[U-Boot] Boot ELF image using tftpboot
Hello,
I want to boot vxworks with uboot 1.3.4 using tftp.
After I got the prompt I wrote: tftpboot.
The vxworks ELF image was downloaded to the target but then I had to write bootelf.
Should tftpboot load and run the ELF image upon download completion ?
I also tried: tftp; bootelf. After download completion I got the prompt. bootelf was not executed.
Thanks.
The information contained in this communication is proprietary to Israel Aerospace Industries Ltd., ELTA Systems Ltd. and/or third parties, may contain classified or privileged information, and is intended only for the use of the intended addressee thereof. If you are not the intended addressee, please be aware that any use, disclosure, distribution and/or copying of this communication is strictly prohibited. If you receive this communication in error, please notify the sender immediately and delete it from your computer. Thank you.
This message is processed by the PrivaWall Email Security Server.
Dear Vered Zvi,
In message 0E3B1CAFCEB8484D8071762F8538E90317A5CA@ELTIMAIL.elta.co.il you wrote:
I want to boot vxworks with uboot 1.3.4 using tftp. After I got the prompt I wrote: tftpboot. The vxworks ELF image was downloaded to the target but then I had to write bootelf. Should tftpboot load and run the ELF image upon download completion ?
No, it should not.
Can you please shouw us the exact commands you typed, and the output you got?
Please make sure not to post proprietary information to public mailing lists. You could get serious problems with your bosses and/or IAI security authorities when they learn that you disclose proprietary information to the public.
Vered Zvi
