[U-Boot] [PATCH v3 0/7] rk3399: enable host controllers
rk3399 evb has two typec port(dwc3 controller) which support dual role device with separate GPIO for vbus control and two USB 2.0 host port (generic EHCI controller) with one GPIO for vbus control.
This patch set enable all these host controllers and have test with usb disk and usb ethernet devices on rk3399 evb.
Note: type-C port only support usb 2.0 currently because the PD driver and USB 3.0 phy driver not enabled.
Changes in v3: - using fdtdec_get_bool and fdtdec_get_int instead of fdt_get_property - other update by follow comments from Marek and Simon - add Acked-by tag from Simon
Changes in v2: - update for comments from Marek - use regulator_get_by_platname instead of uclass_get_device_by_name - add Acked-by Tag from Simon
Kever Yang (3): dts: rk3399-evb: add regulator-fixed for usb host vbus board: evb-rk3399: enable usb 2.0 host vbus power on board_init config: evb-rk3399: enable fixed regulator
MengDongyang (4): usb: xhci-rockchip: add rockchip dwc3 controller driver rockchip: select DM_USB for rockchip SoC config: rk3399: add usb related configs dts: rk3399: add dwc3_typec node for rk3399
arch/arm/Kconfig | 1 + arch/arm/dts/rk3399-evb.dts | 14 +++ arch/arm/dts/rk3399.dtsi | 45 +++++++ board/rockchip/evb_rk3399/evb-rk3399.c | 15 ++- configs/evb-rk3399_defconfig | 9 ++ drivers/usb/host/Makefile | 1 + drivers/usb/host/xhci-rockchip.c | 211 +++++++++++++++++++++++++++++++++ include/configs/rk3399_common.h | 13 ++ include/linux/usb/dwc3.h | 14 +++ 9 files changed, 322 insertions(+), 1 deletion(-) create mode 100644 drivers/usb/host/xhci-rockchip.c
This patch add support for rockchip dwc3 controller, which corresponding to the two type-C port on rk3399 evb. Only support usb2.0 currently for we have not enable the usb3.0 phy driver and PD(fusb302) driver.
Signed-off-by: MengDongyang daniel.meng@rock-chips.com Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
drivers/usb/host/Makefile | 1 + drivers/usb/host/xhci-rockchip.c | 211 +++++++++++++++++++++++++++++++++++++++ include/linux/usb/dwc3.h | 14 +++ 3 files changed, 226 insertions(+) create mode 100644 drivers/usb/host/xhci-rockchip.c
diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index 620d114..fdefcf6 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -56,6 +56,7 @@ obj-$(CONFIG_USB_EHCI_ZYNQ) += ehci-zynq.o # xhci obj-$(CONFIG_USB_XHCI_HCD) += xhci.o xhci-mem.o xhci-ring.o obj-$(CONFIG_USB_XHCI_DWC3) += xhci-dwc3.o +obj-$(CONFIG_USB_XHCI_ROCKCHIP) += xhci-rockchip.o obj-$(CONFIG_USB_XHCI_ZYNQMP) += xhci-zynqmp.o obj-$(CONFIG_USB_XHCI_KEYSTONE) += xhci-keystone.o obj-$(CONFIG_USB_XHCI_EXYNOS) += xhci-exynos5.o diff --git a/drivers/usb/host/xhci-rockchip.c b/drivers/usb/host/xhci-rockchip.c new file mode 100644 index 0000000..561bf86 --- /dev/null +++ b/drivers/usb/host/xhci-rockchip.c @@ -0,0 +1,211 @@ +/* + * Copyright (c) 2016 Rockchip, Inc. + * Authors: Daniel Meng daniel.meng@rock-chips.