[U-Boot] [PATCH 1/2] Make mpc8572ds, mpc8544ds, mpc8536ds relocatable
Fixes boot crash from bad string pointers in get_table_entry_name when flash is erased or differs from current u-boot image.
Remove .fixup from .text section since __fixup_entries is only calculated from .reloc section.
Signed-off-by: Ed Swarthout Ed.Swarthout@freescale.com ---
tested with freescale-powerpc-linux-gnu-4.2-171.i686.rpm
Patch #2 is needed only if x86 emulation is used for video bios.
Compiling the x86 bios emulator with -mrelocatable removes the need to force the function pointer tables into got2. see patch #2
board/freescale/mpc8536ds/config.mk | 1 + board/freescale/mpc8536ds/u-boot.lds | 1 - board/freescale/mpc8544ds/config.mk | 1 + board/freescale/mpc8544ds/u-boot.lds | 1 - board/freescale/mpc8572ds/config.mk | 1 + board/freescale/mpc8572ds/u-boot.lds | 1 - 6 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/board/freescale/mpc8536ds/config.mk b/board/freescale/mpc8536ds/config.mk index 9775ff4..b293583 100644 --- a/board/freescale/mpc8536ds/config.mk +++ b/board/freescale/mpc8536ds/config.mk @@ -30,3 +30,4 @@ endif PLATFORM_CPPFLAGS += -DCONFIG_E500=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC85xx=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC8536=1 +PLATFORM_CPPFLAGS += -mrelocatable -DCONFIG_RELOC_FIXUP_WORKS diff --git a/board/freescale/mpc8536ds/u-boot.lds b/board/freescale/mpc8536ds/u-boot.lds index 901f633..54f9fbc 100644 --- a/board/freescale/mpc8536ds/u-boot.lds +++ b/board/freescale/mpc8536ds/u-boot.lds @@ -58,7 +58,6 @@ SECTIONS .text : { *(.text) - *(.fixup) *(.got1) } :text _etext = .; diff --git a/board/freescale/mpc8544ds/config.mk b/board/freescale/mpc8544ds/config.mk index 85663ef..b5071f2 100644 --- a/board/freescale/mpc8544ds/config.mk +++ b/board/freescale/mpc8544ds/config.mk @@ -30,3 +30,4 @@ endif PLATFORM_CPPFLAGS += -DCONFIG_E500=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC85xx=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC8544=1 +PLATFORM_CPPFLAGS += -mrelocatable -DCONFIG_RELOC_FIXUP_WORKS diff --git a/board/freescale/mpc8544ds/u-boot.lds b/board/freescale/mpc8544ds/u-boot.lds index a05ece5..6477c69 100644 --- a/board/freescale/mpc8544ds/u-boot.lds +++ b/board/freescale/mpc8544ds/u-boot.lds @@ -58,7 +58,6 @@ SECTIONS .text : { *(.text) - *(.fixup) *(.got1) } :text _etext = .; diff --git a/board/freescale/mpc8572ds/config.mk b/board/freescale/mpc8572ds/config.mk index 5b32186..8b3651b 100644 --- a/board/freescale/mpc8572ds/config.mk +++ b/board/freescale/mpc8572ds/config.mk @@ -30,3 +30,4 @@ endif PLATFORM_CPPFLAGS += -DCONFIG_E500=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC85xx=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC8572=1 +PLATFORM_CPPFLAGS += -mrelocatable -DCONFIG_RELOC_FIXUP_WORKS diff --git a/board/freescale/mpc8572ds/u-boot.lds b/board/freescale/mpc8572ds/u-boot.lds index a05ece5..6477c69 100644 --- a/board/freescale/mpc8572ds/u-boot.lds +++ b/board/freescale/mpc8572ds/u-boot.lds @@ -58,7 +58,6 @@ SECTIONS .text : { *(.text) - *(.fixup) *(.got1) } :text _etext = .;
Forcing the tables into got2 caused extra relocation when using -mrelocatable. This patch requires any board defining CONFIG_BIOSEMU to use -mrelocatable.
The only boards which define CONFIG_BIOSEMU are: MPC8536DS, MPC8572DS, MPC8544DS, HPC8641HPCN, and sequoia. I've tested this patch on the 8572 and 8544 boards.
