[U-Boot] AVR32 AP700x - I2C somewhere?
has anyone started or completed work on an I2C driver for AP7000x?
If not, I am at least going to make SOFT I2C defines to read VPD from an At24C64 EEPROM.
Thanks, Reinhard
Am 01.06.2010 16:04, schrieb Reinhard Meyer (-VC):
Dear Reinhard Meyer,
No ...
But I've working soft-i2c here. There are still some other examples in u-boot how to interface a at24xx eeprom.
custom board config file: ---8<--- /* i2c definitions */ #define CONFIG_SOFT_I2C #if defined(CONFIG_SOFT_I2C) #define DEBUG_I2C #ifndef __ASSEMBLY__ #include <asm/arch/portmux.h> #define MEDUCORE_SDA_PIN 6 #define MEDUCORE_SCL_PIN 7
#define I2C_ACTIVE portmux_select_gpio(PORTMUX_PORT_A, (1<<MEDUCORE_SDA_PIN), PORTMUX_DIR_OUTPUT|PORTMUX_INIT_LOW) #define I2C_TRISTATE portmux_select_gpio(PORTMUX_PORT_A, (1<<MEDUCORE_SDA_PIN), PORTMUX_DIR_INPUT|PORTMUX_OPEN_DRAIN) #define I2C_READ pio_get_input_value(GPIO_PIN_PA(MEDUCORE_SDA_PIN)) #define I2C_SDA(bit) pio_set_output_value(GPIO_PIN_PA(MEDUCORE_SDA_PIN), bit) #define I2C_SCL(bit) pio_set_output_value(GPIO_PIN_PA(MEDUCORE_SCL_PIN), bit) #endif
#define I2C_DELAY udelay(3) /* TODO needs testing */ #define I2C_SOFT_DECLARATIONS
#define CONFIG_SYS_I2C_SLAVE 0x0 #define CONFIG_SYS_I2C_SPEED 100000 /* TODO needs testing */ #define CONFIG_CMD_I2C
#endif --->8---
and in our custom board implementation (only snippet): ---8<--- @@ -29,6 +29,8 @@ #include <asm/arch/hmatrix.h> #include <asm/arch/portmux.h>
+#include <i2c.h> + DECLARE_GLOBAL_DATA_PTR;
/* @@ -71,6 +73,38 @@ static const struct sdram_config sdram_config = {
int board_early_init_f(void) { + unsigned char val = 0xFF; + unsigned char version = 0x00; + int ret = -1; // assume error + + // first select SCL gpio + portmux_select_gpio(PORTMUX_PORT_A, (1<<MEDUCORE_SCL_PIN), PORTMUX_DIR_OUTPUT|PORTMUX_INIT_LOW); + // initialize i2c + i2c_init(1000, 0x27); + // check for precedence of port multiplexer + ret = i2c_probe(0x27); + if ( ret != 0 ) { + gd->flags |= GD_FLG_POSTFAIL; + goto out; + } + + ret |= i2c_write(0x27, 0x06, 1, &val, 1); // set GPPU to FF + ret |= i2c_write(0x27, 0x01, 1, &val, 1); // set IPOL to FF (invert palaritiy) + if ( ret != 0 ) { + gd->flags |= GD_FLG_POSTFAIL; + goto out; + } + + ret = i2c_read(0x27, 0x09, 1, &version, 1); // read in the version value + if ( ret != 0 ) { + gd->flags |= GD_FLG_POSTFAIL; + goto out; + } + // version can be used from here
--->8---
regards
Andreas Bießmann
No ...
Thank you. That worked to verify my setup. I was fooled by the AtTiny on the NGW100 which does try to slow I2C Transfers by pulling SCL low. That feature however is NOT honored by the SOFT_I2C driver. So accesses to my At24C64 had to fail. After removing the AtTiny it works fine :)
The functions ACTIVE and TRISTATE are not required when the Pins are initialized OUTPUT and OPENDRAIN as follows:
int board_early_init_f(void) { ... #ifdef CONFIG_CMD_I2C // first select SCL and SDA gpio portmux_select_gpio(PORTMUX_PORT_A,(1<<SDA_PIN), PORTMUX_DIR_OUTPUT|PORTMUX_INIT_LOW|PORTMUX_OPEN_DRAIN); portmux_select_gpio(PORTMUX_PORT_A,(1<<SCL_PIN), PORTMUX_DIR_OUTPUT|PORTMUX_INIT_LOW|PORTMUX_OPEN_DRAIN); // initialize i2c i2c_init(1000, 0x27); #endif return 0; }
The I2C Bus by definition is a wired-or bus, all devices must have open drain outputs for SDA and SCL!
Best Regards, Reinhard
Andreas Bießmann
