[U-Boot] [PATCH 1/2] ARM: move #ifdef to match the error handling code
Match the #ifdef ... #endif and the code,
ret = do_something(); if (ret) return ret;
This will make it easier to add more #ifdef'ed code.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/lib/bootm-fdt.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/arch/arm/lib/bootm-fdt.c b/arch/arm/lib/bootm-fdt.c index 7677358..76b75d8 100644 --- a/arch/arm/lib/bootm-fdt.c +++ b/arch/arm/lib/bootm-fdt.c @@ -42,11 +42,14 @@ int arch_fixup_fdt(void *blob) }
ret = fdt_fixup_memory_banks(blob, start, size, CONFIG_NR_DRAM_BANKS); -#ifdef CONFIG_ARMV7_NONSEC if (ret) return ret;
+#ifdef CONFIG_ARMV7_NONSEC ret = psci_update_dt(blob); + if (ret) + return ret; #endif - return ret; + + return 0; }
There are two enable methods supported by ARM64 Linux; psci and spin-table. The latter is simpler and easier to use for quick SoC bring-up.
So, I used the spin-table for my first ARMv8 SoC porting, but I found its support in U-Boot was poor. It is true there exists a code fragment for the spin code in arch/arm/cpu/armv8/start.S, but I see some problems:
- We must hard-code CPU_RELEASE_ADDR so that it matches the "cpu-release-addr" property in the DT that comes from the kernel tree.
- The Documentation/arm64/booting.txt in Linux requires that the release address must be zero-initialized, but it is not cared by the common code in U-Boot. So, we must do it in a board specific manner.
- There is no systematic way to protect the spin code from the kernel. U-Boot relocates itself during the boot, so it is difficult to predict where the spin code will be located after the relocation, which makes it even more difficult to hard-code /memreserve/ in the DT of the kernel. One possible work-around would be to pre-fetch the spin-code into the I-cache of secondary CPUs, but this is an unsafe solution.
So, here is a patch to solve the problems. In this approach, the DT is run-time modified to reserve the spin code (+ cpu-release-addr). Also, the "cpu-release-addr" property is set to an appropriate address after the relocation, which means we no longer need the hard-coded CPU_RELEASE_ADDR.
Currently this patch only supports ARMv8, but theoretically nothing about the spin-table is arch-specific. Perhaps, we might want to support it on PowerPC in the future. So, I put the DT fixup code into the common/ directory. Very little code must be written in assembler, which went to the arch/arm/cpu/armv8/ directory.
arch/arm/cpu/armv8/Kconfig | 18 +++++++++++ arch/arm/cpu/armv8/Makefile | 1 + arch/arm/cpu/armv8/spin_table_v8.S | 22 ++++++++++++++ arch/arm/cpu/armv8/start.S | 10 +++--- arch/arm/lib/bootm-fdt.c | 7 +++++ common/Makefile | 1 + common/spin_table.c | 62 ++++++++++++++++++++++++++++++++++++++ include/spin_table.h | 14 +++++++++ 8 files changed, 131 insertions(+), 4 deletions(-) create mode 100644 arch/arm/cpu/armv8/spin_table_v8.S create mode 100644 common/spin_table.c create mode 100644 include/spin_table.h
diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 3d19bbf..019b625 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -3,4 +3,22 @@ if ARM64 config ARMV8_MULTIENTRY boolean "Enable multiple CPUs to enter into U-Boot"
+config SPIN_TABLE + bool "Support spin-table enable method" + depends on ARMV8_MULTIENTRY && OF_LIBFDT + help + Say Y here to support "spin-table" enable method for booting Linux. + + To use this feature, you must do: + - Specify enable-method = "spin-table" in each CPU node in the + Device Tree you are using to boot the kernel + - Let secondary CPUs in U-Boot (in a board specific manner) + before the master CPU jumps to the kernel + + U-Boot automatically does: + - Set "cpu-release-addr" property of each CPU node + (overwrites it if already exists). + - Reserve the code for the spin-table and the release address + via a /memreserve/ region in the Device Tree. + endif diff --git a/arch/arm/cpu/armv8/Makefile b/arch/arm/cpu/armv8/Makefile index 1c85aa9..2e3f421 100644 --- a/arch/arm/cpu/armv8/Makefile +++ b/arch/arm/cpu/armv8/Makefile @@ -15,6 +15,7 @@ obj-y += cache.o obj-y += tlb.o obj-y += transition.o obj-y += fwcall.o +obj-$(CONFIG_SPIN_TABLE) += spin_table_v8.o