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <dm.h> +#include <fdtdec.h> +#include <libfdt.h> +#include <malloc.h> +#include <usb.h> +#include <watchdog.h> +#include <asm/gpio.h> +#include <asm-generic/errno.h> +#include <linux/compat.h> +#include <linux/usb/dwc3.h> + +#include "xhci.h" + +DECLARE_GLOBAL_DATA_PTR; + +struct rockchip_xhci_platdata { + fdt_addr_t hcd_base; + fdt_addr_t phy_base; + struct gpio_desc vbus_gpio; +}; + +/* + * Contains pointers to register base addresses + * for the usb controller. + */ +struct rockchip_xhci { + struct usb_platdata usb_plat; + struct xhci_ctrl ctrl; + struct xhci_hccr *hcd; + struct dwc3 *dwc3_reg; +}; + +static int xhci_usb_ofdata_to_platdata(struct udevice *dev) +{ + struct rockchip_xhci_platdata *plat = dev_get_platdata(dev); + struct udevice *child; + int ret = 0; + + /* + * Get the base address for XHCI controller from the device node + */ + plat->hcd_base = dev_get_addr(dev); + if (plat->hcd_base == FDT_ADDR_T_NONE) { + debug("Can't get the XHCI register base address\n"); + return -ENXIO; + } + + /* Get the base address for usbphy from the device node */ + for (device_find_first_child(dev, &child); child; + device_find_next_child(&child)) { + if (!of_device_is_compatible(child, "rockchip,rk3399-usb3-phy")) + continue; + plat->phy_base = dev_get_addr(child); + break; + } + + if (plat->phy_base == FDT_ADDR_T_NONE) { + debug("Can't get the usbphy register address\n"); + return -ENXIO; + } + + /* Vbus gpio */ + ret = gpio_request_by_name(dev, "rockchip,vbus-gpio", 0, + &plat->vbus_gpio, GPIOD_IS_OUT); + if (ret) + debug("rockchip,vbus-gpio node missing!"); + + return 0; +} + +/* + * rockchip_dwc3_phy_setup() - Configure USB PHY Interface of DWC3 Core + * @dwc: Pointer to our controller context structure + * @dev: Pointer to ulcass device + */ +static void rockchip_dwc3_phy_setup(struct dwc3 *dwc3_reg, + struct udevice *dev) +{ + u32 reg; + const void *blob = gd->fdt_blob; + u32 utmi_bits; + + /* Set dwc3 usb2 phy config */ + reg = readl(&dwc3_reg->g_usb2phycfg[0]); + + if (fdtdec_get_bool(blob, dev->of_offset, + "snps,dis-enblslpm-quirk")) + reg &= ~DWC3_GUSB2PHYCFG_ENBLSLPM; + + utmi_bits = fdtdec_get_int(blob, dev->of_offset, + "snps,phyif-utmi-bits", -1); + if (utmi_bits == 16) { + reg |= DWC3_GUSB2PHYCFG_PHYIF; + reg &= ~DWC3_GUSB2PHYCFG_USBTRDTIM_MASK; + reg |= DWC3_GUSB2PHYCFG_USBTRDTIM_16BIT; + } else if (utmi_bits == 8) { + reg &= ~DWC3_GUSB2PHYCFG_PHYIF; + reg &= ~DWC3_GUSB2PHYCFG_USBTRDTIM_MASK; + reg |= DWC3_GUSB2PHYCFG_USBTRDTIM_8BIT; + } + + if (fdtdec_get_bool(blob, dev->of_offset, + "snps,dis-u2-freeclk-exists-quirk")) + reg &= ~DWC3_GUSB2PHYCFG_U2_FREECLK_EXISTS; + + if (fdtdec_get_bool(blob, dev->of_offset, + "snps,dis-u2-susphy-quirk")) + reg &= ~DWC3_GUSB2PHYCFG_SUSPHY; + + writel(reg, &dwc3_reg->g_usb2phycfg[0]); +} + +static int rockchip_xhci_core_init(struct rockchip_xhci *rkxhci, + struct udevice *dev) +{ + int ret; + + ret = dwc3_core_init(rkxhci->dwc3_reg); + if (ret) { + debug("failed to initialize core\n"); + return ret; + } + + rockchip_dwc3_phy_setup(rkxhci->dwc3_reg, dev); + + /* We