[U-Boot] [RFC Patch v6] Consolidate bool type
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99.
All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0.
Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files.
Signed-off-by: York Sun yorksun@freescale.com --- Change since v1: Move 'false' and 'true' to the common header file.
Change since v2: Use stdbool.h Consolidate all TRUE, FALSE, True, False, true, false
Change since v3: Fix boolean_t which was missed in v2.
Change since v4: Replace FALSE, False with false. Replace TRUE, True with true.
Change since v5: Revert changes for *.py, *.php, lib/* files. Revert change to type conversions. Revert comment-only changes. (Not sure about if we should replace the comments). Fix many coding style issues but left drivers/net/npe alone (way too many issues).
This patch doesn't address the white space issue where TRUE/FALSE is repalced.
Need help to test on all ARCHs with differnt toolchains as well as USE_PRIVATE_LIBGCC.
arch/arm/cpu/arm926ejs/spear/spear600.c | 37 +++-- arch/arm/cpu/arm926ejs/spear/spl_boot.c | 2 +- arch/blackfin/include/asm/posix_types.h | 3 - arch/m68k/lib/interrupts.c | 2 +- arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c | 2 +- arch/powerpc/cpu/ppc4xx/44x_spd_ddr.c | 71 +++++---- arch/powerpc/cpu/ppc4xx/44x_spd_ddr2.c | 201 ++++++++++++------------- arch/powerpc/cpu/ppc4xx/denali_spd_ddr2.c | 15 +- board/Marvell/db64360/mv_eth.h | 7 - board/Marvell/db64460/mv_eth.h | 7 - board/Marvell/include/core.h | 5 - board/amcc/bamboo/bamboo.c | 22 +-- board/amcc/bamboo/bamboo.h | 3 - board/amcc/yucca/yucca.c | 3 - board/bf533-ezkit/flash-defines.h | 2 - board/bf533-ezkit/flash.c | 4 +- board/bf533-stamp/video.h | 3 - board/esd/common/lcd.c | 10 +- board/esd/common/lcd.h | 5 - board/esd/cpci750/mv_eth.h | 7 - board/esd/dasa_sim/cmd_dasa_sim.c | 6 +- board/esd/pmc440/fpga.c | 16 +- board/evb64260/eth_addrtbl.c | 11 +- board/gen860t/fpga.c | 8 +- board/mpl/common/isa.c | 13 +- board/mpl/mip405/mip405.c | 5 +- board/mpl/pip405/pip405.c | 10 +- board/prodrive/p3mx/mv_eth.h | 7 - board/sacsng/clkinit.c | 4 +- board/sacsng/clkinit.h | 5 - board/spear/x600/fpga.c | 8 +- board/teejet/mt_ventoux/mt_ventoux.c | 4 +- board/xilinx/common/xbasic_types.c | 2 +- board/xilinx/common/xbasic_types.h | 8 - board/xilinx/common/xversion.c | 8 +- common/bedbug.c | 63 ++++---- common/cmd_bedbug.c | 4 +- common/cmd_fdc.c | 117 +++++++------- common/cmd_scsi.c | 18 +-- drivers/bios_emulator/atibios.c | 8 +- drivers/bios_emulator/x86emu/debug.c | 2 +- drivers/block/ahci.c | 6 +- drivers/block/sata_dwc.c | 34 ++--- drivers/block/sata_dwc.h | 7 - drivers/block/sym53c8xx.c | 14 +- drivers/fpga/ACEX1K.c | 14 +- drivers/fpga/altera.c | 4 +- drivers/fpga/cyclon2.c | 6 +- drivers/fpga/lattice.c | 4 +- drivers/fpga/spartan2.c | 58 +++---- drivers/fpga/spartan3.c | 60 ++++---- drivers/fpga/virtex2.c | 34 ++--- drivers/fpga/xilinx.c | 4 +- drivers/mtd/nand/mxc_nand.c | 2 - drivers/net/armada100_fec.c | 6 +- drivers/net/armada100_fec.h | 7 - drivers/net/e1000.c | 120 +++++++-------- drivers/net/e1000.h | 55 +++---- drivers/net/e1000_spi.c | 34 ++--- drivers/net/ne2000_base.h | 4 - drivers/net/npe/IxEthAcc.c | 10 +- drivers/net/npe/IxEthAccCommon.c | 26 ++-- drivers/net/npe/IxEthAccDataPlane.c | 16 +- drivers/net/npe/IxEthAccMac.c | 72 ++++----- drivers/net/npe/IxEthDBAPI.c | 26 ++-- drivers/net/npe/IxEthDBAPISupport.c | 42 +++--- drivers/net/npe/IxEthDBCore.c | 8 +- drivers/net/npe/IxEthDBEvents.c | 22 +-- drivers/net/npe/IxEthDBFeatures.c | 18 +-- drivers/net/npe/IxEthDBFirewall.c | 2 +- drivers/net/npe/IxEthDBNPEAdaptor.c | 2 +- drivers/net/npe/IxEthDBPortUpdate.c | 22 +-- drivers/net/npe/IxEthDBReports.c | 10 +- drivers/net/npe/IxEthDBSearch.c | 16 +- drivers/net/npe/IxEthDBUtil.c | 6 +- drivers/net/npe/IxEthMii.c | 22 +-- drivers/net/npe/IxFeatureCtrl.c | 18 +-- drivers/net/npe/IxNpeDl.c | 26 ++-- drivers/net/npe/IxNpeDlImageMgr.c | 16 +- drivers/net/npe/IxNpeDlNpeMgr.c | 10 +- drivers/net/npe/IxNpeMh.c | 6 +- drivers/net/npe/IxNpeMhConfig.c | 6 +- drivers/net/npe/IxNpeMhSend.c | 2 +- drivers/net/npe/IxOsalOsSemaphore.c | 4 +- drivers/net/npe/IxQMgrDispatcher.c | 24 +-- drivers/net/npe/IxQMgrInit.c | 6 +- drivers/net/npe/IxQMgrQCfg.c | 30 ++-- drivers/net/npe/include/IxEthAcc_p.h | 4 +- drivers/net/npe/include/IxEthDB_p.h | 22 +-- drivers/net/npe/include/IxOsalTypes.h | 16 -- drivers/net/npe/include/IxQMgrAqmIf_p.h | 22 +-- drivers/net/npe/npe.c | 14 +- drivers/rtc/ds1374.c | 29 ++-- drivers/usb/musb-new/linux-compat.h | 2 - fs/ext4/ext4_common.h | 2 - fs/ext4/ext4_journal.c | 8 +- include/at91rm9200_net.h | 4 - include/bedbug/ppc.h | 5 - include/fpga.h | 8 - include/galileo/core.h | 5 - include/linux/types.h | 1 + include/scsi.h | 8 - include/sym53c8xx.h | 7 - include/xyzModem.h | 8 - 104 files changed, 820 insertions(+), 1024 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/spear/spear600.c b/arch/arm/cpu/arm926ejs/spear/spear600.c index ff52131..9f0c1d1 100644 --- a/arch/arm/cpu/arm926ejs/spear/spear600.c +++ b/arch/arm/cpu/arm926ejs/spear/spear600.c @@ -28,9 +28,6 @@ #include <asm/arch/spr_misc.h> #include <asm/arch/spr_defs.h>
-#define FALSE 0 -#define TRUE (!FALSE) - static void sel_1v8(void) { struct misc_regs *misc_p = (struct misc_regs *)CONFIG_SPEAR_MISCBASE; @@ -133,8 +130,8 @@ void soc_init(void) /* * xxx_boot_selected: * - * return TRUE if the particular booting option is selected - * return FALSE otherwise + * return true if the particular booting option is selected + * return false otherwise */ static u32 read_bootstrap(void) { @@ -150,18 +147,18 @@ int snor_boot_selected(void) /* Check whether SNOR boot is selected */ if ((bootstrap & CONFIG_SPEAR_ONLYSNORBOOT) == CONFIG_SPEAR_ONLYSNORBOOT) - return TRUE; + return true;
if ((bootstrap & CONFIG_SPEAR_NORNANDBOOT) == CONFIG_SPEAR_NORNAND8BOOT) - return TRUE; + return true;
if ((bootstrap & CONFIG_SPEAR_NORNANDBOOT) == CONFIG_SPEAR_NORNAND16BOOT) - return TRUE; + return true; }
- return FALSE; + return false; }
int nand_boot_selected(void) @@ -172,20 +169,20 @@ int nand_boot_selected(void) /* Check whether NAND boot is selected */ if ((bootstrap & CONFIG_SPEAR_NORNANDBOOT) == CONFIG_SPEAR_NORNAND8BOOT) - return TRUE; + return true;
int pnor_boot_selected(void) { /* Parallel NOR boot is not selected in any SPEAr600 revision */ - return FALSE; + return false; }
int usb_boot_selected(void) @@ -195,39 +192,39 @@ int usb_boot_selected(void) if (USB_BOOT_SUPPORTED) { /* Check whether USB boot is selected */ if (!(bootstrap & CONFIG_SPEAR_USBBOOT)) - return TRUE; + return true; }
int tftp_boot_selected(void) { /* TFTP boot is not selected in any SPEAr600 revision */ - return FALSE; + return false; }
int uart_boot_selected(void) { /* UART boot is not selected in any SPEAr600 revision */ - return FALSE; + return false; }
int spi_boot_selected(void) { /* SPI boot is not selected in any SPEAr600 revision */ - return FALSE; + return false; }
int i2c_boot_selected(void) { /* I2C boot is not selected in any SPEAr600 revision */ - return FALSE; + return false; }
int mmc_boot_selected(void) { - return FALSE; + return false; }
void plat_late_init(void) diff --git a/arch/arm/cpu/arm926ejs/spear/spl_boot.c b/arch/arm/cpu/arm926ejs/spear/spl_boot.c index f2f9a49..3e2953c 100644 --- a/arch/arm/cpu/arm926ejs/spear/spl_boot.c +++ b/arch/arm/cpu/arm926ejs/spear/spl_boot.c @@ -120,7 +120,7 @@ u32 spl_boot(void) /* * All the supported booting devices are listed here. Each of * the booting type supported by the platform would define the - * macro xxx_BOOT_SUPPORTED to TRUE. + * macro xxx_BOOT_SUPPORTED to true. */
if (SNOR_BOOT_SUPPORTED && snor_boot_selected()) { diff --git a/arch/blackfin/include/asm/posix_types.h b/arch/blackfin/include/asm/posix_types.h index 000ffe5..1f28b36 100644 --- a/arch/blackfin/include/asm/posix_types.h +++ b/arch/blackfin/include/asm/posix_types.h @@ -61,9 +61,6 @@ typedef unsigned int __kernel_gid32_t; typedef unsigned short __kernel_old_uid_t; typedef unsigned short __kernel_old_gid_t;
-#define BOOL_WAS_DEFINED -typedef enum { false = 0, true = 1 } bool; - #ifdef __GNUC__ typedef long long __kernel_loff_t; #endif diff --git a/arch/m68k/lib/interrupts.c b/arch/m68k/lib/interrupts.c index 133494f..9751db4 100644 --- a/arch/m68k/lib/interrupts.c +++ b/arch/m68k/lib/interrupts.c @@ -96,7 +96,7 @@ int disable_interrupts (void) sr = get_sr (); set_sr (sr | 0x0700);
- return ((sr & 0x0700) == 0); /* return TRUE, if interrupts were enabled before */ + return ((sr & 0x0700) == 0); /* return true, if interrupts were enabled before */ }
void int_handler (struct pt_regs *fp) diff --git a/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c b/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c index 00e1c11..b621adf 100644 --- a/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c +++ b/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c @@ -517,7 +517,7 @@ void fsl_serdes_init(void) size_t arglen; #endif #ifdef CONFIG_SYS_P4080_ERRATUM_SERDES_A001 - int need_serdes_a001; /* TRUE == need work-around for SERDES A001 */ + int need_serdes_a001; /* true == need work-around for SERDES A001 */ #endif #ifdef CONFIG_SYS_P4080_ERRATUM_SERDES8 char buffer[HWCONFIG_BUFFER_SIZE]; diff --git a/arch/powerpc/cpu/ppc4xx/44x_spd_ddr.c b/arch/powerpc/cpu/ppc4xx/44x_spd_ddr.c index 8a20a2b..161d274 100644 --- a/arch/powerpc/cpu/ppc4xx/44x_spd_ddr.c +++ b/arch/powerpc/cpu/ppc4xx/44x_spd_ddr.c @@ -88,8 +88,6 @@ void spd_ddr_init_hang (void) __attribute__((weak, alias("__spd_ddr_init_hang")) #define NUMMEMTESTS 8 #define NUMMEMWORDS 8 #define MAXBXCR 4 -#define TRUE 1 -#define FALSE 0
/* * This DDR2 setup code can dynamically setup the TLB entries for the DDR2 memory @@ -298,7 +296,7 @@ static void get_spd_info(unsigned long *dimm_populated, unsigned char num_of_bytes; unsigned char total_size;
- dimm_found = FALSE; + dimm_found = false; for (dimm_num = 0; dimm_num < num_dimm_banks; dimm_num++) { num_of_bytes = 0; total_size = 0; @@ -307,16 +305,16 @@ static void get_spd_info(unsigned long *dimm_populated, total_size = spd_read(iic0_dimm_addr[dimm_num], 1);
if ((num_of_bytes != 0) && (total_size != 0)) { - dimm_populated[dimm_num] = TRUE; - dimm_found = TRUE; + dimm_populated[dimm_num] = true; + dimm_found = true; debug("DIMM slot %lu: populated\n", dimm_num); } else { - dimm_populated[dimm_num] = FALSE; + dimm_populated[dimm_num] = false; debug("DIMM slot %lu: Not populated\n", dimm_num); } }
- if (dimm_found == FALSE) { + if (dimm_found == false) { printf("ERROR - No memory installed. Install a DDR-SDRAM DIMM.\n\n"); spd_ddr_init_hang (); } @@ -330,7 +328,7 @@ static void check_mem_type(unsigned long *dimm_populated, unsigned char dimm_type;
for (dimm_num = 0; dimm_num < num_dimm_banks; dimm_num++) { - if (dimm_populated[dimm_num] == TRUE) { + if (dimm_populated[dimm_num] == true) { dimm_type = spd_read(iic0_dimm_addr[dimm_num], 2); switch (dimm_type) { case 7: @@ -356,7 +354,7 @@ static void check_volt_type(unsigned long *dimm_populated, unsigned long voltage_type;
for (dimm_num = 0; dimm_num < num_dimm_banks; dimm_num++) { - if (dimm_populated[dimm_num] == TRUE) { + if (dimm_populated[dimm_num] == true) { voltage_type = spd_read(iic0_dimm_addr[dimm_num], 8); if (voltage_type != 0x04) { printf("ERROR: DIMM %lu with unsupported voltage level.\n", @@ -398,12 +396,12 @@ static void program_cfg0(unsigned long *dimm_populated, /* * FIXME: assume the DDR SDRAMs in both banks are the same */ - ecc_enabled = TRUE; + ecc_enabled = true; for (dimm_num = 0; dimm_num < num_dimm_banks; dimm_num++) { - if (dimm_populated[dimm_num] == TRUE) { + if (dimm_populated[dimm_num] == true) { ecc = spd_read(iic0_dimm_addr[dimm_num], 11); if (ecc != 0x02) { - ecc_enabled = FALSE; + ecc_enabled = false; }
/* @@ -437,7 +435,7 @@ static void program_cfg0(unsigned long *dimm_populated, /* * program Memory Data Error Checking */ - if (ecc_enabled == TRUE) { + if (ecc_enabled == true) { cfg0 |= SDRAM_CFG0_MCHK_GEN; } else { cfg0 |= SDRAM_CFG0_MCHK_NON; @@ -493,7 +491,7 @@ static void program_rtr(unsigned long *dimm_populated, bus_period_x_10 = ONE_BILLION / (sys_info.freqPLB / 10);
for (dimm_num = 0; dimm_num < num_dimm_banks; dimm_num++) { - if (dimm_populated[dimm_num] == TRUE) { + if (dimm_populated[dimm_num] == true) { refresh_rate_type = 0x7F & spd_read(iic0_dimm_addr[dimm_num], 12); switch (refresh_rate_type) { case 0x00: @@ -585,15 +583,15 @@ static void program_tr0(unsigned long *dimm_populated, t_rp_ns = 0; t_rcd_ns = 0; t_ras_ns = 0; - cas_2_0_available = TRUE; - cas_2_5_available = TRUE; - cas_3_0_available = TRUE; + cas_2_0_available = true; + cas_2_5_available = true; + cas_3_0_available = true; tcyc_2_0_ns_x_10 = 0; tcyc_2_5_ns_x_10 = 0; tcyc_3_0_ns_x_10 = 0;
for (dimm_num = 0; dimm_num < num_dimm_banks; dimm_num++) { - if (dimm_populated[dimm_num] == TRUE) { + if (dimm_populated[dimm_num] == true) { wcsbc = spd_read(iic0_dimm_addr[dimm_num], 15); t_rp_ns = spd_read(iic0_dimm_addr[dimm_num], 27) >> 2; t_rcd_ns = spd_read(iic0_dimm_addr[dimm_num], 29) >> 2; @@ -640,7 +638,7 @@ static void program_tr0(unsigned long *dimm_populated, if (cas_index != 0) { cas_index++; } - cas_3_0_available = FALSE; + cas_3_0_available = false; }
if (((cas_bit & 0x08) != 0) || (cas_index < 3)) { @@ -650,7 +648,7 @@ static void program_tr0(unsigned long *dimm_populated, if (cas_index != 0) { cas_index++; } - cas_2_5_available = FALSE; + cas_2_5_available = false; }
if (((cas_bit & 0x04) != 0) || (cas_index < 3)) { @@ -660,7 +658,7 @@ static void program_tr0(unsigned long *dimm_populated, if (cas_index != 0) { cas_index++; } - cas_2_0_available = FALSE; + cas_2_0_available = false; }
break; @@ -683,13 +681,13 @@ static void program_tr0(unsigned long *dimm_populated, /* * Program SD_CASL field */ - if ((cas_2_0_available == TRUE) && + if ((cas_2_0_available == true) && (bus_period_x_10 >= tcyc_2_0_ns_x_10)) { tr0 |= SDRAM_TR0_SDCL_2_0_CLK; - } else if ((cas_2_5_available == TRUE) && + } else if ((cas_2_5_available == true) && (bus_period_x_10 >= tcyc_2_5_ns_x_10)) { tr0 |= SDRAM_TR0_SDCL_2_5_CLK; - } else if ((cas_3_0_available == TRUE) && + } else if ((cas_3_0_available == true) && (bus_period_x_10 >= tcyc_3_0_ns_x_10)) { tr0 |= SDRAM_TR0_SDCL_3_0_CLK; } else { @@ -950,9 +948,9 @@ static void program_tr1(void) current_fail_length = 0; current_start = 0; rdclt_offset = 0; - window_found = FALSE; - fail_found = FALSE; - pass_found = FALSE; + window_found = false; + fail_found = false; + pass_found = false; debug("Starting memory test ");
for (k = 0; k < NUMHALFCYCLES; k++) { @@ -963,8 +961,8 @@ static void program_tr1(void) mtsdram(SDRAM0_TR1, (tr1 | SDRAM_TR1_RDCT_ENCODE(rdclt)));
if (short_mem_test()) { - if (fail_found == TRUE) { - pass_found = TRUE; + if (fail_found == true) { + pass_found = true; if (current_pass_length == 0) { current_start = rdclt_offset + rdclt; } @@ -983,10 +981,10 @@ static void program_tr1(void) current_fail_length++;
if (current_fail_length >= (dly_val>>2)) { - if (fail_found == FALSE) { - fail_found = TRUE; - } else if (pass_found == TRUE) { - window_found = TRUE; + if (fail_found == false) { + fail_found = true; + } else if (pass_found == true) { + window_found = true; break; } } @@ -994,9 +992,8 @@ static void program_tr1(void) } debug(".");
- if (window_found == TRUE) { + if (window_found == true) break; - }
tr1 = tr1 ^ SDRAM_TR1_RDCD_MASK; rdclt_offset += dly_val; @@ -1006,7 +1003,7 @@ static void program_tr1(void) /* * make sure we find the window */ - if (window_found == FALSE) { + if (window_found == false) { printf("ERROR: Cannot determine a common read delay.\n"); spd_ddr_init_hang (); } @@ -1115,7 +1112,7 @@ static unsigned long program_bxcr(unsigned long *dimm_populated, bank_base_addr = CONFIG_SYS_SDRAM_BASE;
for (dimm_num = 0; dimm_num < num_dimm_banks; dimm_num++) { - if (dimm_populated[dimm_num] == TRUE) { + if (dimm_populated[dimm_num] == true) { num_row_addr = spd_read(iic0_dimm_addr[dimm_num], 3); num_col_addr = spd_read(iic0_dimm_addr[dimm_num], 4); num_banks = spd_read(iic0_dimm_addr[dimm_num], 5); diff --git a/arch/powerpc/cpu/ppc4xx/44x_spd_ddr2.c b/arch/powerpc/cpu/ppc4xx/44x_spd_ddr2.c index 85217ea..def7ebf 100644 --- a/arch/powerpc/cpu/ppc4xx/44x_spd_ddr2.c +++ b/arch/powerpc/cpu/ppc4xx/44x_spd_ddr2.c @@ -241,13 +241,6 @@ void board_add_ram_info(int use_default) /*-----------------------------------------------------------------------------+ * Defines *-----------------------------------------------------------------------------*/ -#ifndef TRUE -#define TRUE 1 -#endif -#ifndef FALSE -#define FALSE 0 -#endif - #define SDRAM_DDR1 1 #define SDRAM_DDR2 2 #define SDRAM_NONE 0 @@ -683,7 +676,7 @@ static void get_spd_info(unsigned long *dimm_populated, unsigned char num_of_bytes; unsigned char total_size;
