[PATCH 0/2] U-Boot ENV in EXT4 support for Expressobin (revised)
Hi
Per comments of Stefan I have split the patch in two: - one for env file changes - one for espressobin related changes
Let me know if any other changes are needed.
Regards
Rogier
Rogier Stam (2): Fix Espressobin build for configs where ENV is not in SPI Add SCSI scan for ENV in EXT4 or FAT
arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi | 2 ++ board/Marvell/mvebu_armada-37xx/board.c | 4 +++- env/ext4.c | 5 +++++ env/fat.c | 5 +++++ 4 files changed, 15 insertions(+), 1 deletion(-)
When storing the UBoot Environment in for example EXT4, the U-Boot build is broken for several reasons: 1. armada-385-turris-omnia-u-boot.dtsi will not allow CONFIG_ENV_OFFSET and CONFIG_ENV_SIZE to be undefined 2. armada-37xx/board.c ft_board_setup function does not exist if CONFIG_ENV_IS_IN_SPI_FLASH is not defined
This commit changes these files so that selecting a different location for the environment is possible.
Signed-off-by: Rogier Stam rogier@unrailed.org --- arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi | 2 ++ board/Marvell/mvebu_armada-37xx/board.c | 4 +++- 2 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi b/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi index 3ff76c9..008787e 100644 --- a/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi +++ b/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi @@ -38,6 +38,7 @@ }; };
+#ifdef CONFIG_ENV_IS_IN_SPI_FLASH &spi0 { u-boot,dm-pre-reloc;
@@ -56,6 +57,7 @@ }; }; }; +#endif
&uart0 { u-boot,dm-pre-reloc; diff --git a/board/Marvell/mvebu_armada-37xx/board.c b/board/Marvell/mvebu_armada-37xx/board.c index d7b6eca..5bace0c 100644 --- a/board/Marvell/mvebu_armada-37xx/board.c +++ b/board/Marvell/mvebu_armada-37xx/board.c @@ -328,9 +328,10 @@ int board_network_enable(struct mii_dev *bus) return 0; }
-#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_ENV_IS_IN_SPI_FLASH) +#ifdef CONFIG_OF_BOARD_SETUP int ft_board_setup(void *blob, struct bd_info *bd) { +#ifdef CONFIG_ENV_IS_IN_SPI_FLASH int ret; int spi_off; int parts_off; @@ -424,6 +425,7 @@ int ft_board_setup(void *blob, struct bd_info *bd) return 0; }
+#endif return 0; } #endif
+ Marek, Stefan
- armada-385-turris-omnia-u-boot.dtsi will not allow CONFIG_ENV_OFFSET and CONFIG_ENV_SIZE to be undefined
- armada-37xx/board.c ft_board_setup function does not exist if CONFIG_ENV_IS_IN_SPI_FLASH is not defined
Reviewed-by: Pali Rohár pali@kernel.org
+#endif return 0; }
#endif
2.7.4
On 2/28/22 08:10, Pali Rohár wrote:
- Marek, Stefan
Applied to u-boot-marvell/master
Thanks, Stefan
+#endif return 0; }
#endif
2.7.4
Viele Grüße, Stefan Roese
When having environment stored in EXT4 or FAT and using an AHCI or SCSI device / partition the scan would not be performed early enough and hence the device would not be recognized. This change adds the scan when the interface is "scsi" in a similar way to mmc_initialize.
Signed-off-by: Rogier Stam rogier@unrailed.org --- env/ext4.c | 5 +++++ env/fat.c | 5 +++++ 2 files changed, 10 insertions(+)
diff --git a/env/ext4.c b/env/ext4.c index 9f65afb..47e05a4 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -31,6 +31,7 @@ #include <errno.h> #include <ext4fs.h> #include <mmc.h> +#include <scsi.h> #include <asm/global_data.h>
DECLARE_GLOBAL_DATA_PTR; @@ -146,6 +147,10 @@ static int env_ext4_load(void) if (!strcmp(ifname, "mmc")) mmc_initialize(NULL); #endif +#if defined(CONFIG_AHCI) || defined(CONFIG_SCSI) + if (!strcmp(ifname, "scsi")) + scsi_scan(true); +#endif
part = blk_get_device_part_str(ifname, dev_and_part, &dev_desc, &info, 1); diff --git a/env/fat.c b/env/fat.c index fdccd6c..dbd6a13 100644 --- a/env/fat.c +++ b/env/fat.c @@ -17,6 +17,7 @@ #include <errno.h> #include <fat.h> #include <mmc.h> +#include <scsi.h> #include <asm/cache.h> #include <asm/global_data.h> #include <linux/stddef.h> @@ -122,6 +123,10 @@ static int env_fat_load(void) if (!strcmp(CONFIG_ENV_FAT_INTERFACE, "mmc")) mmc_initialize(NULL); #endif +#if defined(CONFIG_AHCI) || defined(CONFIG_SCSI) + if (!strcmp(CONFIG_ENV_FAT_INTERFACE, "scsi")) + scsi_scan(true); +#endif
part = blk_get_device_part_str(CONFIG_ENV_FAT_INTERFACE, env_fat_device_and_part(),
+ Simon, could you review this change? It would be nice to have this fix in upcoming U-Boot release.