are hard-coding DWC3 core to Host Mode */ + dwc3_set_mode(rkxhci->dwc3_reg, DWC3_GCTL_PRTCAP_HOST); + + return 0; +} + +static int rockchip_xhci_core_exit(struct rockchip_xhci *rkxhci) +{ + return 0; +} + +static int xhci_usb_probe(struct udevice *dev) +{ + struct rockchip_xhci_platdata *plat = dev_get_platdata(dev); + struct rockchip_xhci *ctx = dev_get_priv(dev); + struct xhci_hcor *hcor; + int ret; + + ctx->hcd = (struct xhci_hccr *)plat->hcd_base; + ctx->dwc3_reg = (struct dwc3 *)((char *)(ctx->hcd) + DWC3_REG_OFFSET); + hcor = (struct xhci_hcor *)((uint64_t)ctx->hcd + + HC_LENGTH(xhci_readl(&ctx->hcd->cr_capbase))); + + /* setup the Vbus gpio here */ + if (dm_gpio_is_valid(&plat->vbus_gpio)) + dm_gpio_set_value(&plat->vbus_gpio, 1); + + ret = rockchip_xhci_core_init(ctx, dev); + if (ret) { + debug("XHCI: failed to initialize controller\n"); + return ret; + } + + return xhci_register(dev, ctx->hcd, hcor); +} + +static int xhci_usb_remove(struct udevice *dev) +{ + struct rockchip_xhci *ctx = dev_get_priv(dev); + int ret; + + ret = xhci_deregister(dev); + if (ret) + return ret; + ret = rockchip_xhci_core_exit(ctx); + if (ret) + return ret; + + return 0; +} + +static const struct udevice_id xhci_usb_ids[] = { + { .compatible = "rockchip,rk3399-xhci" }, + { } +}; + +U_BOOT_DRIVER(usb_xhci) = { + .name = "xhci_rockchip", + .id = UCLASS_USB, + .of_match = xhci_usb_ids, + .ofdata_to_platdata = xhci_usb_ofdata_to_platdata, + .probe = xhci_usb_probe, + .remove = xhci_usb_remove, + .ops = &xhci_usb_ops, + .bind = dm_scan_fdt_dev, + .platdata_auto_alloc_size = sizeof(struct rockchip_xhci_platdata), + .priv_auto_alloc_size = sizeof(struct rockchip_xhci), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +}; + +static const struct udevice_id usb_phy_ids[] = { + { .compatible = "rockchip,rk3399-usb3-phy" }, + { } +}; + +U_BOOT_DRIVER(usb_phy) = { + .name = "usb_phy_rockchip", + .of_match = usb_phy_ids, +}; diff --git a/include/linux/usb/dwc3.h b/include/linux/usb/dwc3.h index 6d1e365..a027446 100644 --- a/include/linux/usb/dwc3.h +++ b/include/linux/usb/dwc3.h @@ -180,7 +180,21 @@ struct dwc3 { /* offset: 0xC100 */
/* Global USB2 PHY Configuration Register */ #define DWC3_GUSB2PHYCFG_PHYSOFTRST (1 << 31) +#define DWC3_GUSB2PHYCFG_U2_FREECLK_EXISTS (1 << 30) +#define DWC3_GUSB2PHYCFG_ENBLSLPM (1 << 8) #define DWC3_GUSB2PHYCFG_SUSPHY (1 << 6) +#define DWC3_GUSB2PHYCFG_PHYIF (1 << 3) + +/* Global USB2 PHY Configuration Mask */ +#define DWC3_GUSB2PHYCFG_USBTRDTIM_MASK (0xf << 10) + +/* Global USB2 PHY Configuration Offset */ +#define DWC3_GUSB2PHYCFG_USBTRDTIM_OFFSET 10 + +#define DWC3_GUSB2PHYCFG_USBTRDTIM_16BIT (0x5 << \ + DWC3_GUSB2PHYCFG_USBTRDTIM_OFFSET) +#define DWC3_GUSB2PHYCFG_USBTRDTIM_8BIT (0x9 << \ + DWC3_GUSB2PHYCFG_USBTRDTIM_OFFSET)
/* Global USB3 PIPE Control Register */ #define DWC3_GUSB3PIPECTL_PHYSOFTRST (1 << 31)
Changes in v3:
Changes in v2:
Thanks
Changes in v3:
Changes in v2:
Changes in v3:
Changes in v2:
This series is in my queue so I will apply it.