- dimm_found = FALSE; + dimm_found = false; for (dimm_num = 0; dimm_num < num_dimm_banks; dimm_num++) { num_of_bytes = 0; total_size = 0; @@ -696,16 +689,16 @@ static void get_spd_info(unsigned long *dimm_populated, iic0_dimm_addr[dimm_num], total_size);
- if (dimm_found == FALSE) { + if (dimm_found == false) { printf("ERROR - No memory installed. Install a DDR-SDRAM DIMM.\n\n"); spd_ddr_init_hang (); } @@ -724,7 +717,7 @@ static void check_mem_type(unsigned long *dimm_populated, unsigned long dimm_type;
for (dimm_num = 0; dimm_num < num_dimm_banks; dimm_num++) { - if (dimm_populated[dimm_num] == TRUE) { + if (dimm_populated[dimm_num] == true) { dimm_type = spd_read(iic0_dimm_addr[dimm_num], 2); switch (dimm_type) { case 1: @@ -994,14 +987,14 @@ static void program_copt1(unsigned long *dimm_populated, unsigned long val;
#ifdef CONFIG_DDR_ECC - ecc_enabled = TRUE; + ecc_enabled = true; #else - ecc_enabled = FALSE; + ecc_enabled = false; #endif - dimm_32bit = FALSE; - dimm_64bit = FALSE; - buf0 = FALSE; - buf1 = FALSE; + dimm_32bit = false; + dimm_64bit = false; + buf0 = false; + buf1 = false;
/*------------------------------------------------------------------ * Set memory controller options reg 1, SDRAM_MCOPT1. @@ -1026,7 +1019,7 @@ static void program_copt1(unsigned long *dimm_populated, /* test ecc support */ ecc = (unsigned long)spd_read(iic0_dimm_addr[dimm_num], 11); if (ecc != 0x02) /* ecc not supported */ - ecc_enabled = FALSE; + ecc_enabled = false;
/* test bank count */ bankcount = (unsigned long)spd_read(iic0_dimm_addr[dimm_num], 17); @@ -1048,15 +1041,15 @@ static void program_copt1(unsigned long *dimm_populated, if (registered == 1) { /* DDR2 always buffered */ /* TODO: what about above comments ? */ mcopt1 |= SDRAM_MCOPT1_RDEN; - buf0 = TRUE; + buf0 = true; } else { /* TODO: the mask 0x02 doesn't match Samsung def for byte 21. */ if ((attribute & 0x02) == 0x00) { /* buffered not supported */ - buf0 = FALSE; + buf0 = false; } else { mcopt1 |= SDRAM_MCOPT1_RDEN; - buf0 = TRUE; + buf0 = true; } } } @@ -1068,14 +1061,14 @@ static void program_copt1(unsigned long *dimm_populated, if (registered == 1) { /* DDR2 always buffered */ mcopt1 |= SDRAM_MCOPT1_RDEN; - buf1 = TRUE; + buf1 = true; } else { if ((attribute & 0x02) == 0x00) { /* buffered not supported */ - buf1 = FALSE; + buf1 = false; } else { mcopt1 |= SDRAM_MCOPT1_RDEN; - buf1 = TRUE; + buf1 = true; } } } @@ -1087,11 +1080,11 @@ static void program_copt1(unsigned long *dimm_populated, switch (data_width) { case 72: case 64: - dimm_64bit = TRUE; + dimm_64bit = true; break; case 40: case 32: - dimm_32bit = TRUE; + dimm_32bit = true; break; default: printf("WARNING: Detected a DIMM with a data width of %lu bits.\n", @@ -1110,20 +1103,19 @@ static void program_copt1(unsigned long *dimm_populated, } }
- if ((dimm_64bit == TRUE) && (dimm_32bit == TRUE)) { + if ((dimm_64bit == true) && (dimm_32bit == true)) { printf("ERROR: Cannot mix 32 bit and 64 bit DDR-SDRAM DIMMs together.\n"); spd_ddr_init_hang (); - } - else if ((dimm_64bit == TRUE) && (dimm_32bit == FALSE)) { + } else if ((dimm_64bit == true) && (dimm_32bit == false)) { mcopt1 |= SDRAM_MCOPT1_DMWD_64; - } else if ((dimm_64bit == FALSE) && (dimm_32bit == TRUE)) { + } else if ((dimm_64bit == false) && (dimm_32bit == true)) { mcopt1 |= SDRAM_MCOPT1_DMWD_32; } else { printf("ERROR: Please install only 32 or 64 bit DDR-SDRAM DIMMs.\n\n"); spd_ddr_init_hang (); }
- if (ecc_enabled == TRUE) + if (ecc_enabled == true) mcopt1 |= SDRAM_MCOPT1_MCHK_GEN; else mcopt1 |= SDRAM_MCOPT1_MCHK_NON; @@ -1171,14 +1163,14 @@ static void program_codt(unsigned long *dimm_populated, total_rank += dimm_rank; total_dimm++; if ((dimm_num == 0) && (total_dimm == 1)) - firstSlot = TRUE; + firstSlot = true; else - firstSlot = FALSE; + firstSlot = false; } } if (dimm_type == SDRAM_DDR2) { codt |= SDRAM_CODT_DQS_1_8_V_DDR2; - if ((total_dimm == 1) && (firstSlot == TRUE)) { + if ((total_dimm == 1) && (firstSlot == true)) { if (total_rank == 1) { /* PUUU */ codt |= CALC_ODT_R(0); modt0 = CALC_ODT_W(0); @@ -1193,7 +1185,7 @@ static void program_codt(unsigned long *dimm_populated, modt2 = 0x00000000; modt3 = 0x00000000; } - } else if ((total_dimm == 1) && (firstSlot != TRUE)) { + } else if ((total_dimm == 1) && (firstSlot != true)) { if (total_rank == 1) { /* UUPU */ codt |= CALC_ODT_R(2); modt0 = 0x00000000; @@ -1467,26 +1459,26 @@ static void program_mode(unsigned long *dimm_populated, * the dimm modules installed. *-----------------------------------------------------------------*/ t_wr_ns = 0; - cas_2_0_available = TRUE; - cas_2_5_available = TRUE; - cas_3_0_available = TRUE; - cas_4_0_available = TRUE; - cas_5_0_available = TRUE; + cas_2_0_available = true; + cas_2_5_available = true; + cas_3_0_available = true; + cas_4_0_available = true; + cas_5_0_available = true; max_2_0_tcyc_ns_x_100 = 10; max_2_5_tcyc_ns_x_100 = 10; max_3_0_tcyc_ns_x_100 = 10; max_4_0_tcyc_ns_x_100 = 10; max_5_0_tcyc_ns_x_100 = 10; - sdram_ddr1 = TRUE; + sdram_ddr1 = true;
/* loop through all the DIMM slots on the board */ for (dimm_num = 0; dimm_num < num_dimm_banks; dimm_num++) { /* If a dimm is installed in a particular slot ... */ if (dimm_populated[dimm_num] != SDRAM_NONE) { if (dimm_populated[dimm_num] == SDRAM_DDR1) - sdram_ddr1 = TRUE; + sdram_ddr1 = true; else - sdram_ddr1 = FALSE; + sdram_ddr1 = false;
cas_bit = spd_read(iic0_dimm_addr[dimm_num], 18); debug("cas_bit[SPD byte 18]=%02lx\n", cas_bit); @@ -1543,7 +1535,7 @@ static void program_mode(unsigned long *dimm_populated, } else { if (cas_index != 0) cas_index++; - cas_4_0_available = FALSE; + cas_4_0_available = false; }
if (((cas_bit & 0x10) == 0x10) && (cas_index < 3) && @@ -1554,7 +1546,7 @@ static void program_mode(unsigned long *dimm_populated, } else { if (cas_index != 0) cas_index++; - cas_3_0_available = FALSE; + cas_3_0_available = false; }
if (((cas_bit & 0x08) == 0x08) && (cas_index < 3) && @@ -1565,7 +1557,7 @@ static void program_mode(unsigned long *dimm_populated, } else { if (cas_index != 0) cas_index++; - cas_2_5_available = FALSE; + cas_2_5_available = false; }
if (((cas_bit & 0x04) == 0x04) && (cas_index < 3) && @@ -1576,7 +1568,7 @@ static void program_mode(unsigned long *dimm_populated, } else { if (cas_index != 0) cas_index++; - cas_2_0_available = FALSE; + cas_2_0_available = false; } } else { /* @@ -1592,7 +1584,7 @@ static void program_mode(unsigned long *dimm_populated, } else { if (cas_index != 0) cas_index++; - cas_5_0_available = FALSE; + cas_5_0_available = false; }
if (((cas_bit & 0x10) == 0x10) && (cas_index < 3) && @@ -1603,7 +1595,7 @@ static void program_mode(unsigned long *dimm_populated, } else { if (cas_index != 0) cas_index++; - cas_4_0_available = FALSE; + cas_4_0_available = false; }
if (((cas_bit & 0x08) == 0x08) && (cas_index < 3) && @@ -1614,7 +1606,7 @@ static void program_mode(unsigned long *dimm_populated, } else { if (cas_index != 0) cas_index++; - cas_3_0_available = FALSE; + cas_3_0_available = false; } } } @@ -1636,14 +1628,17 @@ static void program_mode(unsigned long *dimm_populated, debug("cycle_4_0_clk=%lu\n", cycle_4_0_clk); debug("cycle_5_0_clk=%lu\n", cycle_5_0_clk);
- if (sdram_ddr1 == TRUE) { /* DDR1 */ - if ((cas_2_0_available == TRUE) && (sdram_freq <= cycle_2_0_clk)) { + if (sdram_ddr1 == true) { /* DDR1 */ + if ((cas_2_0_available == true) && + (sdram_freq <= cycle_2_0_clk)) { mmode |= SDRAM_MMODE_DCL_DDR1_2_0_CLK; *selected_cas = DDR_CAS_2; - } else if ((cas_2_5_available == TRUE) && (sdram_freq <= cycle_2_5_clk)) { + } else if ((cas_2_5_available == true) && + (sdram_freq <= cycle_2_5_clk)) { mmode |= SDRAM_MMODE_DCL_DDR1_2_5_CLK; *selected_cas = DDR_CAS_2_5; - } else if ((cas_3_0_available == TRUE) && (sdram_freq <= cycle_3_0_clk)) { + } else if ((cas_3_0_available == true) && + (sdram_freq <= cycle_3_0_clk)) { mmode |= SDRAM_MMODE_DCL_DDR1_3_0_CLK; *selected_cas = DDR_CAS_3; } else { @@ -1656,13 +1651,16 @@ static void program_mode(unsigned long *dimm_populated, debug("cas_3_0_available=%d\n", cas_3_0_available); debug("cas_4_0_available=%d\n", cas_4_0_available); debug("cas_5_0_available=%d\n", cas_5_0_available); - if ((cas_3_0_available == TRUE) && (sdram_freq <= cycle_3_0_clk)) { + if ((cas_3_0_available == true) && + (sdram_freq <= cycle_3_0_clk)) { mmode |= SDRAM_MMODE_DCL_DDR2_3_0_CLK; *selected_cas = DDR_CAS_3; - } else if ((cas_4_0_available == TRUE) && (sdram_freq <= cycle_4_0_clk)) { + } else if ((cas_4_0_available == true) && + (sdram_freq <= cycle_4_0_clk)) { mmode |= SDRAM_MMODE_DCL_DDR2_4_0_CLK; *selected_cas = DDR_CAS_4; - } else if ((cas_5_0_available == TRUE) && (sdram_freq <= cycle_5_0_clk)) { + } else if ((cas_5_0_available == true) && + (sdram_freq <= cycle_5_0_clk)) { mmode |= SDRAM_MMODE_DCL_DDR2_5_0_CLK; *selected_cas = DDR_CAS_5; } else { @@ -1677,7 +1675,7 @@ static void program_mode(unsigned long *dimm_populated, } }
- if (sdram_ddr1 == TRUE) + if (sdram_ddr1 == true) mmode |= SDRAM_MMODE_WR_DDR1; else {
@@ -1851,16 +1849,16 @@ static void program_tr(unsigned long *dimm_populated, t_wpc_ns = 0; t_wtr_ns = 0; t_rpc_ns = 0; - sdram_ddr1 = TRUE; + sdram_ddr1 = true;
/* loop through all the DIMM slots on the board */ for (dimm_num = 0; dimm_num < num_dimm_banks; dimm_num++) { /* If a dimm is installed in a particular slot ... */ if (dimm_populated[dimm_num] != SDRAM_NONE) { if (dimm_populated[dimm_num] == SDRAM_DDR2) - sdram_ddr1 = TRUE; + sdram_ddr1 = true; else - sdram_ddr1 = FALSE; + sdram_ddr1 = false;
t_rcd_ns = max(t_rcd_ns, spd_read(iic0_dimm_addr[dimm_num], 29) >> 2); t_rrd_ns = max(t_rrd_ns, spd_read(iic0_dimm_addr[dimm_num], 28) >> 2); @@ -1925,7 +1923,7 @@ static void program_tr(unsigned long *dimm_populated, break; }
- if (sdram_ddr1 == TRUE) { /* DDR1 */ + if (sdram_ddr1 == true) { /* DDR1 */ if (sdram_freq < 200000000) { sdtr2 |= SDRAM_SDTR2_WTR_1_CLK; sdtr2 |= SDRAM_SDTR2_WPC_2_CLK; @@ -2548,8 +2546,8 @@ calibration_loop: current_pass_length = 0; current_fail_length = 0; current_start = 0; - fail_found = FALSE; - pass_found = FALSE; + fail_found = false; + pass_found = false;
/* * get the delay line calibration register value @@ -2570,8 +2568,8 @@ calibration_loop: * See if the rffd value passed. *-----------------------------------------------------------------*/ if (short_mem_test()) { - if (fail_found == TRUE) { - pass_found = TRUE; + if (fail_found == true) { + pass_found = true; if (current_pass_length == 0) current_start = rffd;
@@ -2589,11 +2587,10 @@ calibration_loop: current_fail_length++;
if (current_fail_length >= (dly_val >> 2)) { - if (fail_found == FALSE) { - fail_found = TRUE; - } else if (pass_found == TRUE) { + if (fail_found == false) + fail_found = true; + else if (pass_found == true) break; - } } } } /* for rffd */ @@ -2618,9 +2615,9 @@ calibration_loop: current_pass_length = 0; current_fail_length = 0; current_start = 0; - window_found = FALSE; - fail_found = FALSE; - pass_found = FALSE; + window_found = false; + fail_found = false; + pass_found = false;
for (rqfd = 0; rqfd <= SDRAM_RQDC_RQFD_MAX; rqfd++) { mfsdram(SDRAM_RQDC, rqdc_reg); @@ -2635,8 +2632,8 @@ calibration_loop: * See if the rffd value passed. *-----------------------------------------------------------------*/ if (short_mem_test()) { - if (fail_found == TRUE) { - pass_found = TRUE; + if (fail_found == true) { + pass_found = true; if (current_pass_length == 0) current_start = rqfd;
@@ -2653,10 +2650,10 @@ calibration_loop: current_pass_length = 0; current_fail_length++;
- if (fail_found == FALSE) { - fail_found = TRUE; - } else if (pass_found == TRUE) { - window_found = TRUE; + if (fail_found == false) { + fail_found = true; + } else if (pass_found == true) { + window_found = true; break; } } @@ -2667,7 +2664,7 @@ calibration_loop: /*------------------------------------------------------------------ * Make sure we found the valid read passing window. Halt if not *-----------------------------------------------------------------*/ - if (window_found == FALSE) { + if (window_found == false) { if (rqfd_start < SDRAM_RQDC_RQFD_MAX) { putc('\b'); putc(slash[loopi++ % 8]); @@ -2769,13 +2766,13 @@ static void test(void) mtsdram(SDRAM_MCOPT1, (val & ~SDRAM_MCOPT1_MCHK_MASK) | SDRAM_MCOPT1_MCHK_NON);
- window_found = FALSE; - begin_found[0] = FALSE; - end_found[0] = FALSE; - search_end[0] = FALSE; - begin_found[1] = FALSE; - end_found[1] = FALSE; - search_end[1] = FALSE; + window_found = false; + begin_found[0] = false; + end_found[0] = false; + search_end[0] = false; + begin_found[1] = false; + end_found[1] = false; + search_end[1] = false;
for (dimm_num = 0; dimm_num < MAXDIMMS; dimm_num++) { mfsdram(SDRAM_MB0CF + (bxcr_num << 2), bxcf[bxcr_num]); @@ -2812,32 +2809,32 @@ static void test(void) * See if the rffd value passed. *-----------------------------------------------------------------*/ if (i < NUMMEMTESTS) { - if ((end_found[dimm_num] == FALSE) && - (search_end[dimm_num] == TRUE)) { - end_found[dimm_num] = TRUE; + if ((end_found[dimm_num] == false) && + (search_end[dimm_num] == true)) { + end_found[dimm_num] = true; } - if ((end_found[0] == TRUE) && - (end_found[1] == TRUE)) + if ((end_found[0] == true) && + (end_found[1] == true)) break; } else { - if (begin_found[dimm_num] == FALSE) { - begin_found[dimm_num] = TRUE; - search_end[dimm_num] = TRUE; + if (begin_found[dimm_num] == false) { + begin_found[dimm_num] = true; + search_end[dimm_num] = true; } } } else { - begin_found[dimm_num] = TRUE; - end_found[dimm_num] = TRUE; + begin_found[dimm_num] = true; + end_found[dimm_num] = true; } }
- if ((begin_found[0] == TRUE) && (begin_found[1] == TRUE)) - window_found = TRUE; + if ((begin_found[0] == true) && (begin_found[1] == true)) + window_found = true;
/*------------------------------------------------------------------ * Make sure we found the valid read passing window. Halt if not *-----------------------------------------------------------------*/ - if (window_found == FALSE) { + if (window_found == false) { printf("ERROR: Cannot determine a common read delay for the " "DIMM(s) installed.\n"); spd_ddr_init_hang (); diff --git a/arch/powerpc/cpu/ppc4xx/denali_spd_ddr2.c b/arch/powerpc/cpu/ppc4xx/denali_spd_ddr2.c index ce769a7..3ceab32 100644 --- a/arch/powerpc/cpu/ppc4xx/denali_spd_ddr2.c +++ b/arch/powerpc/cpu/ppc4xx/denali_spd_ddr2.c @@ -53,13 +53,6 @@ /*-----------------------------------------------------------------------------+ * Defines *-----------------------------------------------------------------------------*/ -#ifndef TRUE -#define TRUE 1 -#endif -#ifndef FALSE -#define FALSE 0 -#endif - #define MAXDIMMS 2 #define MAXRANKS 2
@@ -279,7 +272,7 @@ static void get_spd_info(unsigned long dimm_ranks[], unsigned long num_dimm_banks) { unsigned long dimm_num; - unsigned long dimm_found = FALSE; + unsigned long dimm_found = false; unsigned long const max_ranks_per_dimm = (1 == num_dimm_banks) ? 2 : 1; unsigned char num_of_bytes; unsigned char total_size; @@ -334,7 +327,7 @@ static void get_spd_info(unsigned long dimm_ranks[], "\n\n"); spd_ddr_init_hang(); } - dimm_found = TRUE; + dimm_found = true; debug("DIMM slot %lu: populated with %lu-rank DDR2 DIMM" "\n", dimm_num, ranks_on_dimm); if (ranks_on_dimm > max_ranks_per_dimm) { @@ -355,7 +348,7 @@ static void get_spd_info(unsigned long dimm_ranks[], debug("DIMM slot %lu: Not populated\n", dimm_num); } } - if (dimm_found == FALSE) { + if (dimm_found == false) { printf("ERROR: No memory installed.\n"); printf("Install at least one DDR2 DIMM.\n\n"); spd_ddr_init_hang(); @@ -882,7 +875,7 @@ static void program_ddr0_22(unsigned long dimm_ranks[], /* Check for ECC */ if (0 == (spd_read(iic0_dimm_addr[dimm_num], 11) & 0x02)) { - ecc_available = FALSE; + ecc_available = false; } } } diff --git a/board/Marvell/db64360/mv_eth.h b/board/Marvell/db64360/mv_eth.h index bd8e05d..d7de9d9 100644 --- a/board/Marvell/db64360/mv_eth.h +++ b/board/Marvell/db64360/mv_eth.h @@ -46,13 +46,6 @@ ************************************************************************** ************************************************************************** *************************************************************************/ -#ifndef TRUE -#define TRUE 1 -#endif -#ifndef FALSE -#define FALSE 0 -#endif - /* In case not using SG on Tx, define MAX_SKB_FRAGS as 0 */ #ifndef MAX_SKB_FRAGS #define MAX_SKB_FRAGS 0 diff --git a/board/Marvell/db64460/mv_eth.h b/board/Marvell/db64460/mv_eth.h index af4e818..1107e95 100644 --- a/board/Marvell/db64460/mv_eth.h +++ b/board/Marvell/db64460/mv_eth.h @@ -47,13 +47,6 @@ ************************************************************************** ************************************************************************** *************************************************************************/ -#ifndef TRUE -#define TRUE 1 -#endif -#ifndef FALSE -#define FALSE 0 -#endif - /* In case not using SG on Tx, define MAX_SKB_FRAGS as 0 */ #ifndef MAX_SKB_FRAGS #define MAX_SKB_FRAGS 0 diff --git a/board/Marvell/include/core.h b/board/Marvell/include/core.h index c413439..3119d0a 100644 --- a/board/Marvell/include/core.h +++ b/board/Marvell/include/core.h @@ -91,11 +91,6 @@ extern unsigned int INTERNAL_REG_BASE_ADDR; #define _1G 0x40000000 #define _2G 0x80000000
