[U-Boot] [PATCH v3 00/22] mx6sabre: Add DM and SPL FIT support
The second version is here: https://lists.denx.de/pipermail/u-boot/2019-January/356557.html
Changes since v2: * Removed the unecessary SYS_MALLOC_F_LEN from both defocnfig * Fixed the copyright for all the *u-boot.dtsi files
Abel Vesa (22): usb: Rename SPL_USB_SUPPORT to SPL_USB_STORAGE usb: ehci-mx6: Make regulator DM_REGULATOR dependent configs: imx6sabreauto: Add DM_MMC support configs: imx6sabreauto: Add DM_USB support mmc: fsl_esdhc: Fix DM_REGULATOR ifdefs for SPL builds board: mx6sabresd: Add board_fit_config_name_match to support FIT in SPL board: mx6sabreauto: Add board_fit_config_name_match to support FIT in SPL arm: dts: Add all the imx6[q|qp|dl] sabre[auto|sd] u-boot dts[i] files arm: dts: Update all the dts[i] files for imx6[q|qp|dl] sabre[auto|sd] arm: imx: Add FIT SPL its configs: mx6sabreauto: Add SPL FIT and DM support configs: mx6sabresd: Add SPL FIT and DM support mx6sabreauto: Add DM_GPIO support mx6sabresd: Add DM_GPIO support configs: mx6sabreauto: Add DM_SPI_FLASH necessary configs configs: mx6sabresd: Add DM_SPI_FLASH necessary configs board: mx6sabreauto: Remove the non-DM code board: mx6sabresd: Remove non-DM code board: mx6sabresd: Remove the enet reset gpio handling configs: mx6sabresd: Reduce size for SPL by disabling SPL_DOS and SPL_EFI board: mx6sabreauto: Update README with the SPL DM FIT info board: mx6sabresd: Update README with the SPL DM FIT info
arch/arm/dts/Makefile | 8 +- arch/arm/dts/imx6dl-sabreauto-u-boot.dtsi | 6 + arch/arm/dts/imx6dl-sabreauto.dts | 13 + arch/arm/dts/imx6dl-sabresd-u-boot.dtsi | 6 + arch/arm/dts/imx6dl-sabresd.dts | 18 + arch/arm/dts/imx6dl.dtsi | 306 ++++++++++- arch/arm/dts/imx6q-sabreauto-u-boot.dtsi | 6 + arch/arm/dts/imx6q-sabreauto.dts | 18 + arch/arm/dts/imx6q-sabresd-u-boot.dtsi | 6 + arch/arm/dts/imx6q-sabresd.dts | 23 + arch/arm/dts/imx6q.dtsi | 310 +++++++++-- arch/arm/dts/imx6qdl-sabreauto-u-boot.dtsi | 21 + arch/arm/dts/imx6qdl-sabreauto.dtsi | 810 ++++++++++++++++++++++++++++ arch/arm/dts/imx6qdl-sabresd-u-boot.dtsi | 14 + arch/arm/dts/imx6qdl-sabresd.dtsi | 741 +++++++++++++++++++++++++ arch/arm/dts/imx6qdl-u-boot.dtsi | 4 +- arch/arm/dts/imx6qdl.dtsi | 455 +++++++++------- arch/arm/dts/imx6qp-sabreauto-u-boot.dtsi | 6 + arch/arm/dts/imx6qp-sabreauto.dts | 55 ++ arch/arm/dts/imx6qp-sabresd-u-boot.dtsi | 6 + arch/arm/dts/imx6qp-sabresd.dts | 55 ++ arch/arm/dts/imx6qp.dtsi | 115 ++++ arch/arm/include/asm/arch-am33xx/spl.h | 2 +- arch/arm/mach-imx/mx6/fit_spl.its | 41 ++ arch/arm/mach-omap2/boot-common.c | 2 +- board/freescale/mx6sabreauto/README | 6 +- board/freescale/mx6sabreauto/mx6sabreauto.c | 91 +--- board/freescale/mx6sabresd/README | 9 +- board/freescale/mx6sabresd/mx6sabresd.c | 78 +-- common/Makefile | 5 +- common/spl/Kconfig | 4 +- common/spl/Makefile | 2 +- common/spl/spl_usb.c | 4 - configs/am43xx_evm_usbhost_boot_defconfig | 2 +- configs/am43xx_hs_evm_defconfig | 2 +- configs/mx6sabreauto_defconfig | 21 +- configs/mx6sabresd_defconfig | 26 +- drivers/mmc/fsl_esdhc.c | 8 +- drivers/usb/host/ehci-mx6.c | 7 +- 39 files changed, 2900 insertions(+), 412 deletions(-) create mode 100644 arch/arm/dts/imx6dl-sabreauto-u-boot.dtsi create mode 100644 arch/arm/dts/imx6dl-sabreauto.dts create mode 100644 arch/arm/dts/imx6dl-sabresd-u-boot.dtsi create mode 100644 arch/arm/dts/imx6dl-sabresd.dts create mode 100644 arch/arm/dts/imx6q-sabreauto-u-boot.dtsi create mode 100644 arch/arm/dts/imx6q-sabreauto.dts create mode 100644 arch/arm/dts/imx6q-sabresd-u-boot.dtsi create mode 100644 arch/arm/dts/imx6q-sabresd.dts create mode 100644 arch/arm/dts/imx6qdl-sabreauto-u-boot.dtsi create mode 100644 arch/arm/dts/imx6qdl-sabreauto.dtsi create mode 100644 arch/arm/dts/imx6qdl-sabresd-u-boot.dtsi create mode 100644 arch/arm/dts/imx6qdl-sabresd.dtsi create mode 100644 arch/arm/dts/imx6qp-sabreauto-u-boot.dtsi create mode 100644 arch/arm/dts/imx6qp-sabreauto.dts create mode 100644 arch/arm/dts/imx6qp-sabresd-u-boot.dtsi create mode 100644 arch/arm/dts/imx6qp-sabresd.dts create mode 100644 arch/arm/dts/imx6qp.dtsi create mode 100644 arch/arm/mach-imx/mx6/fit_spl.its
Since there is the SPL_USB_HOST_SUPPORT for enabling USB support in SPL, makes more sense to rename the SPL_USB_SUPPORT as SPL_USB_STORAGE. Everything that is not part of the usb storage support in SPL is now build under SPL_USB_HOST_SUPPORT.
Signed-off-by: Abel Vesa abel.vesa@nxp.com Reviewed-by: Tom Rini trini@konsulko.com --- arch/arm/include/asm/arch-am33xx/spl.h | 2 +- arch/arm/mach-omap2/boot-common.c | 2 +- common/Makefile | 5 +++-- common/spl/Kconfig | 4 ++-- common/spl/Makefile | 2 +- common/spl/spl_usb.c | 4 ---- configs/am43xx_evm_usbhost_boot_defconfig | 2 +- configs/am43xx_hs_evm_defconfig | 2 +- 8 files changed, 10 insertions(+), 13 deletions(-)
diff --git a/arch/arm/include/asm/arch-am33xx/spl.h b/arch/arm/include/asm/arch-am33xx/spl.h index 0bf8c17..f3910c2 100644 --- a/arch/arm/include/asm/arch-am33xx/spl.h +++ b/arch/arm/include/asm/arch-am33xx/spl.h @@ -62,7 +62,7 @@ #define BOOT_DEVICE_CPGMAC 0x47
#define MMC_BOOT_DEVICES_START BOOT_DEVICE_MMC1 -#ifdef CONFIG_SPL_USB_SUPPORT +#ifdef CONFIG_SPL_USB_STORAGE #define MMC_BOOT_DEVICES_END BOOT_DEVICE_USB #else #define MMC_BOOT_DEVICES_END BOOT_DEVICE_MMC2 diff --git a/arch/arm/mach-omap2/boot-common.c b/arch/arm/mach-omap2/boot-common.c index 2db1922..c8b8ac6 100644 --- a/arch/arm/mach-omap2/boot-common.c +++ b/arch/arm/mach-omap2/boot-common.c @@ -93,7 +93,7 @@ void save_omap_boot_params(void) sys_boot_device = 1; break; #endif -#if defined(BOOT_DEVICE_USB) && !defined(CONFIG_SPL_USB_SUPPORT) +#if defined(BOOT_DEVICE_USB) && !defined(CONFIG_SPL_USB_STORAGE) case BOOT_DEVICE_USB: sys_boot_device = 1; break; diff --git a/common/Makefile b/common/Makefile index ad390d0..8c92feb 100644 --- a/common/Makefile +++ b/common/Makefile @@ -75,8 +75,9 @@ obj-$(CONFIG_SPL_NET_SUPPORT) += miiphyutil.o obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += fdt_support.o
ifdef CONFIG_SPL_USB_HOST_SUPPORT -obj-$(CONFIG_SPL_USB_SUPPORT) += usb.o usb_hub.o -obj-$(CONFIG_USB_STORAGE) += usb_storage.o +obj-y += usb.o +obj-y += usb_hub.o +obj-$(CONFIG_SPL_USB_STORAGE) += usb_storage.o else obj-$(CONFIG_USB_MUSB_HOST) += usb.o endif diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 54b0dc3..8b0627e 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -766,9 +766,9 @@ config SPL_USB_HOST_SUPPORT device can be attached. This option enables the drivers in drivers/usb/host as part of an SPL build.
-config SPL_USB_SUPPORT +config SPL_USB_STORAGE bool "Support loading from USB" - depends on SPL_USB_HOST_SUPPORT + depends on SPL_USB_HOST_SUPPORT && !(BLK && !DM_USB) help Enable support for USB devices in SPL. This allows use of USB devices such as hard drives and flash drivers for loading U-Boot. diff --git a/common/spl/Makefile b/common/spl/Makefile index 6f8d759..a3980ce 100644 --- a/common/spl/Makefile +++ b/common/spl/Makefile @@ -22,7 +22,7 @@ obj-$(CONFIG_$(SPL_TPL_)NET_SUPPORT) += spl_net.o obj-$(CONFIG_$(SPL_TPL_)MMC_SUPPORT) += spl_mmc.o obj-$(CONFIG_$(SPL_TPL_)ATF) += spl_atf.o obj-$(CONFIG_$(SPL_TPL_)OPTEE) += spl_optee.o -obj-$(CONFIG_$(SPL_TPL_)USB_SUPPORT) += spl_usb.o +obj-$(CONFIG_$(SPL_TPL_)USB_STORAGE) += spl_usb.o obj-$(CONFIG_$(SPL_TPL_)FAT_SUPPORT) += spl_fat.o obj-$(CONFIG_$(SPL_TPL_)EXT_SUPPORT) += spl_ext.o obj-$(CONFIG_$(SPL_TPL_)SATA_SUPPORT) += spl_sata.o diff --git a/common/spl/spl_usb.c b/common/spl/spl_usb.c index c8d8231..e29d579 100644 --- a/common/spl/spl_usb.c +++ b/common/spl/spl_usb.c @@ -15,9 +15,7 @@ #include <usb.h> #include <fat.h>
-#ifdef CONFIG_USB_STORAGE static int usb_stor_curr_dev = -1; /* current device */ -#endif
static int spl_usb_load_image(struct spl_image_info *spl_image, struct spl_boot_device *bootdev) @@ -34,13 +32,11 @@ static int spl_usb_load_image(struct spl_image_info *spl_image, return err; }
-#ifdef CONFIG_USB_STORAGE /* try to recognize storage devices immediately */ usb_stor_curr_dev = usb_stor_scan(1); stor_dev = blk_get_devnum_by_type(IF_TYPE_USB, usb_stor_curr_dev); if (!stor_dev) return -ENODEV; -#endif
debug("boot mode - FAT\n");
diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 5131f19..5bd919b 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -14,7 +14,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_USB_HOST_SUPPORT=y -CONFIG_SPL_USB_SUPPORT=y +CONFIG_SPL_USB_STORAGE=y CONFIG_CMD_SPL=y CONFIG_CMD_SPL_NAND_OFS=0x00100000 CONFIG_CMD_SPL_WRITE_SIZE=0x40000 diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index 99e4ccb..c01fda9 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -24,7 +24,7 @@ CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NET_SUPPORT=y CONFIG_SPL_NET_VCI_STRING="AM43xx U-Boot SPL" CONFIG_SPL_USB_HOST_SUPPORT=y -CONFIG_SPL_USB_SUPPORT=y +CONFIG_SPL_USB_STORAGE=y CONFIG_SPL_USB_GADGET=y CONFIG_SPL_USB_ETHER=y # CONFIG_CMD_FLASH is not set
Do the regulator related work only if the build has the DM_REGULATOR.
Signed-off-by: Abel Vesa abel.vesa@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com --- drivers/usb/host/ehci-mx6.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index 1acf08d..9483947 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -404,6 +404,7 @@ static int mx6_init_after_reset(struct ehci_ctrl *dev) if (ret) return ret;
+#if CONFIG_IS_ENABLED(DM_REGULATOR) if (priv->vbus_supply) { ret = regulator_set_enable(priv->vbus_supply, (type == USB_INIT_DEVICE) ? @@ -413,6 +414,7 @@ static int mx6_init_after_reset(struct ehci_ctrl *dev) return ret; } } +#endif
if (type == USB_INIT_DEVICE) return 0; @@ -514,15 +516,17 @@ static int ehci_usb_probe(struct udevice *dev) priv->portnr = dev->seq; priv->init_type = type;
+#if CONFIG_IS_ENABLED(DM_REGULATOR) ret = device_get_supply_regulator(dev, "vbus-supply", &priv->vbus_supply); if (ret) debug("%s: No vbus supply\n", dev->name); - +#endif ret = ehci_mx6_common_init(ehci, priv->portnr); if (ret) return ret;
+#if CONFIG_IS_ENABLED(DM_REGULATOR) if (priv->vbus_supply) { ret = regulator_set_enable(priv->vbus_supply, (type == USB_INIT_DEVICE) ? @@ -532,6 +536,7 @@ static int ehci_usb_probe(struct udevice *dev) return ret; } } +#endif
if (priv->init_type == USB_INIT_HOST) { setbits_le32(&ehci->usbmode, CM_HOST);
Add DM_MMC config to imx6sabreauto defconfig.
Signed-off-by: Abel Vesa abel.vesa@nxp.com --- configs/mx6sabreauto_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index 40386c2..a3d63a2 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -44,6 +44,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DFU_MMC=y CONFIG_DFU_SF=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y
Add the DM support for USB. For that, DM_REGULATOR is needed.
Signed-off-by: Abel Vesa abel.vesa@nxp.com --- configs/mx6sabreauto_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index a3d63a2..4bdcbb1 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -52,9 +52,11 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_MII=y +CONFIG_DM_REGULATOR=y CONFIG_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="FSL"
Since the fsl_esdhc will also be used by SPL, make the preprocessor switches more generic to allow any kind of build.
Signed-off-by: Abel Vesa abel.vesa@nxp.com --- drivers/mmc/fsl_esdhc.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index b8171ba..47f2a8f 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -804,7 +804,7 @@ static int esdhc_set_voltage(struct mmc *mmc) case MMC_SIGNAL_VOLTAGE_330: if (priv->vs18_enable) return -EIO; -#ifdef CONFIG_DM_REGULATOR +#if CONFIG_IS_ENABLED(DM_REGULATOR) if (!IS_ERR_OR_NULL(priv->vqmmc_dev)) { ret = regulator_set_value(priv->vqmmc_dev, 3300000); if (ret) { @@ -823,7 +823,7 @@ static int esdhc_set_voltage(struct mmc *mmc)
return -EAGAIN; case MMC_SIGNAL_VOLTAGE_180: -#ifdef CONFIG_DM_REGULATOR +#if CONFIG_IS_ENABLED(DM_REGULATOR) if (!IS_ERR_OR_NULL(priv->vqmmc_dev)) { ret = regulator_set_value(priv->vqmmc_dev, 1800000); if (ret) { @@ -1442,7 +1442,7 @@ static int fsl_esdhc_probe(struct udevice *dev) int node = dev_of_offset(dev); struct esdhc_soc_data *data = (struct esdhc_soc_data *)dev_get_driver_data(dev); -#ifdef CONFIG_DM_REGULATOR +#if CONFIG_IS_ENABLED(DM_REGULATOR) struct udevice *vqmmc_dev; #endif fdt_addr_t addr; @@ -1500,7 +1500,7 @@ static int fsl_esdhc_probe(struct udevice *dev)
priv->vs18_enable = 0;
-#ifdef CONFIG_DM_REGULATOR +#if CONFIG_IS_ENABLED(DM_REGULATOR) /* * If emmc I/O has a fixed voltage at 1.8V, this must be provided, * otherwise, emmc will work abnormally.
This matches one of the following three boards (or fails): - imx6q-sabresd - imx6qp-sabresd - imx6dl-sabresd
Signed-off-by: Abel Vesa abel.vesa@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com --- board/freescale/mx6sabresd/mx6sabresd.c | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 0183ede..4688095 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -1062,3 +1062,21 @@ void board_init_f(ulong dummy) board_init_r(NULL, 0); } #endif + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + if (is_mx6dq()) { + if (!strcmp(name, "imx6q-sabresd")) + return 0; + } else if (is_mx6dqp()) { + if (!strcmp(name, "imx6qp-sabresd")) + return 0; + } else if (is_mx6dl()) { + if (!strcmp(name, "imx6dl-sabresd")) + return 0; + } + + return -1; +} +#endif
This matches one of the following three boards (or fails): - imx6q-sabreauto - imx6qp-sabreauto - imx6dl-sabreauto
Signed-off-by: Abel Vesa abel.vesa@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com --- board/freescale/mx6sabreauto/mx6sabreauto.c | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/board/freescale/mx6sabreauto/mx6sabreauto.c b/board/freescale/mx6sabreauto/mx6sabreauto.c index c1bef85..c8f1263 100644 --- a/board/freescale/mx6sabreauto/mx6sabreauto.c +++ b/board/freescale/mx6sabreauto/mx6sabreauto.c @@ -1097,3 +1097,21 @@ void board_init_f(ulong dummy) board_init_r(NULL, 0); } #endif + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + if (is_mx6dq()) { + if (!strcmp(name, "imx6q-sabreauto")) + return 0; + } else if (is_mx6dqp()) { + if (!strcmp(name, "imx6qp-sabreauto")) + return 0; + } else if (is_mx6dl()) { + if (!strcmp(name, "imx6dl-sabreauto")) + return 0; + } + + return -1; +} +#endif
This allows us to keep the basic dts[i] files up-to-date with the ones in kernel, but at the same time allowing the u-boot to add its own properties to the existing nodes.
