[U-Boot] [PATCH] LZMA and LZO causes compile error
If both LZMA and LZO compressions are used there is a compile error in cmd_bootm.c
Signed-off-by: Matthias Weisser weisserm@arcor.de --- common/cmd_bootm.c | 7 +++++-- 1 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index adfa6cd..4562957 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -333,6 +333,9 @@ static int bootm_load_os(image_info_t os, ulong *load_end, int boot_progress) ulong image_start = os.image_start; ulong image_len = os.image_len; uint unc_len = CONFIG_SYS_BOOTM_LEN; +#if defined(CONFIG_LZMA) || defined(CONFIG_LZO) + int ret; +#endif /* defined(CONFIG_LZMA) || defined(CONFIG_LZO) */
const char *type_name = genimg_get_type_name (os.type);
@@ -389,7 +392,7 @@ static int bootm_load_os(image_info_t os, ulong *load_end, int boot_progress) case IH_COMP_LZMA: printf (" Uncompressing %s ... ", type_name);
- int ret = lzmaBuffToBuffDecompress( + ret = lzmaBuffToBuffDecompress( (unsigned char *)load, &unc_len, (unsigned char *)image_start, image_len); if (ret != SZ_OK) { @@ -405,7 +408,7 @@ static int bootm_load_os(image_info_t os, ulong *load_end, int boot_progress) case IH_COMP_LZO: printf (" Uncompressing %s ... ", type_name);
- int ret = lzop_decompress((const unsigned char *)image_start, + ret = lzop_decompress((const unsigned char *)image_start, image_len, (unsigned char *)load, &unc_len); if (ret != LZO_E_OK) {
Dear Matthias Weisser,
Hm... doesn't apply:
Applying: LZMA and LZO causes compile error Using index info to reconstruct a base tree... Falling back to patching base and 3-way merge... Auto-merging common/cmd_bootm.c CONFLICT (content): Merge conflict in common/cmd_bootm.c Failed to merge in the changes. Patch failed at 0001 LZMA and LZO causes compile error When you have resolved this problem run "git am --resolved". If you would prefer to skip this patch, instead run "git am --skip". To restore the original branch and stop patching run "git am --abort".
OK, applied manually. Thanks.
Matthias Weisser
