[PATCH 1/1] acpi: set creator_revision in acpi_fill_header
We should have a single place where we write the default value to the creator revision field. If we ever will have any table created by another tool, we can overwrite the value afterwards.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- arch/x86/lib/acpi_table.c | 2 -- lib/acpi/acpi_table.c | 2 +- lib/acpi/ssdt.c | 1 - test/dm/acpi.c | 3 +-- 4 files changed, 2 insertions(+), 6 deletions(-)
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index a5683132b01..06997948880 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -479,7 +479,6 @@ static int acpi_create_hpet(struct acpi_hpet *hpet) /* Fill out header fields. */ acpi_fill_header(header, "HPET");
- header->creator_revision = ASL_REVISION; header->length = sizeof(struct acpi_hpet); header->revision = acpi_get_table_revision(ACPITAB_HPET);
@@ -570,7 +569,6 @@ void acpi_fadt_common(struct acpi_fadt *fadt, struct acpi_facs *facs, memcpy(header->oem_id, OEM_ID, 6); memcpy(header->oem_table_id, OEM_TABLE_ID, 8); memcpy(header->creator_id, ASLC_ID, 4); - header->creator_revision = 1;
fadt->x_firmware_ctrl = map_to_sysmem(facs); fadt->x_dsdt = map_to_sysmem(dsdt); diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index c16ead6a6ec..6dbfdb22dec 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -117,6 +117,7 @@ void acpi_fill_header(struct acpi_table_header *header, char *signature) memcpy(header->oem_table_id, OEM_TABLE_ID, 8); header->oem_revision = OEM_REVISION; memcpy(header->creator_id, ASLC_ID, 4); + header->creator_revision = ASL_REVISION; }
void acpi_align(struct acpi_ctx *ctx) @@ -219,7 +220,6 @@ void acpi_create_dbg2(struct acpi_dbg2_header *dbg2,
header->revision = acpi_get_table_revision(ACPITAB_DBG2); acpi_fill_header(header, "DBG2"); - header->creator_revision = ASL_REVISION;
/* One debug device defined */ dbg2->devices_offset = sizeof(struct acpi_dbg2_header); diff --git a/lib/acpi/ssdt.c b/lib/acpi/ssdt.c index e032e266b3c..df1d739d117 100644 --- a/lib/acpi/ssdt.c +++ b/lib/acpi/ssdt.c @@ -23,7 +23,6 @@ int acpi_write_ssdt(struct acpi_ctx *ctx, const struct acpi_writer *entry)
acpi_fill_header(ssdt, "SSDT"); ssdt->revision = acpi_get_table_revision(ACPITAB_SSDT); - ssdt->creator_revision = 1; ssdt->length = sizeof(struct acpi_table_header);
acpi_inc(ctx, sizeof(struct acpi_table_header)); diff --git a/test/dm/acpi.c b/test/dm/acpi.c index f14b3962f84..48cf3af1f8f 100644 --- a/test/dm/acpi.c +++ b/test/dm/acpi.c @@ -237,7 +237,6 @@ static int dm_test_acpi_fill_header(struct unit_test_state *uts) hdr.length = 0x11; hdr.revision = 0x22; hdr.checksum = 0x33; - hdr.creator_revision = 0x44; acpi_fill_header(&hdr, "ABCD");
ut_asserteq_mem("ABCD", hdr.signature, sizeof(hdr.signature)); @@ -249,7 +248,7 @@ static int dm_test_acpi_fill_header(struct unit_test_state *uts) sizeof(hdr.oem_table_id)); ut_asserteq(OEM_REVISION, hdr.oem_revision); ut_asserteq_mem(ASLC_ID, hdr.creator_id, sizeof(hdr.creator_id)); - ut_asserteq(0x44, hdr.creator_revision); + ut_asserteq(ASL_REVISION, hdr.creator_revision);
return 0; }