Signed-off-by: Abel Vesa abel.vesa@nxp.com --- arch/arm/dts/imx6dl-sabreauto-u-boot.dtsi | 6 ++++++ arch/arm/dts/imx6dl-sabresd-u-boot.dtsi | 6 ++++++ arch/arm/dts/imx6q-sabreauto-u-boot.dtsi | 6 ++++++ arch/arm/dts/imx6q-sabresd-u-boot.dtsi | 6 ++++++ arch/arm/dts/imx6qdl-sabreauto-u-boot.dtsi | 21 +++++++++++++++++++++ arch/arm/dts/imx6qdl-sabresd-u-boot.dtsi | 14 ++++++++++++++ arch/arm/dts/imx6qdl-u-boot.dtsi | 4 ++-- arch/arm/dts/imx6qp-sabreauto-u-boot.dtsi | 6 ++++++ arch/arm/dts/imx6qp-sabresd-u-boot.dtsi | 6 ++++++ 9 files changed, 73 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/imx6dl-sabreauto-u-boot.dtsi create mode 100644 arch/arm/dts/imx6dl-sabresd-u-boot.dtsi create mode 100644 arch/arm/dts/imx6q-sabreauto-u-boot.dtsi create mode 100644 arch/arm/dts/imx6q-sabresd-u-boot.dtsi create mode 100644 arch/arm/dts/imx6qdl-sabreauto-u-boot.dtsi create mode 100644 arch/arm/dts/imx6qdl-sabresd-u-boot.dtsi create mode 100644 arch/arm/dts/imx6qp-sabreauto-u-boot.dtsi create mode 100644 arch/arm/dts/imx6qp-sabresd-u-boot.dtsi
diff --git a/arch/arm/dts/imx6dl-sabreauto-u-boot.dtsi b/arch/arm/dts/imx6dl-sabreauto-u-boot.dtsi new file mode 100644 index 0000000..d75fcc1 --- /dev/null +++ b/arch/arm/dts/imx6dl-sabreauto-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 NXP + */ + +#include "imx6qdl-sabreauto-u-boot.dtsi" diff --git a/arch/arm/dts/imx6dl-sabresd-u-boot.dtsi b/arch/arm/dts/imx6dl-sabresd-u-boot.dtsi new file mode 100644 index 0000000..e4d7d28 --- /dev/null +++ b/arch/arm/dts/imx6dl-sabresd-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 NXP + */ + +#include "imx6qdl-sabresd-u-boot.dtsi" diff --git a/arch/arm/dts/imx6q-sabreauto-u-boot.dtsi b/arch/arm/dts/imx6q-sabreauto-u-boot.dtsi new file mode 100644 index 0000000..d75fcc1 --- /dev/null +++ b/arch/arm/dts/imx6q-sabreauto-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 NXP + */ + +#include "imx6qdl-sabreauto-u-boot.dtsi" diff --git a/arch/arm/dts/imx6q-sabresd-u-boot.dtsi b/arch/arm/dts/imx6q-sabresd-u-boot.dtsi new file mode 100644 index 0000000..e4d7d28 --- /dev/null +++ b/arch/arm/dts/imx6q-sabresd-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 NXP + */ + +#include "imx6qdl-sabresd-u-boot.dtsi" diff --git a/arch/arm/dts/imx6qdl-sabreauto-u-boot.dtsi b/arch/arm/dts/imx6qdl-sabreauto-u-boot.dtsi new file mode 100644 index 0000000..ea90f40 --- /dev/null +++ b/arch/arm/dts/imx6qdl-sabreauto-u-boot.dtsi @@ -0,0 +1,21 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 NXP + */ + +#include "imx6qdl-u-boot.dtsi" + +/ { + aliases { + mmc0 = &usdhc3; + }; +}; + +&usdhc3 { + no-1-8-v; + u-boot,dm-spl; +}; + +&pinctrl_usdhc3 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx6qdl-sabresd-u-boot.dtsi b/arch/arm/dts/imx6qdl-sabresd-u-boot.dtsi new file mode 100644 index 0000000..45f02b1 --- /dev/null +++ b/arch/arm/dts/imx6qdl-sabresd-u-boot.dtsi @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 NXP + */ + +#include "imx6qdl-u-boot.dtsi" + +&usdhc3 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc3 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx6qdl-u-boot.dtsi b/arch/arm/dts/imx6qdl-u-boot.dtsi index dffc21b..45ae2fa 100644 --- a/arch/arm/dts/imx6qdl-u-boot.dtsi +++ b/arch/arm/dts/imx6qdl-u-boot.dtsi @@ -7,11 +7,11 @@ soc { u-boot,dm-spl;
- aips-bus@02000000 { + aips-bus@2000000 { u-boot,dm-spl; };
- aips-bus@02100000 { + aips-bus@2100000 { u-boot,dm-spl; }; }; diff --git a/arch/arm/dts/imx6qp-sabreauto-u-boot.dtsi b/arch/arm/dts/imx6qp-sabreauto-u-boot.dtsi new file mode 100644 index 0000000..d75fcc1 --- /dev/null +++ b/arch/arm/dts/imx6qp-sabreauto-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 NXP + */ + +#include "imx6qdl-sabreauto-u-boot.dtsi" diff --git a/arch/arm/dts/imx6qp-sabresd-u-boot.dtsi b/arch/arm/dts/imx6qp-sabresd-u-boot.dtsi new file mode 100644 index 0000000..e4d7d28 --- /dev/null +++ b/arch/arm/dts/imx6qp-sabresd-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 NXP + */ + +#include "imx6qdl-sabresd-u-boot.dtsi"
Update all the dts[i] files for imx6[q|qp|dl] sabre[auto|sd] to the ones from kernel v4.20 (commit 8fe28cb58bcb2).
Signed-off-by: Abel Vesa abel.vesa@nxp.com Acked-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/Makefile | 8 +- arch/arm/dts/imx6dl-sabreauto.dts | 13 + arch/arm/dts/imx6dl-sabresd.dts | 18 + arch/arm/dts/imx6dl.dtsi | 306 ++++++++++++-- arch/arm/dts/imx6q-sabreauto.dts | 18 + arch/arm/dts/imx6q-sabresd.dts | 23 + arch/arm/dts/imx6q.dtsi | 310 ++++++++++++-- arch/arm/dts/imx6qdl-sabreauto.dtsi | 810 ++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx6qdl-sabresd.dtsi | 741 +++++++++++++++++++++++++++++++++ arch/arm/dts/imx6qdl.dtsi | 455 +++++++++++--------- arch/arm/dts/imx6qp-sabreauto.dts | 55 +++ arch/arm/dts/imx6qp-sabresd.dts | 55 +++ arch/arm/dts/imx6qp.dtsi | 115 +++++ 13 files changed, 2669 insertions(+), 258 deletions(-) create mode 100644 arch/arm/dts/imx6dl-sabreauto.dts create mode 100644 arch/arm/dts/imx6dl-sabresd.dts create mode 100644 arch/arm/dts/imx6q-sabreauto.dts create mode 100644 arch/arm/dts/imx6q-sabresd.dts create mode 100644 arch/arm/dts/imx6qdl-sabreauto.dtsi create mode 100644 arch/arm/dts/imx6qdl-sabresd.dtsi create mode 100644 arch/arm/dts/imx6qp-sabreauto.dts create mode 100644 arch/arm/dts/imx6qp-sabresd.dts create mode 100644 arch/arm/dts/imx6qp.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 5c3225b..c18da3d 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -443,7 +443,13 @@ dtb-$(CONFIG_MX6QDL) += \ imx6q-icore.dtb \ imx6q-icore-mipi.dtb \ imx6q-icore-rqs.dtb \ - imx6q-logicpd.dtb + imx6q-logicpd.dtb \ + imx6q-sabreauto.dtb \ + imx6q-sabresd.dtb \ + imx6dl-sabreauto.dtb \ + imx6dl-sabresd.dtb \ + imx6qp-sabreauto.dtb \ + imx6qp-sabresd.dtb
dtb-$(CONFIG_MX6SL) += imx6sl-evk.dtb
diff --git a/arch/arm/dts/imx6dl-sabreauto.dts b/arch/arm/dts/imx6dl-sabreauto.dts new file mode 100644 index 0000000..660d52a --- /dev/null +++ b/arch/arm/dts/imx6dl-sabreauto.dts @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0 +// +// Copyright (C) 2013 Freescale Semiconductor, Inc. + +/dts-v1/; + +#include "imx6dl.dtsi" +#include "imx6qdl-sabreauto.dtsi" + +/ { + model = "Freescale i.MX6 DualLite/Solo SABRE Automotive Board"; + compatible = "fsl,imx6dl-sabreauto", "fsl,imx6dl"; +}; diff --git a/arch/arm/dts/imx6dl-sabresd.dts b/arch/arm/dts/imx6dl-sabresd.dts new file mode 100644 index 0000000..cd6bbf2 --- /dev/null +++ b/arch/arm/dts/imx6dl-sabresd.dts @@ -0,0 +1,18 @@ +// SPDX-License-Identifier: GPL-2.0 +// +// Copyright (C) 2013 Freescale Semiconductor, Inc. + +/dts-v1/; + +#include "imx6dl.dtsi" +#include "imx6qdl-sabresd.dtsi" + +/ { + model = "Freescale i.MX6 DualLite SABRE Smart Device Board"; + compatible = "fsl,imx6dl-sabresd", "fsl,imx6dl"; +}; + +&ipu1_csi1_from_ipu1_csi1_mux { + clock-lanes = <0>; + data-lanes = <1 2>; +}; diff --git a/arch/arm/dts/imx6dl.dtsi b/arch/arm/dts/imx6dl.dtsi index 9a4c22c..f0607eb 100644 --- a/arch/arm/dts/imx6dl.dtsi +++ b/arch/arm/dts/imx6dl.dtsi @@ -1,12 +1,6 @@ - -/* - * Copyright 2013 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * - */ +// SPDX-License-Identifier: GPL-2.0 +// +// Copyright 2013 Freescale Semiconductor, Inc.
#include <dt-bindings/interrupt-controller/irq.h> #include "imx6dl-pinfunc.h" @@ -39,6 +33,7 @@ 396000 1175000 >; clock-latency = <61036>; /* two CLK32 periods */ + #cooling-cells = <2>; clocks = <&clks IMX6QDL_CLK_ARM>, <&clks IMX6QDL_CLK_PLL2_PFD2_396M>, <&clks IMX6QDL_CLK_STEP>, @@ -56,39 +51,57 @@ device_type = "cpu"; reg = <1>; next-level-cache = <&L2>; + operating-points = < + /* kHz uV */ + 996000 1250000 + 792000 1175000 + 396000 1150000 + >; + fsl,soc-operating-points = < + /* ARM kHz SOC-PU uV */ + 996000 1175000 + 792000 1175000 + 396000 1175000 + >; + clock-latency = <61036>; /* two CLK32 periods */ + clocks = <&clks IMX6QDL_CLK_ARM>, + <&clks IMX6QDL_CLK_PLL2_PFD2_396M>, + <&clks IMX6QDL_CLK_STEP>, + <&clks IMX6QDL_CLK_PLL1_SW>, + <&clks IMX6QDL_CLK_PLL1_SYS>; + clock-names = "arm", "pll2_pfd2_396m", "step", + "pll1_sw", "pll1_sys"; + arm-supply = <®_arm>; + pu-supply = <®_pu>; + soc-supply = <®_soc>; }; };
soc { - ocram: sram@00900000 { + ocram: sram@900000 { compatible = "mmio-sram"; reg = <0x00900000 0x20000>; clocks = <&clks IMX6QDL_CLK_OCRAM>; };
- aips1: aips-bus@02000000 { - iomuxc: iomuxc@020e0000 { + aips1: aips-bus@2000000 { + iomuxc: iomuxc@20e0000 { compatible = "fsl,imx6dl-iomuxc"; };
- pxp: pxp@020f0000 { + pxp: pxp@20f0000 { reg = <0x020f0000 0x4000>; interrupts = <0 98 IRQ_TYPE_LEVEL_HIGH>; };
- epdc: epdc@020f4000 { + epdc: epdc@20f4000 { reg = <0x020f4000 0x4000>; interrupts = <0 97 IRQ_TYPE_LEVEL_HIGH>; }; - - lcdif: lcdif@020f8000 { - reg = <0x020f8000 0x4000>; - interrupts = <0 39 IRQ_TYPE_LEVEL_HIGH>; - }; };
- aips2: aips-bus@02100000 { - i2c4: i2c@021f8000 { + aips2: aips-bus@2100000 { + i2c4: i2c@21f8000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6q-i2c", "fsl,imx21-i2c"; @@ -100,14 +113,177 @@ }; };
+ capture-subsystem { + compatible = "fsl,imx-capture-subsystem"; + ports = <&ipu1_csi0>, <&ipu1_csi1>; + }; + display-subsystem { compatible = "fsl,imx-display-subsystem"; ports = <&ipu1_di0>, <&ipu1_di1>; }; +}; + +&gpio1 { + gpio-ranges = <&iomuxc 0 131 2>, <&iomuxc 2 137 8>, <&iomuxc 10 189 2>, + <&iomuxc 12 194 1>, <&iomuxc 13 193 1>, <&iomuxc 14 192 1>, + <&iomuxc 15 191 1>, <&iomuxc 16 185 2>, <&iomuxc 18 184 1>, + <&iomuxc 19 187 1>, <&iomuxc 20 183 1>, <&iomuxc 21 188 1>, + <&iomuxc 22 123 3>, <&iomuxc 25 121 1>, <&iomuxc 26 127 1>, + <&iomuxc 27 126 1>, <&iomuxc 28 128 1>, <&iomuxc 29 130 1>, + <&iomuxc 30 129 1>, <&iomuxc 31 122 1>; +}; + +&gpio2 { + gpio-ranges = <&iomuxc 0 161 8>, <&iomuxc 8 208 8>, <&iomuxc 16 74 1>, + <&iomuxc 17 73 1>, <&iomuxc 18 72 1>, <&iomuxc 19 71 1>, + <&iomuxc 20 70 1>, <&iomuxc 21 69 1>, <&iomuxc 22 68 1>, + <&iomuxc 23 79 2>, <&iomuxc 25 118 2>, <&iomuxc 27 117 1>, + <&iomuxc 28 113 4>; +}; + +&gpio3 { + gpio-ranges = <&iomuxc 0 97 2>, <&iomuxc 2 105 8>, <&iomuxc 10 99 6>, + <&iomuxc 16 81 16>; +}; + +&gpio4 { + gpio-ranges = <&iomuxc 5 136 1>, <&iomuxc 6 145 1>, <&iomuxc 7 150 1>, + <&iomuxc 8 146 1>, <&iomuxc 9 151 1>, <&iomuxc 10 147 1>, + <&iomuxc 11 152 1>, <&iomuxc 12 148 1>, <&iomuxc 13 153 1>, + <&iomuxc 14 149 1>, <&iomuxc 15 154 1>, <&iomuxc 16 39 7>, + <&iomuxc 23 56 1>, <&iomuxc 24 61 7>, <&iomuxc 31 46 1>; +};
- gpu-subsystem { - compatible = "fsl,imx-gpu-subsystem"; - cores = <&gpu_2d>, <&gpu_3d>; +&gpio5 { + gpio-ranges = <&iomuxc 0 120 1>, <&iomuxc 2 77 1>, <&iomuxc 4 76 1>, + <&iomuxc 5 47 9>, <&iomuxc 14 57 4>, <&iomuxc 18 37 1>, + <&iomuxc 19 36 1>, <&iomuxc 20 35 1>, <&iomuxc 21 38 1>, + <&iomuxc 22 29 6>, <&iomuxc 28 19 4>; +}; + +&gpio6 { + gpio-ranges = <&iomuxc 0 23 6>, <&iomuxc 6 75 1>, <&iomuxc 7 156 1>, + <&iomuxc 8 155 1>, <&iomuxc 9 170 1>, <&iomuxc 10 169 1>, + <&iomuxc 11 157 1>, <&iomuxc 14 158 3>, <&iomuxc 17 204 1>, + <&iomuxc 18 203 1>, <&iomuxc 19 182 1>, <&iomuxc 20 177 4>, + <&iomuxc 24 175 1>, <&iomuxc 25 171 1>, <&iomuxc 26 181 1>, + <&iomuxc 27 172 3>, <&iomuxc 30 176 1>, <&iomuxc 31 78 1>; +}; + +&gpio7 { + gpio-ranges = <&iomuxc 0 202 1>, <&iomuxc 1 201 1>, <&iomuxc 2 196 1>, + <&iomuxc 3 195 1>, <&iomuxc 4 197 4>, <&iomuxc 8 205 1>, + <&iomuxc 9 207 1>, <&iomuxc 10 206 1>, <&iomuxc 11 133 3>; +}; + +&gpr { + ipu1_csi0_mux { + compatible = "video-mux"; + mux-controls = <&mux 0>; + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + ipu1_csi0_mux_from_mipi_vc0: endpoint { + remote-endpoint = <&mipi_vc0_to_ipu1_csi0_mux>; + }; + }; + + port@1 { + reg = <1>; + + ipu1_csi0_mux_from_mipi_vc1: endpoint { + remote-endpoint = <&mipi_vc1_to_ipu1_csi0_mux>; + }; + }; + + port@2 { + reg = <2>; + + ipu1_csi0_mux_from_mipi_vc2: endpoint { + remote-endpoint = <&mipi_vc2_to_ipu1_csi0_mux>; + }; + }; + + port@3 { + reg = <3>; + + ipu1_csi0_mux_from_mipi_vc3: endpoint { + remote-endpoint = <&mipi_vc3_to_ipu1_csi0_mux>; + }; + }; + + port@4 { + reg = <4>; + + ipu1_csi0_mux_from_parallel_sensor: endpoint { + }; + }; + + port@5 { + reg = <5>; + + ipu1_csi0_mux_to_ipu1_csi0: endpoint { + remote-endpoint = <&ipu1_csi0_from_ipu1_csi0_mux>; + }; + }; + }; + + ipu1_csi1_mux { + compatible = "video-mux"; + mux-controls = <&mux 1>; + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + ipu1_csi1_mux_from_mipi_vc0: endpoint { + remote-endpoint = <&mipi_vc0_to_ipu1_csi1_mux>; + }; + }; + + port@1 { + reg = <1>; + + ipu1_csi1_mux_from_mipi_vc1: endpoint { + remote-endpoint = <&mipi_vc1_to_ipu1_csi1_mux>; + }; + }; + + port@2 { + reg = <2>; + + ipu1_csi1_mux_from_mipi_vc2: endpoint { + remote-endpoint = <&mipi_vc2_to_ipu1_csi1_mux>; + }; + }; + + port@3 { + reg = <3>; + + ipu1_csi1_mux_from_mipi_vc3: endpoint { + remote-endpoint = <&mipi_vc3_to_ipu1_csi1_mux>; + }; + }; + + port@4 { + reg = <4>; + + ipu1_csi1_mux_from_parallel_sensor: endpoint { + }; + }; + + port@5 { + reg = <5>; + + ipu1_csi1_mux_to_ipu1_csi1: endpoint { + remote-endpoint = <&ipu1_csi1_from_ipu1_csi1_mux>; + }; + }; }; };
@@ -119,6 +295,12 @@ compatible = "fsl,imx6dl-hdmi"; };
+&ipu1_csi1 { + ipu1_csi1_from_ipu1_csi1_mux: endpoint { + remote-endpoint = <&ipu1_csi1_mux_to_ipu1_csi1>; + }; +}; + &ldb { clocks = <&clks IMX6QDL_CLK_LDB_DI0_SEL>, <&clks IMX6QDL_CLK_LDB_DI1_SEL>, <&clks IMX6QDL_CLK_IPU1_DI0_SEL>, <&clks IMX6QDL_CLK_IPU1_DI1_SEL>, @@ -128,6 +310,82 @@ "di0", "di1"; };
+&mipi_csi { + port@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + mipi_vc0_to_ipu1_csi0_mux: endpoint@0 { + reg = <0>; + remote-endpoint = <&ipu1_csi0_mux_from_mipi_vc0>; + }; + + mipi_vc0_to_ipu1_csi1_mux: endpoint@1 { + reg = <1>; + remote-endpoint = <&ipu1_csi1_mux_from_mipi_vc0>; + }; + }; + + port@2 { + reg = <2>; + #address-cells = <1>; + #size-cells = <0>; + + mipi_vc1_to_ipu1_csi0_mux: endpoint@0 { + reg = <0>; + remote-endpoint = <&ipu1_csi0_mux_from_mipi_vc1>; + }; + + mipi_vc1_to_ipu1_csi1_mux: endpoint@1 { + reg = <1>; + remote-endpoint = <&ipu1_csi1_mux_from_mipi_vc1>; + }; + }; + + port@3 { + reg = <3>; + #address-cells = <1>; + #size-cells = <0>; + + mipi_vc2_to_ipu1_csi0_mux: endpoint@0 { + reg = <0>; + remote-endpoint = <&ipu1_csi0_mux_from_mipi_vc2>; + }; + + mipi_vc2_to_ipu1_csi1_mux: endpoint@1 { + reg = <1>; + remote-endpoint = <&ipu1_csi1_mux_from_mipi_vc2>; + }; + }; + + port@4 { + reg = <4>; + #address-cells = <1>; + #size-cells = <0>; + + mipi_vc3_to_ipu1_csi0_mux: endpoint@0 { + reg = <0>; + remote-endpoint = <&ipu1_csi0_mux_from_mipi_vc3>; + }; + + mipi_vc3_to_ipu1_csi1_mux: endpoint@1 { + reg = <1>; + remote-endpoint = <&ipu1_csi1_mux_from_mipi_vc3>; + }; + }; +}; + +&mux { + mux-reg-masks = <0x34 0x00000007>, /* IPU_CSI0_MUX */ + <0x34 0x00000038>, /* IPU_CSI1_MUX */ + <0x0c 0x0000000c>, /* HDMI_MUX_CTL */ + <0x0c 0x000000c0>, /* LVDS0_MUX_CTL */ + <0x0c 0x00000300>, /* LVDS1_MUX_CTL */ + <0x28 0x00000003>, /* DCIC1_MUX_CTL */ + <0x28 0x0000000c>; /* DCIC2_MUX_CTL */ +}; + &vpu { compatible = "fsl,imx6dl-vpu", "cnm,coda960"; }; diff --git a/arch/arm/dts/imx6q-sabreauto.dts b/arch/arm/dts/imx6q-sabreauto.dts new file mode 100644 index 0000000..6e981a3 --- /dev/null +++ b/arch/arm/dts/imx6q-sabreauto.dts @@ -0,0 +1,18 @@ +// SPDX-License-Identifier: GPL-2.0+ +// +// Copyright 2012 Freescale Semiconductor, Inc. +// Copyright 2011 Linaro Ltd. + +/dts-v1/; + +#include "imx6q.dtsi" +#include "imx6qdl-sabreauto.dtsi" + +/ { + model = "Freescale i.MX6 Quad SABRE Automotive Board"; + compatible = "fsl,imx6q-sabreauto", "fsl,imx6q"; +}; + +&sata { + status = "okay"; +}; diff --git a/arch/arm/dts/imx6q-sabresd.dts b/arch/arm/dts/imx6q-sabresd.dts new file mode 100644 index 0000000..eec9446 --- /dev/null +++ b/arch/arm/dts/imx6q-sabresd.dts @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0+ +// +// Copyright 2012 Freescale Semiconductor, Inc. +// Copyright 2011 Linaro Ltd. + +/dts-v1/; + +#include "imx6q.dtsi" +#include "imx6qdl-sabresd.dtsi" + +/ { + model = "Freescale i.MX6 Quad SABRE Smart Device Board"; + compatible = "fsl,imx6q-sabresd", "fsl,imx6q"; +}; + +&sata { + status = "okay"; +}; + +&ipu1_csi1_from_mipi_vc1 { + clock-lanes = <0>; + data-lanes = <1 2>; +}; diff --git a/arch/arm/dts/imx6q.dtsi b/arch/arm/dts/imx6q.dtsi index c30c836..8381d24 100644 --- a/arch/arm/dts/imx6q.dtsi +++ b/arch/arm/dts/imx6q.dtsi @@ -1,12 +1,6 @@ - -/* - * Copyright 2013 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * - */ +// SPDX-License-Identifier: GPL-2.0 +// +// Copyright 2013 Freescale Semiconductor, Inc.
