RE: [U-Boot-Users] u-boot 834x spd_ram
18 Apr
2006
18 Apr
'06
6:54 p.m.
Ok thank you
That's what i thought it should be
-----Original Message----- From: Dan Malek [mailto:dan@embeddededge.com] Sent: Tuesday, April 18, 2006 11:45 AM To: Kumar Gala Cc: Aziz Mzili; u-boot-users@lists.sourceforge.net Subject: Re: [U-Boot-Users] u-boot 834x spd_ram
On Apr 18, 2006, at 9:51 AM, Kumar Gala wrote:
I'm not aware of any. I'm just guessing the boards people have were built this way.
I have a board that doesn't use CS2/CS3. Once I get it running well I'll submit the patches. Basically, I created a #define in the board configuration header file that indicates the base chip select used. I then use this base and base+1 in the code in place of the hard coded assumption of CS2/3 in the spd_sdram.c file.
-- Dan
6958
Aziz Mzili