obj-$(CONFIG_FSL_LAYERSCAPE) += fsl-layerscape/ obj-$(CONFIG_ARCH_ZYNQMP) += zynqmp/ diff --git a/arch/arm/cpu/armv8/spin_table_v8.S b/arch/arm/cpu/armv8/spin_table_v8.S new file mode 100644 index 0000000..2f1bd61 --- /dev/null +++ b/arch/arm/cpu/armv8/spin_table_v8.S @@ -0,0 +1,22 @@ +/* + * Copyright (C) 2016 Masahiro Yamada yamada.masahiro@socionext.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <linux/linkage.h> + +ENTRY(spin_table_secondary_jump) +.globl spin_table_reserve_begin +spin_table_reserve_begin: +0: wfe + ldr x0, spin_table_cpu_release_addr + cbz x0, 0b + br x0 +.globl spin_table_cpu_release_addr + .align 3 +spin_table_cpu_release_addr: + .quad 0 +.globl spin_table_reserve_end +spin_table_reserve_end: +ENDPROC(spin_table_secondary_jump) diff --git a/arch/arm/cpu/armv8/start.S b/arch/arm/cpu/armv8/start.S index 670e323..15ca864 100644 --- a/arch/arm/cpu/armv8/start.S +++ b/arch/arm/cpu/armv8/start.S @@ -94,7 +94,11 @@ reset: /* Processor specific initialization */ bl lowlevel_init
-#ifdef CONFIG_ARMV8_MULTIENTRY +#if defined(CONFIG_SPIN_TABLE) + branch_if_master x0, x1, master_cpu + b spin_table_secondary_jump + /* never return */ +#elif defined(CONFIG_ARMV8_MULTIENTRY) branch_if_master x0, x1, master_cpu
/* @@ -106,10 +110,8 @@ slave_cpu: ldr x0, [x1] cbz x0, slave_cpu br x0 /* branch to the given address */ -master_cpu: - /* On the master CPU */ #endif /* CONFIG_ARMV8_MULTIENTRY */ - +master_cpu: bl _main
#ifdef CONFIG_SYS_RESET_SCTRL diff --git a/arch/arm/lib/bootm-fdt.c b/arch/arm/lib/bootm-fdt.c index 76b75d8..ec581ac 100644 --- a/arch/arm/lib/bootm-fdt.c +++ b/arch/arm/lib/bootm-fdt.c @@ -21,6 +21,7 @@ #include <asm/armv7.h> #endif #include <asm/psci.h> +#include <spin_table.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -51,5 +52,11 @@ int arch_fixup_fdt(void *blob) return ret; #endif
+#ifdef CONFIG_SPIN_TABLE + ret = spin_table_update_dt(blob); + if (ret) + return ret; +#endif + return 0; } diff --git a/common/Makefile b/common/Makefile index 1557a04..f4eb381 100644 --- a/common/Makefile +++ b/common/Makefile @@ -141,6 +141,7 @@ obj-$(CONFIG_ANDROID_BOOT_IMAGE) += image-android.o obj-$(CONFIG_$(SPL_)OF_LIBFDT) += image-fdt.o obj-$(CONFIG_$(SPL_)FIT) += image-fit.o obj-$(CONFIG_$(SPL_)FIT_SIGNATURE) += image-sig.o +obj-$(CONFIG_$(SPL_)SPIN_TABLE) += spin_table.o obj-$(CONFIG_IO_TRACE) += iotrace.o obj-y += memsize.o obj-y += stdio.o diff --git a/common/spin_table.c b/common/spin_table.c new file mode 100644 index 0000000..046af8f --- /dev/null +++ b/common/spin_table.c @@ -0,0 +1,62 @@ +/* + * Copyright (C) 2016 Masahiro Yamada yamada.masahiro@socionext.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <libfdt.h> +#include <spin_table.h> + +int spin_table_update_dt(void *fdt) +{ + int cpus_offset, offset; + const char *prop; + int ret; + unsigned long rsv_addr = (unsigned long)&spin_table_reserve_begin; + unsigned long rsv_size = &spin_table_reserve_end - + &spin_table_reserve_begin; + + cpus_offset = fdt_path_offset(fdt, "/cpus"); + if (cpus_offset < 0) + return -ENODEV; + + for (offset = fdt_first_subnode(fdt, cpus_offset); + offset >= 0; + offset = fdt_next_subnode(fdt, offset)) { + prop = fdt_getprop(fdt, offset, "device_type", NULL); + if (!prop || strcmp(prop, "cpu")) + continue; + + /* + * In the first loop, we check if every CPU node specifies + * spin-table. Otherwise, just return successfully to not + * disturb other methods, like psci. + */ + prop = fdt_getprop(fdt, offset, "enable-method", NULL); + if (!prop || strcmp(prop, "spin-table")) + return 0; + } + + for (offset = fdt_first_subnode(fdt, cpus_offset); + offset >= 0; + offset = fdt_next_subnode(fdt, offset)) { + prop = fdt_getprop(fdt, offset, "device_type", NULL); + if (!prop || strcmp(prop, "cpu")) + continue; + + ret = fdt_setprop_u64(fdt, offset, "cpu-release-addr", + (unsigned long)&spin_table_cpu_release_addr); + if (ret) + return -ENOSPC; + } + + ret = fdt_add_mem_rsv(fdt, rsv_addr, rsv_size); + if (ret) + return -ENOSPC; + + printf(" Reserved memory region for spin-table: addr=%lx size=%lx\n", + rsv_addr, rsv_size); + + return 0; +} diff --git a/include/spin_table.h b/include/spin_table.h new file mode 100644 index 0000000..cf455a1 --- /dev/null +++ b/include/spin_table.h @@ -0,0 +1,14 @@ +/* + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __SPIN_TABLE_H__ +#define __SPIN_TABLE_H__ + +extern u64 spin_table_cpu_release_addr; +extern char spin_table_reserve_begin; +extern char spin_table_reserve_end; + +int spin_table_update_dt(void *fdt); + +#endif /* __SPIN_TABLE_H__ */
It's worth noting that while both arm64 and PPC have something called "spin-table", they're not quite the same. The arm64 version just reused the enable-method and property names for something different (and arch-specific).
I have no strong feelings about where the code lives, however.
Otherwise, these sound like useful improvements.
Thanks, Mark.
+config SPIN_TABLE
- bool "Support spin-table enable method"
- depends on ARMV8_MULTIENTRY && OF_LIBFDT
- help
- Copyright (C) 2016 Masahiro Yamada yamada.masahiro@socionext.com
- ldr x0, spin_table_cpu_release_addr
- cbz x0, 0b
- br x0
- .align 3
- .quad 0
- branch_if_master x0, x1, master_cpu
- b spin_table_secondary_jump
- /* never return */
- ret = spin_table_update_dt(blob);
- if (ret)
return ret;
- int cpus_offset, offset;
- const char *prop;
- int ret;
- unsigned long rsv_addr = (unsigned long)&spin_table_reserve_begin;
- unsigned long rsv_size = &spin_table_reserve_end -
- cpus_offset = fdt_path_offset(fdt, "/cpus");
- if (cpus_offset < 0)
return -ENODEV;
- for (offset = fdt_first_subnode(fdt, cpus_offset);
offset >= 0;
continue;
offset >= 0;
continue;
if (ret)
return -ENOSPC;
- ret = fdt_add_mem_rsv(fdt, rsv_addr, rsv_size);
- if (ret)
return -ENOSPC;
- printf(" Reserved memory region for spin-table: addr=%lx size=%lx\n",
1.9.1
2016-06-18 0:05 GMT+09:00 Mark Rutland mark.rutland@arm.com:
I did not know this. Thanks.
Maybe I should consider moving all the code to arch/arm/cpu/armv8/ and renaming CONFIG_SPIN_TABLE to CONFIG_ARMV8_SPIN_TABLE.
+config SPIN_TABLE
- help
- endif
- cbz x0, 0b
- br x0
- .align 3
- .quad 0
- if (ret)
return ret;
- return 0; }
- const char *prop;
- int ret;
return -ENODEV;
offset >= 0;
continue;
offset >= 0;
continue;
if (ret)
return -ENOSPC;
- if (ret)
return -ENOSPC;
Masahiro,
Because ARMv8 had no spin table support at time of our bring-up, and the core id is SoC specific, we put the code under SoC folder, now arch/arm/cpu/armv8/fsl-layerscape/fdt.c and arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S. We actually use multiple tables. More specifically one table per core. The spin table is protected from kernel by fdt_add_mem_rsv() function.
It will be great if we can consolidate the code and reuse what we already have.
York
On Fri, Jun 17, 2016 at 2:51 PM, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Is part of the motivation for this approach to boot an ARMv8 system without using the ARM Trusted Firmware?
Yours, Linus Walleij
2016-06-18 18:40 GMT+09:00 Linus Walleij linus.walleij@linaro.org:
Yes, exactly.
It would be the best choice to switch over to PSCI with ATF in a long run, but, I decided to use spin-table for the initial SoC bring-up because of tight schedule.
If I use spin-table, I can keep the boot sequence very simple.
Yes, exactly.
So if you don't have an ATF port ready, why not use U-Boot's PSCI implementation meanwhile? I think there are efforts underway to make PSCI enablement for random new boards a walk in the park (by making the PSCI support as generic as possible, CCing Chen-Yu for this).