#include <dt-bindings/interrupt-controller/irq.h> #include "imx6q-pinfunc.h" @@ -44,6 +38,7 @@ 396000 1175000 >; clock-latency = <61036>; /* two CLK32 periods */ + #cooling-cells = <2>; clocks = <&clks IMX6QDL_CLK_ARM>, <&clks IMX6QDL_CLK_PLL2_PFD2_396M>, <&clks IMX6QDL_CLK_STEP>, @@ -56,38 +51,119 @@ soc-supply = <®_soc>; };
- cpu@1 { + cpu1: cpu@1 { compatible = "arm,cortex-a9"; device_type = "cpu"; reg = <1>; next-level-cache = <&L2>; + operating-points = < + /* kHz uV */ + 1200000 1275000 + 996000 1250000 + 852000 1250000 + 792000 1175000 + 396000 975000 + >; + fsl,soc-operating-points = < + /* ARM kHz SOC-PU uV */ + 1200000 1275000 + 996000 1250000 + 852000 1250000 + 792000 1175000 + 396000 1175000 + >; + clock-latency = <61036>; /* two CLK32 periods */ + clocks = <&clks IMX6QDL_CLK_ARM>, + <&clks IMX6QDL_CLK_PLL2_PFD2_396M>, + <&clks IMX6QDL_CLK_STEP>, + <&clks IMX6QDL_CLK_PLL1_SW>, + <&clks IMX6QDL_CLK_PLL1_SYS>; + clock-names = "arm", "pll2_pfd2_396m", "step", + "pll1_sw", "pll1_sys"; + arm-supply = <®_arm>; + pu-supply = <®_pu>; + soc-supply = <®_soc>; };
- cpu@2 { + cpu2: cpu@2 { compatible = "arm,cortex-a9"; device_type = "cpu"; reg = <2>; next-level-cache = <&L2>; + operating-points = < + /* kHz uV */ + 1200000 1275000 + 996000 1250000 + 852000 1250000 + 792000 1175000 + 396000 975000 + >; + fsl,soc-operating-points = < + /* ARM kHz SOC-PU uV */ + 1200000 1275000 + 996000 1250000 + 852000 1250000 + 792000 1175000 + 396000 1175000 + >; + clock-latency = <61036>; /* two CLK32 periods */ + clocks = <&clks IMX6QDL_CLK_ARM>, + <&clks IMX6QDL_CLK_PLL2_PFD2_396M>, + <&clks IMX6QDL_CLK_STEP>, + <&clks IMX6QDL_CLK_PLL1_SW>, + <&clks IMX6QDL_CLK_PLL1_SYS>; + clock-names = "arm", "pll2_pfd2_396m", "step", + "pll1_sw", "pll1_sys"; + arm-supply = <®_arm>; + pu-supply = <®_pu>; + soc-supply = <®_soc>; };
- cpu@3 { + cpu3: cpu@3 { compatible = "arm,cortex-a9"; device_type = "cpu"; reg = <3>; next-level-cache = <&L2>; + operating-points = < + /* kHz uV */ + 1200000 1275000 + 996000 1250000 + 852000 1250000 + 792000 1175000 + 396000 975000 + >; + fsl,soc-operating-points = < + /* ARM kHz SOC-PU uV */ + 1200000 1275000 + 996000 1250000 + 852000 1250000 + 792000 1175000 + 396000 1175000 + >; + clock-latency = <61036>; /* two CLK32 periods */ + clocks = <&clks IMX6QDL_CLK_ARM>, + <&clks IMX6QDL_CLK_PLL2_PFD2_396M>, + <&clks IMX6QDL_CLK_STEP>, + <&clks IMX6QDL_CLK_PLL1_SW>, + <&clks IMX6QDL_CLK_PLL1_SYS>; + clock-names = "arm", "pll2_pfd2_396m", "step", + "pll1_sw", "pll1_sys"; + arm-supply = <®_arm>; + pu-supply = <®_pu>; + soc-supply = <®_soc>; }; };
soc { - ocram: sram@00900000 { + ocram: sram@900000 { compatible = "mmio-sram"; reg = <0x00900000 0x40000>; clocks = <&clks IMX6QDL_CLK_OCRAM>; };
- aips-bus@02000000 { /* AIPS1 */ - spba-bus@02000000 { - ecspi5: ecspi@02018000 { + aips-bus@2000000 { /* AIPS1 */ + spba-bus@2000000 { + ecspi5: spi@2018000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6q-ecspi", "fsl,imx51-ecspi"; @@ -96,18 +172,18 @@ clocks = <&clks IMX6Q_CLK_ECSPI5>, <&clks IMX6Q_CLK_ECSPI5>; clock-names = "ipg", "per"; - dmas = <&sdma 11 7 1>, <&sdma 12 7 2>; + dmas = <&sdma 11 8 1>, <&sdma 12 8 2>; dma-names = "rx", "tx"; status = "disabled"; }; };
- iomuxc: iomuxc@020e0000 { + iomuxc: iomuxc@20e0000 { compatible = "fsl,imx6q-iomuxc"; }; };
- sata: sata@02200000 { + sata: sata@2200000 { compatible = "fsl,imx6q-ahci"; reg = <0x02200000 0x4000>; interrupts = <0 39 IRQ_TYPE_LEVEL_HIGH>; @@ -118,17 +194,17 @@ status = "disabled"; };
- gpu_vg: gpu@02204000 { + gpu_vg: gpu@2204000 { compatible = "vivante,gc"; reg = <0x02204000 0x4000>; interrupts = <0 11 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6QDL_CLK_OPENVG_AXI>, <&clks IMX6QDL_CLK_GPU2D_CORE>; clock-names = "bus", "core"; - power-domains = <&gpc 1>; + power-domains = <&pd_pu>; };
- ipu2: ipu@02800000 { + ipu2: ipu@2800000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6q-ipu"; @@ -143,10 +219,18 @@
ipu2_csi0: port@0 { reg = <0>; + + ipu2_csi0_from_mipi_vc2: endpoint { + remote-endpoint = <&mipi_vc2_to_ipu2_csi0>; + }; };
ipu2_csi1: port@1 { reg = <1>; + + ipu2_csi1_from_ipu2_csi1_mux: endpoint { + remote-endpoint = <&ipu2_csi1_mux_to_ipu2_csi1>; + }; };
ipu2_di0: port@2 { @@ -154,22 +238,27 @@ #size-cells = <0>; reg = <2>;
- ipu2_di0_disp0: disp0-endpoint { + ipu2_di0_disp0: endpoint@0 { + reg = <0>; };
- ipu2_di0_hdmi: hdmi-endpoint { + ipu2_di0_hdmi: endpoint@1 { + reg = <1>; remote-endpoint = <&hdmi_mux_2>; };
- ipu2_di0_mipi: mipi-endpoint { + ipu2_di0_mipi: endpoint@2 { + reg = <2>; remote-endpoint = <&mipi_mux_2>; };
- ipu2_di0_lvds0: lvds0-endpoint { + ipu2_di0_lvds0: endpoint@3 { + reg = <3>; remote-endpoint = <&lvds0_mux_2>; };
- ipu2_di0_lvds1: lvds1-endpoint { + ipu2_di0_lvds1: endpoint@4 { + reg = <4>; remote-endpoint = <&lvds1_mux_2>; }; }; @@ -179,33 +268,136 @@ #size-cells = <0>; reg = <3>;
- ipu2_di1_hdmi: hdmi-endpoint { + ipu2_di1_hdmi: endpoint@1 { + reg = <1>; remote-endpoint = <&hdmi_mux_3>; };
- ipu2_di1_mipi: mipi-endpoint { + ipu2_di1_mipi: endpoint@2 { + reg = <2>; remote-endpoint = <&mipi_mux_3>; };
- ipu2_di1_lvds0: lvds0-endpoint { + ipu2_di1_lvds0: endpoint@3 { + reg = <3>; remote-endpoint = <&lvds0_mux_3>; };
- ipu2_di1_lvds1: lvds1-endpoint { + ipu2_di1_lvds1: endpoint@4 { + reg = <4>; remote-endpoint = <&lvds1_mux_3>; }; }; }; };
+ capture-subsystem { + compatible = "fsl,imx-capture-subsystem"; + ports = <&ipu1_csi0>, <&ipu1_csi1>, <&ipu2_csi0>, <&ipu2_csi1>; + }; + display-subsystem { compatible = "fsl,imx-display-subsystem"; ports = <&ipu1_di0>, <&ipu1_di1>, <&ipu2_di0>, <&ipu2_di1>; }; +}; + +&gpio1 { + gpio-ranges = <&iomuxc 0 136 2>, <&iomuxc 2 141 1>, <&iomuxc 3 139 1>, + <&iomuxc 4 142 2>, <&iomuxc 6 140 1>, <&iomuxc 7 144 2>, + <&iomuxc 9 138 1>, <&iomuxc 10 213 3>, <&iomuxc 13 20 1>, + <&iomuxc 14 19 1>, <&iomuxc 15 21 1>, <&iomuxc 16 208 1>, + <&iomuxc 17 207 1>, <&iomuxc 18 210 3>, <&iomuxc 21 209 1>, + <&iomuxc 22 116 10>; +}; + +&gpio2 { + gpio-ranges = <&iomuxc 0 191 16>, <&iomuxc 16 55 14>, <&iomuxc 30 35 1>, + <&iomuxc 31 44 1>; +}; + +&gpio3 { + gpio-ranges = <&iomuxc 0 69 16>, <&iomuxc 16 36 8>, <&iomuxc 24 45 8>; +}; + +&gpio4 { + gpio-ranges = <&iomuxc 5 149 1>, <&iomuxc 6 126 10>, <&iomuxc 16 87 16>; +}; + +&gpio5 { + gpio-ranges = <&iomuxc 0 85 1>, <&iomuxc 2 34 1>, <&iomuxc 4 53 1>, + <&iomuxc 5 103 13>, <&iomuxc 18 150 14>; +}; + +&gpio6 { + gpio-ranges = <&iomuxc 0 164 6>, <&iomuxc 6 54 1>, <&iomuxc 7 181 5>, + <&iomuxc 14 186 3>, <&iomuxc 17 170 2>, <&iomuxc 19 22 12>, + <&iomuxc 31 86 1>; +}; + +&gpio7 { + gpio-ranges = <&iomuxc 0 172 9>, <&iomuxc 9 189 2>, <&iomuxc 11 146 3>; +}; + +&gpr { + ipu1_csi0_mux { + compatible = "video-mux"; + mux-controls = <&mux 0>; + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + ipu1_csi0_mux_from_mipi_vc0: endpoint { + remote-endpoint = <&mipi_vc0_to_ipu1_csi0_mux>; + }; + }; + + port@1 { + reg = <1>; + + ipu1_csi0_mux_from_parallel_sensor: endpoint { + }; + };
- gpu-subsystem { - compatible = "fsl,imx-gpu-subsystem"; - cores = <&gpu_2d>, <&gpu_3d>, <&gpu_vg>; + port@2 { + reg = <2>; + + ipu1_csi0_mux_to_ipu1_csi0: endpoint { + remote-endpoint = <&ipu1_csi0_from_ipu1_csi0_mux>; + }; + }; + }; + + ipu2_csi1_mux { + compatible = "video-mux"; + mux-controls = <&mux 1>; + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + ipu2_csi1_mux_from_mipi_vc3: endpoint { + remote-endpoint = <&mipi_vc3_to_ipu2_csi1_mux>; + }; + }; + + port@1 { + reg = <1>; + + ipu2_csi1_mux_from_parallel_sensor: endpoint { + }; + }; + + port@2 { + reg = <2>; + + ipu2_csi1_mux_to_ipu2_csi1: endpoint { + remote-endpoint = <&ipu2_csi1_from_ipu2_csi1_mux>; + }; + }; }; };
@@ -229,6 +421,12 @@ }; };
+&ipu1_csi1 { + ipu1_csi1_from_mipi_vc1: endpoint { + remote-endpoint = <&mipi_vc1_to_ipu1_csi1>; + }; +}; + &ldb { clocks = <&clks IMX6QDL_CLK_LDB_DI0_SEL>, <&clks IMX6QDL_CLK_LDB_DI1_SEL>, <&clks IMX6QDL_CLK_IPU1_DI0_SEL>, <&clks IMX6QDL_CLK_IPU1_DI1_SEL>, @@ -275,6 +473,40 @@ }; };
+&mipi_csi { + port@1 { + reg = <1>; + + mipi_vc0_to_ipu1_csi0_mux: endpoint { + remote-endpoint = <&ipu1_csi0_mux_from_mipi_vc0>; + }; + }; + + port@2 { + reg = <2>; + + mipi_vc1_to_ipu1_csi1: endpoint { + remote-endpoint = <&ipu1_csi1_from_mipi_vc1>; + }; + }; + + port@3 { + reg = <3>; + + mipi_vc2_to_ipu2_csi0: endpoint { + remote-endpoint = <&ipu2_csi0_from_mipi_vc2>; + }; + }; + + port@4 { + reg = <4>; + + mipi_vc3_to_ipu2_csi1_mux: endpoint { + remote-endpoint = <&ipu2_csi1_mux_from_mipi_vc3>; + }; + }; +}; + &mipi_dsi { ports { port@2 { @@ -295,6 +527,16 @@ }; };
+&mux { + mux-reg-masks = <0x04 0x00080000>, /* MIPI_IPU1_MUX */ + <0x04 0x00100000>, /* MIPI_IPU2_MUX */ + <0x0c 0x0000000c>, /* HDMI_MUX_CTL */ + <0x0c 0x000000c0>, /* LVDS0_MUX_CTL */ + <0x0c 0x00000300>, /* LVDS1_MUX_CTL */ + <0x28 0x00000003>, /* DCIC1_MUX_CTL */ + <0x28 0x0000000c>; /* DCIC2_MUX_CTL */ +}; + &vpu { compatible = "fsl,imx6q-vpu", "cnm,coda960"; }; diff --git a/arch/arm/dts/imx6qdl-sabreauto.dtsi b/arch/arm/dts/imx6qdl-sabreauto.dtsi new file mode 100644 index 0000000..a6dc5c4 --- /dev/null +++ b/arch/arm/dts/imx6qdl-sabreauto.dtsi @@ -0,0 +1,810 @@ +// SPDX-License-Identifier: GPL-2.0+ +// +// Copyright 2012 Freescale Semiconductor, Inc. +// Copyright 2011 Linaro Ltd. + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> + +/ { + chosen { + stdout-path = &uart4; + }; + + memory@10000000 { + reg = <0x10000000 0x80000000>; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_leds>; + + user { + label = "debug"; + gpios = <&gpio5 15 GPIO_ACTIVE_HIGH>; + }; + }; + + gpio-keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_keys>; + + home { + label = "Home"; + gpios = <&gpio1 11 GPIO_ACTIVE_LOW>; + linux,code = <KEY_HOME>; + wakeup-source; + }; + + back { + label = "Back"; + gpios = <&gpio1 12 GPIO_ACTIVE_LOW>; + linux,code = <KEY_BACK>; + wakeup-source; + }; + + program { + label = "Program"; + gpios = <&gpio2 12 GPIO_ACTIVE_LOW>; + linux,code = <KEY_PROGRAM>; + wakeup-source; + }; + + volume-up { + label = "Volume Up"; + gpios = <&gpio2 15 GPIO_ACTIVE_LOW>; + linux,code = <KEY_VOLUMEUP>; + wakeup-source; + }; + + volume-down { + label = "Volume Down"; + gpios = <&gpio5 14 GPIO_ACTIVE_LOW>; + linux,code = <KEY_VOLUMEDOWN>; + wakeup-source; + }; + }; + + clocks { + codec_osc: anaclk2 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24576000>; + }; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + reg_audio: regulator@0 { + compatible = "regulator-fixed"; + reg = <0>; + regulator-name = "cs42888_supply"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + reg_usb_h1_vbus: regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "usb_h1_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&max7310_b 7 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + reg_usb_otg_vbus: regulator@2 { + compatible = "regulator-fixed"; + reg = <2>; + regulator-name = "usb_otg_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&max7310_c 1 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + }; + + sound-cs42888 { + compatible = "fsl,imx6-sabreauto-cs42888", + "fsl,imx-audio-cs42888"; + model = "imx-cs42888"; + audio-cpu = <&esai>; + audio-asrc = <&asrc>; + audio-codec = <&codec>; + audio-routing = + "Line Out Jack", "AOUT1L", + "Line Out Jack", "AOUT1R", + "Line Out Jack", "AOUT2L", + "Line Out Jack", "AOUT2R", + "Line Out Jack", "AOUT3L", + "Line Out Jack", "AOUT3R", + "Line Out Jack", "AOUT4L", + "Line Out Jack", "AOUT4R", + "AIN1L", "Line In Jack", + "AIN1R", "Line In Jack", + "AIN2L", "Line In Jack", + "AIN2R", "Line In Jack"; + }; + + sound-spdif { + compatible = "fsl,imx-audio-spdif", + "fsl,imx-sabreauto-spdif"; + model = "imx-spdif"; + spdif-controller = <&spdif>; + spdif-in; + }; + + backlight { + compatible = "pwm-backlight"; + pwms = <&pwm3 0 5000000>; + brightness-levels = <0 4 8 16 32 64 128 255>; + default-brightness-level = <7>; + status = "okay"; + }; + + i2cmux { + compatible = "i2c-mux-gpio"; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3mux>; + mux-gpios = <&gpio5 4 0>; + i2c-parent = <&i2c3>; + idle-state = <0>; + + i2c@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + + adv7180: camera@21 { + compatible = "adi,adv7180"; + reg = <0x21>; + powerdown-gpios = <&max7310_b 2 GPIO_ACTIVE_LOW>; + interrupt-parent = <&gpio1>; + interrupts = <27 IRQ_TYPE_LEVEL_LOW>; + + port { + adv7180_to_ipu1_csi0_mux: endpoint { + remote-endpoint = <&ipu1_csi0_mux_from_parallel_sensor>; + bus-width = <8>; + }; + }; + }; + + max7310_a: gpio@30 { + compatible = "maxim,max7310"; + reg = <0x30>; + gpio-controller; + #gpio-cells = <2>; + }; + + max7310_b: gpio@32 { + compatible = "maxim,max7310"; + reg = <0x32>; + gpio-controller; + #gpio-cells = <2>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_max7310>; + reset-gpios = <&gpio1 15 GPIO_ACTIVE_LOW>; + }; + + max7310_c: gpio@34 { + compatible = "maxim,max7310"; + reg = <0x34>; + gpio-controller; + #gpio-cells = <2>; + }; + + light-sensor@44 { + compatible = "isil,isl29023"; + reg = <0x44>; + interrupt-parent = <&gpio5>; + interrupts = <17 IRQ_TYPE_EDGE_FALLING>; + }; + + magnetometer@e { + compatible = "fsl,mag3110"; + reg = <0x0e>; + interrupt-parent = <&gpio2>; + interrupts = <29 IRQ_TYPE_EDGE_RISING>; + }; + + accelerometer@1c { + compatible = "fsl,mma8451"; + reg = <0x1c>; + interrupt-parent = <&gpio6>; + interrupts = <31 IRQ_TYPE_LEVEL_LOW>; + }; + }; + }; +}; + +&ipu1_csi0_from_ipu1_csi0_mux { + bus-width = <8>; +}; + +&ipu1_csi0_mux_from_parallel_sensor { + remote-endpoint = <&adv7180_to_ipu1_csi0_mux>; + bus-width = <8>; +}; + +&ipu1_csi0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ipu1_csi0>; +}; + +&clks { + assigned-clocks = <&clks IMX6QDL_PLL4_BYPASS_SRC>, + <&clks IMX6QDL_PLL4_BYPASS>, + <&clks IMX6QDL_CLK_LDB_DI0_SEL>, + <&clks IMX6QDL_CLK_LDB_DI1_SEL>, + <&clks IMX6QDL_CLK_PLL4_POST_DIV>; + assigned-clock-parents = <&clks IMX6QDL_CLK_LVDS2_IN>, + <&clks IMX6QDL_PLL4_BYPASS_SRC>, + <&clks IMX6QDL_CLK_PLL3_USB_OTG>, + <&clks IMX6QDL_CLK_PLL3_USB_OTG>; + assigned-clock-rates = <0>, <0>, <0>, <0>, <24576000>; +}; + +&ecspi1 { + cs-gpios = <&gpio3 19 0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi1 &pinctrl_ecspi1_cs>; + status = "disabled"; /* pin conflict with WEIM NOR */ + + flash: m25p80@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "st,m25p32", "jedec,spi-nor"; + spi-max-frequency = <20000000>; + reg = <0>; + }; +}; + +&esai { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_esai>; + assigned-clocks = <&clks IMX6QDL_CLK_ESAI_SEL>, + <&clks IMX6QDL_CLK_ESAI_EXTAL>; + assigned-clock-parents = <&clks IMX6QDL_CLK_PLL4_AUDIO_DIV>; + assigned-clock-rates = <0>, <24576000>; + status = "okay"; +}; + +&fec { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet>; + phy-mode = "rgmii"; + interrupts-extended = <&gpio1 6 IRQ_TYPE_LEVEL_HIGH>, + <&intc 0 119 IRQ_TYPE_LEVEL_HIGH>; + fsl,err006687-workaround-present; + status = "okay"; +}; + +&gpmi { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpmi_nand>; + status = "okay"; +}; + +&hdmi { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hdmi_cec>; + ddc-i2c-bus = <&i2c2>; + status = "okay"; +}; + +&i2c2 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; + + pmic: pfuze100@8 { + compatible = "fsl,pfuze100"; + reg = <0x08>; + + regulators { + sw1a_reg: sw1ab { + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw1c_reg: sw1c { + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw2_reg: sw2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + sw3a_reg: sw3a { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1975000>; + regulator-boot-on; + regulator-always-on; + }; + + sw3b_reg: sw3b { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1975000>; + regulator-boot-on; + regulator-always-on; + }; + + sw4_reg: sw4 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + }; + + swbst_reg: swbst { + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5150000>; + }; + + snvs_reg: vsnvs { + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3000000>; + regulator-boot-on; + regulator-always-on; + }; + + vref_reg: vrefddr { + regulator-boot-on; + regulator-always-on; + }; + + vgen1_reg: vgen1 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + }; + + vgen2_reg: vgen2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + }; + + vgen3_reg: vgen3 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + }; + + vgen4_reg: vgen4 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen5_reg: vgen5 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen6_reg: vgen6 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; + + codec: cs42888@48 { + compatible = "cirrus,cs42888"; + reg = <0x48>; + clocks = <&codec_osc>; + clock-names = "mclk"; + VA-supply = <®_audio>; + VD-supply = <®_audio>; + VLS-supply = <®_audio>; + VLC-supply = <®_audio>; + }; + + touchscreen@4 { + compatible = "eeti,egalax_ts"; + reg = <0x04>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_egalax_int>; + interrupt-parent = <&gpio2>; + interrupts = <28 IRQ_TYPE_EDGE_FALLING>; + wakeup-gpios = <&gpio2 28 GPIO_ACTIVE_HIGH>; + }; +}; + +&i2c3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "okay"; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + imx6qdl-sabreauto { + pinctrl_hog: hoggrp { + fsl,pins = < + MX6QDL_PAD_NANDF_CS2__GPIO6_IO15 0x80000000 + MX6QDL_PAD_SD2_DAT2__GPIO1_IO13 0x80000000 + MX6QDL_PAD_GPIO_18__SD3_VSELECT 0x17059 + >; + }; + + pinctrl_ecspi1: ecspi1grp { + fsl,pins = < + MX6QDL_PAD_EIM_D17__ECSPI1_MISO 0x100b1 + MX6QDL_PAD_EIM_D18__ECSPI1_MOSI 0x100b1 + MX6QDL_PAD_EIM_D16__ECSPI1_SCLK 0x100b1 + >; + }; + + pinctrl_ecspi1_cs: ecspi1cs { + fsl,pins = < + MX6QDL_PAD_EIM_D19__GPIO3_IO19 0x80000000 + >; + }; + + pinctrl_egalax_int: egalax-intgrp { + fsl,pins = < + MX6QDL_PAD_EIM_EB0__GPIO2_IO28 0xb0b1 + >; + }; + + pinctrl_enet: enetgrp { + fsl,pins = < + MX6QDL_PAD_KEY_COL1__ENET_MDIO 0x1b0b0 + MX6QDL_PAD_KEY_COL2__ENET_MDC 0x1b0b0 + MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x1b030 + MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x1b030 + MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x1b030 + MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x1b030 + MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x1b030 + MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x1b030 + MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x1b0b0 + MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x1b030 + MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x1b030 + MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x1b030 + MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x1b030 + MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x1b030 + MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x1b030 + MX6QDL_PAD_GPIO_6__ENET_IRQ 0x000b1 + >; + }; + + pinctrl_esai: esaigrp { + fsl,pins = < + MX6QDL_PAD_ENET_CRS_DV__ESAI_TX_CLK 0x1b030 + MX6QDL_PAD_ENET_RXD1__ESAI_TX_FS 0x1b030 + MX6QDL_PAD_ENET_TX_EN__ESAI_TX3_RX2 0x1b030 + MX6QDL_PAD_GPIO_5__ESAI_TX2_RX3 0x1b030 + MX6QDL_PAD_ENET_TXD0__ESAI_TX4_RX1 0x1b030 + MX6QDL_PAD_ENET_MDC__ESAI_TX5_RX0 0x1b030 + MX6QDL_PAD_GPIO_17__ESAI_TX0 0x1b030 + MX6QDL_PAD_NANDF_CS3__ESAI_TX1 0x1b030 + MX6QDL_PAD_ENET_MDIO__ESAI_RX_CLK 0x1b030 + MX6QDL_PAD_GPIO_9__ESAI_RX_FS 0x1b030 + >; + }; + + pinctrl_gpio_keys: gpiokeysgrp { + fsl,pins = < + MX6QDL_PAD_SD2_CMD__GPIO1_IO11 0x1b0b0 + MX6QDL_PAD_SD2_DAT3__GPIO1_IO12 0x1b0b0 + MX6QDL_PAD_SD4_DAT4__GPIO2_IO12 0x1b0b0 + MX6QDL_PAD_SD4_DAT7__GPIO2_IO15 0x1b0b0 + MX6QDL_PAD_DISP0_DAT20__GPIO5_IO14 0x1b0b0 + >; + }; + + pinctrl_gpio_leds: gpioledsgrp { + fsl,pins = < + MX6QDL_PAD_DISP0_DAT21__GPIO5_IO15 0x80000000 + >; + }; + + pinctrl_gpmi_nand: gpminandgrp { + fsl,pins = < + MX6QDL_PAD_NANDF_CLE__NAND_CLE 0xb0b1 + MX6QDL_PAD_NANDF_ALE__NAND_ALE 0xb0b1 + MX6QDL_PAD_NANDF_WP_B__NAND_WP_B 0xb0b1 + MX6QDL_PAD_NANDF_RB0__NAND_READY_B 0xb000 + MX6QDL_PAD_NANDF_CS0__NAND_CE0_B 0xb0b1 + MX6QDL_PAD_NANDF_CS1__NAND_CE1_B 0xb0b1 + MX6QDL_PAD_SD4_CMD__NAND_RE_B 0xb0b1 + MX6QDL_PAD_SD4_CLK__NAND_WE_B 0xb0b1 + MX6QDL_PAD_NANDF_D0__NAND_DATA00 0xb0b1 + MX6QDL_PAD_NANDF_D1__NAND_DATA01 0xb0b1 + MX6QDL_PAD_NANDF_D2__NAND_DATA02 0xb0b1 + MX6QDL_PAD_NANDF_D3__NAND_DATA03 0xb0b1 + MX6QDL_PAD_NANDF_D4__NAND_DATA04 0xb0b1 + MX6QDL_PAD_NANDF_D5__NAND_DATA05 0xb0b1 + MX6QDL_PAD_NANDF_D6__NAND_DATA06 0xb0b1 + MX6QDL_PAD_NANDF_D7__NAND_DATA07 0xb0b1 + MX6QDL_PAD_SD4_DAT0__NAND_DQS 0x00b1 + >; + }; + + pinctrl_hdmi_cec: hdmicecgrp { + fsl,pins = < + MX6QDL_PAD_EIM_A25__HDMI_TX_CEC_LINE 0x1f8b0 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX6QDL_PAD_EIM_EB2__I2C2_SCL 0x4001b8b1 + MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX6QDL_PAD_GPIO_3__I2C3_SCL 0x4001b8b1 + MX6QDL_PAD_EIM_D18__I2C3_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c3mux: i2c3muxgrp { + fsl,pins = < + MX6QDL_PAD_EIM_A24__GPIO5_IO04 0x0b0b1 + >; + }; + + pinctrl_ipu1_csi0: ipu1csi0grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT12__IPU1_CSI0_DATA12 0x1b0b0 + MX6QDL_PAD_CSI0_DAT13__IPU1_CSI0_DATA13 0x1b0b0 + MX6QDL_PAD_CSI0_DAT14__IPU1_CSI0_DATA14 0x1b0b0 + MX6QDL_PAD_CSI0_DAT15__IPU1_CSI0_DATA15 0x1b0b0 + MX6QDL_PAD_CSI0_DAT16__IPU1_CSI0_DATA16 0x1b0b0 + MX6QDL_PAD_CSI0_DAT17__IPU1_CSI0_DATA17 0x1b0b0 + MX6QDL_PAD_CSI0_DAT18__IPU1_CSI0_DATA18 0x1b0b0 + MX6QDL_PAD_CSI0_DAT19__IPU1_CSI0_DATA19 0x1b0b0 + MX6QDL_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK 0x1b0b0 + MX6QDL_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC 0x1b0b0 + MX6QDL_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC 0x1b0b0 + >; + }; + + pinctrl_max7310: max7310grp { + fsl,pins = < + MX6QDL_PAD_SD2_DAT0__GPIO1_IO15 0x1b0b0 + >; + }; + + pinctrl_pwm3: pwm1grp { + fsl,pins = < + MX6QDL_PAD_SD4_DAT1__PWM3_OUT 0x1b0b1 + >; + }; + + pinctrl_gpt_input_capture0: gptinputcapture0grp { + fsl,pins = < + MX6QDL_PAD_SD1_DAT0__GPT_CAPTURE1 0x1b0b0 + >; + }; + + pinctrl_gpt_input_capture1: gptinputcapture1grp { + fsl,pins = < + MX6QDL_PAD_SD1_DAT1__GPT_CAPTURE2 0x1b0b0 + >; + }; + + pinctrl_spdif: spdifgrp { + fsl,pins = < + MX6QDL_PAD_KEY_COL3__SPDIF_IN 0x1b0b0 + >; + }; + + pinctrl_uart4: uart4grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL0__UART4_TX_DATA 0x1b0b1 + MX6QDL_PAD_KEY_ROW0__UART4_RX_DATA 0x1b0b1 + >; + }; + + pinctrl_usbotg: usbotggrp { + fsl,pins = < + MX6QDL_PAD_ENET_RX_ER__USB_OTG_ID 0x17059 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX6QDL_PAD_SD3_CMD__SD3_CMD 0x17059 + MX6QDL_PAD_SD3_CLK__SD3_CLK 0x10059 + MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x17059 + MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x17059 + MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x17059 + MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x17059 + MX6QDL_PAD_SD3_DAT4__SD3_DATA4 0x17059 + MX6QDL_PAD_SD3_DAT5__SD3_DATA5 0x17059 + MX6QDL_PAD_SD3_DAT6__SD3_DATA6 0x17059 + MX6QDL_PAD_SD3_DAT7__SD3_DATA7 0x17059 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3grp100mhz { + fsl,pins = < + MX6QDL_PAD_SD3_CMD__SD3_CMD 0x170b9 + MX6QDL_PAD_SD3_CLK__SD3_CLK 0x100b9 + MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x170b9 + MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x170b9 + MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x170b9 + MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x170b9 + MX6QDL_PAD_SD3_DAT4__SD3_DATA4 0x170b9 + MX6QDL_PAD_SD3_DAT5__SD3_DATA5 0x170b9 + MX6QDL_PAD_SD3_DAT6__SD3_DATA6 0x170b9 + MX6QDL_PAD_SD3_DAT7__SD3_DATA7 0x170b9 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3grp200mhz { + fsl,pins = < + MX6QDL_PAD_SD3_CMD__SD3_CMD 0x170f9 + MX6QDL_PAD_SD3_CLK__SD3_CLK 0x100f9 + MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x170f9 + MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x170f9 + MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x170f9 + MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x170f9 + MX6QDL_PAD_SD3_DAT4__SD3_DATA4 0x170f9 + MX6QDL_PAD_SD3_DAT5__SD3_DATA5 0x170f9 + MX6QDL_PAD_SD3_DAT6__SD3_DATA6 0x170f9 + MX6QDL_PAD_SD3_DAT7__SD3_DATA7 0x170f9 + >; + }; + + pinctrl_weim_cs0: weimcs0grp { + fsl,pins = < + MX6QDL_PAD_EIM_CS0__EIM_CS0_B 0xb0b1 + >; + }; + + pinctrl_weim_nor: weimnorgrp { + fsl,pins = < + MX6QDL_PAD_EIM_OE__EIM_OE_B 0xb0b1 + MX6QDL_PAD_EIM_RW__EIM_RW 0xb0b1 + MX6QDL_PAD_EIM_WAIT__EIM_WAIT_B 0xb060 + MX6QDL_PAD_EIM_D16__EIM_DATA16 0x1b0b0 + MX6QDL_PAD_EIM_D17__EIM_DATA17 0x1b0b0 + MX6QDL_PAD_EIM_D18__EIM_DATA18 0x1b0b0 + MX6QDL_PAD_EIM_D19__EIM_DATA19 0x1b0b0 + MX6QDL_PAD_EIM_D20__EIM_DATA20 0x1b0b0 + MX6QDL_PAD_EIM_D21__EIM_DATA21 0x1b0b0 + MX6QDL_PAD_EIM_D22__EIM_DATA22 0x1b0b0 + MX6QDL_PAD_EIM_D23__EIM_DATA23 0x1b0b0 + MX6QDL_PAD_EIM_D24__EIM_DATA24 0x1b0b0 + MX6QDL_PAD_EIM_D25__EIM_DATA25 0x1b0b0 + MX6QDL_PAD_EIM_D26__EIM_DATA26 0x1b0b0 + MX6QDL_PAD_EIM_D27__EIM_DATA27 0x1b0b0 + MX6QDL_PAD_EIM_D28__EIM_DATA28 0x1b0b0 + MX6QDL_PAD_EIM_D29__EIM_DATA29 0x1b0b0 + MX6QDL_PAD_EIM_D30__EIM_DATA30 0x1b0b0 + MX6QDL_PAD_EIM_D31__EIM_DATA31 0x1b0b0 + MX6QDL_PAD_EIM_A23__EIM_ADDR23 0xb0b1 + MX6QDL_PAD_EIM_A22__EIM_ADDR22 0xb0b1 + MX6QDL_PAD_EIM_A21__EIM_ADDR21 0xb0b1 + MX6QDL_PAD_EIM_A20__EIM_ADDR20 0xb0b1 + MX6QDL_PAD_EIM_A19__EIM_ADDR19 0xb0b1 + MX6QDL_PAD_EIM_A18__EIM_ADDR18 0xb0b1 + MX6QDL_PAD_EIM_A17__EIM_ADDR17 0xb0b1 + MX6QDL_PAD_EIM_A16__EIM_ADDR16 0xb0b1 + MX6QDL_PAD_EIM_DA15__EIM_AD15 0xb0b1 + MX6QDL_PAD_EIM_DA14__EIM_AD14 0xb0b1 + MX6QDL_PAD_EIM_DA13__EIM_AD13 0xb0b1 + MX6QDL_PAD_EIM_DA12__EIM_AD12 0xb0b1 + MX6QDL_PAD_EIM_DA11__EIM_AD11 0xb0b1 + MX6QDL_PAD_EIM_DA10__EIM_AD10 0xb0b1 + MX6QDL_PAD_EIM_DA9__EIM_AD09 0xb0b1 + MX6QDL_PAD_EIM_DA8__EIM_AD08 0xb0b1 + MX6QDL_PAD_EIM_DA7__EIM_AD07 0xb0b1 + MX6QDL_PAD_EIM_DA6__EIM_AD06 0xb0b1 + MX6QDL_PAD_EIM_DA5__EIM_AD05 0xb0b1 + MX6QDL_PAD_EIM_DA4__EIM_AD04 0xb0b1 + MX6QDL_PAD_EIM_DA3__EIM_AD03 0xb0b1 + MX6QDL_PAD_EIM_DA2__EIM_AD02 0xb0b1 + MX6QDL_PAD_EIM_DA1__EIM_AD01 0xb0b1 + MX6QDL_PAD_EIM_DA0__EIM_AD00 0xb0b1 + >; + }; + }; +}; + +&ldb { + status = "okay"; + + lvds-channel@0 { + fsl,data-mapping = "spwg"; + fsl,data-width = <18>; + status = "okay"; + + display-timings { + native-mode = <&timing0>; + timing0: hsd100pxn1 { + clock-frequency = <65000000>; + hactive = <1024>; + vactive = <768>; + hback-porch = <220>; + hfront-porch = <40>; + vback-porch = <21>; + vfront-porch = <7>; + hsync-len = <60>; + vsync-len = <10>; + }; + }; + }; +}; + +&pwm3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm3>; + status = "okay"; +}; + +&spdif { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_spdif>; + status = "okay"; +}; + +&uart4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart4>; + status = "okay"; +}; + +&usbh1 { + vbus-supply = <®_usb_h1_vbus>; + status = "okay"; +}; + +&usbotg { + vbus-supply = <®_usb_otg_vbus>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbotg>; + status = "okay"; +}; + +&usdhc3 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>; + cd-gpios = <&gpio6 15 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio1 13 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&weim { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_weim_nor &pinctrl_weim_cs0>; + ranges = <0 0 0x08000000 0x08000000>; + status = "disabled"; /* pin conflict with SPI NOR */ + + nor@0,0 { + compatible = "cfi-flash"; + reg = <0 0 0x02000000>; + #address-cells = <1>; + #size-cells = <1>; + bank-width = <2>; + fsl,weim-cs-timing = <0x00620081 0x00000001 0x1c022000 + 0x0000c000 0x1404a38e 0x00000000>; + }; +}; diff --git a/arch/arm/dts/imx6qdl-sabresd.dtsi b/arch/arm/dts/imx6qdl-sabresd.dtsi new file mode 100644 index 0000000..2cd5a9f --- /dev/null +++ b/arch/arm/dts/imx6qdl-sabresd.dtsi @@ -0,0 +1,741 @@ +// SPDX-License-Identifier: GPL-2.0+ +// +// Copyright 2012 Freescale Semiconductor, Inc. +// Copyright 2011 Linaro Ltd. + +#include <dt-bindings/clock/imx6qdl-clock.