[U-Boot] uboot compilation problem
Hi, I am working As R&D engineer. Presently i am compiling u-boot.2011.03 and i am facing bit problem.following is the problem while compiling u-boot. i am using cross compile tool chain.
make -C arch/arm/cpu/arm926ejs/at91/ make[1]: Entering directory `/data1/UBOOT/u-boot-2011.03/arch/arm/cpu/arm926ejs/at91' make[1]: Warning: File `.depend' has modification time 1.7e+04 s in the future armv5l-analogics-linux-gnueabi-gcc -D__ASSEMBLY__ -g -Os -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x23f00000 -I/data1/UBOOT/u-boot-2011.03/include -fno-builtin -ffreestanding -nostdinc -isystem /opt/analogics/at91sam9261_ek/toolchain/bin/../lib/gcc/armv5l-analogics-linux-gnueabi/4.2.4/include -pipe -DCONFIG_ARM -D__ARM__ -marm -mabi=aapcs-linux -mno-thumb-interwork -march=armv5te -o lowlevel_init.o lowlevel_init.S -c armv5l-analogics-linux-gnueabi-gcc -g -Os -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x23f00000 -I/data1/UBOOT/u-boot-2011.03/include -fno-builtin -ffreestanding -nostdinc -isystem /opt/analogics/at91sam9261_ek/toolchain/bin/../lib/gcc/armv5l-analogics-linux-gnueabi/4.2.4/include -pipe -DCONFIG_ARM -D__ARM__ -marm -mabi=aapcs-linux -mno-thumb-interwork -march=armv5te -Wall -Wstrict-prototypes -fno-stack-protector -o clock.o clock.c -c clock.c: In function 'get_cpu_clk_rate': clock.c:30: error: 'gd_t' has no member named 'cpu_clk_rate_hz' clock.c: In function 'get_main_clk_rate': clock.c:35: error: 'gd_t' has no member named 'main_clk_rate_hz' clock.c: In function 'get_mck_clk_rate': clock.c:40: error: 'gd_t' has no member named 'mck_rate_hz' clock.c: In function 'get_plla_clk_rate': clock.c:45: error: 'gd_t' has no member named 'plla_rate_hz' clock.c: In function 'get_pllb_clk_rate': clock.c:50: error: 'gd_t' has no member named 'pllb_rate_hz' clock.c: In function 'get_pllb_init': clock.c:55: error: 'gd_t' has no member named 'at91_pllb_usb_init' clock.c: In function 'at91_css_to_rate': clock.c:64: error: 'gd_t' has no member named 'main_clk_rate_hz' clock.c:66: error: 'gd_t' has no member named 'plla_rate_hz' clock.c:68: error: 'gd_t' has no member named 'pllb_rate_hz' clock.c: In function 'at91_clock_init': clock.c:167: error: 'gd_t' has no member named 'main_clk_rate_hz' clock.c:170: error: 'gd_t' has no member named 'plla_rate_hz' clock.c:179: error: 'gd_t' has no member named 'at91_pllb_usb_init' clock.c:181: error: 'gd_t' has no member named 'pllb_rate_hz' clock.c:181: error: 'gd_t' has no member named 'at91_pllb_usb_init' clock.c:193: error: 'gd_t' has no member named 'mck_rate_hz' clock.c:194: error: 'gd_t' has no member named 'mck_rate_hz' clock.c:212: error: 'gd_t' has no member named 'mck_rate_hz' clock.c:214: error: 'gd_t' has no member named 'cpu_clk_rate_hz' make[1]: *** [clock.o] Error 1 make[1]: Leaving directory `/data1/UBOOT/u-boot-2011.03/arch/arm/cpu/arm926ejs/at91' make: *** [arch/arm/cpu/arm926ejs/at91/libat91.o] Error 2
Hi, I am working As R&D engineer. Presently i am compiling u-boot.2011.03 and i am facing bit problem.following is the problem while compiling u-boot. i am using cross compile tool chain. I am trying to compile for AT91SAM9260/61 controller.
Dear Rajeev Rao Battu:
The AT91SAM9260/61 support in u-boot-2011.03 is brocken. Try the current git tree
Best regards
Jens
Jens Scharsig
Rajeev Rao Battu