-#ifndef BOOL_WAS_DEFINED -#define BOOL_WAS_DEFINED -typedef enum _bool{false,true} bool; -#endif - /* Little to Big endian conversion macros */
#ifdef LE /* Little Endian */ diff --git a/board/amcc/bamboo/bamboo.c b/board/amcc/bamboo/bamboo.c index 79788a8..6f5d0a6 100644 --- a/board/amcc/bamboo/bamboo.c +++ b/board/amcc/bamboo/bamboo.c @@ -477,16 +477,16 @@ int is_powerpc440ep_pass1(void) pvr = get_pvr();
if (pvr == PVR_POWERPC_440EP_PASS1) - return TRUE; + return true; else if (pvr == PVR_POWERPC_440EP_PASS2) - return FALSE; + return false; else { printf("brdutil error 3\n"); for (;;) ; }
- return(FALSE); + return false; }
/*----------------------------------------------------------------------------+ @@ -495,9 +495,9 @@ int is_powerpc440ep_pass1(void) int is_nand_selected(void) { #ifdef CONFIG_BAMBOO_NAND - return TRUE; + return true; #else - return FALSE; + return false; #endif }
@@ -507,7 +507,7 @@ int is_nand_selected(void) unsigned char config_on_ebc_cs4_is_small_flash(void) { /* Not implemented yet => returns constant value */ - return TRUE; + return true; }
/*----------------------------------------------------------------------------+ @@ -561,7 +561,7 @@ void ext_bus_cntlr_init(void) /*-------------------------------------------------------------------------+ | PPC440EP Pass1 +-------------------------------------------------------------------------*/ - if (is_powerpc440ep_pass1() == TRUE) { + if (is_powerpc440ep_pass1() == true) { switch(bootstrap_settings) { case SDR0_PSTRP0_BOOTSTRAP_SETTINGS0: /* Default Strap Settings 0 : CPU 400 - PLB 133 - Boot EBC 8 bit 33MHz */ @@ -738,7 +738,7 @@ void ext_bus_cntlr_init(void) /*------------------------------------------------------------------------- */ ebc0_cs0_bnap_value = EBC0_BNAP_SMALL_FLASH; ebc0_cs0_bncr_value = EBC0_BNCR_SMALL_FLASH_CS0; - if ((is_nand_selected()) == TRUE) { + if ((is_nand_selected()) == true) { /* NAND Flash */ ebc0_cs1_bnap_value = EBC0_BNAP_NAND_FLASH; ebc0_cs1_bncr_value = EBC0_BNCR_NAND_FLASH_CS1; @@ -765,7 +765,7 @@ void ext_bus_cntlr_init(void) /*------------------------------------------------------------------------- */ ebc0_cs0_bnap_value = EBC0_BNAP_LARGE_FLASH_OR_SRAM; ebc0_cs0_bncr_value = EBC0_BNCR_LARGE_FLASH_OR_SRAM_CS0; - if ((is_nand_selected()) == TRUE) { + if ((is_nand_selected()) == true) { /* NAND Flash */ ebc0_cs1_bnap_value = EBC0_BNAP_NAND_FLASH; ebc0_cs1_bncr_value = EBC0_BNCR_NAND_FLASH_CS1; @@ -812,7 +812,7 @@ void ext_bus_cntlr_init(void) ebc0_cs0_bnap_value = 0; ebc0_cs0_bncr_value = 0;
- if ((is_nand_selected()) == TRUE) { + if ((is_nand_selected()) == true) { /* NAND Flash */ ebc0_cs1_bnap_value = EBC0_BNAP_NAND_FLASH; ebc0_cs1_bncr_value = EBC0_BNCR_NAND_FLASH_CS1; @@ -830,7 +830,7 @@ void ext_bus_cntlr_init(void) ebc0_cs3_bncr_value = 0; }
- if ((config_on_ebc_cs4_is_small_flash()) == TRUE) { + if ((config_on_ebc_cs4_is_small_flash()) == true) { /* Small Flash */ ebc0_cs4_bnap_value = EBC0_BNAP_SMALL_FLASH; ebc0_cs4_bncr_value = EBC0_BNCR_SMALL_FLASH_CS4; diff --git a/board/amcc/bamboo/bamboo.h b/board/amcc/bamboo/bamboo.h index f2b78a9..6c49733 100644 --- a/board/amcc/bamboo/bamboo.h +++ b/board/amcc/bamboo/bamboo.h @@ -250,9 +250,6 @@ #define PVR_POWERPC_440EP_PASS1 0x42221850 #define PVR_POWERPC_440EP_PASS2 0x422218D3
-#define TRUE 1 -#define FALSE 0 - #define GPIO0 0 #define GPIO1 1
diff --git a/board/amcc/yucca/yucca.c b/board/amcc/yucca/yucca.c index 1fab794..f606d92 100644 --- a/board/amcc/yucca/yucca.c +++ b/board/amcc/yucca/yucca.c @@ -47,9 +47,6 @@ void fpga_init (void); #define DEBUGF(fmt,args...) #endif
-#define FALSE 0 -#define TRUE 1 - int board_early_init_f (void) { /*----------------------------------------------------------------------------+ diff --git a/board/bf533-ezkit/flash-defines.h b/board/bf533-ezkit/flash-defines.h index eb0af94..f073c0c 100644 --- a/board/bf533-ezkit/flash-defines.h +++ b/board/bf533-ezkit/flash-defines.h @@ -32,8 +32,6 @@
#define V_ULONG(a) (*(volatile unsigned long *)( a )) #define V_BYTE(a) (*(volatile unsigned char *)( a )) -#define TRUE 0x1 -#define FALSE 0x0 #define BUFFER_SIZE 0x80000 #define NO_COMMAND 0 #define GET_CODES 1 diff --git a/board/bf533-ezkit/flash.c b/board/bf533-ezkit/flash.c index ab808d8..e4fcd1e 100644 --- a/board/bf533-ezkit/flash.c +++ b/board/bf533-ezkit/flash.c @@ -309,7 +309,7 @@ int read_flash(long nOffset, int *pnValue) nValue = *(volatile unsigned short *)addr; SSYNC(); *pnValue = nValue; - return TRUE; + return true; }
int poll_toggle_bit(long lOffset) @@ -398,7 +398,7 @@ int erase_block_flash(int nBlock, unsigned long address) long ulSectorOff = 0x0;
if ((nBlock < 0) || (nBlock > AFP_NumSectors)) - return FALSE; + return false;
ulSectorOff = (address - CONFIG_SYS_FLASH_BASE);
diff --git a/board/bf533-stamp/video.h b/board/bf533-stamp/video.h index 80837e2..949c3d8 100644 --- a/board/bf533-stamp/video.h +++ b/board/bf533-stamp/video.h @@ -9,9 +9,6 @@ #define YELLOW (0xD292D210) /* yellow pixel pattern */ #define WHITE (0xFE80FE80) /* white pixel pattern */
-#define true 1 -#define false 0 - typedef struct { unsigned int sav; unsigned int eav; diff --git a/board/esd/common/lcd.c b/board/esd/common/lcd.c index 3dfbf3b..1a5f656 100644 --- a/board/esd/common/lcd.c +++ b/board/esd/common/lcd.c @@ -260,7 +260,7 @@ int lcd_init(uchar *lcd_reg, uchar *lcd_mem, S1D_REGS *regs, int reg_count, /* * Big epson detected */ - reg_byte_swap = FALSE; + reg_byte_swap = false; palette_index = 0x1e2; palette_value = 0x1e4; lcd_depth = 16; @@ -269,7 +269,7 @@ int lcd_init(uchar *lcd_reg, uchar *lcd_mem, S1D_REGS *regs, int reg_count, /* * Big epson detected (with register swap bug) */ - reg_byte_swap = TRUE; + reg_byte_swap = true; palette_index = 0x1e3; palette_value = 0x1e5; lcd_depth = 16; @@ -278,7 +278,7 @@ int lcd_init(uchar *lcd_reg, uchar *lcd_mem, S1D_REGS *regs, int reg_count, /* * Small epson detected (704) */ - reg_byte_swap = FALSE; + reg_byte_swap = false; palette_index = 0x15; palette_value = 0x17; lcd_depth = 8; @@ -287,7 +287,7 @@ int lcd_init(uchar *lcd_reg, uchar *lcd_mem, S1D_REGS *regs, int reg_count, /* * Small epson detected (705) */ - reg_byte_swap = FALSE; + reg_byte_swap = false; palette_index = 0x15; palette_value = 0x17; lcd_depth = 8; @@ -300,7 +300,7 @@ int lcd_init(uchar *lcd_reg, uchar *lcd_mem, S1D_REGS *regs, int reg_count, /* * S1D13505 detected */ - reg_byte_swap = TRUE; + reg_byte_swap = true; palette_index = 0x25; palette_value = 0x27; lcd_depth = 16; diff --git a/board/esd/common/lcd.h b/board/esd/common/lcd.h index 01f6019..5c48b5a 100644 --- a/board/esd/common/lcd.h +++ b/board/esd/common/lcd.h @@ -35,11 +35,6 @@ #define LOAD_LONG(data) SWAP_LONG(data) #define LOAD_SHORT(data) SWAP_SHORT(data)
-#ifndef FALSE -#define FALSE 0 -#define TRUE (!FALSE) -#endif - #define S1D_WRITE_PALETTE(p,i,r,g,b) \ { \ out_8(&((uchar*)(p))[palette_index], (uchar)(i)); \ diff --git a/board/esd/cpci750/mv_eth.h b/board/esd/cpci750/mv_eth.h index 3d0cb10..94745bc 100644 --- a/board/esd/cpci750/mv_eth.h +++ b/board/esd/cpci750/mv_eth.h @@ -47,13 +47,6 @@ ************************************************************************** ************************************************************************** *************************************************************************/ -#ifndef TRUE -#define TRUE 1 -#endif -#ifndef FALSE -#define FALSE 0 -#endif - /* In case not using SG on Tx, define MAX_SKB_FRAGS as 0 */ #ifndef MAX_SKB_FRAGS #define MAX_SKB_FRAGS 0 diff --git a/board/esd/dasa_sim/cmd_dasa_sim.c b/board/esd/dasa_sim/cmd_dasa_sim.c index 0014808..ccea715 100644 --- a/board/esd/dasa_sim/cmd_dasa_sim.c +++ b/board/esd/dasa_sim/cmd_dasa_sim.c @@ -30,10 +30,6 @@ #define OK 0 #define ERROR (-1)
-#define TRUE 1 -#define FALSE 0 - - extern u_long pci9054_iobase;
@@ -97,7 +93,7 @@ static int PciEepromWriteLongVPD (int offs, unsigned int value) } }
diff --git a/board/esd/pmc440/fpga.c b/board/esd/pmc440/fpga.c index f92bbff..d38cc96 100644 --- a/board/esd/pmc440/fpga.c +++ b/board/esd/pmc440/fpga.c @@ -113,7 +113,7 @@ void fpga_serialslave_init(void) { debug("%s:%d: Initialize serial slave interface\n", __FUNCTION__, __LINE__); - fpga_pgm_fn(FALSE, FALSE, 0); /* make sure program pin is inactive */ + fpga_pgm_fn(false, false, 0); /* make sure program pin is inactive */ }
@@ -188,7 +188,7 @@ int fpga_done_fn(int cookie) int fpga_pre_config_fn(int cookie) { debug("%s:%d: FPGA pre-configuration\n", __FUNCTION__, __LINE__); - fpga_reset(TRUE); + fpga_reset(true);
/* release init# */ out_be32((void*)GPIO0_OR, in_be32((void*)GPIO0_OR) | GPIO0_FPGA_FORCEINIT); @@ -213,9 +213,9 @@ int fpga_post_config_fn(int cookie) /* enable PLD0..7 pins */ out_be32((void*)GPIO1_OR, in_be32((void*)GPIO1_OR) & ~GPIO1_IOEN_N);
- fpga_reset(TRUE); + fpga_reset(true); udelay (100); - fpga_reset(FALSE); + fpga_reset(false); udelay (100);
FPGA_OUT32(&fpga->status, (gd->board_type << STATUS_HWREV_SHIFT) & STATUS_HWREV_MASK); @@ -296,7 +296,7 @@ void ngcc_fpga_serialslave_init(void) __FUNCTION__, __LINE__);
/* make sure program pin is inactive */ - ngcc_fpga_pgm_fn (FALSE, FALSE, 0); + ngcc_fpga_pgm_fn(false, false, 0); }
/* @@ -382,10 +382,10 @@ int ngcc_fpga_pre_config_fn(int cookie) pmc440_fpga_t *fpga = (pmc440_fpga_t *)FPGA_BA; debug("%s:%d: FPGA pre-configuration\n", __FUNCTION__, __LINE__);
- ngcc_fpga_reset(TRUE); + ngcc_fpga_reset(true); FPGA_CLRBITS(&fpga->ctrla, 0xfffffe00);
- ngcc_fpga_reset(TRUE); + ngcc_fpga_reset(true); return 0; }
@@ -401,7 +401,7 @@ int ngcc_fpga_post_config_fn(int cookie) debug("%s:%d: NGCC FPGA post configuration\n", __FUNCTION__, __LINE__);
udelay (100); - ngcc_fpga_reset(FALSE); + ngcc_fpga_reset(false);
FPGA_SETBITS(&fpga->ctrla, 0x29f8c000);
diff --git a/board/evb64260/eth_addrtbl.c b/board/evb64260/eth_addrtbl.c index e8ef0e3..8c2c17f 100644 --- a/board/evb64260/eth_addrtbl.c +++ b/board/evb64260/eth_addrtbl.c @@ -6,9 +6,6 @@ #include "eth.h" #include "eth_addrtbl.h"
-#define TRUE 1 -#define FALSE 0 - #define PRINTF printf
#ifdef CONFIG_GT_USE_MAC_HASH_TABLE @@ -160,8 +157,8 @@ u32 hashTableFunction (u32 macH, u32 macL, u32 HashSize, u32 hash_mode) * rd - the RD field in the address table. * Outputs * address table entry is added. - * TRUE if success. - * FALSE if table full + * true if success. + * false if table full */ int addAddressTableEntry (u32 port, u32 macH, u32 macL, u32 rd, u32 skip) { @@ -206,7 +203,7 @@ int addAddressTableEntry (u32 port, u32 macH, u32 macL, u32 rd, u32 skip)
if (i == HOP_NUMBER) { PRINTF ("addGT64260addressTableEntry: table section is full\n"); - return (FALSE); + return false; }
/* @@ -215,7 +212,7 @@ int addAddressTableEntry (u32 port, u32 macH, u32 macL, u32 rd, u32 skip) entry->hi = newHi; entry->lo = newLo; DCACHE_FLUSH_N_SYNC ((u32) entry, MAC_ENTRY_SIZE); - return (TRUE); + return true; }
#endif /* CONFIG_GT_USE_MAC_HASH_TABLE */ diff --git a/board/gen860t/fpga.c b/board/gen860t/fpga.c index d42c500..4c36009 100644 --- a/board/gen860t/fpga.c +++ b/board/gen860t/fpga.c @@ -182,7 +182,7 @@ void fpga_selectmap_init (void) { PRINTF ("%s:%d: Initialize SelectMap interface\n", __FUNCTION__, __LINE__); - fpga_pgm_fn (FALSE, FALSE, 0); /* make sure program pin is inactive */ + fpga_pgm_fn(false, false, 0); /* make sure program pin is inactive */ }
@@ -314,7 +314,7 @@ int fpga_abort_fn (int cookie) int fpga_pre_config_fn (int cookie) { PRINTF ("%s:%d: FPGA pre-configuration\n", __FUNCTION__, __LINE__); - fpga_reset (TRUE); + fpga_reset(true); return 0; }
@@ -328,9 +328,9 @@ int fpga_post_config_fn (int cookie) int rc;
PRINTF ("%s:%d: FPGA post configuration\n", __FUNCTION__, __LINE__); - fpga_reset (TRUE); + fpga_reset(true); udelay (1000); - fpga_reset (FALSE); + fpga_reset(false); udelay (1000);
/* diff --git a/board/mpl/common/isa.c b/board/mpl/common/isa.c index fc56153..66724ed 100644 --- a/board/mpl/common/isa.c +++ b/board/mpl/common/isa.c @@ -41,13 +41,6 @@ #define PRINTF(fmt,args...) #endif
-#ifndef TRUE -#define TRUE 1 -#endif -#ifndef FALSE -#define FALSE 0 -#endif - #if defined(CONFIG_PIP405)
extern int drv_isa_kbd_init (void); @@ -116,9 +109,9 @@ unsigned char open_cfg_super_IO(int address) out8(CONFIG_SYS_ISA_IO_BASE_ADDRESS | address,0x55); /* open config */ out8(CONFIG_SYS_ISA_IO_BASE_ADDRESS | address,0x20); /* set address to DEV ID */ if(in8(CONFIG_SYS_ISA_IO_BASE_ADDRESS | address | 0x1)==0x40) /* ok Device ID is correct */ - return TRUE; + return true; else - return FALSE; + return false; }
void close_cfg_super_IO(int address) @@ -179,7 +172,7 @@ void isa_sio_loadtable(void)
void isa_sio_setup(void) { - if(open_cfg_super_IO(SIO_CFG_PORT)==TRUE) + if (open_cfg_super_IO(SIO_CFG_PORT) == true) { isa_sio_loadtable(); close_cfg_super_IO(0x3F0); diff --git a/board/mpl/mip405/mip405.c b/board/mpl/mip405/mip405.c index 56a84e9..89ea276 100644 --- a/board/mpl/mip405/mip405.c +++ b/board/mpl/mip405/mip405.c @@ -77,8 +77,6 @@ DECLARE_GLOBAL_DATA_PTR;
#undef SDRAM_DEBUG #define ENABLE_ECC /* for ecc boards */ -#define FALSE 0 -#define TRUE 1
/* stdlib.h causes some compatibility problems; should fixe these! -- wd */ #ifndef __ldiv_t_defined @@ -771,7 +769,8 @@ int last_stage_init (void)
int overwrite_console (void) { - return ((in8 (PLD_EXT_CONF_REG) & 0x1)==0); /* return TRUE if console should be overwritten */ + /* return true if console should be overwritten */ + return ((in8(PLD_EXT_CONF_REG) & 0x1) == 0); }
diff --git a/board/mpl/pip405/pip405.c b/board/mpl/pip405/pip405.c index 75f57ad..b203037 100644 --- a/board/mpl/pip405/pip405.c +++ b/board/mpl/pip405/pip405.c @@ -36,9 +36,6 @@ DECLARE_GLOBAL_DATA_PTR;
#undef SDRAM_DEBUG
-#define FALSE 0 -#define TRUE 1 - /* stdlib.h causes some compatibility problems; should fixe these! -- wd */ #ifndef __ldiv_t_defined typedef struct { @@ -700,7 +697,8 @@ int misc_init_r (void)
int overwrite_console (void) { - return (in8 (CONFIG_PORT_ADDR) & 0x1); /* return TRUE if console should be overwritten */ + /* return true if console should be overwritten */ + return in8(CONFIG_PORT_ADDR) & 0x1; }
@@ -945,7 +943,7 @@ void print_pip405_info (void)
void user_led0 (unsigned char on) { - if (on == TRUE) + if (on == true) out8 (PLD_LED_USER_REG, (in8 (PLD_LED_USER_REG) | 0x1)); else out8 (PLD_LED_USER_REG, (in8 (PLD_LED_USER_REG) & 0xfe)); @@ -953,7 +951,7 @@ void user_led0 (unsigned char on)
void user_led1 (unsigned char on) { - if (on == TRUE) + if (on == true) out8 (PLD_LED_USER_REG, (in8 (PLD_LED_USER_REG) | 0x2)); else out8 (PLD_LED_USER_REG, (in8 (PLD_LED_USER_REG) & 0xfd)); diff --git a/board/prodrive/p3mx/mv_eth.h b/board/prodrive/p3mx/mv_eth.h index 8cc00dc..58a8cb9 100644 --- a/board/prodrive/p3mx/mv_eth.h +++ b/board/prodrive/p3mx/mv_eth.h @@ -47,13 +47,6 @@ ************************************************************************** ************************************************************************** *************************************************************************/ -#ifndef TRUE -#define TRUE 1 -#endif -#ifndef FALSE -#define FALSE 0 -#endif - /* In case not using SG on Tx, define MAX_SKB_FRAGS as 0 */ #ifndef MAX_SKB_FRAGS #define MAX_SKB_FRAGS 0 diff --git a/board/sacsng/clkinit.c b/board/sacsng/clkinit.c index 4a7f362..3894a5c 100644 --- a/board/sacsng/clkinit.c +++ b/board/sacsng/clkinit.c @@ -94,11 +94,11 @@ uint Daq_BRG_Get_Div16(uint brg)
if (*brg_ptr & CPM_BRG_DIV16) { /* DIV16 active */ - return (TRUE); + return true; } else { /* DIV16 inactive */ - return (FALSE); + return false; } }
diff --git a/board/sacsng/clkinit.h b/board/sacsng/clkinit.h index 011638f..68d69db 100644 --- a/board/sacsng/clkinit.h +++ b/board/sacsng/clkinit.h @@ -22,11 +22,6 @@ * MA 02111-1307 USA */
-#ifndef FALSE -#define FALSE 0 -#define TRUE (!FALSE) -#endif - #define SLRCLK_EN_MASK 0x00040000 /* PA13 - SLRCLK_EN* */
#define MIN_SAMPLE_RATE 4000 /* Minimum sample rate */ diff --git a/board/spear/x600/fpga.c b/board/spear/x600/fpga.c index 85eb31b..74baa3f 100644 --- a/board/spear/x600/fpga.c +++ b/board/spear/x600/fpga.c @@ -113,7 +113,7 @@ static int fpga_done_fn(int cookie) static int fpga_pre_config_fn(int cookie) { debug("%s:%d: FPGA pre-configuration\n", __func__, __LINE__); - fpga_reset(TRUE); + fpga_reset(true);
