncmp(product_id, "STAR64", 6)) { + fdtfile = FDTFILE_PINE64_STAR64; } else { log_err("Unknown product\n"); return;
Off-list we reasoned further about the correct PHY values.
As our reference was the pre-loaded SPI NOR content containing dtb data:
ethernet@16030000 { ... ethernet-phy@0 { rxc_dly_en = <0x01>; tx_delay_sel_fe = <0x05>; tx_delay_sel = <0x0a>; tx_inverted_10 = <0x01>; tx_inverted_100 = <0x01>; tx_inverted_1000 = <0x01>; phandle = <0x54>; }; ... ethernet@16040000 { ... ethernet-phy@1 { tx_delay_sel_fe = <0x05>; tx_delay_sel = <0x00>; rxc_dly_en = <0x00>; tx_inverted_10 = <0x01>; tx_inverted_100 = <0x01>; tx_inverted_1000 = <0x00>; phandle = <0x56>; };
This is identical to ethernet-phy@0 and ethernet-phy@1 sections in Linux-riscv series 705018 "Add Ethernet driver for StarFive JH7110 SoC":
https://patchwork.kernel.org/project/linux-riscv/patch/20221216070632.11444-...
Defaults are assumed to be from that version of the motorcomm driver. More recent versions of the driver deprecate setting the Fast Ethernet TX delay tx_delay_sel_fe and instead is this comment in the source code: "Generally, it is not necessary to adjust YT8531_RC1R_FE_TX_DELAY"
Changes since v1
Add: {"/soc/ethernet@16030000/mdio/ethernet-phy@0", "motorcomm,tx-clk-10-inverted", NULL},
This rx-clk-drv-microamp value 3970 is suspect. Delete rx-clk-drv-microamp property or set default value 2910.
From drivers/net/phy/motorcomm.c:
YT8531_RGMII_RX_DS_DEFAULT 0x3
Presumably this default is the same as in the version of the motorcomm driver that is included on pre-loaded SPI NOR content.
N.b. tx-internal-delay-ps corresponds to tx_delay_sel (1000Mbit GE) and there is not any property corresponding to tx_delay_sel_fe (10/100Mbit FE). The driver does not implement tx_delay_sel_fe so no corresponding property on @0, else it would be included here.
Add: "motorcomm,tx-clk-10-inverted", NULL}, {"/soc/ethernet@16040000/mdio/ethernet-phy@1",
Nit: delete space between curly bracket and open-quote to match other lines.
Again suspect 3970 value. Delete or set default 2910.
N.b. driver does not implement tx_delay_sel_fe so no corresponding property on @1, else it would be included here.
u32 phandle;
u8 i;
int offset;
int ret;
"Pine64 Star64");
/* gmac0 */
/* gmac1 */
else
if (ret) {
break;
-- 2.44.0
I've posted builds to people interested in testing where I add a tx-internal-delay-ps property and register setting in motorcomm.c which would be some later patch if it has a useful result.
P.S. some typo in my last message.
Changes since v1
From drivers/net/phy/motorcomm.c: YT8531_RGMII_RX_DS_DEFAULT 0x3
u32 phandle;
u8 i;
int offset;
int ret;
"Pine64 Star64");
/* gmac0 */
/* gmac1 */
else
if (ret) {
break;
-- 2.44.0
Fixing my typo: The future testing is tx-internal-delay-fe-ps corresponding to tx_delay_sel_fe.
- E
E Shattow
H Bell