Applied to u-boot-rockchip/next, thanks!
Select DM_USB to compatible with USB DM driver model.
Signed-off-by: MengDongyang daniel.meng@rock-chips.com Signed-off-by: Kever Yang kever.yang@rock-chips.com Acked-by: Simon Glass sjg@chromium.org ---
arch/arm/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 5ac9401..4dfd4b2 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -861,6 +861,7 @@ config ARCH_ROCKCHIP select DM_SERIAL select DM_SPI select DM_SPI_FLASH + select DM_USB if USB
config TARGET_THUNDERX_88XX bool "Support ThunderX 88xx"
This patch to enable configs for usb module - xhci - ehci - usb storage - usb net
configs/evb-rk3399_defconfig | 7 +++++++ include/configs/rk3399_common.h | 13 +++++++++++++ 2 files changed, 20 insertions(+)
diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 2951678..378111f 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_USB=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y @@ -36,3 +37,9 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_USE_TINY_PRINTF=y CONFIG_ERRNO_STR=y +CONFIG_USB=y +CONFIG_USB_STORAGE=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index fcd1700..ce7ac7c 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -105,4 +105,17 @@
#endif
+/* enable usb config for usb ether */ +#define CONFIG_USB_HOST_ETHER + +#define CONFIG_USB_ETHER_ASIX +#define CONFIG_USB_ETHER_ASIX88179 +#define CONFIG_USB_ETHER_MCS7830 +#define CONFIG_USB_ETHER_SMSC95XX +#define CONFIG_USB_ETHER_RTL8152 + +/* rockchip xhci host driver */ +#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_XHCI_ROCKCHIP + #endif
- xhci
- ehci
- usb storage
- usb net
rk3399 has two dwc3 controller for type-C port, add the dts node and enable them.
arch/arm/dts/rk3399-evb.dts | 8 ++++++++ arch/arm/dts/rk3399.dtsi | 45 +++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 53 insertions(+)
diff --git a/arch/arm/dts/rk3399-evb.dts b/arch/arm/dts/rk3399-evb.dts index e92a492..7b49f6f 100644 --- a/arch/arm/dts/rk3399-evb.dts +++ b/arch/arm/dts/rk3399-evb.dts @@ -85,6 +85,10 @@ status = "okay"; };
+&dwc3_typec0 { + status = "okay"; +}; + &usb_host1_ehci { status = "okay"; }; @@ -93,6 +97,10 @@ status = "okay"; };
+&dwc3_typec1 { + status = "okay"; +}; + &pinctrl { pmic { pmic_int_l: pmic-int-l { diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi index 6d82078..179860c 100644 --- a/arch/arm/dts/rk3399.dtsi +++ b/arch/arm/dts/rk3399.dtsi @@ -9,6 +9,7 @@ #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/pinctrl/rockchip.h> +#define USB_CLASS_HUB 9
/ { compatible = "rockchip,rk3399"; @@ -230,6 +231,50 @@ status = "disabled"; };