return 0; } @@ -128,9 +128,9 @@ static int fpga_post_config_fn(int cookie)
debug("%s:%d: FPGA post configuration\n", __func__, __LINE__);
- fpga_reset(TRUE); + fpga_reset(true); udelay(100); - fpga_reset(FALSE); + fpga_reset(false); udelay(100);
return rc; @@ -200,7 +200,7 @@ static Xilinx_desc fpga[CONFIG_FPGA_COUNT] = { static void fpga_serialslave_init(void) { debug("%s:%d: Initialize serial slave interface\n", __func__, __LINE__); - fpga_pgm_fn(FALSE, FALSE, 0); /* make sure program pin is inactive */ + fpga_pgm_fn(false, false, 0); /* make sure program pin is inactive */ }
static int expi_setup(int freq) diff --git a/board/teejet/mt_ventoux/mt_ventoux.c b/board/teejet/mt_ventoux/mt_ventoux.c index 9622a81..6629480 100644 --- a/board/teejet/mt_ventoux/mt_ventoux.c +++ b/board/teejet/mt_ventoux/mt_ventoux.c @@ -177,9 +177,9 @@ int fpga_post_config_fn(int cookie) { debug("%s:%d: FPGA post-configuration\n", __func__, __LINE__);
return 0; } diff --git a/board/xilinx/common/xbasic_types.c b/board/xilinx/common/xbasic_types.c index c3a171a..a82ab6e 100644 --- a/board/xilinx/common/xbasic_types.c +++ b/board/xilinx/common/xbasic_types.c @@ -77,7 +77,7 @@ unsigned int XAssertStatus; * such that it does not wait infinitely. Use the debugger to disable the * waiting during testing of asserts. */ -u32 XWaitInAssert = TRUE; +u32 XWaitInAssert = true;
/* The callback function to be invoked when an assert is taken */ static XAssertCallback XAssertCallbackRoutine = (XAssertCallback) NULL; diff --git a/board/xilinx/common/xbasic_types.h b/board/xilinx/common/xbasic_types.h index ef0b7c2..a89fe02 100644 --- a/board/xilinx/common/xbasic_types.h +++ b/board/xilinx/common/xbasic_types.h @@ -68,14 +68,6 @@ /***************************** Include Files *********************************/
/************************** Constant Definitions *****************************/ - -#ifndef TRUE -#define TRUE 1 -#endif -#ifndef FALSE -#define FALSE 0 -#endif - #ifndef NULL #define NULL 0 #endif diff --git a/board/xilinx/common/xversion.c b/board/xilinx/common/xversion.c index c8a6915..47070a9 100644 --- a/board/xilinx/common/xversion.c +++ b/board/xilinx/common/xversion.c @@ -187,14 +187,14 @@ XVersion_IsEqual(XVersion * InstancePtr, XVersion * VersionPtr) */ for (Index = 0; Index < sizeof (XVersion); Index++) { if (Version1[Index] != Version2[Index]) { - return FALSE; + return false; } }
/* No byte was found to be different between the versions, so indicate * the versions are equal */ - return TRUE; + return true; }
/***************************************************************************** @@ -343,8 +343,8 @@ IsVersionStringValid(s8 * StringPtr) (StringPtr[XVE_MINOR_ONES_CHAR] > '9') || (StringPtr[XVE_COMP_CHAR] < 'a') || (StringPtr[XVE_COMP_CHAR] > 'z')) { - return FALSE; + return false; }
- return TRUE; + return true; } diff --git a/common/bedbug.c b/common/bedbug.c index 60109cf..0961602 100644 --- a/common/bedbug.c +++ b/common/bedbug.c @@ -137,8 +137,8 @@ int disppc (unsigned char *memaddr, unsigned char *virtual, int num_instr, for (i = 0; i < num_instr; ++i, memaddr += 4, ctx.virtual += 4) { #ifdef USE_SOURCE_CODE if (ctx.flags & F_LINENO) { - if ((line_info_from_addr ((Elf32_Word) ctx.virtual, filename, - funcname, &line_no) == TRUE) && + if ((line_info_from_addr ((Elf32_Word) ctx.virtual, + filename, funcname, &line_no) == true) && ((line_no != last_line_no) || (strcmp (last_funcname, funcname) != 0))) { print_source_line (filename, funcname, line_no, pfunc); @@ -154,15 +154,15 @@ int disppc (unsigned char *memaddr, unsigned char *virtual, int num_instr, #ifdef USE_SOURCE_CODE if (ctx.flags & F_SYMBOL) { if ((symname = - symbol_name_from_addr ((Elf32_Word) ctx.virtual, - TRUE, 0)) != 0) { + symbol_name_from_addr((Elf32_Word) ctx.virtual, + true, 0)) != 0) { cursym = symname; symoffset = 0; } else { if ((cursym == 0) && ((symname = - symbol_name_from_addr ((Elf32_Word) ctx.virtual, - FALSE, &symoffset)) != 0)) { + symbol_name_from_addr((Elf32_Word) ctx.virtual, + false, &symoffset)) != 0)) { cursym = symname; } else { symoffset += 4; @@ -205,7 +205,8 @@ int disppc (unsigned char *memaddr, unsigned char *virtual, int num_instr, }
if (((ctx.flags & F_SIMPLE) == 0) || - (ctx.op->hfunc == 0) || ((*ctx.op->hfunc) (&ctx) == FALSE)) { + (ctx.op->hfunc == 0) || + ((*ctx.op->hfunc) (&ctx) == false)) { sprintf (&ctx.data[ctx.datalen], "%-7s ", ctx.op->name); ctx.datalen += 8; print_operands (&ctx); @@ -214,7 +215,7 @@ int disppc (unsigned char *memaddr, unsigned char *virtual, int num_instr, (*pfunc) (ctx.data); }
- return TRUE; + return true; } /* disppc */
@@ -379,7 +380,7 @@ int get_operand_value (struct opcode *op, unsigned long instr, /*------------------------------------------------------------*/
if (field > n_operands) { - return FALSE; /* bad operand ?! */ + return false; /* bad operand ?! */ }
/* Walk through the operands and list each in order */ @@ -393,10 +394,10 @@ int get_operand_value (struct opcode *op, unsigned long instr, if (value) { *value = (instr >> opr->shift) & ((1 << opr->bits) - 1); } - return TRUE; + return true; }
- return FALSE; + return false; } /* operand_value */
@@ -669,33 +670,33 @@ int handle_bc (struct ppc_ctx *ctx)
- if (get_operand_value (ctx->op, ctx->instr, O_BO, &bo) == FALSE) - return FALSE; + if (get_operand_value(ctx->op, ctx->instr, O_BO, &bo) == false) + return false;
- if (get_operand_value (ctx->op, ctx->instr, O_BI, &bi) == FALSE) - return FALSE; + if (get_operand_value(ctx->op, ctx->instr, O_BI, &bi) == false) + return false;
if ((bo == 12) && (bi == 0)) { ctx->op = &blt; sprintf (&ctx->data[ctx->datalen], "%-7s ", ctx->op->name); ctx->datalen += 8; print_operands (ctx); - return TRUE; + return true; } else if ((bo == 4) && (bi == 10)) { ctx->op = =⃥ sprintf (&ctx->data[ctx->datalen], "%-7s ", ctx->op->name); ctx->datalen += 8; print_operands (ctx); - return TRUE; + return true; } else if ((bo == 16) && (bi == 0)) { ctx->op = &bdnz; sprintf (&ctx->data[ctx->datalen], "%-7s ", ctx->op->name); ctx->datalen += 8; print_operands (ctx); - return TRUE; + return true; }
- return FALSE; + return false; } /* handle_blt */
@@ -734,7 +735,7 @@ int print_source_line (char *filename, char *funcname, sprintf (out_buf, "%s %s(): line %d", filename, funcname, line_no); (*pfunc) (out_buf);
- return TRUE; + return true; } /* print_source_line */
@@ -1039,12 +1040,12 @@ int downstring (char *s) * Arguments: * nextaddr The address (to be filled in) of the next * instruction to execute. This will only be a valid - * address if TRUE is returned. + * address if true is returned. * * step_over A flag indicating how to compute addresses for * branch statements: - * TRUE = Step over the branch (next) - * FALSE = step into the branch (step) + * true = Step over the branch (next) + * false = step into the branch (step) * * Returns TRUE if it was able to compute the address. Returns FALSE if * it has a problem reading the current instruction or one of the registers. @@ -1075,7 +1076,7 @@ int find_next_address (unsigned char *nextaddr, int step_over,
if (nextaddr == 0 || regs == 0) { printf ("find_next_address: bad args"); - return FALSE; + return false; }
pc = regs->nip & 0xfffffffc; @@ -1083,7 +1084,7 @@ int find_next_address (unsigned char *nextaddr, int step_over,
if ((op = find_opcode (instr)) == (struct opcode *) 0) { printf ("find_next_address: can't parse opcode 0x%lx", instr); - return FALSE; + return false; }
ctr = regs->ctr; @@ -1100,7 +1101,7 @@ int find_next_address (unsigned char *nextaddr, int step_over, !get_operand_value (op, instr, O_BI, &bi) || !get_operand_value (op, instr, O_AA, &aa) || !get_operand_value (op, instr, O_LK, &lk)) - return FALSE; + return false;
if ((addr & (1 << 13)) != 0) addr = addr - (1 << 14); @@ -1116,7 +1117,7 @@ int find_next_address (unsigned char *nextaddr, int step_over, if (!get_operand_value (op, instr, O_LI, &addr) || !get_operand_value (op, instr, O_AA, &aa) || !get_operand_value (op, instr, O_LK, &lk)) - return FALSE; + return false;
if ((addr & (1 << 23)) != 0) addr = addr - (1 << 24); @@ -1130,7 +1131,7 @@ int find_next_address (unsigned char *nextaddr, int step_over, if (!get_operand_value (op, instr, O_BO, &bo) || !get_operand_value (op, instr, O_BI, &bi) || !get_operand_value (op, instr, O_LK, &lk)) - return FALSE; + return false;
addr = ctr; aa = 1; @@ -1143,7 +1144,7 @@ int find_next_address (unsigned char *nextaddr, int step_over, if (!get_operand_value (op, instr, O_BO, &bo) || !get_operand_value (op, instr, O_BI, &bi) || !get_operand_value (op, instr, O_LK, &lk)) - return FALSE; + return false;
addr = lr; aa = 1; @@ -1227,12 +1228,12 @@ int find_next_address (unsigned char *nextaddr, int step_over, step = next = pc + 4; }
- if (step_over == TRUE) + if (step_over == true) *(unsigned long *) nextaddr = next; else *(unsigned long *) nextaddr = step;
- return TRUE; + return true; } /* find_next_address */
diff --git a/common/cmd_bedbug.c b/common/cmd_bedbug.c index 9791423..77b6e3e 100644 --- a/common/cmd_bedbug.c +++ b/common/cmd_bedbug.c @@ -292,7 +292,7 @@ int do_bedbug_step (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) return 1; }
- if (!find_next_address ((unsigned char *) &addr, FALSE, bug_ctx.regs)) + if (!find_next_address((unsigned char *) &addr, false, bug_ctx.regs)) return 1;
if (bug_ctx.set) @@ -323,7 +323,7 @@ int do_bedbug_next (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) return 1; }
- if (!find_next_address ((unsigned char *) &addr, TRUE, bug_ctx.regs)) + if (!find_next_address((unsigned char *) &addr, true, bug_ctx.regs)) return 1;
if (bug_ctx.set) diff --git a/common/cmd_fdc.c b/common/cmd_fdc.c index 66e0ef0..dfa3690 100644 --- a/common/cmd_fdc.c +++ b/common/cmd_fdc.c @@ -39,13 +39,6 @@ #define PRINTF(fmt,args...) #endif
-#ifndef TRUE -#define TRUE 1 -#endif -#ifndef FALSE -#define FALSE 0 -#endif - /*#if defined(CONFIG_CMD_DATE) */ /*#include <rtc.h> */ /*#endif */ @@ -214,9 +207,9 @@ int wait_for_fdc_int(void) timeout--; udelay(10); if(timeout==0) /* timeout occured */ - return FALSE; + return false; } - return TRUE; + return true; }
/* reads a byte from the FIFO of the FDC and checks direction and RQM bit @@ -244,7 +237,7 @@ int fdc_need_more_output(void) c=(unsigned char)read_fdc_byte(); printf("Error: more output: %x\n",c); } - return TRUE; + return true; }
@@ -260,10 +253,10 @@ int write_fdc_byte(unsigned char val) udelay(10); fdc_need_more_output(); if(timeout==0) /* timeout occured */ - return FALSE; + return false; } write_fdc_reg(FDC_FIFO,val); - return TRUE; + return true; }
/* sets up all FDC commands and issues it to the FDC. If @@ -344,9 +337,9 @@ int fdc_issue_cmd(FDC_COMMAND_STRUCT *pCMD,FD_GEO_STRUCT *pFG) } for(i=0;i<pCMD->cmdlen;i++) { /* PRINTF("write cmd%d = 0x%02X\n",i,pCMD->cmd[i]); */ - if(write_fdc_byte(pCMD->cmd[i])==FALSE) { + if (write_fdc_byte(pCMD->cmd[i]) == false) { PRINTF("Error: timeout while issue cmd%d\n",i); - return FALSE; + return false; } } timeout=FDC_TIME_OUT; @@ -355,12 +348,12 @@ int fdc_issue_cmd(FDC_COMMAND_STRUCT *pCMD,FD_GEO_STRUCT *pFG) timeout--; if(timeout==0) { PRINTF(" timeout while reading result%d MSR=0x%02X\n",i,read_fdc_reg(FDC_MSR)); - return FALSE; + return false; } } pCMD->result[i]=(unsigned char)read_fdc_byte(); } - return TRUE; + return true; }
/* selects the drive assigned in the cmd structur and @@ -391,9 +384,10 @@ void stop_fdc_drive(FDC_COMMAND_STRUCT *pCMD) int fdc_recalibrate(FDC_COMMAND_STRUCT *pCMD,FD_GEO_STRUCT *pFG) { pCMD->cmd[COMMAND]=FDC_CMD_RECALIBRATE; - if(fdc_issue_cmd(pCMD,pFG)==FALSE) - return FALSE; - while(wait_for_fdc_int()!=TRUE); + if (fdc_issue_cmd(pCMD, pFG) == false) + return false; + while (wait_for_fdc_int() != true); + pCMD->cmd[COMMAND]=FDC_CMD_SENSE_INT; return(fdc_issue_cmd(pCMD,pFG)); } @@ -403,9 +397,10 @@ int fdc_recalibrate(FDC_COMMAND_STRUCT *pCMD,FD_GEO_STRUCT *pFG) int fdc_seek(FDC_COMMAND_STRUCT *pCMD,FD_GEO_STRUCT *pFG) { pCMD->cmd[COMMAND]=FDC_CMD_SEEK; - if(fdc_issue_cmd(pCMD,pFG)==FALSE) - return FALSE; - while(wait_for_fdc_int()!=TRUE); + if (fdc_issue_cmd(pCMD, pFG) == false) + return false; + while (wait_for_fdc_int() != true); + pCMD->cmd[COMMAND]=FDC_CMD_SENSE_INT; return(fdc_issue_cmd(pCMD,pFG)); } @@ -421,7 +416,7 @@ int fdc_terminate(FDC_COMMAND_STRUCT *pCMD) for(i=0;i<7;i++) { pCMD->result[i]=(unsigned char)read_fdc_byte(); } - return TRUE; + return true; }
/* reads data from FDC, seek commands are issued automatic */ @@ -440,18 +435,18 @@ int fdc_read_data(unsigned char *buffer, unsigned long blocks,FDC_COMMAND_STRUCT retriesrw=0; retriescal=0; offset=0; - if(fdc_seek(pCMD,pFG)==FALSE) { + if (fdc_seek(pCMD, pFG) == false) { stop_fdc_drive(pCMD); if (flags) enable_interrupts(); - return FALSE; + return false; } if((pCMD->result[STATUS_0]&0x20)!=0x20) { printf("Seek error Status: %02X\n",pCMD->result[STATUS_0]); stop_fdc_drive(pCMD); if (flags) enable_interrupts(); - return FALSE; + return false; } /* now determine the next seek point */ /* lastblk=pCMD->blnr + blocks; */ @@ -466,11 +461,11 @@ int fdc_read_data(unsigned char *buffer, unsigned long blocks,FDC_COMMAND_STRUCT retryrw: len=sect_size * readblk; pCMD->cmd[COMMAND]=FDC_CMD_READ; - if(fdc_issue_cmd(pCMD,pFG)==FALSE) { + if (fdc_issue_cmd(pCMD, pFG) == false) { stop_fdc_drive(pCMD); if (flags) enable_interrupts(); - return FALSE; + return false; } for (i=0;i<len;i++) { timeout=FDC_TIME_OUT; @@ -492,15 +487,15 @@ retryrw: stop_fdc_drive(pCMD); if (flags) enable_interrupts(); - return FALSE; + return false; } else { PRINTF(" trying to recalibrate Try %d\n",retriescal); - if(fdc_recalibrate(pCMD,pFG)==FALSE) { + if (fdc_recalibrate(pCMD, pFG) == false) { stop_fdc_drive(pCMD); if (flags) enable_interrupts(); - return FALSE; + return false; } retriesrw=0; goto retrycal; @@ -512,7 +507,7 @@ retryrw: } /* else >FDC_RW_RETRIES */ }/* if output */ timeout--; - }while(TRUE); + } while (true); } /* for len */ /* the last sector of a track or all data has been read, * we need to get the results */ @@ -530,22 +525,22 @@ retryrw: readblk=blocks; retrycal: /* a seek is necessary */ - if(fdc_seek(pCMD,pFG)==FALSE) { + if (fdc_seek(pCMD, pFG) == false) { stop_fdc_drive(pCMD); if (flags) enable_interrupts(); - return FALSE; + return false; } if((pCMD->result[STATUS_0]&0x20)!=0x20) { PRINTF("Seek error Status: %02X\n",pCMD->result[STATUS_0]); stop_fdc_drive(pCMD); - return FALSE; + return false; } - }while(TRUE); /* start over */ + } while (true); /* start over */ stop_fdc_drive(pCMD); /* switch off drive */ if (flags) enable_interrupts(); - return TRUE; + return true; }
/* Scan all drives and check if drive is present and disk is inserted */ @@ -559,20 +554,20 @@ int fdc_check_drive(FDC_COMMAND_STRUCT *pCMD, FD_GEO_STRUCT *pFG) pCMD->drive=drives; select_fdc_drive(pCMD); pCMD->blnr=0; /* set to the 1st block */ - if(fdc_recalibrate(pCMD,pFG)==FALSE) + if (fdc_recalibrate(pCMD, pFG) == false) continue; if((pCMD->result[STATUS_0]&0x10)==0x10) continue; /* ok drive connected check for disk */ state|=(1<<drives); pCMD->blnr=pFG->size; /* set to the last block */ - if(fdc_seek(pCMD,pFG)==FALSE) + if (fdc_seek(pCMD, pFG) == false) continue; pCMD->blnr=0; /* set to the 1st block */ - if(fdc_recalibrate(pCMD,pFG)==FALSE) + if (fdc_recalibrate(pCMD, pFG) == false) continue; pCMD->cmd[COMMAND]=FDC_CMD_READ_ID; - if(fdc_issue_cmd(pCMD,pFG)==FALSE) + if (fdc_issue_cmd(pCMD, pFG) == false) continue; state|=(0x10<<drives); } @@ -584,7 +579,7 @@ int fdc_check_drive(FDC_COMMAND_STRUCT *pCMD, FD_GEO_STRUCT *pFG) ((state&(0x10<<i))==(0x10<<i)) ? pFG->name : ""); } pCMD->flags=state; - return TRUE; + return true; }
@@ -611,9 +606,9 @@ int fdc_setup(int drive, FDC_COMMAND_STRUCT *pCMD, FD_GEO_STRUCT *pFG) write_fdc_reg(FDC_CCR,pFG->rate); /* then initialize the DSR */ write_fdc_reg(FDC_DSR,pFG->rate); - if(wait_for_fdc_int()==FALSE) { + if (wait_for_fdc_int() == false) { PRINTF("Time Out after writing CCR\n"); - return FALSE; + return false; } /* now issue sense Interrupt and status command * assuming only one drive present (drive 0) */ @@ -621,7 +616,7 @@ int fdc_setup(int drive, FDC_COMMAND_STRUCT *pCMD, FD_GEO_STRUCT *pFG) for(i=0;i<4;i++) { /* issue sense interrupt for all 4 possible drives */ pCMD->cmd[COMMAND]=FDC_CMD_SENSE_INT; - if(fdc_issue_cmd(pCMD,pFG)==FALSE) { + if (fdc_issue_cmd(pCMD, pFG) == false) { PRINTF("Sense Interrupt for drive %d failed\n",i); } } @@ -629,24 +624,24 @@ int fdc_setup(int drive, FDC_COMMAND_STRUCT *pCMD, FD_GEO_STRUCT *pFG) pCMD->drive=drive; select_fdc_drive(pCMD); pCMD->cmd[COMMAND]=FDC_CMD_CONFIGURE; - if(fdc_issue_cmd(pCMD,pFG)==FALSE) { + if (fdc_issue_cmd(pCMD, pFG) == false) { PRINTF(" configure timeout\n"); stop_fdc_drive(pCMD); - return FALSE; + return false; } /* issue specify command */ pCMD->cmd[COMMAND]=FDC_CMD_SPECIFY; - if(fdc_issue_cmd(pCMD,pFG)==FALSE) { + if (fdc_issue_cmd(pCMD, pFG) == false) { PRINTF(" specify timeout\n"); stop_fdc_drive(pCMD); - return FALSE; + return false;