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> + +/ { + aliases { + mmc1 = &usdhc3; + }; + + chosen { + stdout-path = &uart1; + }; + + memory@10000000 { + reg = <0x10000000 0x40000000>; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + reg_usb_otg_vbus: regulator@0 { + compatible = "regulator-fixed"; + reg = <0>; + regulator-name = "usb_otg_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio3 22 0>; + enable-active-high; + vin-supply = <&swbst_reg>; + }; + + reg_usb_h1_vbus: regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "usb_h1_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio1 29 0>; + enable-active-high; + vin-supply = <&swbst_reg>; + }; + + reg_audio: regulator@2 { + compatible = "regulator-fixed"; + reg = <2>; + regulator-name = "wm8962-supply"; + gpio = <&gpio4 10 0>; + enable-active-high; + }; + + reg_pcie: regulator@3 { + compatible = "regulator-fixed"; + reg = <3>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pcie_reg>; + regulator-name = "MPCIE_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio3 19 0>; + enable-active-high; + }; + }; + + gpio-keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_keys>; + + power { + label = "Power Button"; + gpios = <&gpio3 29 GPIO_ACTIVE_LOW>; + wakeup-source; + linux,code = <KEY_POWER>; + }; + + volume-up { + label = "Volume Up"; + gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; + wakeup-source; + linux,code = <KEY_VOLUMEUP>; + }; + + volume-down { + label = "Volume Down"; + gpios = <&gpio1 5 GPIO_ACTIVE_LOW>; + wakeup-source; + linux,code = <KEY_VOLUMEDOWN>; + }; + }; + + sound { + compatible = "fsl,imx6q-sabresd-wm8962", + "fsl,imx-audio-wm8962"; + model = "wm8962-audio"; + ssi-controller = <&ssi2>; + audio-codec = <&codec>; + audio-routing = + "Headphone Jack", "HPOUTL", + "Headphone Jack", "HPOUTR", + "Ext Spk", "SPKOUTL", + "Ext Spk", "SPKOUTR", + "AMIC", "MICBIAS", + "IN3R", "AMIC"; + mux-int-port = <2>; + mux-ext-port = <3>; + }; + + backlight_lvds: backlight-lvds { + compatible = "pwm-backlight"; + pwms = <&pwm1 0 5000000>; + brightness-levels = <0 4 8 16 32 64 128 255>; + default-brightness-level = <7>; + status = "okay"; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_leds>; + + red { + gpios = <&gpio1 2 0>; + default-state = "on"; + }; + }; + + panel { + compatible = "hannstar,hsd100pxn1"; + backlight = <&backlight_lvds>; + + port { + panel_in: endpoint { + remote-endpoint = <&lvds0_out>; + }; + }; + }; +}; + +&ipu1_csi0_from_ipu1_csi0_mux { + bus-width = <8>; + data-shift = <12>; /* Lines 19:12 used */ + hsync-active = <1>; + vsync-active = <1>; +}; + +&ipu1_csi0_mux_from_parallel_sensor { + remote-endpoint = <&ov5642_to_ipu1_csi0_mux>; +}; + +&ipu1_csi0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ipu1_csi0>; +}; + +&mipi_csi { + status = "okay"; + + port@0 { + reg = <0>; + + mipi_csi2_in: endpoint { + remote-endpoint = <&ov5640_to_mipi_csi2>; + clock-lanes = <0>; + data-lanes = <1 2>; + }; + }; +}; + +&audmux { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_audmux>; + status = "okay"; +}; + +&clks { + assigned-clocks = <&clks IMX6QDL_CLK_LDB_DI0_SEL>, + <&clks IMX6QDL_CLK_LDB_DI1_SEL>; + assigned-clock-parents = <&clks IMX6QDL_CLK_PLL3_USB_OTG>, + <&clks IMX6QDL_CLK_PLL3_USB_OTG>; +}; + +&ecspi1 { + cs-gpios = <&gpio4 9 0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi1>; + status = "okay"; + + flash: m25p80@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "st,m25p32", "jedec,spi-nor"; + spi-max-frequency = <20000000>; + reg = <0>; + }; +}; + +&fec { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet>; + phy-mode = "rgmii"; + phy-reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&hdmi { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hdmi_cec>; + ddc-i2c-bus = <&i2c2>; + status = "okay"; +}; + +&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + codec: wm8962@1a { + compatible = "wlf,wm8962"; + reg = <0x1a>; + clocks = <&clks IMX6QDL_CLK_CKO>; + DCVDD-supply = <®_audio>; + DBVDD-supply = <®_audio>; + AVDD-supply = <®_audio>; + CPVDD-supply = <®_audio>; + MICVDD-supply = <®_audio>; + PLLVDD-supply = <®_audio>; + SPKVDD1-supply = <®_audio>; + SPKVDD2-supply = <®_audio>; + gpio-cfg = < + 0x0000 /* 0:Default */ + 0x0000 /* 1:Default */ + 0x0013 /* 2:FN_DMICCLK */ + 0x0000 /* 3:Default */ + 0x8014 /* 4:FN_DMICCDAT */ + 0x0000 /* 5:Default */ + >; + }; + + ov5642: camera@3c { + compatible = "ovti,ov5642"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ov5642>; + clocks = <&clks IMX6QDL_CLK_CKO>; + clock-names = "xclk"; + reg = <0x3c>; + DOVDD-supply = <&vgen4_reg>; /* 1.8v */ + AVDD-supply = <&vgen3_reg>; /* 2.8v, rev C board is VGEN3 + rev B board is VGEN5 */ + DVDD-supply = <&vgen2_reg>; /* 1.5v*/ + powerdown-gpios = <&gpio1 16 GPIO_ACTIVE_HIGH>; + reset-gpios = <&gpio1 17 GPIO_ACTIVE_LOW>; + status = "disabled"; + + port { + ov5642_to_ipu1_csi0_mux: endpoint { + remote-endpoint = <&ipu1_csi0_mux_from_parallel_sensor>; + bus-width = <8>; + hsync-active = <1>; + vsync-active = <1>; + }; + }; + }; +}; + +&i2c2 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; + + ov5640: camera@3c { + compatible = "ovti,ov5640"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ov5640>; + reg = <0x3c>; + clocks = <&clks IMX6QDL_CLK_CKO>; + clock-names = "xclk"; + DOVDD-supply = <&vgen4_reg>; /* 1.8v */ + AVDD-supply = <&vgen3_reg>; /* 2.8v, rev C board is VGEN3 + rev B board is VGEN5 */ + DVDD-supply = <&vgen2_reg>; /* 1.5v*/ + powerdown-gpios = <&gpio1 19 GPIO_ACTIVE_HIGH>; + reset-gpios = <&gpio1 20 GPIO_ACTIVE_LOW>; + + port { + ov5640_to_mipi_csi2: endpoint { + remote-endpoint = <&mipi_csi2_in>; + clock-lanes = <0>; + data-lanes = <1 2>; + }; + }; + }; + + pmic: pfuze100@8 { + compatible = "fsl,pfuze100"; + reg = <0x08>; + + regulators { + sw1a_reg: sw1ab { + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw1c_reg: sw1c { + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw2_reg: sw2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw3a_reg: sw3a { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1975000>; + regulator-boot-on; + regulator-always-on; + }; + + sw3b_reg: sw3b { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1975000>; + regulator-boot-on; + regulator-always-on; + }; + + sw4_reg: sw4 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + swbst_reg: swbst { + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5150000>; + }; + + snvs_reg: vsnvs { + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3000000>; + regulator-boot-on; + regulator-always-on; + }; + + vref_reg: vrefddr { + regulator-boot-on; + regulator-always-on; + }; + + vgen1_reg: vgen1 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + }; + + vgen2_reg: vgen2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + }; + + vgen3_reg: vgen3 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + }; + + vgen4_reg: vgen4 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen5_reg: vgen5 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen6_reg: vgen6 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; +}; + +&i2c3 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "okay"; + + egalax_ts@4 { + compatible = "eeti,egalax_ts"; + reg = <0x04>; + interrupt-parent = <&gpio6>; + interrupts = <7 2>; + wakeup-gpios = <&gpio6 7 0>; + }; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + imx6qdl-sabresd { + pinctrl_hog: hoggrp { + fsl,pins = < + MX6QDL_PAD_NANDF_D0__GPIO2_IO00 0x1b0b0 + MX6QDL_PAD_NANDF_D1__GPIO2_IO01 0x1b0b0 + MX6QDL_PAD_NANDF_D2__GPIO2_IO02 0x1b0b0 + MX6QDL_PAD_NANDF_D3__GPIO2_IO03 0x1b0b0 + MX6QDL_PAD_GPIO_0__CCM_CLKO1 0x130b0 + MX6QDL_PAD_NANDF_CLE__GPIO6_IO07 0x1b0b0 + MX6QDL_PAD_ENET_TXD1__GPIO1_IO29 0x1b0b0 + MX6QDL_PAD_EIM_D22__GPIO3_IO22 0x1b0b0 + MX6QDL_PAD_ENET_CRS_DV__GPIO1_IO25 0x1b0b0 + >; + }; + + pinctrl_audmux: audmuxgrp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT7__AUD3_RXD 0x130b0 + MX6QDL_PAD_CSI0_DAT4__AUD3_TXC 0x130b0 + MX6QDL_PAD_CSI0_DAT5__AUD3_TXD 0x110b0 + MX6QDL_PAD_CSI0_DAT6__AUD3_TXFS 0x130b0 + >; + }; + + pinctrl_ecspi1: ecspi1grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL1__ECSPI1_MISO 0x100b1 + MX6QDL_PAD_KEY_ROW0__ECSPI1_MOSI 0x100b1 + MX6QDL_PAD_KEY_COL0__ECSPI1_SCLK 0x100b1 + MX6QDL_PAD_KEY_ROW1__GPIO4_IO09 0x1b0b0 + >; + }; + + pinctrl_enet: enetgrp { + fsl,pins = < + MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1b0b0 + MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1b0b0 + MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x1b030 + MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x1b030 + MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x1b030 + MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x1b030 + MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x1b030 + MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x1b030 + MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x1b0b0 + MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x1b030 + MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x1b030 + MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x1b030 + MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x1b030 + MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x1b030 + MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x1b030 + MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x4001b0a8 + >; + }; + + pinctrl_gpio_keys: gpio_keysgrp { + fsl,pins = < + MX6QDL_PAD_EIM_D29__GPIO3_IO29 0x1b0b0 + MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x1b0b0 + MX6QDL_PAD_GPIO_5__GPIO1_IO05 0x1b0b0 + >; + }; + + pinctrl_hdmi_cec: hdmicecgrp { + fsl,pins = < + MX6QDL_PAD_KEY_ROW2__HDMI_TX_CEC_LINE 0x1f8b0 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT8__I2C1_SDA 0x4001b8b1 + MX6QDL_PAD_CSI0_DAT9__I2C1_SCL 0x4001b8b1 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x4001b8b1 + MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX6QDL_PAD_GPIO_3__I2C3_SCL 0x4001b8b1 + MX6QDL_PAD_GPIO_6__I2C3_SDA 0x4001b8b1 + >; + }; + + pinctrl_ipu1_csi0: ipu1csi0grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT12__IPU1_CSI0_DATA12 0x1b0b0 + MX6QDL_PAD_CSI0_DAT13__IPU1_CSI0_DATA13 0x1b0b0 + MX6QDL_PAD_CSI0_DAT14__IPU1_CSI0_DATA14 0x1b0b0 + MX6QDL_PAD_CSI0_DAT15__IPU1_CSI0_DATA15 0x1b0b0 + MX6QDL_PAD_CSI0_DAT16__IPU1_CSI0_DATA16 0x1b0b0 + MX6QDL_PAD_CSI0_DAT17__IPU1_CSI0_DATA17 0x1b0b0 + MX6QDL_PAD_CSI0_DAT18__IPU1_CSI0_DATA18 0x1b0b0 + MX6QDL_PAD_CSI0_DAT19__IPU1_CSI0_DATA19 0x1b0b0 + MX6QDL_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK 0x1b0b0 + MX6QDL_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC 0x1b0b0 + MX6QDL_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC 0x1b0b0 + >; + }; + + pinctrl_ov5640: ov5640grp { + fsl,pins = < + MX6QDL_PAD_SD1_DAT2__GPIO1_IO19 0x1b0b0 + MX6QDL_PAD_SD1_CLK__GPIO1_IO20 0x1b0b0 + >; + }; + + pinctrl_ov5642: ov5642grp { + fsl,pins = < + MX6QDL_PAD_SD1_DAT0__GPIO1_IO16 0x1b0b0 + MX6QDL_PAD_SD1_DAT1__GPIO1_IO17 0x1b0b0 + >; + }; + + pinctrl_pcie: pciegrp { + fsl,pins = < + MX6QDL_PAD_GPIO_17__GPIO7_IO12 0x1b0b0 + >; + }; + + pinctrl_pcie_reg: pciereggrp { + fsl,pins = < + MX6QDL_PAD_EIM_D19__GPIO3_IO19 0x1b0b0 + >; + }; + + pinctrl_pwm1: pwm1grp { + fsl,pins = < + MX6QDL_PAD_SD1_DAT3__PWM1_OUT 0x1b0b1 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT10__UART1_TX_DATA 0x1b0b1 + MX6QDL_PAD_CSI0_DAT11__UART1_RX_DATA 0x1b0b1 + >; + }; + + pinctrl_usbotg: usbotggrp { + fsl,pins = < + MX6QDL_PAD_ENET_RX_ER__USB_OTG_ID 0x17059 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x17059 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x10059 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x17059 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x17059 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x17059 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x17059 + MX6QDL_PAD_NANDF_D4__SD2_DATA4 0x17059 + MX6QDL_PAD_NANDF_D5__SD2_DATA5 0x17059 + MX6QDL_PAD_NANDF_D6__SD2_DATA6 0x17059 + MX6QDL_PAD_NANDF_D7__SD2_DATA7 0x17059 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX6QDL_PAD_SD3_CMD__SD3_CMD 0x17059 + MX6QDL_PAD_SD3_CLK__SD3_CLK 0x10059 + MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x17059 + MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x17059 + MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x17059 + MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x17059 + MX6QDL_PAD_SD3_DAT4__SD3_DATA4 0x17059 + MX6QDL_PAD_SD3_DAT5__SD3_DATA5 0x17059 + MX6QDL_PAD_SD3_DAT6__SD3_DATA6 0x17059 + MX6QDL_PAD_SD3_DAT7__SD3_DATA7 0x17059 + >; + }; + + pinctrl_usdhc4: usdhc4grp { + fsl,pins = < + MX6QDL_PAD_SD4_CMD__SD4_CMD 0x17059 + MX6QDL_PAD_SD4_CLK__SD4_CLK 0x10059 + MX6QDL_PAD_SD4_DAT0__SD4_DATA0 0x17059 + MX6QDL_PAD_SD4_DAT1__SD4_DATA1 0x17059 + MX6QDL_PAD_SD4_DAT2__SD4_DATA2 0x17059 + MX6QDL_PAD_SD4_DAT3__SD4_DATA3 0x17059 + MX6QDL_PAD_SD4_DAT4__SD4_DATA4 0x17059 + MX6QDL_PAD_SD4_DAT5__SD4_DATA5 0x17059 + MX6QDL_PAD_SD4_DAT6__SD4_DATA6 0x17059 + MX6QDL_PAD_SD4_DAT7__SD4_DATA7 0x17059 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX6QDL_PAD_GPIO_1__WDOG2_B 0x1b0b0 + >; + }; + }; + + gpio_leds { + pinctrl_gpio_leds: gpioledsgrp { + fsl,pins = < + MX6QDL_PAD_GPIO_2__GPIO1_IO02 0x1b0b0 + >; + }; + }; +}; + +&ldb { + status = "okay"; + + lvds-channel@1 { + fsl,data-mapping = "spwg"; + fsl,data-width = <18>; + status = "okay"; + + port@4 { + reg = <4>; + + lvds0_out: endpoint { + remote-endpoint = <&panel_in>; + }; + }; + }; +}; + +&pcie { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pcie>; + reset-gpio = <&gpio7 12 GPIO_ACTIVE_LOW>; + vpcie-supply = <®_pcie>; + status = "okay"; +}; + +&pwm1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm1>; + status = "okay"; +}; + +®_arm { + vin-supply = <&sw1a_reg>; +}; + +®_pu { + vin-supply = <&sw1c_reg>; +}; + +®_soc { + vin-supply = <&sw1c_reg>; +}; + +&snvs_poweroff { + status = "okay"; +}; + +&ssi2 { + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; +}; + +&usbh1 { + vbus-supply = <®_usb_h1_vbus>; + status = "okay"; +}; + +&usbotg { + vbus-supply = <®_usb_otg_vbus>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbotg>; + disable-over-current; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc2>; + bus-width = <8>; + cd-gpios = <&gpio2 2 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio2 3 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&usdhc3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc3>; + bus-width = <8>; + cd-gpios = <&gpio2 0 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio2 1 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&usdhc4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc4>; + bus-width = <8>; + non-removable; + no-1-8-v; + status = "okay"; +}; + +&wdog1 { + status = "disabled"; +}; + +&wdog2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; diff --git a/arch/arm/dts/imx6qdl.dtsi b/arch/arm/dts/imx6qdl.dtsi index b13b0b2..e4daf15 100644 --- a/arch/arm/dts/imx6qdl.dtsi +++ b/arch/arm/dts/imx6qdl.dtsi @@ -1,21 +1,23 @@ -/* - * Copyright 2011 Freescale Semiconductor, Inc. - * Copyright 2011 Linaro Ltd. - * - * The code contained herein is licensed under the GNU General Public - * License. You may obtain a copy of the GNU General Public License - * Version 2 or later at the following locations: - * - * http://www.opensource.org/licenses/gpl-license.html - * http://www.gnu.org/copyleft/gpl.html - */ +// SPDX-License-Identifier: GPL-2.0+ +// +// Copyright 2011 Freescale Semiconductor, Inc. +// Copyright 2011 Linaro Ltd.