+ dwc3_typec0: usb@fe800000 { + compatible = "rockchip,rk3399-xhci"; + reg = <0x0 0xfe800000 0x0 0x100000>; + status = "disabled"; + rockchip,vbus-gpio = <&gpio1 3 GPIO_ACTIVE_HIGH>; + snps,dis-enblslpm-quirk; + snps,phyif-utmi-bits = <16>; + snps,dis-u2-freeclk-exists-quirk; + snps,dis-u2-susphy-quirk; + + #address-cells = <2>; + #size-cells = <2>; + hub { + compatible = "usb-hub"; + usb,device-class = <USB_CLASS_HUB>; + }; + typec_phy0 { + compatible = "rockchip,rk3399-usb3-phy"; + reg = <0x0 0xff7c0000 0x0 0x40000>; + }; + }; + + dwc3_typec1: usb@fe900000 { + compatible = "rockchip,rk3399-xhci"; + reg = <0x0 0xfe900000 0x0 0x100000>; + status = "disabled"; + rockchip,vbus-gpio = <&gpio1 4 GPIO_ACTIVE_HIGH>; + snps,dis-enblslpm-quirk; + snps,phyif-utmi-bits = <16>; + snps,dis-u2-freeclk-exists-quirk; + snps,dis-u2-susphy-quirk; + + #address-cells = <2>; + #size-cells = <2>; + hub { + compatible = "usb-hub"; + usb,device-class = <USB_CLASS_HUB>; + }; + typec_phy1 { + compatible = "rockchip,rk3399-usb3-phy"; + reg = <0x0 0xff800000 0x0 0x40000>; + }; + }; + gic: interrupt-controller@fee00000 { compatible = "arm,gic-v3"; #interrupt-cells = <3>;
rk3399 evb using one gpio to enable 5V output for both USB 2.0 host port, let's use fixed regulator for them.
arch/arm/dts/rk3399-evb.dts | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/dts/rk3399-evb.dts b/arch/arm/dts/rk3399-evb.dts index 7b49f6f..bd7801b 100644 --- a/arch/arm/dts/rk3399-evb.dts +++ b/arch/arm/dts/rk3399-evb.dts @@ -43,6 +43,12 @@ regulator-always-on; regulator-boot-on; }; + + vcc5v0_host: vcc5v0-host-en { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_host"; + gpio = <&gpio4 25 GPIO_ACTIVE_HIGH>; + }; };
&emmc_phy {
rk3399 using one gpio control signal for two usb 2.0 host port, it's better to enable the power in board file instead of in usb driver.
Changes in v3: - add Acked-by tag from Simon
Changes in v2: - use regulator_get_by_platname instead of uclass_get_device_by_name
board/rockchip/evb_rk3399/evb-rk3399.c | 15 ++++++++++++++- 1 file changed, 14 insertions(+), 1 deletion(-)
diff --git a/board/rockchip/evb_rk3399/evb-rk3399.c b/board/rockchip/evb_rk3399/evb-rk3399.c index 5d3a09a..5b245e4 100644 --- a/board/rockchip/evb_rk3399/evb-rk3399.c +++ b/board/rockchip/evb_rk3399/evb-rk3399.c @@ -9,12 +9,13 @@ #include <asm/arch/periph.h> #include <usb.h> #include <dwc3-uboot.h> +#include <power/regulator.h>
int board_init(void) { - struct udevice *pinctrl; + struct udevice *pinctrl, *regulator; int ret;
/* @@ -40,6 +41,18 @@ int board_init(void) goto out; }
+ ret = regulator_get_by_platname("vcc5v0_host", ®ulator); + if (ret) { + debug("%s vcc5v0_host init fail! ret %d\n", __func__, ret); + goto out; + } + + ret = regulator_set_enable(regulator, true); + if (ret) { + debug("%s vcc5v0-host-en set fail!\n", __func__); + goto out; + } + out: return 0; }
Changes in v3:
Changes in v2:
This patch enable fixed regulator driver for rk3399 evb.
Changes in v3: None Changes in v2: - add Acked-by Tag from Simon
configs/evb-rk3399_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 378111f..9a6d422 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -43,3 +43,5 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y
Changes in v3:
Changes in v2:
-- 1.9.1
No more comments and it has been almost two weeks, so I'm going to merge this.
Kever Yang
