[U-Boot] Using U-boot command to write NAND flash
Please help, I am new to u-boot. The processor that we are using is AVR32 (AT32AP7000). U-Boot is a Boot Loader, its primary purpose is to load some operating system. Can we use the U-Boot to load our small application before loading the operating system (Linux)? Our small application will read a FPGA bit file from the NAND flash and configure the FPGA. U-Boot includes a basic interactive command interpreter, support for download over Ethernet and the capability to program the flash. Can we update the FPGA bit file (by programming NAND flash using U-boot command)? If yes, then which flash file system that U-boot uses to program the flash? and does that flasf file system take care of wear leveling in the NAND flash?
Thank you so much,
U-boot has low-level support for writing to NAND flash, but AFAIK does not have writeable support for any filesystems, wear-leveling, etc. If you need that, I suggest using Linux to update your flash.
-Scott
Dear Lyn.Tran@L-3com.com,
In message 615935CE76907149AFEC6599C969D4D5356B31@XCGTXH01.corp.eos.l-3com.com you wrote:
You could do that - but it raises the question why you would need a separate application to do that - U-Boot itself contains code to boot FPGAs. Why are you not using U-Boots capabilities?
You can use U-Boot to write JFFS2 and UBIFS images, but both of these are read-only, i. e. you cannot write a single file into an existing file system. Normally you would create a separate partition for such data if you need to update it in U-Boot context. UBI provides some flexible options for such tasks.
Lyn.Tran@L-3com.com
Scott Wood