drivers/bios_emulator/x86emu/ops.c | 17 +++++++---------- drivers/bios_emulator/x86emu/ops2.c | 5 +---- 2 files changed, 8 insertions(+), 14 deletions(-)
diff --git a/drivers/bios_emulator/x86emu/ops.c b/drivers/bios_emulator/x86emu/ops.c index 10f2757..b0ad1fa 100644 --- a/drivers/bios_emulator/x86emu/ops.c +++ b/drivers/bios_emulator/x86emu/ops.c @@ -70,9 +70,6 @@ * calls is especially important; otherwise mistakes in coding an * "add" would represent a nightmare in maintenance. * -* Jason ported this file to u-boot. place all the function pointer in -* the got2 sector. Removed some opcode. -* ****************************************************************************/
#include <common.h> @@ -91,7 +88,7 @@ static char *x86emu_GenOpName[8] = { #endif
/* used by several opcodes */ -static u8 (*genop_byte_operation[])(u8 d, u8 s) __attribute__ ((section(GOT2_TYPE))) = +static u8 (*genop_byte_operation[])(u8 d, u8 s) = { add_byte, /* 00 */ or_byte, /* 01 */ @@ -103,7 +100,7 @@ static u8 (*genop_byte_operation[])(u8 d, u8 s) __attribute__ ((section(GOT2_TYP cmp_byte, /* 07 */ };
-static u16 (*genop_word_operation[])(u16 d, u16 s) __attribute__ ((section(GOT2_TYPE))) = +static u16 (*genop_word_operation[])(u16 d, u16 s) = { add_word, /*00 */ or_word, /*01 */ @@ -115,7 +112,7 @@ static u16 (*genop_word_operation[])(u16 d, u16 s) __attribute__ ((section(GOT2_ cmp_word, /*07 */ };
-static u32 (*genop_long_operation[])(u32 d, u32 s) __attribute__ ((section(GOT2_TYPE))) = +static u32 (*genop_long_operation[])(u32 d, u32 s) = { add_long, /*00 */ or_long, /*01 */ @@ -128,7 +125,7 @@ static u32 (*genop_long_operation[])(u32 d, u32 s) __attribute__ ((section(GOT2_ };
/* used by opcodes 80, c0, d0, and d2. */ -static u8(*opcD0_byte_operation[])(u8 d, u8 s) __attribute__ ((section(GOT2_TYPE))) = +static u8(*opcD0_byte_operation[])(u8 d, u8 s) = { rol_byte, ror_byte, @@ -141,7 +138,7 @@ static u8(*opcD0_byte_operation[])(u8 d, u8 s) __attribute__ ((section(GOT2_TYPE };
/* used by opcodes c1, d1, and d3. */ -static u16(*opcD1_word_operation[])(u16 s, u8 d) __attribute__ ((section(GOT2_TYPE))) = +static u16(*opcD1_word_operation[])(u16 s, u8 d) = { rol_word, ror_word, @@ -154,7 +151,7 @@ static u16(*opcD1_word_operation[])(u16 s, u8 d) __attribute__ ((section(GOT2_TY };
/* used by opcodes c1, d1, and d3. */ -static u32 (*opcD1_long_operation[])(u32 s, u8 d) __attribute__ ((section(GOT2_TYPE))) = +static u32 (*opcD1_long_operation[])(u32 s, u8 d) = { rol_long, ror_long, @@ -5147,7 +5144,7 @@ void x86emuOp_opcFF_word_RM(u8 X86EMU_UNUSED(op1)) /*************************************************************************** * Single byte operation code table: **************************************************************************/ -void (*x86emu_optab[256])(u8) __attribute__ ((section(GOT2_TYPE))) = +void (*x86emu_optab[256])(u8) = { /* 0x00 */ x86emuOp_genop_byte_RM_R, /* 0x01 */ x86emuOp_genop_word_RM_R, diff --git a/drivers/bios_emulator/x86emu/ops2.c b/drivers/bios_emulator/x86emu/ops2.c index d90d366..99d1eae 100644 --- a/drivers/bios_emulator/x86emu/ops2.c +++ b/drivers/bios_emulator/x86emu/ops2.c @@ -39,9 +39,6 @@ * and emulation of all the x86 extended two-byte processor * instructions. * -* Jason port this file to u-boot. Put the function pointer into -* got2 sector. -* ****************************************************************************/
#include <common.h> @@ -1498,7 +1495,7 @@ void x86emuOp2_movsx_word_R_RM(u8 X86EMU_UNUSED(op2)) /*************************************************************************** * Double byte operation code table: **************************************************************************/ -void (*x86emu_optab2[256])(u8) __attribute__((section(GOT2_TYPE))) = +void (*x86emu_optab2[256])(u8) = { /* 0x00 */ x86emuOp2_illegal_op, /* Group F (ring 0 PM) */ /* 0x01 */ x86emuOp2_illegal_op, /* Group G (ring 0 PM) */
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Swarthout Edward L-SWARTHOU Sent: Thursday, October 09, 2008 2:27 PM To: u-boot@lists.denx.de Cc: Swarthout Edward L-SWARTHOU Subject: [U-Boot] [PATCH 2/2] Leave x86emu op code tables in default section
Ack, Tested on 8536DS board.
Jason
Ed Swarthout
Jin Zhengxiong-R64188