} /* then, we clear the reset in the DOR */ /* fdc_check_drive(pCMD,pFG); */ /* write_fdc_reg(FDC_DOR,0x04); */
#if defined(CONFIG_CMD_FDOS) @@ -664,30 +659,30 @@ int fdc_fdos_init (int drive) FDC_COMMAND_STRUCT *pCMD = &cmd;
/* setup FDC and scan for drives */ - if(fdc_setup(drive,pCMD,pFG)==FALSE) { + if (fdc_setup(drive, pCMD, pFG) == false) { printf("\n** Error in setup FDC **\n"); - return FALSE; + return false; } - if(fdc_check_drive(pCMD,pFG)==FALSE) { + if (fdc_check_drive(pCMD, pFG) == false) { printf("\n** Error in check_drives **\n"); - return FALSE; + return false; } if((pCMD->flags&(1<<drive))==0) { /* drive not available */ printf("\n** Drive %d not available **\n",drive); - return FALSE; + return false; } if((pCMD->flags&(0x10<<drive))==0) { /* no disk inserted */ printf("\n** No disk inserted in drive %d **\n",drive); - return FALSE; + return false; } /* ok, we have a valid source */ pCMD->drive=drive;
/* read first block */ pCMD->blnr=0; - return TRUE; + return true; } /************************************************************************** * int fdc_fdos_seek @@ -747,11 +742,11 @@ int do_fdcboot (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return CMD_RET_USAGE; } /* setup FDC and scan for drives */ - if(fdc_setup(boot_drive,pCMD,pFG)==FALSE) { + if (fdc_setup(boot_drive, pCMD, pFG) == false) { printf("\n** Error in setup FDC **\n"); return 1; } - if(fdc_check_drive(pCMD,pFG)==FALSE) { + if (fdc_check_drive(pCMD, pFG) == false) { printf("\n** Error in check_drives **\n"); return 1; } @@ -769,7 +764,7 @@ int do_fdcboot (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) pCMD->drive=boot_drive; /* read first block */ pCMD->blnr=0; - if(fdc_read_data((unsigned char *)addr,1,pCMD,pFG)==FALSE) { + if (fdc_read_data((unsigned char *)addr, 1, pCMD, pFG) == false) { printf("\nRead error:"); for(i=0;i<7;i++) printf("result%d: 0x%02X\n",i,pCMD->result[i]); @@ -801,7 +796,7 @@ int do_fdcboot (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) nrofblk++; printf("Loading %ld Bytes (%d blocks) at 0x%08lx..\n",imsize,nrofblk,addr); pCMD->blnr=0; - if(fdc_read_data((unsigned char *)addr,nrofblk,pCMD,pFG)==FALSE) { + if (fdc_read_data((unsigned char *)addr, nrofblk, pCMD, pFG) == false) { /* read image block */ printf("\nRead error:"); for(i=0;i<7;i++) diff --git a/common/cmd_scsi.c b/common/cmd_scsi.c index 266bfa6..13b3d99 100644 --- a/common/cmd_scsi.c +++ b/common/cmd_scsi.c @@ -110,7 +110,7 @@ void scsi_scan(int mode) scsi_dev_desc[i].vendor[0]=0; scsi_dev_desc[i].product[0]=0; scsi_dev_desc[i].revision[0]=0; - scsi_dev_desc[i].removable=FALSE; + scsi_dev_desc[i].removable = false; scsi_dev_desc[i].if_type=IF_TYPE_SCSI; scsi_dev_desc[i].dev=i; scsi_dev_desc[i].part_type=PART_TYPE_UNKNOWN; @@ -125,7 +125,7 @@ void scsi_scan(int mode) pccb->pdata=(unsigned char *)&tempbuff; pccb->datalen=512; scsi_setup_inquiry(pccb); - if(scsi_exec(pccb)!=TRUE) { + if (scsi_exec(pccb) != true) { if(pccb->contr_stat==SCSI_SEL_TIME_OUT) { debug ("Selection timeout ID %d\n",pccb->target); continue; /* selection timeout => assuming no device present */ @@ -139,7 +139,7 @@ void scsi_scan(int mode) continue; /* skip unknown devices */ } if((modi&0x80)==0x80) /* drive is removable */ - scsi_dev_desc[scsi_max_devs].removable=TRUE; + scsi_dev_desc[scsi_max_devs].removable=true; /* get info for this device */ scsi_ident_cpy((unsigned char *)&scsi_dev_desc[scsi_max_devs].vendor[0], &tempbuff[8], 8); @@ -152,8 +152,8 @@ void scsi_scan(int mode)
pccb->datalen=0; scsi_setup_test_unit_ready(pccb); - if(scsi_exec(pccb)!=TRUE) { - if(scsi_dev_desc[scsi_max_devs].removable==TRUE) { + if (scsi_exec(pccb) != true) { + if (scsi_dev_desc[scsi_max_devs].removable == true) { scsi_dev_desc[scsi_max_devs].type=perq; goto removable; } @@ -404,7 +404,7 @@ static ulong scsi_read(int device, ulong blknr, lbaint_t blkcnt, void *buffer) debug("scsi_read_ext: startblk " LBAF ", blccnt %x buffer %lx\n", start, smallblks, buf_addr); - if(scsi_exec(pccb)!=TRUE) { + if (scsi_exec(pccb) != true) { scsi_print_error(pccb); blkcnt-=blks; break; @@ -458,7 +458,7 @@ static ulong scsi_write(int device, ulong blknr, } debug("%s: startblk " LBAF ", blccnt %x buffer %lx\n", __func__, start, smallblks, buf_addr); - if (scsi_exec(pccb) != TRUE) { + if (scsi_exec(pccb) != true) { scsi_print_error(pccb); blkcnt -= blks; break; @@ -521,7 +521,7 @@ int scsi_read_capacity(ccb *pccb, lbaint_t *capacity, unsigned long *blksz) pccb->msgout[0] = SCSI_IDENTIFY; /* NOT USED */
pccb->datalen = 8; - if (scsi_exec(pccb) != TRUE) + if (scsi_exec(pccb) != true) return 1;
*capacity = ((lbaint_t)pccb->pdata[0] << 24) | @@ -547,7 +547,7 @@ int scsi_read_capacity(ccb *pccb, lbaint_t *capacity, unsigned long *blksz) pccb->msgout[0] = SCSI_IDENTIFY; /* NOT USED */
pccb->datalen = 16; - if (scsi_exec(pccb) != TRUE) + if (scsi_exec(pccb) != true) return 1;
*capacity = ((uint64_t)pccb->pdata[0] << 56) | diff --git a/drivers/bios_emulator/atibios.c b/drivers/bios_emulator/atibios.c index dbb5e8c..3b2ed6e 100644 --- a/drivers/bios_emulator/atibios.c +++ b/drivers/bios_emulator/atibios.c @@ -52,10 +52,6 @@ /* Length of the BIOS image */ #define MAX_BIOSLEN (128 * 1024L)
-/* Define some useful types and macros */ -#define true 1 -#define false 0 - /* Place to save PCI BAR's that we change and later restore */ static u32 saveROMBaseAddress; static u32 saveBaseAddress10; @@ -242,7 +238,7 @@ pcidev - PCI device info for the video card on the bus to boot VGAInfo - BIOS emulator VGA info structure
RETURNS: -True if successfully initialised, false if not. +true if successfully initialised, false if not.
REMARKS: Loads and POST's the display controllers BIOS, directly from the BIOS @@ -295,7 +291,7 @@ static int PCI_postController(pci_dev_t pcidev, BE_VGAInfo * VGAInfo) PARAMETERS: pcidev - PCI device info for the video card on the bus to boot pVGAInfo - Place to return VGA info structure is requested -cleanUp - True to clean up on exit, false to leave emulator active +cleanUp - true to clean up on exit, false to leave emulator active
REMARKS: Boots the PCI/AGP video card on the bus using the Video ROM BIOS image diff --git a/drivers/bios_emulator/x86emu/debug.c b/drivers/bios_emulator/x86emu/debug.c index 6417d09..2fa8050 100644 --- a/drivers/bios_emulator/x86emu/debug.c +++ b/drivers/bios_emulator/x86emu/debug.c @@ -309,7 +309,7 @@ void x86emu_single_step(void) case 'P': noDecode = (noDecode) ? 0 : 1; printk("Toggled decoding to %s\n", - (noDecode) ? "FALSE" : "TRUE"); + (noDecode) ? "false" : "true"); break; case 't': case 0: diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index 8c785ae..cab7f8c 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -865,14 +865,14 @@ int scsi_exec(ccb *pccb) break; default: printf("Unsupport SCSI command 0x%02x\n", pccb->cmd[0]); - return FALSE; + return false; }
if (ret) { debug("SCSI command 0x%02x ret errno %d\n", pccb->cmd[0], ret); - return FALSE; + return false; } - return TRUE; + return true;
diff --git a/drivers/block/sata_dwc.c b/drivers/block/sata_dwc.c index 28d87f5..49288a7 100644 --- a/drivers/block/sata_dwc.c +++ b/drivers/block/sata_dwc.c @@ -360,7 +360,7 @@ int init_sata(int dev) if (status == 0x7f) { printf("Hard Disk not found.\n"); dev_state = SATA_NODEVICE; - rc = FALSE; + rc = false; return rc; }
@@ -381,7 +381,7 @@ int init_sata(int dev) printf("** TimeOUT **\n");
dev_state = SATA_NODEVICE; - rc = FALSE; + rc = false; return rc; } if ((i >= 100) && ((i % 100) == 0)) @@ -458,7 +458,7 @@ static int sata_dwc_softreset(struct ata_port *ap) } else { printf("No device found\n"); dev_state = SATA_NODEVICE; - return FALSE; + return false; }
tmp = ATA_DEVICE_OBS; @@ -737,7 +737,7 @@ static int ata_dev_read_id(struct ata_device *dev, unsigned int *p_class, status = ata_busy_wait(ap, ATA_BUSY, 30000); if (status & ATA_BUSY) { printf("BSY = 0 check. timeout.\n"); - rc = FALSE; + rc = false; return rc; }
@@ -987,7 +987,7 @@ unsigned ata_exec_internal(struct ata_device *dev, status = ata_busy_wait(ap, ATA_BUSY, 300000); if (status & ATA_BUSY) { printf("BSY = 0 check. timeout.\n"); - rc = FALSE; + rc = false; return rc; }
@@ -997,7 +997,7 @@ unsigned ata_exec_internal(struct ata_device *dev, tag = ATA_TAG_INTERNAL;
if (test_and_set_bit(tag, &ap->qc_allocated)) { - rc = FALSE; + rc = false; return rc; }
@@ -1656,14 +1656,14 @@ static int check_sata_dev_state(void)
ret = ata_dev_read_sectors(pdata, datalen, 0, 1);
- if (ret == TRUE) + if (ret == true) break;
i++; if (i > (ATA_RESET_TIME * 100)) { printf("** TimeOUT **\n"); dev_state = SATA_NODEVICE; - return FALSE; + return false; }
if ((i >= 100) && ((i % 100) == 0)) @@ -1672,7 +1672,7 @@ static int check_sata_dev_state(void)
dev_state = SATA_READY;
static unsigned int ata_dev_set_feature(struct ata_device *dev, @@ -1772,7 +1772,7 @@ ulong sata_read(int device, ulong blknr, lbaint_t blkcnt, void *buffer) blks = 0; }
- if (ata_dev_read_sectors(pdata, datalen, block, n_block) != TRUE) { + if (ata_dev_read_sectors(pdata, datalen, block, n_block) != true) { printf("sata_dwc : Hard disk read error.\n"); blkcnt -= blks; break; @@ -1795,7 +1795,7 @@ static int ata_dev_read_sectors(unsigned char *pdata, unsigned long datalen, int may_fallback = 1;
if (dev_state == SATA_ERROR) - return FALSE; + return false;
ata_dev_select(ap, dev->devno, 1, 1);
@@ -1893,11 +1893,11 @@ retry: goto err_out; }
err_out: printf("failed to READ SECTORS (%s, err_mask=0x%x)\n", reason, err_mask); - return FALSE; + return false; }
#if defined(CONFIG_SATA_DWC) && !defined(CONFIG_LBA48) @@ -1946,7 +1946,7 @@ ulong sata_write(int device, ulong blknr, lbaint_t blkcnt, const void *buffer) blks = 0; }
- if (ata_dev_write_sectors(pdata, datalen, block, n_block) != TRUE) { + if (ata_dev_write_sectors(pdata, datalen, block, n_block) != true) { printf("sata_dwc : Hard disk read error.\n"); blkcnt -= blks; break; @@ -1969,7 +1969,7 @@ static int ata_dev_write_sectors(unsigned char* pdata, unsigned long datalen, int may_fallback = 1;
@@ -2068,9 +2068,9 @@ retry: goto err_out; }
err_out: printf("failed to WRITE SECTORS (%s, err_mask=0x%x)\n", reason, err_mask); - return FALSE; + return false; } diff --git a/drivers/block/sata_dwc.h b/drivers/block/sata_dwc.h index 204d644..e4e4ab1 100644 --- a/drivers/block/sata_dwc.h +++ b/drivers/block/sata_dwc.h @@ -467,11 +467,4 @@ struct ata_port { unsigned char *pdata; };
-#ifndef TRUE -#define TRUE 1 -#endif -#ifndef FALSE -#define FALSE 0 -#endif - #endif diff --git a/drivers/block/sym53c8xx.c b/drivers/block/sym53c8xx.c index 564aa98..656683a 100644 --- a/drivers/block/sym53c8xx.c +++ b/drivers/block/sym53c8xx.c @@ -764,9 +764,9 @@ int scsi_exec(ccb *pccb) retry: scsi_issue(pccb); if(pccb->contr_stat!=SIR_COMPLETE) - return FALSE; + return false; if(pccb->status==S_GOOD) - return TRUE; + return true; if(pccb->status==S_CHECK_COND) { /* check condition */ for(i=0;i<16;i++) tmpcmd[i]=pccb->cmd[i]; @@ -797,12 +797,12 @@ retry: case SENSE_NO_SENSE: case SENSE_RECOVERED_ERROR: /* seems to be ok */ - return TRUE; + return true; break; case SENSE_NOT_READY: if((pccb->sense_buf[12]!=0x04)||(pccb->sense_buf[13]!=0x01)) { /* if device is not in process of becoming ready */ - return FALSE; + return false; break; } /* else fall through */ case SENSE_UNIT_ATTENTION: @@ -814,13 +814,13 @@ retry: goto retry; } PRINTF("Target %d not ready, %d retried\n",pccb->target,retrycnt); - return FALSE; + return false; default: - return FALSE; + return false; } } PRINTF("Status = %X\n",pccb->status); - return FALSE; + return false; }
diff --git a/drivers/fpga/ACEX1K.c b/drivers/fpga/ACEX1K.c index 4703fc1..0ae78f9 100644 --- a/drivers/fpga/ACEX1K.c +++ b/drivers/fpga/ACEX1K.c @@ -140,7 +140,7 @@ static int ACEX1K_ps_load(Altera_desc *desc, const void *buf, size_t bsize) }
/* Establish the initial state */ - (*fn->config) (TRUE, TRUE, cookie); /* Assert nCONFIG */ + (*fn->config) (true, true, cookie); /* Assert nCONFIG */
udelay(2); /* T_cfg > 2us */
@@ -152,7 +152,7 @@ static int ACEX1K_ps_load(Altera_desc *desc, const void *buf, size_t bsize) return FPGA_FAIL; }
- (*fn->config) (FALSE, TRUE, cookie); /* Deassert nCONFIG */ + (*fn->config) (false, true, cookie); /* Deassert nCONFIG */ udelay(2); /* T_cf2st1 < 4us */
/* Wait for nSTATUS to be released (i.e. deasserted) */ @@ -192,13 +192,13 @@ static int ACEX1K_ps_load(Altera_desc *desc, const void *buf, size_t bsize) i = 8; do { /* Deassert the clock */ - (*fn->clk) (FALSE, TRUE, cookie); + (*fn->clk) (false, true, cookie); CONFIG_FPGA_DELAY (); /* Write data */ - (*fn->data) ( (val & 0x01), TRUE, cookie); + (*fn->data) ((val & 0x01), true, cookie); CONFIG_FPGA_DELAY (); /* Assert the clock */ - (*fn->clk) (TRUE, TRUE, cookie); + (*fn->clk) (true, true, cookie); CONFIG_FPGA_DELAY (); val >>= 1; i --; @@ -232,9 +232,9 @@ static int ACEX1K_ps_load(Altera_desc *desc, const void *buf, size_t bsize)
for (i = 0; i < 12; i++) { CONFIG_FPGA_DELAY (); - (*fn->clk) (TRUE, TRUE, cookie); /* Assert the clock pin */ + (*fn->clk) (true, true, cookie); /* Assert the clock pin */ CONFIG_FPGA_DELAY (); - (*fn->clk) (FALSE, TRUE, cookie); /* Deassert the clock pin */ + (*fn->clk) (false, true, cookie); /* Deassert the clock pin */ }
ret_val = FPGA_SUCCESS; diff --git a/drivers/fpga/altera.c b/drivers/fpga/altera.c index f087d01..8388da5 100644 --- a/drivers/fpga/altera.c +++ b/drivers/fpga/altera.c @@ -215,7 +215,7 @@ int altera_info( Altera_desc *desc )
static int altera_validate (Altera_desc * desc, const char *fn) { - int ret_val = FALSE; + int ret_val = false;
if (desc) { if ((desc->family > min_altera_type) && @@ -223,7 +223,7 @@ static int altera_validate (Altera_desc * desc, const char *fn) if ((desc->iface > min_altera_iface_type) && (desc->iface < max_altera_iface_type)) { if (desc->size) { - ret_val = TRUE; + ret_val = true; } else { printf ("%s: NULL part size\n", fn); } diff --git a/drivers/fpga/cyclon2.c b/drivers/fpga/cyclon2.c index 0773e73..6b734c2 100644 --- a/drivers/fpga/cyclon2.c +++ b/drivers/fpga/cyclon2.c @@ -144,9 +144,9 @@ static int CYC2_ps_load(Altera_desc *desc, const void *buf, size_t bsize) }
/* Establish the initial state */ - (*fn->config) (FALSE, TRUE, cookie); /* De-assert nCONFIG */ + (*fn->config) (false, true, cookie); /* De-assert nCONFIG */ udelay(100); - (*fn->config) (TRUE, TRUE, cookie); /* Assert nCONFIG */ + (*fn->config) (true, true, cookie); /* Assert nCONFIG */
@@ -164,7 +164,7 @@ static int CYC2_ps_load(Altera_desc *desc, const void *buf, size_t bsize) /* Get ready for the burn */ CONFIG_FPGA_DELAY ();
- ret = (*fn->write) (buf, bsize, TRUE, cookie); + ret = (*fn->write) (buf, bsize, true, cookie); if (ret) { puts ("** Write failed.\n"); (*fn->abort) (cookie); diff --git a/drivers/fpga/lattice.c b/drivers/fpga/lattice.c index d8b642a..8c3465a 100644 --- a/drivers/fpga/lattice.c +++ b/drivers/fpga/lattice.c @@ -275,7 +275,7 @@ signed char ispVM(void)
static int lattice_validate(Lattice_desc *desc, const char *fn) { - int ret_val = FALSE; + int ret_val = false;
if (desc) { if ((desc->family > min_lattice_type) && @@ -283,7 +283,7 @@ static int lattice_validate(Lattice_desc *desc, const char *fn) if ((desc->iface > min_lattice_iface_type) && (desc->iface < max_lattice_iface_type)) { if (desc->size) { - ret_val = TRUE; + ret_val = true; } else { printf("%s: NULL part size\n", fn); } diff --git a/drivers/fpga/spartan2.c b/drivers/fpga/spartan2.c index 4bc7070..0bc400d 100644 --- a/drivers/fpga/spartan2.c +++ b/drivers/fpga/spartan2.c @@ -162,11 +162,11 @@ static int Spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) }
/* Establish the initial state */ - (*fn->pgm) (TRUE, TRUE, cookie); /* Assert the program, commit */ + (*fn->pgm) (true, true, cookie); /* Assert the program, commit */
/* Get ready for the burn */ CONFIG_FPGA_DELAY (); - (*fn->pgm) (FALSE, TRUE, cookie); /* Deassert the program, commit */ + (*fn->pgm) (false, true, cookie); /* Deassert the program, commit */
ts = get_timer (0); /* get current time */ /* Now wait for INIT and BUSY to go high */ @@ -179,20 +179,20 @@ static int Spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) } } while ((*fn->init) (cookie) && (*fn->busy) (cookie));
- (*fn->wr) (TRUE, TRUE, cookie); /* Assert write, commit */ - (*fn->cs) (TRUE, TRUE, cookie); /* Assert chip select, commit */ - (*fn->clk) (TRUE, TRUE, cookie); /* Assert the clock pin */ + (*fn->wr) (true, true, cookie); /* Assert write, commit */ + (*fn->cs) (true, true, cookie); /* Assert chip select, commit */ + (*fn->clk) (true, true, cookie); /* Assert the clock pin */