IIRC the spin-table boot method was just introduced to cope with cores that don't have EL3 and thus cannot provide PSCI services the normal way (and that don't want to or cannot sacrifice EL2 for that). So I am a bit wary of proliferating this SMP method.
Wouldn't it be better to help making U-Boot's PSCI stack as easy to use as possible? I don't see technical reasons that adding PSCI support for a board should be harder or more involved than adding spin-table support - in the end you need to tell it about the SMP pen, maybe providing (or faking?) reset and shutdown for 0.2 compliance.
Cheers, Andre.
Yes, exactly.
We have a team working on PSCI for ARMv8. The patches are floating and need some minor fix. With these patches, PSCI will be used instead of spin-table. However, a trusted firmware (or other kind) is required.
York
Hi York,
2016-06-21 1:30 GMT+09:00 york sun york.sun@nxp.com:
Yes, exactly.
That's great.
So, what should we do about this patch?
I admit PSCI with ATF is the best way in the end, but I believe having a simpler alternative should not hurt.
On 06/24/2016 09:15 PM, Masahiro Yamada wrote:
Hi York,
Yes, exactly.
That's great.
I support using spin table as alternative. I see you already sent out v2 patch. It would be easier to maintain if we consolidate existing code with generic code.
York
Hi Andre,
2016-06-19 19:33 GMT+09:00 André Przywara andre.przywara@arm.com:
Yes, exactly.
So, you mean U-Boot can serve PSCI for ARMv8 SoCs without ATF, right? (and efforts underway for further improvement)
I know PSCI support is available for ARMv7 (arch/arm/cpu/armv7/psci.S), but I could not find PSCI implementation in arch/arm/cpu/armv8/ directory in the mainline U-Boot.
I checked Chen-Yu's patches on Patchwork, but I think they are mostly for improvement of ARMv7 PSCI support.
If I am missing something, could you point me to the reference, please?
Proliferating?
Many of ARM 32bit SoCs have vendor-specific SMP methods. On the other hand, ARM64 only has two methods; psci and spin-table.
Is this a problem?
Right.
My motivation is to bring up Linux quickly before ATF becomes ready.
From your statement, I felt
efforts for the ARMv8 PSCI implementation in U-Boot are underway. If so, I am definitely interested in it.
Hi Masahiro,
On 25/06/16 05:08, Masahiro Yamada wrote:
Hi Andre,
Yes, exactly.
Yes, if I am not mistaken then there are patches floating around to achieve this.
I think that's work in progress (as in "on the ML").
I think you found this yourself already in that other mail of yours?
Proliferating?
Yes, and this is a massive PITA, but hard to change now.
For a reason: Actually we just wanted to have PSCI only, but it turns out that it's not easily possible on cores that don't implement EL3 (which is architecturally allowed and also implemented). So spin-table support was added to provide a fall-back for those cases. But if you have the choice, then PSCI is your friend. Please note that any support for another SMP method is very unlikely to ever get merged into upstream Linux.
Is this a problem?
As mentioned, if you have a proper PSCI framework (as we are about to get for U-Boot and which ATF already provides), adding SMP support is not more involved than implementing spin tables. After all it's about specifying the pen address and possibly providing per-core power hooks.
Cheers, Andre.
Right.
From your statement, I felt efforts for the ARMv8 PSCI implementation in U-Boot are underway. If so, I am definitely interested in it.
On Mon, Jun 27, 2016 at 6:47 PM, Andre Przywara andre.przywara@arm.com wrote:
Hi Masahiro,
Hi Andre,
Yes, exactly.
The first part of the PSCI rework is already in master. The second part is here:
http://lists.denx.de/pipermail/u-boot/2016-June/258484.html
Or a rebased version:
https://github.com/wens/u-boot-sunxi/tree/psci-improve-part2
My work is still focused on ARMv7. However, with a lot of the code rewritten in C and modularized, I see no reason it could be moved up to arch/arm and reused for ARMv8. Same probably goes for the non-secure related stuff, but I haven't looked into those yet.
The remaining bits of assembly for PSCI are:
- exception vector table - PSCI secure monitor entry - stack setup - CPU entry function - ARMv7(?) SMP toggling (can be done in C with inline assembly) - ARMv7 specific cache flush
My only ARMv8 board (Pine64) is still gathering dust, and Andre is already working on an ATF port, so it's unlikely I will spend time there. Also I'm very unfamiliar with ARMv8.
Proliferating?
Get everyone on board with PSCI? :)
Regards ChenYu
Is this a problem?
Cheers, Andre.
Right.
participants (8)
Andre Przywara
André Przywara
Chen-Yu Tsai
Linus Walleij
Mark Rutland
Masahiro Yamada
york sun