#include <dt-bindings/clock/imx6qdl-clock.h> #include <dt-bindings/interrupt-controller/arm-gic.h>
-#include "skeleton.dtsi" - / { + #address-cells = <1>; + #size-cells = <1>; + /* + * The decompressor and also some bootloaders rely on a + * pre-existing /chosen node to be available to insert the + * command line and merge other ATAGS info. + * Also for U-Boot there must be a pre-existing /memory node. + */ + chosen {}; + memory { device_type = "memory"; }; + aliases { ethernet0 = &fec; can0 = &can1; @@ -49,9 +51,6 @@ };
clocks { - #address-cells = <1>; - #size-cells = <0>; - ckil { compatible = "fsl,imx-ckil", "fixed-clock"; #clock-cells = <0>; @@ -71,6 +70,75 @@ }; };
+ tempmon: tempmon { + compatible = "fsl,imx6q-tempmon"; + interrupt-parent = <&gpc>; + interrupts = <0 49 IRQ_TYPE_LEVEL_HIGH>; + fsl,tempmon = <&anatop>; + fsl,tempmon-data = <&ocotp>; + clocks = <&clks IMX6QDL_CLK_PLL3_USB_OTG>; + }; + + ldb: ldb { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx6q-ldb", "fsl,imx53-ldb"; + gpr = <&gpr>; + status = "disabled"; + + lvds-channel@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + status = "disabled"; + + port@0 { + reg = <0>; + + lvds0_mux_0: endpoint { + remote-endpoint = <&ipu1_di0_lvds0>; + }; + }; + + port@1 { + reg = <1>; + + lvds0_mux_1: endpoint { + remote-endpoint = <&ipu1_di1_lvds0>; + }; + }; + }; + + lvds-channel@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + status = "disabled"; + + port@0 { + reg = <0>; + + lvds1_mux_0: endpoint { + remote-endpoint = <&ipu1_di0_lvds1>; + }; + }; + + port@1 { + reg = <1>; + + lvds1_mux_1: endpoint { + remote-endpoint = <&ipu1_di1_lvds1>; + }; + }; + }; + }; + + pmu: pmu { + compatible = "arm,cortex-a9-pmu"; + interrupt-parent = <&gpc>; + interrupts = <0 94 IRQ_TYPE_LEVEL_HIGH>; + }; + soc { #address-cells = <1>; #size-cells = <1>; @@ -78,7 +146,7 @@ interrupt-parent = <&gpc>; ranges;
- dma_apbh: dma-apbh@00110000 { + dma_apbh: dma-apbh@110000 { compatible = "fsl,imx6q-dma-apbh", "fsl,imx28-dma-apbh"; reg = <0x00110000 0x2000>; interrupts = <0 13 IRQ_TYPE_LEVEL_HIGH>, @@ -91,7 +159,7 @@ clocks = <&clks IMX6QDL_CLK_APBH_DMA>; };
- gpmi: gpmi-nand@00112000 { + gpmi: gpmi-nand@112000 { compatible = "fsl,imx6q-gpmi-nand"; #address-cells = <1>; #size-cells = <1>; @@ -111,7 +179,7 @@ status = "disabled"; };
- hdmi: hdmi@0120000 { + hdmi: hdmi@120000 { #address-cells = <1>; #size-cells = <0>; reg = <0x00120000 0x9000>; @@ -139,7 +207,7 @@ }; };
- gpu_3d: gpu@00130000 { + gpu_3d: gpu@130000 { compatible = "vivante,gc"; reg = <0x00130000 0x4000>; interrupts = <0 9 IRQ_TYPE_LEVEL_HIGH>; @@ -147,20 +215,20 @@ <&clks IMX6QDL_CLK_GPU3D_CORE>, <&clks IMX6QDL_CLK_GPU3D_SHADER>; clock-names = "bus", "core", "shader"; - power-domains = <&gpc 1>; + power-domains = <&pd_pu>; };
- gpu_2d: gpu@00134000 { + gpu_2d: gpu@134000 { compatible = "vivante,gc"; reg = <0x00134000 0x4000>; interrupts = <0 10 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6QDL_CLK_GPU2D_AXI>, <&clks IMX6QDL_CLK_GPU2D_CORE>; clock-names = "bus", "core"; - power-domains = <&gpc 1>; + power-domains = <&pd_pu>; };
- timer@00a00600 { + timer@a00600 { compatible = "arm,cortex-a9-twd-timer"; reg = <0x00a00600 0x20>; interrupts = <1 13 0xf01>; @@ -168,7 +236,7 @@ clocks = <&clks IMX6QDL_CLK_TWD>; };
- intc: interrupt-controller@00a01000 { + intc: interrupt-controller@a01000 { compatible = "arm,cortex-a9-gic"; #interrupt-cells = <3>; interrupt-controller; @@ -177,7 +245,7 @@ interrupt-parent = <&intc>; };
- L2: l2-cache@00a02000 { + L2: l2-cache@a02000 { compatible = "arm,pl310-cache"; reg = <0x00a02000 0x1000>; interrupts = <0 92 IRQ_TYPE_LEVEL_HIGH>; @@ -188,7 +256,7 @@ arm,shared-override; };
- pcie: pcie@0x01000000 { + pcie: pcie@1ffc000 { compatible = "fsl,imx6q-pcie", "snps,dw-pcie"; reg = <0x01ffc000 0x04000>, <0x01f00000 0x80000>; @@ -196,6 +264,7 @@ #address-cells = <3>; #size-cells = <2>; device_type = "pci"; + bus-range = <0x00 0xff>; ranges = <0x81000000 0 0 0x01f80000 0 0x00010000 /* downstream I/O */ 0x82000000 0 0x01000000 0x01000000 0 0x00f00000>; /* non-prefetchable memory */ num-lanes = <1>; @@ -204,9 +273,9 @@ #interrupt-cells = <1>; interrupt-map-mask = <0 0 0 0x7>; interrupt-map = <0 0 0 1 &gpc GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <0 0 0 2 &gpc GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <0 0 0 3 &gpc GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <0 0 0 4 &gpc GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + <0 0 0 2 &gpc GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, + <0 0 0 3 &gpc GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, + <0 0 0 4 &gpc GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6QDL_CLK_PCIE_AXI>, <&clks IMX6QDL_CLK_LVDS1_GATE>, <&clks IMX6QDL_CLK_PCIE_REF_125M>; @@ -214,26 +283,21 @@ status = "disabled"; };
- pmu { - compatible = "arm,cortex-a9-pmu"; - interrupts = <0 94 IRQ_TYPE_LEVEL_HIGH>; - }; - - aips-bus@02000000 { /* AIPS1 */ + aips-bus@2000000 { /* AIPS1 */ compatible = "fsl,aips-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; reg = <0x02000000 0x100000>; ranges;
- spba-bus@02000000 { + spba-bus@2000000 { compatible = "fsl,spba-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; reg = <0x02000000 0x40000>; ranges;
- spdif: spdif@02004000 { + spdif: spdif@2004000 { compatible = "fsl,imx35-spdif"; reg = <0x02004000 0x4000>; interrupts = <0 52 IRQ_TYPE_LEVEL_HIGH>; @@ -253,7 +317,7 @@ status = "disabled"; };
- ecspi1: ecspi@02008000 { + ecspi1: spi@2008000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6q-ecspi", "fsl,imx51-ecspi"; @@ -267,7 +331,7 @@ status = "disabled"; };
- ecspi2: ecspi@0200c000 { + ecspi2: spi@200c000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6q-ecspi", "fsl,imx51-ecspi"; @@ -281,7 +345,7 @@ status = "disabled"; };
- ecspi3: ecspi@02010000 { + ecspi3: spi@2010000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6q-ecspi", "fsl,imx51-ecspi"; @@ -295,7 +359,7 @@ status = "disabled"; };
- ecspi4: ecspi@02014000 { + ecspi4: spi@2014000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6q-ecspi", "fsl,imx51-ecspi"; @@ -309,7 +373,7 @@ status = "disabled"; };
- uart1: serial@02020000 { + uart1: serial@2020000 { compatible = "fsl,imx6q-uart", "fsl,imx21-uart"; reg = <0x02020000 0x4000>; interrupts = <0 26 IRQ_TYPE_LEVEL_HIGH>; @@ -321,7 +385,7 @@ status = "disabled"; };
- esai: esai@02024000 { + esai: esai@2024000 { #sound-dai-cells = <0>; compatible = "fsl,imx35-esai"; reg = <0x02024000 0x4000>; @@ -337,7 +401,7 @@ status = "disabled"; };
- ssi1: ssi@02028000 { + ssi1: ssi@2028000 { #sound-dai-cells = <0>; compatible = "fsl,imx6q-ssi", "fsl,imx51-ssi"; @@ -353,7 +417,7 @@ status = "disabled"; };
- ssi2: ssi@0202c000 { + ssi2: ssi@202c000 { #sound-dai-cells = <0>; compatible = "fsl,imx6q-ssi", "fsl,imx51-ssi"; @@ -369,7 +433,7 @@ status = "disabled"; };
- ssi3: ssi@02030000 { + ssi3: ssi@2030000 { #sound-dai-cells = <0>; compatible = "fsl,imx6q-ssi", "fsl,imx51-ssi"; @@ -385,7 +449,7 @@ status = "disabled"; };
- asrc: asrc@02034000 { + asrc: asrc@2034000 { compatible = "fsl,imx53-asrc"; reg = <0x02034000 0x4000>; interrupts = <0 50 IRQ_TYPE_LEVEL_HIGH>; @@ -410,12 +474,12 @@ status = "okay"; };
- spba@0203c000 { + spba@203c000 { reg = <0x0203c000 0x4000>; }; };
- vpu: vpu@02040000 { + vpu: vpu@2040000 { compatible = "cnm,coda960"; reg = <0x02040000 0x3c000>; interrupts = <0 12 IRQ_TYPE_LEVEL_HIGH>, @@ -424,16 +488,16 @@ clocks = <&clks IMX6QDL_CLK_VPU_AXI>, <&clks IMX6QDL_CLK_MMDC_CH0_AXI>; clock-names = "per", "ahb"; - power-domains = <&gpc 1>; + power-domains = <&pd_pu>; resets = <&src 1>; iram = <&ocram>; };
- aipstz@0207c000 { /* AIPSTZ1 */ + aipstz@207c000 { /* AIPSTZ1 */ reg = <0x0207c000 0x4000>; };
- pwm1: pwm@02080000 { + pwm1: pwm@2080000 { #pwm-cells = <2>; compatible = "fsl,imx6q-pwm", "fsl,imx27-pwm"; reg = <0x02080000 0x4000>; @@ -444,7 +508,7 @@ status = "disabled"; };
- pwm2: pwm@02084000 { + pwm2: pwm@2084000 { #pwm-cells = <2>; compatible = "fsl,imx6q-pwm", "fsl,imx27-pwm"; reg = <0x02084000 0x4000>; @@ -455,7 +519,7 @@ status = "disabled"; };
- pwm3: pwm@02088000 { + pwm3: pwm@2088000 { #pwm-cells = <2>; compatible = "fsl,imx6q-pwm", "fsl,imx27-pwm"; reg = <0x02088000 0x4000>; @@ -466,7 +530,7 @@ status = "disabled"; };
- pwm4: pwm@0208c000 { + pwm4: pwm@208c000 { #pwm-cells = <2>; compatible = "fsl,imx6q-pwm", "fsl,imx27-pwm"; reg = <0x0208c000 0x4000>; @@ -477,7 +541,7 @@ status = "disabled"; };
- can1: flexcan@02090000 { + can1: flexcan@2090000 { compatible = "fsl,imx6q-flexcan"; reg = <0x02090000 0x4000>; interrupts = <0 110 IRQ_TYPE_LEVEL_HIGH>; @@ -487,7 +551,7 @@ status = "disabled"; };
- can2: flexcan@02094000 { + can2: flexcan@2094000 { compatible = "fsl,imx6q-flexcan"; reg = <0x02094000 0x4000>; interrupts = <0 111 IRQ_TYPE_LEVEL_HIGH>; @@ -497,7 +561,7 @@ status = "disabled"; };
- gpt: gpt@02098000 { + gpt: gpt@2098000 { compatible = "fsl,imx6q-gpt", "fsl,imx31-gpt"; reg = <0x02098000 0x4000>; interrupts = <0 55 IRQ_TYPE_LEVEL_HIGH>; @@ -507,7 +571,7 @@ clock-names = "ipg", "per", "osc_per"; };
- gpio1: gpio@0209c000 { + gpio1: gpio@209c000 { compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; reg = <0x0209c000 0x4000>; interrupts = <0 66 IRQ_TYPE_LEVEL_HIGH>, @@ -518,7 +582,7 @@ #interrupt-cells = <2>; };
- gpio2: gpio@020a0000 { + gpio2: gpio@20a0000 { compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; reg = <0x020a0000 0x4000>; interrupts = <0 68 IRQ_TYPE_LEVEL_HIGH>, @@ -529,7 +593,7 @@ #interrupt-cells = <2>; };
- gpio3: gpio@020a4000 { + gpio3: gpio@20a4000 { compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; reg = <0x020a4000 0x4000>; interrupts = <0 70 IRQ_TYPE_LEVEL_HIGH>, @@ -540,7 +604,7 @@ #interrupt-cells = <2>; };
- gpio4: gpio@020a8000 { + gpio4: gpio@20a8000 { compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; reg = <0x020a8000 0x4000>; interrupts = <0 72 IRQ_TYPE_LEVEL_HIGH>, @@ -551,7 +615,7 @@ #interrupt-cells = <2>; };
- gpio5: gpio@020ac000 { + gpio5: gpio@20ac000 { compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; reg = <0x020ac000 0x4000>; interrupts = <0 74 IRQ_TYPE_LEVEL_HIGH>, @@ -562,7 +626,7 @@ #interrupt-cells = <2>; };
- gpio6: gpio@020b0000 { + gpio6: gpio@20b0000 { compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; reg = <0x020b0000 0x4000>; interrupts = <0 76 IRQ_TYPE_LEVEL_HIGH>, @@ -573,7 +637,7 @@ #interrupt-cells = <2>; };
- gpio7: gpio@020b4000 { + gpio7: gpio@20b4000 { compatible = "fsl,imx6q-gpio", "fsl,imx35-gpio"; reg = <0x020b4000 0x4000>; interrupts = <0 78 IRQ_TYPE_LEVEL_HIGH>, @@ -584,7 +648,7 @@ #interrupt-cells = <2>; };
- kpp: kpp@020b8000 { + kpp: kpp@20b8000 { compatible = "fsl,imx6q-kpp", "fsl,imx21-kpp"; reg = <0x020b8000 0x4000>; interrupts = <0 82 IRQ_TYPE_LEVEL_HIGH>; @@ -592,14 +656,14 @@ status = "disabled"; };
- wdog1: wdog@020bc000 { + wdog1: wdog@20bc000 { compatible = "fsl,imx6q-wdt", "fsl,imx21-wdt"; reg = <0x020bc000 0x4000>; interrupts = <0 80 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6QDL_CLK_DUMMY>; };
- wdog2: wdog@020c0000 { + wdog2: wdog@20c0000 { compatible = "fsl,imx6q-wdt", "fsl,imx21-wdt"; reg = <0x020c0000 0x4000>; interrupts = <0 81 IRQ_TYPE_LEVEL_HIGH>; @@ -607,7 +671,7 @@ status = "disabled"; };
- clks: ccm@020c4000 { + clks: ccm@20c4000 { compatible = "fsl,imx6q-ccm"; reg = <0x020c4000 0x4000>; interrupts = <0 87 IRQ_TYPE_LEVEL_HIGH>, @@ -615,7 +679,7 @@ #clock-cells = <1>; };
- anatop: anatop@020c8000 { + anatop: anatop@20c8000 { compatible = "fsl,imx6q-anatop", "syscon", "simple-bus"; reg = <0x020c8000 0x1000>; interrupts = <0 49 IRQ_TYPE_LEVEL_HIGH>, @@ -625,8 +689,8 @@ regulator-1p1 { compatible = "fsl,anatop-regulator"; regulator-name = "vdd1p1"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1375000>; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1200000>; regulator-always-on; anatop-reg-offset = <0x110>; anatop-vol-bit-shift = <8>; @@ -634,6 +698,7 @@ anatop-min-bit-val = <4>; anatop-min-voltage = <800000>; anatop-max-voltage = <1375000>; + anatop-enable-bit = <0>; };
regulator-3p0 { @@ -648,20 +713,22 @@ anatop-min-bit-val = <0>; anatop-min-voltage = <2625000>; anatop-max-voltage = <3400000>; + anatop-enable-bit = <0>; };
regulator-2p5 { compatible = "fsl,anatop-regulator"; regulator-name = "vdd2p5"; - regulator-min-microvolt = <2000000>; + regulator-min-microvolt = <2250000>; regulator-max-microvolt = <2750000>; regulator-always-on; anatop-reg-offset = <0x130>; anatop-vol-bit-shift = <8>; anatop-vol-bit-width = <5>; anatop-min-bit-val = <0>; - anatop-min-voltage = <2000000>; - anatop-max-voltage = <2750000>; + anatop-min-voltage = <2100000>; + anatop-max-voltage = <2875000>; + anatop-enable-bit = <0>; };
reg_arm: regulator-vddcore { @@ -716,15 +783,7 @@ }; };
- tempmon: tempmon { - compatible = "fsl,imx6q-tempmon"; - interrupts = <0 49 IRQ_TYPE_LEVEL_HIGH>; - fsl,tempmon = <&anatop>; - fsl,tempmon-data = <&ocotp>; - clocks = <&clks IMX6QDL_CLK_PLL3_USB_OTG>; - }; - - usbphy1: usbphy@020c9000 { + usbphy1: usbphy@20c9000 { compatible = "fsl,imx6q-usbphy", "fsl,imx23-usbphy"; reg = <0x020c9000 0x1000>; interrupts = <0 44 IRQ_TYPE_LEVEL_HIGH>; @@ -732,7 +791,7 @@ fsl,anatop = <&anatop>; };
- usbphy2: usbphy@020ca000 { + usbphy2: usbphy@20ca000 { compatible = "fsl,imx6q-usbphy", "fsl,imx23-usbphy"; reg = <0x020ca000 0x1000>; interrupts = <0 45 IRQ_TYPE_LEVEL_HIGH>; @@ -740,7 +799,7 @@ fsl,anatop = <&anatop>; };
- snvs: snvs@020cc000 { + snvs: snvs@20cc000 { compatible = "fsl,sec-v4.0-mon", "syscon", "simple-mfd"; reg = <0x020cc000 0x4000>;
@@ -756,22 +815,27 @@ compatible = "syscon-poweroff"; regmap = <&snvs>; offset = <0x38>; + value = <0x60>; mask = <0x60>; status = "disabled"; }; + + snvs_lpgpr: snvs-lpgpr { + compatible = "fsl,imx6q-snvs-lpgpr"; + }; };
- epit1: epit@020d0000 { /* EPIT1 */ + epit1: epit@20d0000 { /* EPIT1 */ reg = <0x020d0000 0x4000>; interrupts = <0 56 IRQ_TYPE_LEVEL_HIGH>; };
- epit2: epit@020d4000 { /* EPIT2 */ + epit2: epit@20d4000 { /* EPIT2 */ reg = <0x020d4000 0x4000>; interrupts = <0 57 IRQ_TYPE_LEVEL_HIGH>; };
- src: src@020d8000 { + src: src@20d8000 { compatible = "fsl,imx6q-src", "fsl,imx51-src"; reg = <0x020d8000 0x4000>; interrupts = <0 91 IRQ_TYPE_LEVEL_HIGH>, @@ -779,7 +843,7 @@ #reset-cells = <1>; };
- gpc: gpc@020dc000 { + gpc: gpc@20dc000 { compatible = "fsl,imx6q-gpc"; reg = <0x020dc000 0x4000>; interrupt-controller; @@ -787,91 +851,57 @@ interrupts = <0 89 IRQ_TYPE_LEVEL_HIGH>, <0 90 IRQ_TYPE_LEVEL_HIGH>; interrupt-parent = <&intc>; - pu-supply = <®_pu>; - clocks = <&clks IMX6QDL_CLK_GPU3D_CORE>, - <&clks IMX6QDL_CLK_GPU3D_SHADER>, - <&clks IMX6QDL_CLK_GPU2D_CORE>, - <&clks IMX6QDL_CLK_GPU2D_AXI>, - <&clks IMX6QDL_CLK_OPENVG_AXI>, - <&clks IMX6QDL_CLK_VPU_AXI>; - #power-domain-cells = <1>; - }; - - gpr: iomuxc-gpr@020e0000 { - compatible = "fsl,imx6q-iomuxc-gpr", "syscon"; - reg = <0x020e0000 0x38>; - }; - - iomuxc: iomuxc@020e0000 { - compatible = "fsl,imx6dl-iomuxc", "fsl,imx6q-iomuxc"; - reg = <0x020e0000 0x4000>; - }; - - ldb: ldb@020e0008 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx6q-ldb", "fsl,imx53-ldb"; - gpr = <&gpr>; - status = "disabled"; + clocks = <&clks IMX6QDL_CLK_IPG>; + clock-names = "ipg";
- lvds-channel@0 { + pgc { #address-cells = <1>; #size-cells = <0>; - reg = <0>; - status = "disabled";
- port@0 { + power-domain@0 { reg = <0>; - - lvds0_mux_0: endpoint { - remote-endpoint = <&ipu1_di0_lvds0>; - }; + #power-domain-cells = <0>; }; - - port@1 { + pd_pu: power-domain@1 { reg = <1>; - - lvds0_mux_1: endpoint { - remote-endpoint = <&ipu1_di1_lvds0>; - }; + #power-domain-cells = <0>; + power-supply = <®_pu>; + clocks = <&clks IMX6QDL_CLK_GPU3D_CORE>, + <&clks IMX6QDL_CLK_GPU3D_SHADER>, + <&clks IMX6QDL_CLK_GPU2D_CORE>, + <&clks IMX6QDL_CLK_GPU2D_AXI>, + <&clks IMX6QDL_CLK_OPENVG_AXI>, + <&clks IMX6QDL_CLK_VPU_AXI>; }; }; + };