/* Load the data */ while (bytecount < bsize) { /* XXX - do we check for an Ctrl-C press in here ??? */ /* XXX - Check the error bit? */
- (*fn->wdata) (data[bytecount++], TRUE, cookie); /* write the data */ + (*fn->wdata) (data[bytecount++], true, cookie); /* write the data */ CONFIG_FPGA_DELAY (); - (*fn->clk) (FALSE, TRUE, cookie); /* Deassert the clock pin */ + (*fn->clk) (false, true, cookie); /* Deassert the clock pin */ CONFIG_FPGA_DELAY (); - (*fn->clk) (TRUE, TRUE, cookie); /* Assert the clock pin */ + (*fn->clk) (true, true, cookie); /* Assert the clock pin */
#ifdef CONFIG_SYS_FPGA_CHECK_BUSY ts = get_timer (0); /* get current time */ @@ -201,9 +201,9 @@ static int Spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) * make sure we aren't busy forever... */
if (get_timer (ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ puts ("** Timeout waiting for BUSY to clear.\n"); @@ -220,8 +220,8 @@ static int Spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) }
CONFIG_FPGA_DELAY (); - (*fn->cs) (FALSE, TRUE, cookie); /* Deassert the chip select */ - (*fn->wr) (FALSE, TRUE, cookie); /* Deassert the write pin */ + (*fn->cs) (false, true, cookie); /* Deassert the chip select */ + (*fn->wr) (false, true, cookie); /* Deassert the write pin */
#ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK putc ('\n'); /* terminate the dotted line */ @@ -233,9 +233,9 @@ static int Spartan2_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) while ((*fn->done) (cookie) == FPGA_FAIL) {
if (get_timer (ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ puts ("** Timeout waiting for DONE to clear.\n"); @@ -277,15 +277,15 @@ static int Spartan2_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize)
printf ("Starting Dump of FPGA Device %d...\n", cookie);
- (*fn->cs) (TRUE, TRUE, cookie); /* Assert chip select, commit */ - (*fn->clk) (TRUE, TRUE, cookie); /* Assert the clock pin */ + (*fn->cs) (true, true, cookie); /* Assert chip select, commit */ + (*fn->clk) (true, true, cookie); /* Assert the clock pin */
/* dump the data */ while (bytecount < bsize) { /* XXX - do we check for an Ctrl-C press in here ??? */
- (*fn->clk) (FALSE, TRUE, cookie); /* Deassert the clock pin */ - (*fn->clk) (TRUE, TRUE, cookie); /* Assert the clock pin */ + (*fn->clk) (false, true, cookie); /* Deassert the clock pin */ + (*fn->clk) (true, true, cookie); /* Assert the clock pin */ (*fn->rdata) (&(data[bytecount++]), cookie); /* read the data */ #ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK if (bytecount % (bsize / 40) == 0) @@ -293,9 +293,9 @@ static int Spartan2_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize) #endif }
- (*fn->cs) (FALSE, FALSE, cookie); /* Deassert the chip select */ - (*fn->clk) (FALSE, TRUE, cookie); /* Deassert the clock pin */ - (*fn->clk) (TRUE, TRUE, cookie); /* Assert the clock pin */ + (*fn->cs) (false, false, cookie); /* Deassert the chip select */ + (*fn->clk) (false, true, cookie); /* Deassert the clock pin */ + (*fn->clk) (true, true, cookie); /* Assert the clock pin */
#ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK putc ('\n'); /* terminate the dotted line */ @@ -351,7 +351,7 @@ static int Spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) }
/* Wait for INIT state (init low) */ ts = get_timer (0); /* get current time */ @@ -365,7 +365,7 @@ static int Spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize)
ts = get_timer (0); /* get current time */ /* Now wait for INIT to go high */ @@ -390,13 +390,13 @@ static int Spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) i = 8; do { /* Deassert the clock */ - (*fn->clk) (FALSE, TRUE, cookie); + (*fn->clk) (false, true, cookie); CONFIG_FPGA_DELAY (); /* Write data */ - (*fn->wr) ((val & 0x80), TRUE, cookie); + (*fn->wr) ((val & 0x80), true, cookie); CONFIG_FPGA_DELAY (); /* Assert the clock */ - (*fn->clk) (TRUE, TRUE, cookie); + (*fn->clk) (true, true, cookie); CONFIG_FPGA_DELAY (); val <<= 1; i --; @@ -417,14 +417,14 @@ static int Spartan2_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) /* now check for done signal */ ts = get_timer (0); /* get current time */ ret_val = FPGA_SUCCESS; - (*fn->wr) (TRUE, TRUE, cookie); + (*fn->wr) (true, true, cookie);
while (! (*fn->done) (cookie)) {
putc ('*');
diff --git a/drivers/fpga/spartan3.c b/drivers/fpga/spartan3.c index 1633a70..c63c605 100644 --- a/drivers/fpga/spartan3.c +++ b/drivers/fpga/spartan3.c @@ -166,11 +166,11 @@ static int Spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) }
ts = get_timer (0); /* get current time */ /* Now wait for INIT and BUSY to go high */ @@ -183,20 +183,20 @@ static int Spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) } } while ((*fn->init) (cookie) && (*fn->busy) (cookie));
#ifdef CONFIG_SYS_FPGA_CHECK_BUSY ts = get_timer (0); /* get current time */ @@ -205,9 +205,9 @@ static int Spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) * make sure we aren't busy forever... */
if (get_timer (ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ puts ("** Timeout waiting for BUSY to clear.\n"); @@ -224,8 +224,8 @@ static int Spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) }
#ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK putc ('\n'); /* terminate the dotted line */ @@ -239,9 +239,9 @@ static int Spartan3_sp_load(Xilinx_desc *desc, const void *buf, size_t bsize) * make sure we aren't busy forever... */
if (get_timer (ts) > CONFIG_SYS_FPGA_WAIT) { /* check the time */ puts ("** Timeout waiting for DONE to clear.\n"); @@ -283,15 +283,15 @@ static int Spartan3_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize)
- (*fn->clk) (FALSE, TRUE, cookie); /* Deassert the clock pin */ - (*fn->clk) (TRUE, TRUE, cookie); /* Assert the clock pin */ + (*fn->clk) (false, true, cookie); /* Deassert the clock pin */ + (*fn->clk) (true, true, cookie); /* Assert the clock pin */ (*fn->rdata) (&(data[bytecount++]), cookie); /* read the data */ #ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK if (bytecount % (bsize / 40) == 0) @@ -299,9 +299,9 @@ static int Spartan3_sp_dump(Xilinx_desc *desc, const void *buf, size_t bsize) #endif }
#ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK putc ('\n'); /* terminate the dotted line */ @@ -357,7 +357,7 @@ static int Spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) }
/* Wait for INIT state (init low) */ ts = get_timer (0); /* get current time */ @@ -373,7 +373,7 @@ static int Spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize)
ts = get_timer (0); /* get current time */ /* Now wait for INIT to go high */ @@ -389,7 +389,7 @@ static int Spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize)
/* Load the data */ if(*fn->bwr) - (*fn->bwr) (data, bsize, TRUE, cookie); + (*fn->bwr) (data, bsize, true, cookie); else { while (bytecount < bsize) {
@@ -405,13 +405,13 @@ static int Spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) i = 8; do { /* Deassert the clock */ - (*fn->clk) (FALSE, TRUE, cookie); + (*fn->clk) (false, true, cookie); CONFIG_FPGA_DELAY (); /* Write data */ - (*fn->wr) ((val & 0x80), TRUE, cookie); + (*fn->wr) ((val & 0x80), true, cookie); CONFIG_FPGA_DELAY (); /* Assert the clock */ - (*fn->clk) (TRUE, TRUE, cookie); + (*fn->clk) (true, true, cookie); CONFIG_FPGA_DELAY (); val <<= 1; i --; @@ -433,16 +433,16 @@ static int Spartan3_ss_load(Xilinx_desc *desc, const void *buf, size_t bsize) /* now check for done signal */ ts = get_timer (0); /* get current time */ ret_val = FPGA_SUCCESS; - (*fn->wr) (TRUE, TRUE, cookie); + (*fn->wr) (true, true, cookie);
while (! (*fn->done) (cookie)) { /* XXX - we should have a check in here somewhere to * make sure we aren't busy forever... */
putc ('*');
diff --git a/drivers/fpga/virtex2.c b/drivers/fpga/virtex2.c index b26d231..3974e47 100644 --- a/drivers/fpga/virtex2.c +++ b/drivers/fpga/virtex2.c @@ -221,7 +221,7 @@ static int Virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize) * There is no maximum value for the pulse width. Check to make * sure that INIT_B goes low after assertion of PROG_B */ - (*fn->pgm) (TRUE, TRUE, cookie); + (*fn->pgm) (true, true, cookie); udelay (10); ts = get_timer (0); do { @@ -234,9 +234,9 @@ static int Virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize) } } while (!(*fn->init) (cookie));
- (*fn->pgm) (FALSE, TRUE, cookie); + (*fn->pgm) (false, true, cookie); CONFIG_FPGA_DELAY (); - (*fn->clk) (TRUE, TRUE, cookie); + (*fn->clk) (true, true, cookie);
/* * Start a timer and wait for INIT_B to go high @@ -253,8 +253,8 @@ static int Virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize) } } while ((*fn->init) (cookie) && (*fn->busy) (cookie));
- (*fn->wr) (TRUE, TRUE, cookie); - (*fn->cs) (TRUE, TRUE, cookie); + (*fn->wr) (true, true, cookie); + (*fn->cs) (true, true, cookie);
udelay (10000);
@@ -286,15 +286,15 @@ static int Virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize) } #endif
- (*fn->wdata) (data[bytecount++], TRUE, cookie); + (*fn->wdata) (data[bytecount++], true, cookie); CONFIG_FPGA_DELAY ();
/* * Cycle the clock pin */ - (*fn->clk) (FALSE, TRUE, cookie); + (*fn->clk) (false, true, cookie); CONFIG_FPGA_DELAY (); - (*fn->clk) (TRUE, TRUE, cookie); + (*fn->clk) (true, true, cookie);
#ifdef CONFIG_SYS_FPGA_CHECK_BUSY ts = get_timer (0); @@ -319,8 +319,8 @@ static int Virtex2_ssm_load(Xilinx_desc *desc, const void *buf, size_t bsize) * Finished writing the data; deassert FPGA CS_B and WRITE_B signals. */ CONFIG_FPGA_DELAY (); - (*fn->cs) (FALSE, TRUE, cookie); - (*fn->wr) (FALSE, TRUE, cookie); + (*fn->cs) (false, true, cookie); + (*fn->wr) (false, true, cookie);
#ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK putc ('\n'); @@ -381,8 +381,8 @@ static int Virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize)
- (*fn->cs) (TRUE, TRUE, cookie); - (*fn->clk) (TRUE, TRUE, cookie); + (*fn->cs) (true, true, cookie); + (*fn->clk) (true, true, cookie);
while (bytecount < bsize) { #ifdef CONFIG_SYS_FPGA_CHECK_CTRLC @@ -394,8 +394,8 @@ static int Virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize) /* * Cycle the clock and read the data */ - (*fn->clk) (FALSE, TRUE, cookie); - (*fn->clk) (TRUE, TRUE, cookie); + (*fn->clk) (false, true, cookie); + (*fn->clk) (true, true, cookie); (*fn->rdata) (&(data[bytecount++]), cookie); #ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK if (bytecount % (bsize / 40) == 0) @@ -406,9 +406,9 @@ static int Virtex2_ssm_dump(Xilinx_desc *desc, const void *buf, size_t bsize) /* * Deassert CS_B and cycle the clock to deselect the device. */ - (*fn->cs) (FALSE, FALSE, cookie); - (*fn->clk) (FALSE, TRUE, cookie); - (*fn->clk) (TRUE, TRUE, cookie); + (*fn->cs) (false, false, cookie); + (*fn->clk) (false, true, cookie); + (*fn->clk) (true, true, cookie);
#ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK putc ('\n'); diff --git a/drivers/fpga/xilinx.c b/drivers/fpga/xilinx.c index 4072cb4..32787b2 100644 --- a/drivers/fpga/xilinx.c +++ b/drivers/fpga/xilinx.c @@ -242,7 +242,7 @@ int xilinx_info (Xilinx_desc * desc)
static int xilinx_validate (Xilinx_desc * desc, char *fn) { - int ret_val = FALSE; + int ret_val = false;
if (desc) { if ((desc->family > min_xilinx_type) && @@ -250,7 +250,7 @@ static int xilinx_validate (Xilinx_desc * desc, char *fn) if ((desc->iface > min_xilinx_iface_type) && (desc->iface < max_xilinx_iface_type)) { if (desc->size) { - ret_val = TRUE; + ret_val = true; } else printf ("%s: NULL part size\n", fn); } else diff --git a/drivers/mtd/nand/mxc_nand.c b/drivers/mtd/nand/mxc_nand.c index d0ded48..04836c0 100644 --- a/drivers/mtd/nand/mxc_nand.c +++ b/drivers/mtd/nand/mxc_nand.c @@ -29,8 +29,6 @@
#define DRIVER_NAME "mxc_nand"
-typedef enum {false, true} bool; - struct mxc_nand_host { struct mtd_info mtd; struct nand_chip *nand; diff --git a/drivers/net/armada100_fec.c b/drivers/net/armada100_fec.c index ed7cf20..89ebf0b 100644 --- a/drivers/net/armada100_fec.c +++ b/drivers/net/armada100_fec.c @@ -100,7 +100,7 @@ static int smi_reg_read(const char *devname, u8 phy_addr, u8 phy_reg, }
/* wait for the SMI register to become available */ - if (armdfec_phy_timeout(®s->smi, SMI_BUSY, FALSE)) { + if (armdfec_phy_timeout(®s->smi, SMI_BUSY, false)) { printf("ARMD100 FEC: (%s) PHY busy timeout\n", __func__); return -1; } @@ -108,7 +108,7 @@ static int smi_reg_read(const char *devname, u8 phy_addr, u8 phy_reg, writel((phy_addr << 16) | (phy_reg << 21) | SMI_OP_R, ®s->smi);
/* now wait for the data to be valid */ - if (armdfec_phy_timeout(®s->smi, SMI_R_VALID, TRUE)) { + if (armdfec_phy_timeout(®s->smi, SMI_R_VALID, true)) { val = readl(®s->smi); printf("ARMD100 FEC: (%s) PHY Read timeout, val=0x%x\n", __func__, val); @@ -143,7 +143,7 @@ static int smi_reg_write(const char *devname, }
/* wait for the SMI register to become available */ - if (armdfec_phy_timeout(®s->smi, SMI_BUSY, FALSE)) { + if (armdfec_phy_timeout(®s->smi, SMI_BUSY, false)) { printf("ARMD100 FEC: (%s) PHY busy timeout\n", __func__); return -1; } diff --git a/drivers/net/armada100_fec.h b/drivers/net/armada100_fec.h index e2df4fc..dcac964 100644 --- a/drivers/net/armada100_fec.h +++ b/drivers/net/armada100_fec.h @@ -29,13 +29,6 @@ #ifndef __ARMADA100_FEC_H__ #define __ARMADA100_FEC_H__
-#ifndef TRUE -#define TRUE 1 -#endif -#ifndef FALSE -#define FALSE 0 -#endif - #define PORT_NUM 0x0
/* RX & TX descriptor command */ diff --git a/drivers/net/e1000.c b/drivers/net/e1000.c index faa90b1..3126676 100644 --- a/drivers/net/e1000.c +++ b/drivers/net/e1000.c @@ -313,14 +313,14 @@ void e1000_standby_eeprom(struct e1000_hw *hw) * * hw - Struct containing variables accessed by shared code ****************************************************************************/ -static boolean_t e1000_is_onboard_nvm_eeprom(struct e1000_hw *hw) +static bool e1000_is_onboard_nvm_eeprom(struct e1000_hw *hw) { uint32_t eecd = 0;
DEBUGFUNC();
if (hw->mac_type == e1000_ich8lan) - return FALSE; + return false;
if (hw->mac_type == e1000_82573 || hw->mac_type == e1000_82574) { eecd = E1000_READ_REG(hw, EECD); @@ -330,9 +330,9 @@ static boolean_t e1000_is_onboard_nvm_eeprom(struct e1000_hw *hw)
/* If both bits are set, device is Flash type */ if (eecd == 0x03) - return FALSE; + return false; } - return TRUE; + return true; }
/****************************************************************************** @@ -421,8 +421,8 @@ static int32_t e1000_init_eeprom_params(struct e1000_hw *hw) eeprom->opcode_bits = 3; eeprom->address_bits = 6; eeprom->delay_usec = 50; - eeprom->use_eerd = FALSE; - eeprom->use_eewr = FALSE; + eeprom->use_eerd = false; + eeprom->use_eewr = false; break; case e1000_82540: case e1000_82545: @@ -439,8 +439,8 @@ static int32_t e1000_init_eeprom_params(struct e1000_hw *hw) eeprom->word_size = 64; eeprom->address_bits = 6; } - eeprom->use_eerd = FALSE; - eeprom->use_eewr = FALSE; + eeprom->use_eerd = false; + eeprom->use_eewr = false; break; case e1000_82541: case e1000_82541_rev_2: @@ -469,8 +469,8 @@ static int32_t e1000_init_eeprom_params(struct e1000_hw *hw) eeprom->address_bits = 6; } } - eeprom->use_eerd = FALSE; - eeprom->use_eewr = FALSE; + eeprom->use_eerd = false; + eeprom->use_eewr = false; break; case e1000_82571: case e1000_82572: @@ -484,8 +484,8 @@ static int32_t e1000_init_eeprom_params(struct e1000_hw *hw) eeprom->page_size = 8; eeprom->address_bits = 8; } - eeprom->use_eerd = FALSE; - eeprom->use_eewr = FALSE; + eeprom->use_eerd = false; + eeprom->use_eewr = false; break; case e1000_82573: case e1000_82574: @@ -499,9 +499,9 @@ static int32_t e1000_init_eeprom_params(struct e1000_hw *hw) eeprom->page_size = 8; eeprom->address_bits = 8; } - eeprom->use_eerd = TRUE; - eeprom->use_eewr = TRUE; - if (e1000_is_onboard_nvm_eeprom(hw) == FALSE) { + eeprom->use_eerd = true; + eeprom->use_eewr = true; + if (e1000_is_onboard_nvm_eeprom(hw) == false) { eeprom->type = e1000_eeprom_flash; eeprom->word_size = 2048;
@@ -522,8 +522,8 @@ static int32_t e1000_init_eeprom_params(struct e1000_hw *hw) eeprom->page_size = 8; eeprom->address_bits = 8; } - eeprom->use_eerd = TRUE; - eeprom->use_eewr = FALSE; + eeprom->use_eerd = true; + eeprom->use_eewr = false; break;
/* ich8lan does not support currently. if needed, please @@ -535,8 +535,8 @@ static int32_t e1000_init_eeprom_params(struct e1000_hw *hw) int32_t i = 0;
