[U-Boot] Pull request: ARM
Hello,
The following changes since commit 385a08a60f042061b004642d6b9bb6cfb794ad5a:
ARM: zynq: Remove Jagan from list of maintainers (2015-04-08 18:43:51 -0400)
git://git.denx.de/u-boot-arm master
for you to fetch changes up to 412ae53aadb53cd63e754d638bafe6e426aeafee:
lpc32xx: add support for board work_92105 (2015-04-10 14:23:39 +0200)
There are two ARMv8 patches, Masahiro's neutral mtune/march change, and a series which only adds new drivers and board, so no risk of impacting existing boards.
For some reason, the two ARMv8 commits don't show up in the request-pull output. Here they are:
David Feng (2): ARMv8: enable pre-allocation malloc ARMv8: enable DM in vexpress64 board
arch/arm/include/asm/config.h | 4 ---- arch/arm/lib/crt0_64.S | 13 +++++++++++-- board/armltd/vexpress64/vexpress64.c | 13 +++++++++++++ include/configs/vexpress_aemv8a.h | 13 ++++++++++++- 4 files changed, 36 insertions(+), 7 deletions(-)
---------------------------------------------------------------- Albert ARIBAUD (1): Merge branch 'u-boot/master'
Albert ARIBAUD (3ADEV) (9): lpc32xx: add Ethernet support lpc32xx: mtd: nand: add MLC NAND controller lpc32xx: i2c: add LPC32xx I2C interface support lpc32xx: add GPIO support lpc32xx: add LPC32xx SSP support (SPI mode) dtt: add ds620 support lpc32xx: add lpc32xx-spl.bin boot image target Introduce CONFIG_SPL_PANIC_ON_RAW_IMAGE lpc32xx: add support for board work_92105
Masahiro Yamada (1): ARM: move -march=* and -mtune= options to arch/arm/Makefile
Makefile | 20 +++ README | 10 ++ arch/arm/Kconfig | 6 + arch/arm/Makefile | 32 +++++ arch/arm/cpu/arm1136/config.mk | 9 -- arch/arm/cpu/arm1176/config.mk | 9 -- arch/arm/cpu/arm720t/config.mk | 9 -- arch/arm/cpu/arm920t/config.mk | 8 -- arch/arm/cpu/arm926ejs/config.mk | 8 -- arch/arm/cpu/arm926ejs/lpc32xx/Makefile | 2 + arch/arm/cpu/arm926ejs/lpc32xx/clk.c | 34 +++++ arch/arm/cpu/arm926ejs/lpc32xx/cpu.c | 10 ++ arch/arm/cpu/arm926ejs/lpc32xx/devices.c | 43 +++++++ arch/arm/cpu/arm926ejs/lpc32xx/dram.c | 77 ++++++++++++ arch/arm/cpu/arm926ejs/lpc32xx/lowlevel_init.S | 45 +++++++ arch/arm/cpu/arm946es/config.mk | 8 -- arch/arm/cpu/armv7/config.mk | 5 - arch/arm/cpu/armv8/config.mk | 2 - arch/arm/cpu/pxa/config.mk | 2 - arch/arm/cpu/sa1100/config.mk | 9 -- arch/arm/include/asm/arch-lpc32xx/clk.h | 16 +++ arch/arm/include/asm/arch-lpc32xx/config.h | 3 + arch/arm/include/asm/arch-lpc32xx/cpu.h | 3 + arch/arm/include/asm/arch-lpc32xx/emc.h | 21 ++++ arch/arm/include/asm/arch-lpc32xx/gpio.h | 43 +++++++ arch/arm/include/asm/arch-lpc32xx/mux.h | 18 +++ arch/arm/include/asm/arch-lpc32xx/sys_proto.h | 10 +- board/work-microwave/work_92105/Kconfig | 15 +++ board/work-microwave/work_92105/MAINTAINERS | 6 + board/work-microwave/work_92105/Makefile | 10 ++ board/work-microwave/work_92105/README | 91 ++++++++++++++ board/work-microwave/work_92105/work_92105.c | 77 ++++++++++++ board/work-microwave/work_92105/work_92105_display.c | 349 +++++++++++++++++++++++++++++++++++++++++++++++++++ board/work-microwave/work_92105/work_92105_display.h | 14 +++ board/work-microwave/work_92105/work_92105_spl.c | 85 +++++++++++++ common/image.c | 1 + common/spl/spl.c | 12 ++ configs/work_92105_defconfig | 6 + drivers/gpio/Kconfig | 7 ++ drivers/gpio/Makefile | 1 + drivers/gpio/lpc32xx_gpio.c | 293 +++++++++++++++++++++++++++++++++++++++++++ drivers/hwmon/Makefile | 1 + drivers/hwmon/ds620.c | 65 ++++++++++ drivers/i2c/Makefile | 1 + drivers/i2c/lpc32xx_i2c.c | 249 +++++++++++++++++++++++++++++++++++++ drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/lpc32xx_nand_mlc.c | 764 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/Makefile | 1 + drivers/net/lpc32xx_eth.c | 637 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/spi/Makefile | 1 + drivers/spi/lpc32xx_ssp.c | 144 +++++++++++++++++++++ include/configs/work_92105.h | 241 ++++++++++++++++++++++++++++++++++++ include/dtt.h | 15 +-- include/image.h | 1 + include/netdev.h | 1 + tools/Makefile | 1 + tools/lpc32xximage.c | 178 ++++++++++++++++++++++++++ 57 files changed, 3653 insertions(+), 77 deletions(-) delete mode 100644 arch/arm/cpu/arm1136/config.mk delete mode 100644 arch/arm/cpu/arm1176/config.mk delete mode 100644 arch/arm/cpu/arm720t/config.mk delete mode 100644 arch/arm/cpu/arm920t/config.mk delete mode 100644 arch/arm/cpu/arm926ejs/config.mk create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/dram.c create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/lowlevel_init.S delete mode 100644 arch/arm/cpu/arm946es/config.mk delete mode 100644 arch/arm/cpu/sa1100/config.mk create mode 100644 arch/arm/include/asm/arch-lpc32xx/gpio.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/mux.h create mode 100644 board/work-microwave/work_92105/Kconfig create mode 100644 board/work-microwave/work_92105/MAINTAINERS create mode 100644 board/work-microwave/work_92105/Makefile create mode 100644 board/work-microwave/work_92105/README create mode 100644 board/work-microwave/work_92105/work_92105.c create mode 100644 board/work-microwave/work_92105/work_92105_display.c create mode 100644 board/work-microwave/work_92105/work_92105_display.h create mode 100644 board/work-microwave/work_92105/work_92105_spl.c create mode 100644 configs/work_92105_defconfig create mode 100644 drivers/gpio/lpc32xx_gpio.c create mode 100644 drivers/hwmon/ds620.c create mode 100644 drivers/i2c/lpc32xx_i2c.c create mode 100644 drivers/mtd/nand/lpc32xx_nand_mlc.c create mode 100644 drivers/net/lpc32xx_eth.c create mode 100644 drivers/spi/lpc32xx_ssp.c create mode 100644 include/configs/work_92105.h create mode 100644 tools/lpc32xximage.c
Amicalement,
On Fri, Apr 10, 2015 at 03:34:45PM +0200, Albert ARIBAUD wrote:
Hello,
Albert ARIBAUD