- lvds-channel@1 { - #address-cells = <1>; - #size-cells = <0>; - reg = <1>; - status = "disabled"; - - port@0 { - reg = <0>; - - lvds1_mux_0: endpoint { - remote-endpoint = <&ipu1_di0_lvds1>; - }; - }; + gpr: iomuxc-gpr@20e0000 { + compatible = "fsl,imx6q-iomuxc-gpr", "syscon", "simple-mfd"; + reg = <0x20e0000 0x38>;
- port@1 { - reg = <1>; - - lvds1_mux_1: endpoint { - remote-endpoint = <&ipu1_di1_lvds1>; - }; - }; + mux: mux-controller { + compatible = "mmio-mux"; + #mux-control-cells = <1>; }; };
- dcic1: dcic@020e4000 { + iomuxc: iomuxc@20e0000 { + compatible = "fsl,imx6dl-iomuxc", "fsl,imx6q-iomuxc"; + reg = <0x20e0000 0x4000>; + }; + + dcic1: dcic@20e4000 { reg = <0x020e4000 0x4000>; interrupts = <0 124 IRQ_TYPE_LEVEL_HIGH>; };
- dcic2: dcic@020e8000 { + dcic2: dcic@20e8000 { reg = <0x020e8000 0x4000>; interrupts = <0 125 IRQ_TYPE_LEVEL_HIGH>; };
- sdma: sdma@020ec000 { + sdma: sdma@20ec000 { compatible = "fsl,imx6q-sdma", "fsl,imx35-sdma"; reg = <0x020ec000 0x4000>; interrupts = <0 2 IRQ_TYPE_LEVEL_HIGH>; @@ -883,7 +913,7 @@ }; };
- aips-bus@02100000 { /* AIPS2 */ + aips-bus@2100000 { /* AIPS2 */ compatible = "fsl,aips-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; @@ -892,7 +922,6 @@
crypto: caam@2100000 { compatible = "fsl,sec-v4.0"; - fsl,sec-era = <4>; #address-cells = <1>; #size-cells = <1>; reg = <0x2100000 0x10000>; @@ -916,11 +945,11 @@ }; };
- aipstz@0217c000 { /* AIPSTZ2 */ + aipstz@217c000 { /* AIPSTZ2 */ reg = <0x0217c000 0x4000>; };
- usbotg: usb@02184000 { + usbotg: usb@2184000 { compatible = "fsl,imx6q-usb", "fsl,imx27-usb"; reg = <0x02184000 0x200>; interrupts = <0 43 IRQ_TYPE_LEVEL_HIGH>; @@ -933,7 +962,7 @@ status = "disabled"; };
- usbh1: usb@02184200 { + usbh1: usb@2184200 { compatible = "fsl,imx6q-usb", "fsl,imx27-usb"; reg = <0x02184200 0x200>; interrupts = <0 40 IRQ_TYPE_LEVEL_HIGH>; @@ -947,7 +976,7 @@ status = "disabled"; };
- usbh2: usb@02184400 { + usbh2: usb@2184400 { compatible = "fsl,imx6q-usb", "fsl,imx27-usb"; reg = <0x02184400 0x200>; interrupts = <0 41 IRQ_TYPE_LEVEL_HIGH>; @@ -960,7 +989,7 @@ status = "disabled"; };
- usbh3: usb@02184600 { + usbh3: usb@2184600 { compatible = "fsl,imx6q-usb", "fsl,imx27-usb"; reg = <0x02184600 0x200>; interrupts = <0 42 IRQ_TYPE_LEVEL_HIGH>; @@ -973,16 +1002,17 @@ status = "disabled"; };
- usbmisc: usbmisc@02184800 { + usbmisc: usbmisc@2184800 { #index-cells = <1>; compatible = "fsl,imx6q-usbmisc"; reg = <0x02184800 0x200>; clocks = <&clks IMX6QDL_CLK_USBOH3>; };
- fec: ethernet@02188000 { + fec: ethernet@2188000 { compatible = "fsl,imx6q-fec"; reg = <0x02188000 0x4000>; + interrupt-names = "int0", "pps"; interrupts-extended = <&intc 0 118 IRQ_TYPE_LEVEL_HIGH>, <&intc 0 119 IRQ_TYPE_LEVEL_HIGH>; @@ -993,14 +1023,14 @@ status = "disabled"; };
- mlb@0218c000 { + mlb@218c000 { reg = <0x0218c000 0x4000>; interrupts = <0 53 IRQ_TYPE_LEVEL_HIGH>, <0 117 IRQ_TYPE_LEVEL_HIGH>, <0 126 IRQ_TYPE_LEVEL_HIGH>; };
- usdhc1: usdhc@02190000 { + usdhc1: usdhc@2190000 { compatible = "fsl,imx6q-usdhc"; reg = <0x02190000 0x4000>; interrupts = <0 22 IRQ_TYPE_LEVEL_HIGH>; @@ -1012,7 +1042,7 @@ status = "disabled"; };
- usdhc2: usdhc@02194000 { + usdhc2: usdhc@2194000 { compatible = "fsl,imx6q-usdhc"; reg = <0x02194000 0x4000>; interrupts = <0 23 IRQ_TYPE_LEVEL_HIGH>; @@ -1024,7 +1054,7 @@ status = "disabled"; };
- usdhc3: usdhc@02198000 { + usdhc3: usdhc@2198000 { compatible = "fsl,imx6q-usdhc"; reg = <0x02198000 0x4000>; interrupts = <0 24 IRQ_TYPE_LEVEL_HIGH>; @@ -1036,7 +1066,7 @@ status = "disabled"; };
- usdhc4: usdhc@0219c000 { + usdhc4: usdhc@219c000 { compatible = "fsl,imx6q-usdhc"; reg = <0x0219c000 0x4000>; interrupts = <0 25 IRQ_TYPE_LEVEL_HIGH>; @@ -1048,7 +1078,7 @@ status = "disabled"; };
- i2c1: i2c@021a0000 { + i2c1: i2c@21a0000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6q-i2c", "fsl,imx21-i2c"; @@ -1058,7 +1088,7 @@ status = "disabled"; };
- i2c2: i2c@021a4000 { + i2c2: i2c@21a4000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6q-i2c", "fsl,imx21-i2c"; @@ -1068,7 +1098,7 @@ status = "disabled"; };
- i2c3: i2c@021a8000 { + i2c3: i2c@21a8000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6q-i2c", "fsl,imx21-i2c"; @@ -1078,55 +1108,66 @@ status = "disabled"; };
- romcp@021ac000 { + romcp@21ac000 { reg = <0x021ac000 0x4000>; };
- mmdc0: mmdc@021b0000 { /* MMDC0 */ + mmdc0: mmdc@21b0000 { /* MMDC0 */ compatible = "fsl,imx6q-mmdc"; reg = <0x021b0000 0x4000>; };
- mmdc1: mmdc@021b4000 { /* MMDC1 */ + mmdc1: mmdc@21b4000 { /* MMDC1 */ reg = <0x021b4000 0x4000>; };
- weim: weim@021b8000 { + weim: weim@21b8000 { + #address-cells = <2>; + #size-cells = <1>; compatible = "fsl,imx6q-weim"; reg = <0x021b8000 0x4000>; interrupts = <0 14 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6QDL_CLK_EIM_SLOW>; + fsl,weim-cs-gpr = <&gpr>; + status = "disabled"; };
- ocotp: ocotp@021bc000 { + ocotp: ocotp@21bc000 { compatible = "fsl,imx6q-ocotp", "syscon"; reg = <0x021bc000 0x4000>; clocks = <&clks IMX6QDL_CLK_IIM>; };
- tzasc@021d0000 { /* TZASC1 */ + tzasc@21d0000 { /* TZASC1 */ reg = <0x021d0000 0x4000>; interrupts = <0 108 IRQ_TYPE_LEVEL_HIGH>; };
- tzasc@021d4000 { /* TZASC2 */ + tzasc@21d4000 { /* TZASC2 */ reg = <0x021d4000 0x4000>; interrupts = <0 109 IRQ_TYPE_LEVEL_HIGH>; };
- audmux: audmux@021d8000 { + audmux: audmux@21d8000 { compatible = "fsl,imx6q-audmux", "fsl,imx31-audmux"; reg = <0x021d8000 0x4000>; status = "disabled"; };
- mipi_csi: mipi@021dc000 { + mipi_csi: mipi@21dc000 { + compatible = "fsl,imx6-mipi-csi2"; reg = <0x021dc000 0x4000>; - }; - - mipi_dsi: mipi@021e0000 { #address-cells = <1>; #size-cells = <0>; + interrupts = <0 100 0x04>, <0 101 0x04>; + clocks = <&clks IMX6QDL_CLK_HSI_TX>, + <&clks IMX6QDL_CLK_VIDEO_27M>, + <&clks IMX6QDL_CLK_EIM_PODF>; + clock-names = "dphy", "ref", "pix"; + status = "disabled"; + }; + + mipi_dsi: mipi@21e0000 { reg = <0x021e0000 0x4000>; status = "disabled";
@@ -1152,12 +1193,14 @@ }; };
- vdoa@021e4000 { + vdoa@21e4000 { + compatible = "fsl,imx6q-vdoa"; reg = <0x021e4000 0x4000>; interrupts = <0 18 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_VDOA>; };
- uart2: serial@021e8000 { + uart2: serial@21e8000 { compatible = "fsl,imx6q-uart", "fsl,imx21-uart"; reg = <0x021e8000 0x4000>; interrupts = <0 27 IRQ_TYPE_LEVEL_HIGH>; @@ -1169,7 +1212,7 @@ status = "disabled"; };
- uart3: serial@021ec000 { + uart3: serial@21ec000 { compatible = "fsl,imx6q-uart", "fsl,imx21-uart"; reg = <0x021ec000 0x4000>; interrupts = <0 28 IRQ_TYPE_LEVEL_HIGH>; @@ -1181,7 +1224,7 @@ status = "disabled"; };
- uart4: serial@021f0000 { + uart4: serial@21f0000 { compatible = "fsl,imx6q-uart", "fsl,imx21-uart"; reg = <0x021f0000 0x4000>; interrupts = <0 29 IRQ_TYPE_LEVEL_HIGH>; @@ -1193,7 +1236,7 @@ status = "disabled"; };
- uart5: serial@021f4000 { + uart5: serial@21f4000 { compatible = "fsl,imx6q-uart", "fsl,imx21-uart"; reg = <0x021f4000 0x4000>; interrupts = <0 30 IRQ_TYPE_LEVEL_HIGH>; @@ -1206,7 +1249,7 @@ }; };
- ipu1: ipu@02400000 { + ipu1: ipu@2400000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6q-ipu"; @@ -1221,6 +1264,10 @@
ipu1_csi0: port@0 { reg = <0>; + + ipu1_csi0_from_ipu1_csi0_mux: endpoint { + remote-endpoint = <&ipu1_csi0_mux_to_ipu1_csi0>; + }; };
ipu1_csi1: port@1 { @@ -1232,22 +1279,27 @@ #size-cells = <0>; reg = <2>;
- ipu1_di0_disp0: disp0-endpoint { + ipu1_di0_disp0: endpoint@0 { + reg = <0>; };
- ipu1_di0_hdmi: hdmi-endpoint { + ipu1_di0_hdmi: endpoint@1 { + reg = <1>; remote-endpoint = <&hdmi_mux_0>; };
- ipu1_di0_mipi: mipi-endpoint { + ipu1_di0_mipi: endpoint@2 { + reg = <2>; remote-endpoint = <&mipi_mux_0>; };
- ipu1_di0_lvds0: lvds0-endpoint { + ipu1_di0_lvds0: endpoint@3 { + reg = <3>; remote-endpoint = <&lvds0_mux_0>; };
- ipu1_di0_lvds1: lvds1-endpoint { + ipu1_di0_lvds1: endpoint@4 { + reg = <4>; remote-endpoint = <&lvds1_mux_0>; }; }; @@ -1257,22 +1309,27 @@ #size-cells = <0>; reg = <3>;
- ipu1_di1_disp1: disp1-endpoint { + ipu1_di1_disp1: endpoint@0 { + reg = <0>; };
- ipu1_di1_hdmi: hdmi-endpoint { + ipu1_di1_hdmi: endpoint@1 { + reg = <1>; remote-endpoint = <&hdmi_mux_1>; };
- ipu1_di1_mipi: mipi-endpoint { + ipu1_di1_mipi: endpoint@2 { + reg = <2>; remote-endpoint = <&mipi_mux_1>; };
- ipu1_di1_lvds0: lvds0-endpoint { + ipu1_di1_lvds0: endpoint@3 { + reg = <3>; remote-endpoint = <&lvds0_mux_1>; };
- ipu1_di1_lvds1: lvds1-endpoint { + ipu1_di1_lvds1: endpoint@4 { + reg = <4>; remote-endpoint = <&lvds1_mux_1>; }; }; diff --git a/arch/arm/dts/imx6qp-sabreauto.dts b/arch/arm/dts/imx6qp-sabreauto.dts new file mode 100644 index 0000000..d4caeeb --- /dev/null +++ b/arch/arm/dts/imx6qp-sabreauto.dts @@ -0,0 +1,55 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Copyright 2016 Freescale Semiconductor, Inc. + +/dts-v1/; + +#include "imx6qp.dtsi" +#include "imx6qdl-sabreauto.dtsi" + +/ { + model = "Freescale i.MX6 Quad Plus SABRE Automotive Board"; + compatible = "fsl,imx6qp-sabreauto", "fsl,imx6qp"; +}; + +&i2c2 { + max7322: gpio@68 { + compatible = "maxim,max7322"; + reg = <0x68>; + gpio-controller; + #gpio-cells = <2>; + }; +}; + +&iomuxc { + imx6qdl-sabreauto { + pinctrl_enet: enetgrp { + fsl,pins = < + MX6QDL_PAD_KEY_COL1__ENET_MDIO 0x1b0b0 + MX6QDL_PAD_KEY_COL2__ENET_MDC 0x1b0b0 + MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x1b018 + MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x1b018 + MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x1b018 + MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x1b018 + MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x1b018 + MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x1b018 + MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x1b018 + MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x1b018 + MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x1b018 + MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x1b018 + MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x1b018 + MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x1b018 + MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x4001b0a8 + MX6QDL_PAD_GPIO_6__ENET_IRQ 0x000b1 + >; + }; + }; +}; + +&pcie { + status = "disabled"; +}; + +&vgen3_reg { + regulator-always-on; +}; diff --git a/arch/arm/dts/imx6qp-sabresd.dts b/arch/arm/dts/imx6qp-sabresd.dts new file mode 100644 index 0000000..f1b9cb1 --- /dev/null +++ b/arch/arm/dts/imx6qp-sabresd.dts @@ -0,0 +1,55 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Copyright 2016 Freescale Semiconductor, Inc. + +/dts-v1/; + +#include "imx6qp.dtsi" +#include "imx6qdl-sabresd.dtsi" + +/ { + model = "Freescale i.MX6 Quad Plus SABRE Smart Device Board"; + compatible = "fsl,imx6qp-sabresd", "fsl,imx6qp"; +}; + +®_arm { + vin-supply = <&sw2_reg>; +}; + +&iomuxc { + imx6qdl-sabresd { + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x17059 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x10071 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x17059 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x17059 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x17059 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x17059 + MX6QDL_PAD_NANDF_D4__SD2_DATA4 0x17059 + MX6QDL_PAD_NANDF_D5__SD2_DATA5 0x17059 + MX6QDL_PAD_NANDF_D6__SD2_DATA6 0x17059 + MX6QDL_PAD_NANDF_D7__SD2_DATA7 0x17059 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX6QDL_PAD_SD3_CMD__SD3_CMD 0x17059 + MX6QDL_PAD_SD3_CLK__SD3_CLK 0x10071 + MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x17059 + MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x17059 + MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x17059 + MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x17059 + MX6QDL_PAD_SD3_DAT4__SD3_DATA4 0x17059 + MX6QDL_PAD_SD3_DAT5__SD3_DATA5 0x17059 + MX6QDL_PAD_SD3_DAT6__SD3_DATA6 0x17059 + MX6QDL_PAD_SD3_DAT7__SD3_DATA7 0x17059 + >; + }; + }; +}; + +&pcie { + status = "disabled"; +}; diff --git a/arch/arm/dts/imx6qp.dtsi b/arch/arm/dts/imx6qp.dtsi new file mode 100644 index 0000000..5f51f8e --- /dev/null +++ b/arch/arm/dts/imx6qp.dtsi @@ -0,0 +1,115 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +// +// Copyright 2016 Freescale Semiconductor, Inc. + +#include "imx6q.dtsi" + +/ { + soc { + ocram2: sram@940000 { + compatible = "mmio-sram"; + reg = <0x00940000 0x20000>; + clocks = <&clks IMX6QDL_CLK_OCRAM>; + }; + + ocram3: sram@960000 { + compatible = "mmio-sram"; + reg = <0x00960000 0x20000>; + clocks = <&clks IMX6QDL_CLK_OCRAM>; + }; + + aips-bus@2100000 { + pre1: pre@21c8000 { + compatible = "fsl,imx6qp-pre"; + reg = <0x021c8000 0x1000>; + interrupts = <GIC_SPI 90 IRQ_TYPE_EDGE_RISING>; + clocks = <&clks IMX6QDL_CLK_PRE0>; + clock-names = "axi"; + fsl,iram = <&ocram2>; + }; + + pre2: pre@21c9000 { + compatible = "fsl,imx6qp-pre"; + reg = <0x021c9000 0x1000>; + interrupts = <GIC_SPI 97 IRQ_TYPE_EDGE_RISING>; + clocks = <&clks IMX6QDL_CLK_PRE1>; + clock-names = "axi"; + fsl,iram = <&ocram2>; + }; + + pre3: pre@21ca000 { + compatible = "fsl,imx6qp-pre"; + reg = <0x021ca000 0x1000>; + interrupts = <GIC_SPI 98 IRQ_TYPE_EDGE_RISING>; + clocks = <&clks IMX6QDL_CLK_PRE2>; + clock-names = "axi"; + fsl,iram = <&ocram3>; + }; + + pre4: pre@21cb000 { + compatible = "fsl,imx6qp-pre"; + reg = <0x021cb000 0x1000>; + interrupts = <GIC_SPI 99 IRQ_TYPE_EDGE_RISING>; + clocks = <&clks IMX6QDL_CLK_PRE3>; + clock-names = "axi"; + fsl,iram = <&ocram3>; + }; + + prg1: prg@21cc000 { + compatible = "fsl,imx6qp-prg"; + reg = <0x021cc000 0x1000>; + clocks = <&clks IMX6QDL_CLK_PRG0_APB>, + <&clks IMX6QDL_CLK_PRG0_AXI>; + clock-names = "ipg", "axi"; + fsl,pres = <&pre1>, <&pre2>, <&pre3>; + }; + + prg2: prg@21cd000 { + compatible = "fsl,imx6qp-prg"; + reg = <0x021cd000 0x1000>; + clocks = <&clks IMX6QDL_CLK_PRG1_APB>, + <&clks IMX6QDL_CLK_PRG1_AXI>; + clock-names = "ipg", "axi"; + fsl,pres = <&pre4>, <&pre2>, <&pre3>; + }; + }; + }; +}; + +&fec { + /delete-property/interrupts-extended; + interrupts = <0 118 IRQ_TYPE_LEVEL_HIGH>, + <0 119 IRQ_TYPE_LEVEL_HIGH>; +}; + +&gpc { + compatible = "fsl,imx6qp-gpc", "fsl,imx6q-gpc"; +}; + +&ipu1 { + compatible = "fsl,imx6qp-ipu", "fsl,imx6q-ipu"; + fsl,prg = <&prg1>; +}; + +&ipu2 { + compatible = "fsl,imx6qp-ipu", "fsl,imx6q-ipu"; + fsl,prg = <&prg2>; +}; + +&ldb { + clocks = <&clks IMX6QDL_CLK_LDB_DI0_SEL>, <&clks IMX6QDL_CLK_LDB_DI1_SEL>, + <&clks IMX6QDL_CLK_IPU1_DI0_SEL>, <&clks IMX6QDL_CLK_IPU1_DI1_SEL>, + <&clks IMX6QDL_CLK_IPU2_DI0_SEL>, <&clks IMX6QDL_CLK_IPU2_DI1_SEL>, + <&clks IMX6QDL_CLK_LDB_DI0_PODF>, <&clks IMX6QDL_CLK_LDB_DI1_PODF>; + clock-names = "di0_pll", "di1_pll", + "di0_sel", "di1_sel", "di2_sel", "di3_sel", + "di0", "di1"; +}; + +&mmdc0 { + compatible = "fsl,imx6qp-mmdc", "fsl,imx6q-mmdc"; +}; + +&pcie { + compatible = "fsl,imx6qp-pcie", "snps,dw-pcie"; +};
Add simple its in order to allow SPL to boot u-boot proper via FIT table.
Signed-off-by: Abel Vesa abel.vesa@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/mx6/fit_spl.its | 41 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 41 insertions(+) create mode 100644 arch/arm/mach-imx/mx6/fit_spl.its
diff --git a/arch/arm/mach-imx/mx6/fit_spl.its b/arch/arm/mach-imx/mx6/fit_spl.its new file mode 100644 index 0000000..bf3ffee --- /dev/null +++ b/arch/arm/mach-imx/mx6/fit_spl.its @@ -0,0 +1,41 @@ +/* + * Copyright (C) 2018 NXP + * + * Simple U-boot fit source file containing U-Boot (with dtb appended) + */ + +/dts-v1/; + +/ { + description = "Image for u-boot proper (with dtb appended)"; + #address-cells = <1>; + + images { + #address-cells = <1>; + #size-cells = <0>; + + uboot@1 { + reg = <0>; + description = "U-Boot"; + data = /incbin/("../../../../u-boot-fit-dtb.bin"); + type = "standalone"; + os = "U-Boot"; + compression = "none"; + arch = "arm"; + load = <0x17800000>; + }; + }; + + configurations { + #address-cells = <1>; + #size-cells = <0>; + + default = "conf@1"; + + conf@1 { + reg = <0>; + description = "i.MX armv7"; + loadables = "uboot@1"; + }; + }; +};
Enable all the necessary configs for SPL DM and FIT support for mx6sabreauto.