eeprom->type = e1000_eeprom_ich8; - eeprom->use_eerd = FALSE; - eeprom->use_eewr = FALSE; + eeprom->use_eerd = false; + eeprom->use_eewr = false; eeprom->word_size = E1000_SHADOW_RAM_WORDS; uint32_t flash_size = E1000_READ_ICH_FLASH_REG(hw, ICH_FLASH_GFPREG); @@ -544,7 +544,7 @@ static int32_t e1000_init_eeprom_params(struct e1000_hw *hw) * so as to save time for driver init */ if (hw->eeprom_shadow_ram != NULL) { for (i = 0; i < E1000_SHADOW_RAM_WORDS; i++) { - hw->eeprom_shadow_ram[i].modified = FALSE; + hw->eeprom_shadow_ram[i].modified = false; hw->eeprom_shadow_ram[i].eeprom_word = 0xFFFF; } } @@ -779,8 +779,8 @@ e1000_read_eeprom(struct e1000_hw *hw, uint16_t offset, * directly. In this case, we need to acquire the EEPROM so that * FW or other port software does not interrupt. */ - if (e1000_is_onboard_nvm_eeprom(hw) == TRUE && - hw->eeprom.use_eerd == FALSE) { + if (e1000_is_onboard_nvm_eeprom(hw) == true && + hw->eeprom.use_eerd == false) {
/* Prepare the EEPROM for bit-bang reading */ if (e1000_acquire_eeprom(hw) != E1000_SUCCESS) @@ -788,7 +788,7 @@ e1000_read_eeprom(struct e1000_hw *hw, uint16_t offset, }
/* Eerd register EEPROM access requires no eeprom aquire/release */ - if (eeprom->use_eerd == TRUE) + if (eeprom->use_eerd == true) return e1000_read_eeprom_eerd(hw, offset, words, data);
/* ich8lan does not support currently. if needed, please @@ -935,7 +935,7 @@ e1000_set_phy_mode(struct e1000_hw *hw) if (ret_val) return ret_val;
- hw->phy_reset_disable = FALSE; + hw->phy_reset_disable = false; } }
@@ -1098,17 +1098,17 @@ e1000_swfw_sync_acquire(struct e1000_hw *hw, uint16_t mask) return E1000_SUCCESS; }
-static boolean_t e1000_is_second_port(struct e1000_hw *hw) +static bool e1000_is_second_port(struct e1000_hw *hw) { switch (hw->mac_type) { case e1000_80003es2lan: case e1000_82546: case e1000_82571: if (E1000_READ_REG(hw, STATUS) & E1000_STATUS_FUNC_1) - return TRUE; + return true; /* Fallthrough */ default: - return FALSE; + return false; } }
@@ -1373,7 +1373,7 @@ e1000_reset_hw(struct e1000_hw *hw) E1000_WRITE_FLUSH(hw);
/* The tbi_compatibility_on Flag must be cleared when Rctl is cleared. */ - hw->tbi_compatibility_on = FALSE; + hw->tbi_compatibility_on = false;
/* Delay to allow any outstanding PCI transactions to complete before * resetting the device @@ -2098,7 +2098,7 @@ e1000_copper_link_preconfig(struct e1000_hw *hw) hw->mac_type == e1000_82541 || hw->mac_type == e1000_82547 || hw->mac_type == e1000_82541_rev_2 || hw->mac_type == e1000_82547_rev_2) - hw->phy_reset_disable = FALSE; + hw->phy_reset_disable = false;
return E1000_SUCCESS; } @@ -2118,7 +2118,7 @@ e1000_copper_link_preconfig(struct e1000_hw *hw) ****************************************************************************/
static int32_t -e1000_set_d3_lplu_state(struct e1000_hw *hw, boolean_t active) +e1000_set_d3_lplu_state(struct e1000_hw *hw, bool active) { uint32_t phy_ctrl = 0; int32_t ret_val; @@ -2253,7 +2253,7 @@ e1000_set_d3_lplu_state(struct e1000_hw *hw, boolean_t active) ****************************************************************************/
static int32_t -e1000_set_d0_lplu_state(struct e1000_hw *hw, boolean_t active) +e1000_set_d0_lplu_state(struct e1000_hw *hw, bool active) { uint32_t phy_ctrl = 0; int32_t ret_val; @@ -2378,7 +2378,7 @@ e1000_copper_link_igp_setup(struct e1000_hw *hw) /* The NVM settings will configure LPLU in D3 for IGP2 and IGP3 PHYs */ if (hw->phy_type == e1000_phy_igp) { /* disable lplu d3 during driver init */ - ret_val = e1000_set_d3_lplu_state(hw, FALSE); + ret_val = e1000_set_d3_lplu_state(hw, false); if (ret_val) { DEBUGOUT("Error Disabling LPLU D3\n"); return ret_val; @@ -2386,7 +2386,7 @@ e1000_copper_link_igp_setup(struct e1000_hw *hw) }
/* disable lplu d0 during driver init */ - ret_val = e1000_set_d0_lplu_state(hw, FALSE); + ret_val = e1000_set_d0_lplu_state(hw, false); if (ret_val) { DEBUGOUT("Error Disabling LPLU D0\n"); return ret_val; @@ -2495,9 +2495,9 @@ e1000_copper_link_igp_setup(struct e1000_hw *hw) /***************************************************************************** * This function checks the mode of the firmware. * - * returns - TRUE when the mode is IAMT or FALSE. + * returns - true when the mode is IAMT or false. ****************************************************************************/ -boolean_t +bool e1000_check_mng_mode(struct e1000_hw *hw) { uint32_t fwsm; @@ -2508,12 +2508,12 @@ e1000_check_mng_mode(struct e1000_hw *hw) if (hw->mac_type == e1000_ich8lan) { if ((fwsm & E1000_FWSM_MODE_MASK) == (E1000_MNG_ICH_IAMT_MODE << E1000_FWSM_MODE_SHIFT)) - return TRUE; + return true; } else if ((fwsm & E1000_FWSM_MODE_MASK) == (E1000_MNG_IAMT_MODE << E1000_FWSM_MODE_SHIFT)) - return TRUE; + return true;
static int32_t @@ -2675,7 +2675,7 @@ e1000_copper_link_ggp_setup(struct e1000_hw *hw) * firmware will have already initialized them. We only initialize * them if the HW is not in IAMT mode. */ - if (e1000_check_mng_mode(hw) == FALSE) { + if (e1000_check_mng_mode(hw) == false) { /* Enable Electrical Idle on the PHY */ phy_data |= GG82563_PMCR_ENABLE_ELECTRICAL_IDLE; ret_val = e1000_write_phy_reg(hw, @@ -2879,7 +2879,7 @@ e1000_copper_link_autoneg(struct e1000_hw *hw) } }
- hw->get_link_status = TRUE; + hw->get_link_status = true;
return E1000_SUCCESS; } @@ -3598,7 +3598,7 @@ e1000_check_for_link(struct eth_device *nic) }
if (phy_data & MII_SR_LINK_STATUS) { - hw->get_link_status = FALSE; + hw->get_link_status = false; } else { /* No link detected */ return -E1000_ERR_NOLINK; @@ -3661,7 +3661,7 @@ e1000_check_for_link(struct eth_device *nic) rctl = E1000_READ_REG(hw, RCTL); rctl &= ~E1000_RCTL_SBP; E1000_WRITE_REG(hw, RCTL, rctl); - hw->tbi_compatibility_on = FALSE; + hw->tbi_compatibility_on = false; } } else { /* If TBI compatibility is was previously off, turn it on. For @@ -3670,7 +3670,7 @@ e1000_check_for_link(struct eth_device *nic) * will look like CRC errors to to the hardware. */ if (!hw->tbi_compatibility_on) { - hw->tbi_compatibility_on = TRUE; + hw->tbi_compatibility_on = true; rctl = E1000_READ_REG(hw, RCTL); rctl |= E1000_RCTL_SBP; E1000_WRITE_REG(hw, RCTL, rctl); @@ -4569,7 +4569,7 @@ e1000_detect_gig_phy(struct e1000_hw *hw) { int32_t phy_init_status, ret_val; uint16_t phy_id_high, phy_id_low; - boolean_t match = FALSE; + bool match = false;
DEBUGFUNC();
@@ -4609,11 +4609,11 @@ e1000_detect_gig_phy(struct e1000_hw *hw) switch (hw->mac_type) { case e1000_82543: if (hw->phy_id == M88E1000_E_PHY_ID) - match = TRUE; + match = true; break; case e1000_82544: if (hw->phy_id == M88E1000_I_PHY_ID) - match = TRUE; + match = true; break; case e1000_82540: case e1000_82545: @@ -4621,37 +4621,37 @@ e1000_detect_gig_phy(struct e1000_hw *hw) case e1000_82546: case e1000_82546_rev_3: if (hw->phy_id == M88E1011_I_PHY_ID) - match = TRUE; + match = true; break; case e1000_82541: case e1000_82541_rev_2: case e1000_82547: case e1000_82547_rev_2: if(hw->phy_id == IGP01E1000_I_PHY_ID) - match = TRUE; + match = true;
break; case e1000_82573: if (hw->phy_id == M88E1111_I_PHY_ID) - match = TRUE; + match = true; break; case e1000_82574: if (hw->phy_id == BME1000_E_PHY_ID) - match = TRUE; + match = true; break; case e1000_80003es2lan: if (hw->phy_id == GG82563_E_PHY_ID) - match = TRUE; + match = true; break; case e1000_ich8lan: if (hw->phy_id == IGP03E1000_E_PHY_ID) - match = TRUE; + match = true; if (hw->phy_id == IFE_E_PHY_ID) - match = TRUE; + match = true; if (hw->phy_id == IFE_PLUS_E_PHY_ID) - match = TRUE; + match = true; if (hw->phy_id == IFE_C_E_PHY_ID) - match = TRUE; + match = true; break; default: DEBUGOUT("Invalid MAC type %d\n", hw->mac_type); @@ -4682,7 +4682,7 @@ e1000_set_media_type(struct e1000_hw *hw)
if (hw->mac_type != e1000_82543) { /* tbi_compatibility is only valid on 82543 */ - hw->tbi_compatibility_en = FALSE; + hw->tbi_compatibility_en = false; }
switch (hw->device_id) { @@ -4714,7 +4714,7 @@ e1000_set_media_type(struct e1000_hw *hw) if (status & E1000_STATUS_TBIMODE) { hw->media_type = e1000_media_type_fiber; /* tbi_compatibility not valid on fiber */ - hw->tbi_compatibility_en = FALSE; + hw->tbi_compatibility_en = false; } else { hw->media_type = e1000_media_type_copper; } @@ -4788,8 +4788,8 @@ e1000_sw_init(struct eth_device *nic) hw->media_type = e1000_media_type_fiber; }
- hw->tbi_compatibility_en = TRUE; - hw->wait_autoneg_complete = TRUE; + hw->tbi_compatibility_en = true; + hw->wait_autoneg_complete = true; if (hw->mac_type < e1000_82543) hw->report_tx_early = 0; else @@ -5187,7 +5187,7 @@ e1000_initialize(bd_t * bis) hw->original_fc = e1000_fc_default; hw->autoneg_failed = 0; hw->autoneg = 1; - hw->get_link_status = TRUE; + hw->get_link_status = true; hw->hw_addr = pci_map_bar(devno, PCI_BASE_ADDRESS_0, PCI_REGION_MEM); hw->mac_type = e1000_undefined; diff --git a/drivers/net/e1000.h b/drivers/net/e1000.h index 1bbae50..6b93c2b 100644 --- a/drivers/net/e1000.h +++ b/drivers/net/e1000.h @@ -89,11 +89,6 @@ int do_e1000_spi(cmd_tbl_t *cmdtp, struct e1000_hw *hw, int argc, char * const argv[]); #endif
-typedef enum { - FALSE = 0, - TRUE = 1 -} boolean_t; - /* Enumerated types specific to the e1000 hardware */ /* Media Access Controlers */ typedef enum { @@ -340,7 +335,7 @@ struct e1000_phy_stats { Control and Address */ #define IFE_PHY_SPECIAL_CONTROL 0x11 /* 100BaseTx PHY special control register */ -#define IFE_PHY_RCV_FALSE_CARRIER 0x13 /* 100BaseTx Receive False +#define IFE_PHY_RCV_FALSE_CARRIER 0x13 /* 100BaseTx Receive false Carrier Counter */ #define IFE_PHY_RCV_DISCONNECT 0x14 /* 100BaseTx Receive Disconnet Counter */ @@ -1040,14 +1035,14 @@ struct e1000_hw_stats { };
struct e1000_eeprom_info { - e1000_eeprom_type type; - uint16_t word_size; - uint16_t opcode_bits; - uint16_t address_bits; - uint16_t delay_usec; - uint16_t page_size; - boolean_t use_eerd; - boolean_t use_eewr; +e1000_eeprom_type type; + uint16_t word_size; + uint16_t opcode_bits; + uint16_t address_bits; + uint16_t delay_usec; + uint16_t page_size; + bool use_eerd; + bool use_eewr; };
typedef enum { @@ -1150,20 +1145,20 @@ struct e1000_hw { #if 0 uint8_t perm_mac_addr[NODE_ADDRESS_SIZE]; #endif - boolean_t disable_polarity_correction; - boolean_t speed_downgraded; - boolean_t get_link_status; - boolean_t tbi_compatibility_en; - boolean_t tbi_compatibility_on; - boolean_t fc_strict_ieee; - boolean_t fc_send_xon; - boolean_t report_tx_early; - boolean_t phy_reset_disable; - boolean_t initialize_hw_bits_disable; + bool disable_polarity_correction; + bool speed_downgraded; + bool get_link_status; + bool tbi_compatibility_en; + bool tbi_compatibility_on; + bool fc_strict_ieee; + bool fc_send_xon; + bool report_tx_early; + bool phy_reset_disable; + bool initialize_hw_bits_disable; #if 0 - boolean_t adaptive_ifs; - boolean_t ifs_params_forced; - boolean_t in_ifs_mode; + bool adaptive_ifs; + bool ifs_params_forced; + bool in_ifs_mode; #endif e1000_smart_speed smart_speed; e1000_dsp_config dsp_config_state; @@ -1860,11 +1855,11 @@ struct e1000_hw { * Typical use: * ... * if (TBI_ACCEPT) { - * accept_frame = TRUE; + * accept_frame = true; * e1000_tbi_adjust_stats(adapter, MacAddress); * frame_length--; * } else { - * accept_frame = FALSE; + * accept_frame = false; * } * ... */ @@ -2080,7 +2075,7 @@ struct e1000_hw { #define GG82563_PSSR2_ENERGY_DETECT_CHANGED 0x0010 /* 1=Energy Detect Changed */ #define GG82563_PSSR2_DOWNSHIFT_INTERRUPT 0x0020 /* 1=Downshift Detected */ #define GG82563_PSSR2_MDI_CROSSOVER_CHANGE 0x0040 /* 1=Crossover Changed */ -#define GG82563_PSSR2_FALSE_CARRIER 0x0100 /* 1=False Carrier */ +#define GG82563_PSSR2_FALSE_CARRIER 0x0100 /* 1=false Carrier */ #define GG82563_PSSR2_SYMBOL_ERROR 0x0200 /* 1=Symbol Error */ #define GG82563_PSSR2_LINK_STATUS_CHANGED 0x0400 /* 1=Link Status Changed */ #define GG82563_PSSR2_AUTO_NEG_COMPLETED 0x0800 /* 1=Auto-Neg Completed */ diff --git a/drivers/net/e1000_spi.c b/drivers/net/e1000_spi.c index 5f774f4..93043a1 100644 --- a/drivers/net/e1000_spi.c +++ b/drivers/net/e1000_spi.c @@ -17,7 +17,7 @@ * never return an error. */ static int e1000_spi_xfer(struct e1000_hw *hw, unsigned int bitlen, - const void *dout_mem, void *din_mem, boolean_t intr) + const void *dout_mem, void *din_mem, bool intr) { const uint8_t *dout = dout_mem; uint8_t *din = din_mem; @@ -145,7 +145,7 @@ int spi_xfer(struct spi_slave *spi, unsigned int bitlen, if (flags & SPI_XFER_BEGIN) e1000_standby_eeprom(hw);
- ret = e1000_spi_xfer(hw, bitlen, dout_mem, din_mem, TRUE); + ret = e1000_spi_xfer(hw, bitlen, dout_mem, din_mem, true);
if (flags & SPI_XFER_END) e1000_standby_eeprom(hw); @@ -169,7 +169,7 @@ int spi_xfer(struct spi_slave *spi, unsigned int bitlen, #define SPI_EEPROM_STATUS_BUSY 0x01 #define SPI_EEPROM_STATUS_WREN 0x02
-static int e1000_spi_eeprom_enable_wr(struct e1000_hw *hw, boolean_t intr) +static int e1000_spi_eeprom_enable_wr(struct e1000_hw *hw, bool intr) { u8 op[] = { SPI_EEPROM_ENABLE_WR }; e1000_standby_eeprom(hw); @@ -181,7 +181,7 @@ static int e1000_spi_eeprom_enable_wr(struct e1000_hw *hw, boolean_t intr) * of the EEPROM commands at this time. */ #if 0 -static int e1000_spi_eeprom_disable_wr(struct e1000_hw *hw, boolean_t intr) +static int e1000_spi_eeprom_disable_wr(struct e1000_hw *hw, bool intr) { u8 op[] = { SPI_EEPROM_DISABLE_WR }; e1000_standby_eeprom(hw); @@ -189,7 +189,7 @@ static int e1000_spi_eeprom_disable_wr(struct e1000_hw *hw, boolean_t intr) }
static int e1000_spi_eeprom_write_status(struct e1000_hw *hw, - u8 status, boolean_t intr) + u8 status, bool intr) { u8 op[] = { SPI_EEPROM_WRITE_STATUS, status }; e1000_standby_eeprom(hw); @@ -197,7 +197,7 @@ static int e1000_spi_eeprom_write_status(struct e1000_hw *hw, } #endif
-static int e1000_spi_eeprom_read_status(struct e1000_hw *hw, boolean_t intr) +static int e1000_spi_eeprom_read_status(struct e1000_hw *hw, bool intr) { u8 op[] = { SPI_EEPROM_READ_STATUS, 0 }; e1000_standby_eeprom(hw); @@ -207,7 +207,7 @@ static int e1000_spi_eeprom_read_status(struct e1000_hw *hw, boolean_t intr) }
static int e1000_spi_eeprom_write_page(struct e1000_hw *hw, - const void *data, u16 off, u16 len, boolean_t intr) + const void *data, u16 off, u16 len, bool intr) { u8 op[] = { SPI_EEPROM_WRITE_PAGE, @@ -225,7 +225,7 @@ static int e1000_spi_eeprom_write_page(struct e1000_hw *hw, }
static int e1000_spi_eeprom_read_page(struct e1000_hw *hw, - void *data, u16 off, u16 len, boolean_t intr) + void *data, u16 off, u16 len, bool intr) { u8 op[] = { SPI_EEPROM_READ_PAGE, @@ -242,7 +242,7 @@ static int e1000_spi_eeprom_read_page(struct e1000_hw *hw, return 0; }
-static int e1000_spi_eeprom_poll_ready(struct e1000_hw *hw, boolean_t intr) +static int e1000_spi_eeprom_poll_ready(struct e1000_hw *hw, bool intr) { int status; while ((status = e1000_spi_eeprom_read_status(hw, intr)) >= 0) { @@ -253,7 +253,7 @@ static int e1000_spi_eeprom_poll_ready(struct e1000_hw *hw, boolean_t intr) }
static int e1000_spi_eeprom_dump(struct e1000_hw *hw, - void *data, u16 off, unsigned int len, boolean_t intr) + void *data, u16 off, unsigned int len, bool intr) { /* Interruptibly wait for the EEPROM to be ready */ if (e1000_spi_eeprom_poll_ready(hw, intr)) @@ -282,7 +282,7 @@ static int e1000_spi_eeprom_dump(struct e1000_hw *hw, }
static int e1000_spi_eeprom_program(struct e1000_hw *hw, - const void *data, u16 off, u16 len, boolean_t intr) + const void *data, u16 off, u16 len, bool intr) { /* Program each page in sequence */ while (len) { @@ -362,7 +362,7 @@ static int do_e1000_spi_show(cmd_tbl_t *cmdtp, struct e1000_hw *hw, free(buffer); return 1; } - err = e1000_spi_eeprom_dump(hw, buffer, offset, length, TRUE); + err = e1000_spi_eeprom_dump(hw, buffer, offset, length, true); e1000_release_eeprom(hw); if (err) { E1000_ERR(hw->nic, "Interrupted!\n"); @@ -421,7 +421,7 @@ static int do_e1000_spi_dump(cmd_tbl_t *cmdtp, struct e1000_hw *hw, }
/* Perform the programming operation */ - if (e1000_spi_eeprom_dump(hw, dest, offset, length, TRUE) < 0) { + if (e1000_spi_eeprom_dump(hw, dest, offset, length, true) < 0) { E1000_ERR(hw->nic, "Interrupted!\n"); e1000_release_eeprom(hw); return 1; @@ -456,7 +456,7 @@ static int do_e1000_spi_program(cmd_tbl_t *cmdtp, struct e1000_hw *hw, }
/* Perform the programming operation */ - if (e1000_spi_eeprom_program(hw, source, offset, length, TRUE) < 0) { + if (e1000_spi_eeprom_program(hw, source, offset, length, true) < 0) { E1000_ERR(hw->nic, "Interrupted!\n"); e1000_release_eeprom(hw); return 1; @@ -472,7 +472,7 @@ static int do_e1000_spi_checksum(cmd_tbl_t *cmdtp, struct e1000_hw *hw, { uint16_t i, length, checksum = 0, checksum_reg; uint16_t *buffer; - boolean_t upd; + bool upd;
if (argc == 0) upd = 0; @@ -498,7 +498,7 @@ static int do_e1000_spi_checksum(cmd_tbl_t *cmdtp, struct e1000_hw *hw, }
/* Read the EEPROM */ - if (e1000_spi_eeprom_dump(hw, buffer, 0, length, TRUE) < 0) { + if (e1000_spi_eeprom_dump(hw, buffer, 0, length, true) < 0) { E1000_ERR(hw->nic, "Interrupted!\n"); e1000_release_eeprom(hw); return 1; @@ -533,7 +533,7 @@ static int do_e1000_spi_checksum(cmd_tbl_t *cmdtp, struct e1000_hw *hw, printf("%s: Reprogramming the EEPROM checksum...\n", hw->nic->name); buffer[i] = cpu_to_le16(checksum); if (e1000_spi_eeprom_program(hw, &buffer[i], i * sizeof(uint16_t), - sizeof(uint16_t), TRUE)) { + sizeof(uint16_t), true)) { E1000_ERR(hw->nic, "Interrupted!\n"); e1000_release_eeprom(hw); return 1; diff --git a/drivers/net/ne2000_base.h b/drivers/net/ne2000_base.h index 5446de4..eee0956 100644 --- a/drivers/net/ne2000_base.h +++ b/drivers/net/ne2000_base.h @@ -79,10 +79,6 @@ are GPL, so this is, of course, GPL. #ifndef __NE2000_BASE_H__ #define __NE2000_BASE_H__