- if (!strcmp(ifname, "scsi"))
scsi_scan(true);
- if (!strcmp(CONFIG_ENV_FAT_INTERFACE, "scsi"))
scsi_scan(true);
part = blk_get_device_part_str(CONFIG_ENV_FAT_INTERFACE, env_fat_device_and_part(), -- 2.7.4
Hi Rogier,
On 2/28/22 08:13, Pali Rohár wrote:
- Simon, could you review this change? It would be nice to have this fix in upcoming U-Boot release.
While running some CI tests, this error occurs with this patch:
$ make dra7xx_hs_evm_usb_defconfig ... $ make -s -j20 ... /opt/kernel.org/gcc-11.1.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-ld.bfd: env/fat.o: in function `env_fat_load': /home/stefan/git/u-boot/u-boot-marvell/env/fat.c:134: undefined reference to `scsi_scan' make[1]: *** [scripts/Makefile.spl:512: spl/u-boot-spl] Error 1 make: *** [Makefile:2101: spl/u-boot-spl] Error 2
Could you please take a look? And send a fixed version which also passed a "world build" for all supported targets?
Thanks, Stefan
scsi_scan(true);
scsi_scan(true);
On Thursday 21 April 2022 12:34:30 Stefan Roese wrote:
Hi Rogier,
This is failing while building SPL...
Thanks, Stefan
diff --git a/env/ext4.c b/env/ext4.c index 9f65afb..47e05a4 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -31,6 +31,7 @@ #include <errno.h> #include <ext4fs.h> #include <mmc.h> +#include <scsi.h> #include <asm/global_data.h> DECLARE_GLOBAL_DATA_PTR; @@ -146,6 +147,10 @@ static int env_ext4_load(void) if (!strcmp(ifname, "mmc")) mmc_initialize(NULL); #endif +#if defined(CONFIG_AHCI) || defined(CONFIG_SCSI)
scsi_scan(true);
+#endif part = blk_get_device_part_str(ifname, dev_and_part, &dev_desc, &info, 1); diff --git a/env/fat.c b/env/fat.c index fdccd6c..dbd6a13 100644 --- a/env/fat.c +++ b/env/fat.c @@ -17,6 +17,7 @@ #include <errno.h> #include <fat.h> #include <mmc.h> +#include <scsi.h> #include <asm/cache.h> #include <asm/global_data.h> #include <linux/stddef.h> @@ -122,6 +123,10 @@ static int env_fat_load(void) if (!strcmp(CONFIG_ENV_FAT_INTERFACE, "mmc")) mmc_initialize(NULL); #endif +#if defined(CONFIG_AHCI) || defined(CONFIG_SCSI)
... I guess that you should use CONFIG_IS_ENABLED(AHCI) instead of defined(CONFIG_AHCI) for proper SPL support.
scsi_scan(true);
+#endif part = blk_get_device_part_str(CONFIG_ENV_FAT_INTERFACE, env_fat_device_and_part(), -- 2.7.4
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-51 Fax: (+49)-8142-66989-80 Email: sr@denx.de
Sorry for the late reply. Not much time lately, also had some trouble figuring the world build out. That said I have a fix. Not sure on the usual process, but I will repost it on the mailing list in a moment. Pali was quite close on the solution. I went a slightly different route as I did not want to deviate from style in fat.c, also from reading the recommended CONFIG_IS_ENABLED macro I got the impression you'd have to define separate vars for TPL and SPL which would deviate from normal usage for storing env in fat.
Effectively it amounts to:
+#ifndef CONFIG_SPL_BUILD +#if defined(CONFIG_AHCI) || defined(CONFIG_SCSI) + if (!strcmp(CONFIG_ENV_FAT_INTERFACE, "scsi")) + scsi_scan(true); +#endif +#endif
Anyway, let me know if you disagree.
Thanks and regards
Rogier
Hi Rogier,
Thanks, Stefan
scsi_scan(true);
scsi_scan(true);
Pali Rohár
Rogier Stam
Stefan Roese