Signed-off-by: Abel Vesa abel.vesa@nxp.com --- configs/mx6sabreauto_defconfig | 15 ++++++++++++++- 1 file changed, 14 insertions(+), 1 deletion(-)
diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index 4bdcbb1..6a4d3a4 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -11,12 +11,19 @@ CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_NXP_BOARD_REVISION=y CONFIG_NR_DRAM_BANKS=1 +# CONFIG_SYS_MALLOC_F is not set +CONFIG_FIT=y +CONFIG_SPL_FIT_PRINT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_SOURCE="arch/arm/mach-imx/mx6/fit_spl.its" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y @@ -40,8 +47,15 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx6q-sabreauto" +CONFIG_OF_LIST="imx6dl-sabreauto imx6q-sabreauto imx6qp-sabreauto" +CONFIG_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_DFU_SF=y CONFIG_DM_MMC=y @@ -68,4 +82,3 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_VIDEO=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_OF_LIBFDT=y
Enable all the necessary configs for SPL DM and FIT support for mx6sabresd.
Signed-off-by: Abel Vesa abel.vesa@nxp.com --- configs/mx6sabresd_defconfig | 21 +++++++++++++++++++-- 1 file changed, 19 insertions(+), 2 deletions(-)
diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 3babfd5..d5a4365 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -10,12 +10,19 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 +# CONFIG_SYS_MALLOC_F is not set +CONFIG_FIT=y +CONFIG_SPL_FIT_PRINT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_SOURCE="arch/arm/mach-imx/mx6/fit_spl.its" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_EXT_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_OS_BOOT=y @@ -47,23 +54,34 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_EFI_PARTITION=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx6q-sabresd" +CONFIG_OF_LIST="imx6q-sabresd imx6qp-sabresd imx6dl-sabresd" +CONFIG_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_OF_LIST="imx6dl-sabresd imx6q-sabresd imx6qp-sabresd" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_DM=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_FASTBOOT_BUF_SIZE=0x10000000 CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=2 +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PCI=y +CONFIG_DM_REGULATOR=y CONFIG_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y -CONFIG_USB_STORAGE=y +CONFIG_DM_USB=y +# CONFIG_SPL_DM_USB is not set CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="FSL" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 @@ -73,4 +91,3 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_VIDEO=y # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_OF_LIBFDT=y
Add the DM_GPIO related config for mx6sabreauto. Also add the gpio request calls.
Signed-off-by: Abel Vesa abel.vesa@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com --- board/freescale/mx6sabreauto/mx6sabreauto.c | 3 +++ configs/mx6sabreauto_defconfig | 1 + 2 files changed, 4 insertions(+)
diff --git a/board/freescale/mx6sabreauto/mx6sabreauto.c b/board/freescale/mx6sabreauto/mx6sabreauto.c index c8f1263..c7e3e67 100644 --- a/board/freescale/mx6sabreauto/mx6sabreauto.c +++ b/board/freescale/mx6sabreauto/mx6sabreauto.c @@ -501,6 +501,7 @@ iomux_v3_cfg_t const backlight_pads[] = {
static void setup_iomux_backlight(void) { + gpio_request(IMX_GPIO_NR(2, 9), "backlight"); gpio_direction_output(IMX_GPIO_NR(2, 9), 1); SETUP_IOMUX_PADS(backlight_pads); } @@ -594,6 +595,7 @@ int board_init(void) else setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6dl_i2c_pad_info1); /* I2C 3 Steer */ + gpio_request(IMX_GPIO_NR(5, 4), "steer logic"); gpio_direction_output(IMX_GPIO_NR(5, 4), 1); SETUP_IOMUX_PADS(i2c3_pads); #ifndef CONFIG_SYS_FLASH_CFI @@ -602,6 +604,7 @@ int board_init(void) else setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6dl_i2c_pad_info2); #endif + gpio_request(IMX_GPIO_NR(1, 15), "expander en"); gpio_direction_output(IMX_GPIO_NR(1, 15), 1); SETUP_IOMUX_PADS(port_exp);
diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index 6a4d3a4..31e8153 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -58,6 +58,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_DFU_SF=y +CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_NAND=y
Add the DM_GPIO related config for mx6sabresd. Also add the gpio request calls.
Signed-off-by: Abel Vesa abel.vesa@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com --- board/freescale/mx6sabresd/mx6sabresd.c | 5 +++++ configs/mx6sabresd_defconfig | 1 + 2 files changed, 6 insertions(+)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 4688095..99002bd 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -96,6 +96,7 @@ static void setup_iomux_enet(void) SETUP_IOMUX_PADS(enet_pads);
/* Reset AR8031 PHY */ + gpio_request(IMX_GPIO_NR(1, 25), "ENET PHY Reset"); gpio_direction_output(IMX_GPIO_NR(1, 25) , 0); mdelay(10); gpio_set_value(IMX_GPIO_NR(1, 25), 1); @@ -189,6 +190,7 @@ static iomux_v3_cfg_t const bl_pads[] = { static void enable_backlight(void) { SETUP_IOMUX_PADS(bl_pads); + gpio_request(DISP0_PWR_EN, "Display Power Enable"); gpio_direction_output(DISP0_PWR_EN, 1); }
@@ -307,11 +309,13 @@ int board_mmc_init(bd_t *bis) switch (i) { case 0: SETUP_IOMUX_PADS(usdhc2_pads); + gpio_request(USDHC2_CD_GPIO, "USDHC2 CD"); gpio_direction_input(USDHC2_CD_GPIO); usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); break; case 1: SETUP_IOMUX_PADS(usdhc3_pads); + gpio_request(USDHC3_CD_GPIO, "USDHC3 CD"); gpio_direction_input(USDHC3_CD_GPIO); usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); break; @@ -729,6 +733,7 @@ int checkboard(void) #ifdef CONFIG_SPL_OS_BOOT int spl_start_uboot(void) { + gpio_request(KEY_VOL_UP, "KEY Volume UP"); gpio_direction_input(KEY_VOL_UP);
/* Only enter in Falcon mode if KEY_VOL_UP is pressed */ diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index d5a4365..1f4c5c5 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -69,6 +69,7 @@ CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_FASTBOOT_BUF_SIZE=0x10000000 CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=2 +CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y
Enable all neceassary configs to support DM_SPI_FLASH on mx6sabreauto.
Signed-off-by: Abel Vesa abel.vesa@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com --- configs/mx6sabreauto_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index 31e8153..34fb9d04 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -63,12 +63,14 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_DM_REGULATOR=y CONFIG_SPI=y +CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y CONFIG_DM_USB=y
Enable all neceassary configs to support DM_SPI_FLASH on mx6sabresd.
Signed-off-by: Abel Vesa abel.vesa@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com --- configs/mx6sabresd_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 1f4c5c5..b26e764 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -72,6 +72,7 @@ CONFIG_FASTBOOT_FLASH_MMC_DEV=2 CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y @@ -79,6 +80,7 @@ CONFIG_MII=y CONFIG_PCI=y CONFIG_DM_REGULATOR=y CONFIG_SPI=y +CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y CONFIG_DM_USB=y
Since the mx6sabreauto has DM support, remove the unused non-DM code from mx6sabreauto board file.
Signed-off-by: Abel Vesa abel.vesa@nxp.com --- board/freescale/mx6sabreauto/mx6sabreauto.c | 70 ----------------------------- 1 file changed, 70 deletions(-)
diff --git a/board/freescale/mx6sabreauto/mx6sabreauto.c b/board/freescale/mx6sabreauto/mx6sabreauto.c index c7e3e67..dd72de9 100644 --- a/board/freescale/mx6sabreauto/mx6sabreauto.c +++ b/board/freescale/mx6sabreauto/mx6sabreauto.c @@ -159,44 +159,6 @@ static iomux_v3_cfg_t const port_exp[] = { IOMUX_PADS(PAD_SD2_DAT0__GPIO1_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL)), };
-/*Define for building port exp gpio, pin starts from 0*/ -#define PORTEXP_IO_NR(chip, pin) \ - ((chip << 5) + pin) - -/*Get the chip addr from a ioexp gpio*/ -#define PORTEXP_IO_TO_CHIP(gpio_nr) \ - (gpio_nr >> 5) - -/*Get the pin number from a ioexp gpio*/ -#define PORTEXP_IO_TO_PIN(gpio_nr) \ - (gpio_nr & 0x1f) - -static int port_exp_direction_output(unsigned gpio, int value) -{ - int ret; - - i2c_set_bus_num(2); - ret = i2c_probe(PORTEXP_IO_TO_CHIP(gpio)); - if (ret) - return ret; - - ret = pca953x_set_dir(PORTEXP_IO_TO_CHIP(gpio), - (1 << PORTEXP_IO_TO_PIN(gpio)), - (PCA953X_DIR_OUT << PORTEXP_IO_TO_PIN(gpio))); - - if (ret) - return ret; - - ret = pca953x_set_val(PORTEXP_IO_TO_CHIP(gpio), - (1 << PORTEXP_IO_TO_PIN(gpio)), - (value << PORTEXP_IO_TO_PIN(gpio))); - - if (ret) - return ret; - - return 0; -} - #ifdef CONFIG_MTD_NOR_FLASH static iomux_v3_cfg_t const eimnor_pads[] = { IOMUX_PADS(PAD_EIM_D16__EIM_DATA16 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), @@ -681,19 +643,10 @@ int checkboard(void) }
#ifdef CONFIG_USB_EHCI_MX6 -#define USB_HOST1_PWR PORTEXP_IO_NR(0x32, 7) -#define USB_OTG_PWR PORTEXP_IO_NR(0x34, 1) - -iomux_v3_cfg_t const usb_otg_pads[] = { - IOMUX_PADS(PAD_ENET_RX_ER__USB_OTG_ID | MUX_PAD_CTRL(NO_PAD_CTRL)), -}; - int board_ehci_hcd_init(int port) { switch (port) { case 0: - SETUP_IOMUX_PADS(usb_otg_pads); - /* * Set daisy chain for otg_pin_id on 6q. * For 6dl, this bit is reserved. @@ -708,29 +661,6 @@ int board_ehci_hcd_init(int port) } return 0; } - -int board_ehci_power(int port, int on) -{ - switch (port) { - case 0: - if (on) - port_exp_direction_output(USB_OTG_PWR, 1); - else - port_exp_direction_output(USB_OTG_PWR, 0); - break; - case 1: - if (on) - port_exp_direction_output(USB_HOST1_PWR, 1); - else - port_exp_direction_output(USB_HOST1_PWR, 0); - break; - default: - printf("MXC USB port %d not yet supported\n", port); - return -EINVAL; - } - - return 0; -} #endif
#ifdef CONFIG_SPL_BUILD
Since the mx6sabreauto has DM support, remove the unused non-DM code from mx6sabresd board file.
Signed-off-by: Abel Vesa abel.vesa@nxp.com --- board/freescale/mx6sabresd/mx6sabresd.c | 50 --------------------------------- 1 file changed, 50 deletions(-)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 99002bd..0824a05 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -563,63 +563,13 @@ int board_eth_init(bd_t *bis) }
#ifdef CONFIG_USB_EHCI_MX6 -#define USB_OTHERREGS_OFFSET 0x800 -#define UCTRL_PWR_POL (1 << 9) - -static iomux_v3_cfg_t const usb_otg_pads[] = { - IOMUX_PADS(PAD_EIM_D22__USB_OTG_PWR | MUX_PAD_CTRL(NO_PAD_CTRL)), - IOMUX_PADS(PAD_ENET_RX_ER__USB_OTG_ID | MUX_PAD_CTRL(NO_PAD_CTRL)), -}; - -static iomux_v3_cfg_t const usb_hc1_pads[] = { - IOMUX_PADS(PAD_ENET_TXD1__GPIO1_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL)), -}; - static void setup_usb(void) { - SETUP_IOMUX_PADS(usb_otg_pads); - /* * set daisy chain for otg_pin_id on 6q. * for 6dl, this bit is reserved */ imx_iomux_set_gpr_register(1, 13, 1, 0); - - SETUP_IOMUX_PADS(usb_hc1_pads); -} - -int board_ehci_hcd_init(int port) -{ - u32 *usbnc_usb_ctrl; - - if (port > 1) - return -EINVAL; - - usbnc_usb_ctrl = (u32 *)(USB_BASE_ADDR + USB_OTHERREGS_OFFSET + - port * 4); - - setbits_le32(usbnc_usb_ctrl, UCTRL_PWR_POL); - - return 0; -} - -int board_ehci_power(int port, int on) -{ - switch (port) { - case 0: - break; - case 1: - if (on) - gpio_direction_output(IMX_GPIO_NR(1, 29), 1); - else - gpio_direction_output(IMX_GPIO_NR(1, 29), 0); - break; - default: - printf("MXC USB port %d not yet supported\n", port); - return -EINVAL; - } - - return 0; } #endif
Rely on the phy-reset-gpios which is set in imx6qdl-sabresd dtsi and get rid of the enet reset gpio handling from the board file.
Signed-off-by: Abel Vesa abel.vesa@nxp.com --- board/freescale/mx6sabresd/mx6sabresd.c | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 0824a05..385a18e 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -94,13 +94,6 @@ static iomux_v3_cfg_t const enet_pads[] = { static void setup_iomux_enet(void) { SETUP_IOMUX_PADS(enet_pads); - - /* Reset AR8031 PHY */ - gpio_request(IMX_GPIO_NR(1, 25), "ENET PHY Reset"); - gpio_direction_output(IMX_GPIO_NR(1, 25) , 0); - mdelay(10); - gpio_set_value(IMX_GPIO_NR(1, 25), 1); - udelay(100); }
static iomux_v3_cfg_t const usdhc2_pads[] = {
With DM and FIT enabled in SPL, there is an sram overflow. By disabling CONFIG_SPL_DOS_PARTITION and CONFIG_SPL_EFI_PARTITION, we get to keep the 'one binary to fit all' for imx6[q|qp|dl] on sabresd since the final SPL image is now under 64KB.
Signed-off-by: Abel Vesa abel.vesa@nxp.com --- configs/mx6sabresd_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index b26e764..84840fe 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -54,6 +54,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_EFI_PARTITION=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-sabresd"
There is a new step now. The need to build the u-boot.itb. And instead of flashing the .img file, now the .itb file needs to be flashed.
Signed-off-by: Abel Vesa abel.vesa@nxp.com --- board/freescale/mx6sabreauto/README | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/board/freescale/mx6sabreauto/README b/board/freescale/mx6sabreauto/README index e8c589b..960a7d7 100644 --- a/board/freescale/mx6sabreauto/README +++ b/board/freescale/mx6sabreauto/README @@ -8,6 +8,7 @@ In order to build it: $ make mx6sabreauto_defconfig
$ make +$ make u-boot.itb
This will generate the SPL and u-boot.img binaries.
@@ -17,7 +18,7 @@ $ sudo dd if=SPL of=/dev/sdX bs=1K seek=1 && sync
- Flash the u-boot.img binary into the SD card:
-$ sudo dd if=u-boot.img of=/dev/sdX bs=1K seek=69 && sync +$ sudo dd if=u-boot.itb of=/dev/sdX bs=1K seek=69 && sync
Booting via Falcon mode ----------------------- @@ -31,6 +32,7 @@ In order to build it: $ make mx6sabreauto_defconfig
This will generate the SPL image called SPL and the u-boot.img.
@@ -40,7 +42,7 @@ $ sudo dd if=SPL of=/dev/sdb bs=1K seek=1 && sync
- Flash the u-boot.img image into the SD card:
-$ sudo dd if=u-boot.img of=/dev/sdb bs=1K seek=69 && sync +$ sudo dd if=u-boot.itb of=/dev/sdb bs=1K seek=69 && sync
Create a FAT16 boot partition to store uImage and the dtb file, then copy the files there:
Signed-off-by: Abel Vesa abel.vesa@nxp.com --- board/freescale/mx6sabresd/README | 9 ++++++--- 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/board/freescale/mx6sabresd/README b/board/freescale/mx6sabresd/README index 4b4df06..9b7f7cd 100644 --- a/board/freescale/mx6sabresd/README +++ b/board/freescale/mx6sabresd/README @@ -20,6 +20,7 @@ In order to build it: $ make mx6sabresd_defconfig
@@ -29,7 +30,7 @@ $ sudo dd if=SPL of=/dev/sdX bs=1K seek=1 && sync
2. Booting from eMMC @@ -38,6 +39,7 @@ $ sudo dd if=u-boot.img of=/dev/sdX bs=1K seek=69 && sync $ make mx6sabresd_defconfig
@@ -54,7 +56,7 @@ Mount the eMMC in the host PC: - Flash SPL and u-boot.img binaries into the eMMC:
$ sudo dd if=SPL of=/dev/sdX bs=1K seek=1 && sync -$ sudo dd if=u-boot.img of=/dev/sdX bs=1K seek=69 && sync +$ sudo dd if=u-boot.itb of=/dev/sdX bs=1K seek=69 && sync
Set SW6 to eMMC 8-bit boot: 11010110
@@ -64,6 +66,7 @@ Set SW6 to eMMC 8-bit boot: 11010110
$ make mx6sabresd_defconfig $ make +$ make u-boot.itb
@@ -73,7 +76,7 @@ $ sudo dd if=SPL of=/dev/sdX bs=1K seek=1 oflag=sync status=none && sync
-$ sudo dd if=u-boot.img of=/dev/sdX bs=1K seek=69 oflag=sync status=none && sync +$ sudo dd if=u-boot.itb of=/dev/sdX bs=1K seek=69 oflag=sync status=none && sync
Create a partition for root file system and extract it there:
On Wed, Jan 30, 2019 at 01:39:50PM +0000, Abel Vesa wrote:
The second version is here: https://lists.denx.de/pipermail/u-boot/2019-January/356557.html
Changes since v2:
- Removed the unecessary SYS_MALLOC_F_LEN from both defocnfig
- Fixed the copyright for all the *u-boot.dtsi files
OK, but you didn't answer why you need to specify your own its file when the TI examples show how to have mkimage generate this for you, thanks!
Changes since v2:
I might be wrong here but TI is doing this for MLO, which AFAIU, it's for SPL. The fit_spl.its I'm adding here is actually for u-boot proper.
SPL expects descriptions in the configurations and that can't be done without its file, again, AFAIK.
Please let me know what exactly am I missing here.
-- Tom
Changes since v2:
The flag to mkimage is not about SPL but rather "create a single configurations its file on the fly". This should also be fine for the its file in patch 10/22 (of v2, don't have v3 in front of me in patchwork).
Changes since v2:
Well, I tried something like this (manually):
$ ./tools/mkimage -f auto -C none -A ARM -T standalone -a 0x17800000 -e 0x17800000 -d u-boot-fit-dtb.bin -n "U-Boot" u-boot.itb -E
and the output was:
FIT description: Standalone Program image with one or more FDT blobs Created: Thu Jan 31 13:58:01 2019 Image 0 (standalone-1) Description: U-Boot Created: Thu Jan 31 13:58:01 2019 Type: Standalone Program Compression: uncompressed Data Size: 646400 Bytes = 631.25 KiB = 0.62 MiB Architecture: ARM Load Address: 0x17800000 Entry Point: 0x17800000 Default Configuration: 'conf-1' Configuration 0 (conf-1) Description: unavailable Kernel: unavailable
And then the SPL complains about the configuration description:
U-Boot SPL 2019.01-00374-gbe79a83 (Jan 31 2019 - 13:56:01 +0200) Trying to boot from MMC1 fit_find_config_node: Missing FDT description in DTB No matching DT out of these options: Firmware image with one or more FDT blobs fit_find_config_node: Missing FDT description in DTB No matching DT out of these options: Firmware image with one or more FDT blobs fit_find_config_node: Missing FDT description in DTB No matching DT out of these options: Firmware image with one or more FDT blobs mmc_load_image_raw_sector: mmc block read error spl: no partition table found SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ###
But with the fit_spl.its file I added I have this and works:
FIT description: Image for u-boot proper (with dtb appended) Created: Thu Jan 31 13:57:02 2019 Image 0 (uboot@1) Description: U-Boot Created: Thu Jan 31 13:57:02 2019 Type: Standalone Program Compression: uncompressed Data Size: 646400 Bytes = 631.25 KiB = 0.62 MiB Architecture: ARM Load Address: 0x17800000 Entry Point: unavailable Default Configuration: 'conf@1' Configuration 0 (conf@1) Description: i.MX armv7 Kernel: unavailable Loadables: uboot@1
So the differences between this and the one generated with mkimage+flags are the loadables and the description in the configuration 0.
Can I specify those through flags ?
-- Tom
Changes since v2:
and the output was:
Off the top of my head, I'm not sure what's going on, but thanks for digging at it more. I would say that this case not working is a bug, not a feature, so please figure out what's needed such that mkimage does the right thing in this case. The intention is that for a single configuration FIT we should not have to write the its file by hand. Thanks!
Abel Vesa