-#define bool int -#define false 0 -#define true 1 - /* * Debugging details * diff --git a/drivers/net/npe/IxEthAcc.c b/drivers/net/npe/IxEthAcc.c index 20d3d9e..7185558 100644 --- a/drivers/net/npe/IxEthAcc.c +++ b/drivers/net/npe/IxEthAcc.c @@ -82,7 +82,7 @@ extern PUBLIC IxOsalMutex ixEthAccControlInterfaceMutex; * @ingroup IxEthAccPri * */ -BOOL ixEthAccServiceInit = FALSE; +BOOL ixEthAccServiceInit = false;
/* global filtering bit mask */ PUBLIC UINT32 ixEthAccNewSrcMask; @@ -168,7 +168,7 @@ PUBLIC IxEthAccStatus ixEthAccInit() }
/* initialiasation is complete */ - ixEthAccServiceInit = TRUE; + ixEthAccServiceInit = true;
return IX_ETH_ACC_SUCCESS;
@@ -200,11 +200,11 @@ PUBLIC void ixEthAccUnload(void) /* set all ports as uninitialized */ for (portId = 0; portId < IX_ETH_ACC_NUMBER_OF_PORTS; portId++) { - ixEthAccPortData[portId].portInitialized = FALSE; + ixEthAccPortData[portId].portInitialized = false; }
/* uninitialize the service */ - ixEthAccServiceInit = FALSE; + ixEthAccServiceInit = false; } }
@@ -248,7 +248,7 @@ PUBLIC IxEthAccStatus ixEthAccPortInit( IxEthAccPortId portId) * Set the port init flag. */
- ixEthAccPortData[portId].portInitialized = TRUE; + ixEthAccPortData[portId].portInitialized = true;
#ifdef CONFIG_IXP425_COMPONENT_ETHDB /* init learning/filtering database structures for this port */ diff --git a/drivers/net/npe/IxEthAccCommon.c b/drivers/net/npe/IxEthAccCommon.c index 211203d..b93a8c8 100644 --- a/drivers/net/npe/IxEthAccCommon.c +++ b/drivers/net/npe/IxEthAccCommon.c @@ -102,7 +102,7 @@ IxEthAccQregInfo ixEthAccQmgrRxDefaultTemplate = (IxQMgrCallbackId) 0, /**< Callback tag */ IX_QMGR_Q_SIZE128, /**< Allocate Max Size Q */ IX_QMGR_Q_ENTRY_SIZE1, /**< Queue Entry Sizes - all Q entries are single word entries */ - TRUE, /**< Enable Q notification at startup */ + true, /**< Enable Q notification at startup */ IX_ETH_ACC_RX_FRAME_ETH_Q_SOURCE,/**< Q Condition to drive callback */ IX_QMGR_Q_WM_LEVEL0, /**< Q Low water mark */ IX_QMGR_Q_WM_LEVEL1, /**< Q High water mark - needed by NPE */ @@ -122,7 +122,7 @@ IxEthAccQregInfo ixEthAccQmgrRxSmallTemplate = (IxQMgrCallbackId) 0, /**< Callback tag */ IX_QMGR_Q_SIZE64, /**< Allocate Smaller Q */ IX_QMGR_Q_ENTRY_SIZE1, /**< Queue Entry Sizes - all Q entries are single word entries */ - TRUE, /**< Enable Q notification at startup */ + true, /**< Enable Q notification at startup */ IX_ETH_ACC_RX_FRAME_ETH_Q_SOURCE,/**< Q Condition to drive callback */ IX_QMGR_Q_WM_LEVEL0, /**< Q Low water mark */ IX_QMGR_Q_WM_LEVEL1, /**< Q High water mark - needed by NPE */ @@ -144,7 +144,7 @@ IxEthAccQregInfo ixEthAccQmgrStaticInfo[]= (IxQMgrCallbackId) IX_ETH_PORT_1, IX_QMGR_Q_SIZE128, /**< Allocate Max Size Q */ IX_QMGR_Q_ENTRY_SIZE1, /**< Queue Entry Sizes - all Q entries are single word entries */ - FALSE, /**< Disable Q notification at startup */ + false, /**< Disable Q notification at startup */ IX_ETH_ACC_RX_FREE_BUFF_ENET0_Q_SOURCE, /**< Q Condition to drive callback */ IX_QMGR_Q_WM_LEVEL0, /***< Q Low water mark */ IX_QMGR_Q_WM_LEVEL64, /**< Q High water mark */ @@ -157,7 +157,7 @@ IxEthAccQregInfo ixEthAccQmgrStaticInfo[]= (IxQMgrCallbackId) IX_ETH_PORT_2, IX_QMGR_Q_SIZE128, /**< Allocate Max Size Q */ IX_QMGR_Q_ENTRY_SIZE1, /**< Queue Entry Sizes - all Q entries are single word entries */ - FALSE, /**< Disable Q notification at startup */ + false, /**< Disable Q notification at startup */ IX_ETH_ACC_RX_FREE_BUFF_ENET1_Q_SOURCE, /**< Q Condition to drive callback */ IX_QMGR_Q_WM_LEVEL0, /**< Q Low water mark */ IX_QMGR_Q_WM_LEVEL64, /**< Q High water mark */ @@ -170,7 +170,7 @@ IxEthAccQregInfo ixEthAccQmgrStaticInfo[]= (IxQMgrCallbackId) IX_ETH_PORT_3, IX_QMGR_Q_SIZE128, /**< Allocate Max Size Q */ IX_QMGR_Q_ENTRY_SIZE1, /**< Queue Entry Sizes - all Q entries are single word entries */ - FALSE, /**< Disable Q notification at startup */ + false, /**< Disable Q notification at startup */ IX_ETH_ACC_RX_FREE_BUFF_ENET2_Q_SOURCE, /**< Q Condition to drive callback */ IX_QMGR_Q_WM_LEVEL0, /**< Q Low water mark */ IX_QMGR_Q_WM_LEVEL64, /**< Q High water mark */ @@ -183,7 +183,7 @@ IxEthAccQregInfo ixEthAccQmgrStaticInfo[]= (IxQMgrCallbackId) IX_ETH_PORT_1, IX_QMGR_Q_SIZE128, /**< Allocate Max Size Q */ IX_QMGR_Q_ENTRY_SIZE1, /**< Queue Entry Sizes - all Q entries are single word entries */ - FALSE, /**< Disable Q notification at startup */ + false, /**< Disable Q notification at startup */ IX_ETH_ACC_TX_FRAME_ENET0_Q_SOURCE, /**< Q Condition to drive callback */ IX_QMGR_Q_WM_LEVEL0, /**< Q Low water mark */ IX_QMGR_Q_WM_LEVEL64, /**< Q High water mark */ @@ -196,7 +196,7 @@ IxEthAccQregInfo ixEthAccQmgrStaticInfo[]= (IxQMgrCallbackId) IX_ETH_PORT_2, IX_QMGR_Q_SIZE128, /**< Allocate Max Size Q */ IX_QMGR_Q_ENTRY_SIZE1, /**< Queue Entry Sizes - all Q entries are single word entries */ - FALSE, /**< Disable Q notification at startup */ + false, /**< Disable Q notification at startup */ IX_ETH_ACC_TX_FRAME_ENET1_Q_SOURCE, /**< Q Condition to drive callback */ IX_QMGR_Q_WM_LEVEL0, /**< Q Low water mark */ IX_QMGR_Q_WM_LEVEL64, /**< Q High water mark */ @@ -209,7 +209,7 @@ IxEthAccQregInfo ixEthAccQmgrStaticInfo[]= (IxQMgrCallbackId) IX_ETH_PORT_3, IX_QMGR_Q_SIZE128, /**< Allocate Max Size Q */ IX_QMGR_Q_ENTRY_SIZE1, /** Queue Entry Sizes - all Q entries are single ord entries */ - FALSE, /** Disable Q notification at startup */ + false, /** Disable Q notification at startup */ IX_ETH_ACC_TX_FRAME_ENET2_Q_SOURCE, /** Q Condition to drive callback */ IX_QMGR_Q_WM_LEVEL0, /* No queues use almost empty */ IX_QMGR_Q_WM_LEVEL64, /** Q High water mark - needed used */ @@ -222,7 +222,7 @@ IxEthAccQregInfo ixEthAccQmgrStaticInfo[]= (IxQMgrCallbackId) 0, IX_QMGR_Q_SIZE128, /**< Allocate Max Size Q */ IX_QMGR_Q_ENTRY_SIZE1, /**< Queue Entry Sizes - all Q entries are single word entries */ - TRUE, /**< Enable Q notification at startup */ + true, /**< Enable Q notification at startup */ IX_ETH_ACC_TX_FRAME_DONE_ETH_Q_SOURCE, /**< Q Condition to drive callback */ IX_QMGR_Q_WM_LEVEL0, /**< Q Low water mark */ IX_QMGR_Q_WM_LEVEL2, /**< Q High water mark - needed by NPE */ @@ -449,7 +449,7 @@ ixEthAccQMgrQueueSetup(IxEthAccQregInfo *qInfoDes) /* * Set notification condition for Q */ - if ( qInfoDes->qNotificationEnableAtStartup == TRUE ) + if (qInfoDes->qNotificationEnableAtStartup == true) { if ( ixQMgrNotificationEnable(qInfoDes->qId, qInfoDes->qConditionSource) @@ -513,7 +513,7 @@ IxEthAccStatus ixEthAccQMgrQueuesConfig(void) IxEthDBProperty ixEthDBTrafficClass = IX_ETH_DB_QOS_TRAFFIC_CLASS_0_RX_QUEUE_PROPERTY; IxEthDBPropertyType ixEthDBPropertyType = IX_ETH_DB_INTEGER_PROPERTY; UINT32 ixEthDBParameter = 0; - BOOL completelySorted = FALSE; + BOOL completelySorted = false;
/* Fill the corspondance between ports and queues * This defines the mapping from port to queue Ids. @@ -706,7 +706,7 @@ IxEthAccStatus ixEthAccQMgrQueuesConfig(void) do { sortIterations++; - completelySorted = TRUE; + completelySorted = true; for (rxQueue = 0; rxQueue < rxQueueCount - sortIterations; rxQueue++) @@ -732,7 +732,7 @@ IxEthAccStatus ixEthAccQMgrQueuesConfig(void) rxQueues[rxQueue+1].npeId = npeId; rxQueues[rxQueue+1].qId = qId; rxQueues[rxQueue+1].trafficClass = trafficClass; - completelySorted = FALSE; + completelySorted = false; } } } diff --git a/drivers/net/npe/IxEthAccDataPlane.c b/drivers/net/npe/IxEthAccDataPlane.c index b62f0d0..6df3307 100644 --- a/drivers/net/npe/IxEthAccDataPlane.c +++ b/drivers/net/npe/IxEthAccDataPlane.c @@ -948,7 +948,7 @@ IxEthAccStatus ixEthAccPortRxCallbackRegister(IxEthAccPortId portId, for (port = 0; port < IX_ETH_ACC_NUMBER_OF_PORTS; port++) { if ((ixEthAccMacState[port].portDisableState == ACTIVE) - && (ixEthAccPortData[port].ixEthAccRxData.rxMultiBufferCallbackInUse == TRUE)) + && (ixEthAccPortData[port].ixEthAccRxData.rxMultiBufferCallbackInUse == true)) { /* one of the active ports has a different rx callback type. * Changing the callback type when the port is enabled @@ -977,7 +977,7 @@ IxEthAccStatus ixEthAccPortRxCallbackRegister(IxEthAccPortId portId, return (IX_ETH_ACC_INVALID_ARG); }
- ixEthAccPortData[portId].ixEthAccRxData.rxMultiBufferCallbackInUse = FALSE; + ixEthAccPortData[portId].ixEthAccRxData.rxMultiBufferCallbackInUse = false;
return (IX_ETH_ACC_SUCCESS); } @@ -1025,7 +1025,7 @@ IxEthAccStatus ixEthAccPortMultiBufferRxCallbackRegister( for (port = 0; port < IX_ETH_ACC_NUMBER_OF_PORTS; port++) { if ((ixEthAccMacState[port].portDisableState == ACTIVE) - && (ixEthAccPortData[port].ixEthAccRxData.rxMultiBufferCallbackInUse == FALSE)) + && (ixEthAccPortData[port].ixEthAccRxData.rxMultiBufferCallbackInUse == false)) { /* one of the active ports has a different rx callback type. * Changing the callback type when the port is enabled @@ -1055,7 +1055,7 @@ IxEthAccStatus ixEthAccPortMultiBufferRxCallbackRegister( return (IX_ETH_ACC_INVALID_ARG); }
- ixEthAccPortData[portId].ixEthAccRxData.rxMultiBufferCallbackInUse = TRUE; + ixEthAccPortData[portId].ixEthAccRxData.rxMultiBufferCallbackInUse = true;
return (IX_ETH_ACC_SUCCESS); } @@ -1456,7 +1456,7 @@ ixEthRxFrameProcess(IxEthAccPortId portId, IX_OSAL_MBUF *mbufPtr) IX_ETH_ACC_FATAL_LOG( "ixEthRxFrameProcess: Illegal port: %u\n", (UINT32)portId, 0, 0, 0, 0, 0); - return FALSE; + return false; } #endif
@@ -1468,7 +1468,7 @@ ixEthRxFrameProcess(IxEthAccPortId portId, IX_OSAL_MBUF *mbufPtr) if ((flags & (IX_ETHACC_NE_FILTERMASK | IX_ETHACC_NE_NEWSRCMASK)) == 0) { /* "best case" scenario : nothing special to do for this frame */ - return TRUE; + return true; }
#ifdef CONFIG_IXP425_COMPONENT_ETHDB @@ -1540,10 +1540,10 @@ ixEthRxFrameProcess(IxEthAccPortId portId, IX_OSAL_MBUF *mbufPtr) RX_STATS_INC(portId, rxFiltered);
/* indicate that frame should not be subjected to further processing */ - return FALSE; + return false; }
diff --git a/drivers/net/npe/IxEthAccMac.c b/drivers/net/npe/IxEthAccMac.c index 369ee91..5540b33 100644 --- a/drivers/net/npe/IxEthAccMac.c +++ b/drivers/net/npe/IxEthAccMac.c @@ -304,7 +304,7 @@ ixEthAccPortEnablePriv(IxEthAccPortId portId)
/* set the global state */ ixEthAccMacState[portId].portDisableState = ACTIVE; - ixEthAccMacState[portId].enabled = TRUE; + ixEthAccMacState[portId].enabled = true;
/* rewrite the setup (including mac filtering) depending * on current options @@ -515,7 +515,7 @@ ixEthAccPortDisableRxCallback (UINT32 cbTag, IxEthAccPortId portId = (IxEthAccPortId)cbTag;
/* call the portDisable receive callback */ - (ixEthAccPortDisableRxTable[portId])(portId, mBufPtr, FALSE); + (ixEthAccPortDisableRxTable[portId])(portId, mBufPtr, false); }
PRIVATE void @@ -527,7 +527,7 @@ ixEthAccPortDisableMultiBufferRxCallback (UINT32 cbTag, while (*mBufPtr) { /* call the portDisable receive callback with one buffer at a time */ - (ixEthAccPortDisableRxTable[portId])(portId, *mBufPtr++, TRUE); + (ixEthAccPortDisableRxTable[portId])(portId, *mBufPtr++, true); } }
@@ -820,7 +820,7 @@ ixEthAccPortDisablePriv(IxEthAccPortId portId) }
/* disable MAC Tx and Rx services */ - ixEthAccMacState[portId].enabled = FALSE; + ixEthAccMacState[portId].enabled = false; ixEthAccMacStateUpdate(portId);
/* restore the Rx and TxDone callbacks (within a critical section) */ @@ -869,14 +869,14 @@ ixEthAccPortEnabledQueryPriv(IxEthAccPortId portId, BOOL *enabled) IX_ETH_ACC_WARNING_LOG("EthAcc: Unavailable Eth %d: Cannot enable port.\n",(INT32)portId,0,0,0,0,0);
/* Since Eth NPE is not available, port must be disabled */ - *enabled = FALSE ; + *enabled = false ; return IX_ETH_ACC_SUCCESS ; }
if (!IX_ETH_IS_PORT_INITIALIZED(portId)) { /* Since Eth NPE is not available, port must be disabled */ - *enabled = FALSE ; + *enabled = false ; return (IX_ETH_ACC_PORT_UNINITIALIZED); }
@@ -1259,7 +1259,7 @@ ixEthAccPortPromiscuousModeClearPriv(IxEthAccPortId portId) IX_ETH_ACC_MAC_RX_CNTRL1, regval | IX_ETH_ACC_RX_CNTRL1_ADDR_FLTR_EN);
- ixEthAccMacState[portId].promiscuous = FALSE; + ixEthAccMacState[portId].promiscuous = false;
ixEthAccMulticastAddressSet(portId);
@@ -1297,7 +1297,7 @@ ixEthAccPortPromiscuousModeSetPriv(IxEthAccPortId portId) IX_ETH_ACC_MAC_RX_CNTRL1, regval | IX_ETH_ACC_RX_CNTRL1_ADDR_FLTR_EN);
- ixEthAccMacState[portId].promiscuous = TRUE; + ixEthAccMacState[portId].promiscuous = true;
@@ -1361,7 +1361,7 @@ ixEthAccPortUnicastMacAddressSetPriv (IxEthAccPortId portId, IX_ETH_ACC_MAC_UNI_ADDR_1 + i*sizeof(UINT32), macAddr->macAddress[i]); } - ixEthAccMacState[portId].initDone = TRUE; + ixEthAccMacState[portId].initDone = true;
return IX_ETH_ACC_SUCCESS; } @@ -1552,7 +1552,7 @@ ixEthAccPortMulticastAddressJoinAllPriv (IxEthAccPortId portId) IX_IEEE803_MAC_ADDRESS_SIZE);
ixEthAccMacState[portId].mcastAddrIndex = 1; - ixEthAccMacState[portId].joinAll = TRUE; + ixEthAccMacState[portId].joinAll = true;
@@ -1599,7 +1599,7 @@ ixEthAccPortMulticastAddressLeavePriv (IxEthAccPortId portId, { if(ixEthAccMacEqual(macAddr, &mcastMacAddr)) { - ixEthAccMacState[portId].joinAll = FALSE; + ixEthAccMacState[portId].joinAll = false; } /*Decrement the index into the multicast address table for the current port*/ @@ -1643,7 +1643,7 @@ ixEthAccPortMulticastAddressLeaveAllPriv (IxEthAccPortId portId) }
ixEthAccMacState[portId].mcastAddrIndex = 0; - ixEthAccMacState[portId].joinAll = FALSE; + ixEthAccMacState[portId].joinAll = false;
@@ -1770,7 +1770,7 @@ ixEthAccPortDuplexModeSetPriv (IxEthAccPortId portId, REG_WRITE(ixEthAccMacBase[portId], IX_ETH_ACC_MAC_RX_CNTRL1, rxregval | IX_ETH_ACC_RX_CNTRL1_PAUSE_EN); - ixEthAccMacState[portId].fullDuplex = TRUE; + ixEthAccMacState[portId].fullDuplex = true;
} else if (mode == IX_ETH_ACC_HALF_DUPLEX) @@ -1786,7 +1786,7 @@ ixEthAccPortDuplexModeSetPriv (IxEthAccPortId portId, IX_ETH_ACC_MAC_RX_CNTRL1, rxregval & ~IX_ETH_ACC_RX_CNTRL1_PAUSE_EN);
- ixEthAccMacState[portId].fullDuplex = FALSE; + ixEthAccMacState[portId].fullDuplex = false; } else { @@ -1876,7 +1876,7 @@ ixEthAccPortTxFrameAppendPaddingEnablePriv (IxEthAccPortId portId) regval | IX_ETH_ACC_TX_CNTRL1_PAD_EN);
- ixEthAccMacState[portId].txPADAppend = TRUE; + ixEthAccMacState[portId].txPADAppend = true; return IX_ETH_ACC_SUCCESS; }
@@ -1908,7 +1908,7 @@ ixEthAccPortTxFrameAppendPaddingDisablePriv (IxEthAccPortId portId) IX_ETH_ACC_MAC_TX_CNTRL1, regval & ~IX_ETH_ACC_TX_CNTRL1_PAD_EN);
- ixEthAccMacState[portId].txPADAppend = FALSE; + ixEthAccMacState[portId].txPADAppend = false; return IX_ETH_ACC_SUCCESS; }
@@ -1941,7 +1941,7 @@ ixEthAccPortTxFrameAppendFCSEnablePriv (IxEthAccPortId portId) IX_ETH_ACC_MAC_TX_CNTRL1, regval | IX_ETH_ACC_TX_CNTRL1_FCS_EN);
- ixEthAccMacState[portId].txFCSAppend = TRUE; + ixEthAccMacState[portId].txFCSAppend = true; return IX_ETH_ACC_SUCCESS; }
@@ -1973,7 +1973,7 @@ ixEthAccPortTxFrameAppendFCSDisablePriv (IxEthAccPortId portId) IX_ETH_ACC_MAC_TX_CNTRL1, regval & ~IX_ETH_ACC_TX_CNTRL1_FCS_EN);
- ixEthAccMacState[portId].txFCSAppend = FALSE; + ixEthAccMacState[portId].txFCSAppend = false; return IX_ETH_ACC_SUCCESS; }
@@ -2004,7 +2004,7 @@ ixEthAccPortRxFrameAppendFCSEnablePriv (IxEthAccPortId portId) IX_ETH_ACC_MAC_RX_CNTRL1, regval | IX_ETH_ACC_RX_CNTRL1_CRC_EN);
- ixEthAccMacState[portId].rxFCSAppend = TRUE; + ixEthAccMacState[portId].rxFCSAppend = true; return IX_ETH_ACC_SUCCESS; }
@@ -2035,7 +2035,7 @@ ixEthAccPortRxFrameAppendFCSDisablePriv (IxEthAccPortId portId) IX_ETH_ACC_MAC_RX_CNTRL1, regval & ~IX_ETH_ACC_RX_CNTRL1_CRC_EN);
- ixEthAccMacState[portId].rxFCSAppend = FALSE; + ixEthAccMacState[portId].rxFCSAppend = false; return IX_ETH_ACC_SUCCESS; }
@@ -2327,17 +2327,17 @@ ixEthAccMacInit(IxEthAccPortId portId) return IX_ETH_ACC_SUCCESS ; }
- if(ixEthAccMacState[portId].macInitialised == FALSE) + if(ixEthAccMacState[portId].macInitialised == false) { - ixEthAccMacState[portId].fullDuplex = TRUE; - ixEthAccMacState[portId].rxFCSAppend = TRUE; - ixEthAccMacState[portId].txFCSAppend = TRUE; - ixEthAccMacState[portId].txPADAppend = TRUE; - ixEthAccMacState[portId].enabled = FALSE; - ixEthAccMacState[portId].promiscuous = TRUE; - ixEthAccMacState[portId].joinAll = FALSE; - ixEthAccMacState[portId].initDone = FALSE; - ixEthAccMacState[portId].macInitialised = TRUE; + ixEthAccMacState[portId].fullDuplex = true; + ixEthAccMacState[portId].rxFCSAppend = true; + ixEthAccMacState[portId].txFCSAppend = true; + ixEthAccMacState[portId].txPADAppend = true; + ixEthAccMacState[portId].enabled = false; + ixEthAccMacState[portId].promiscuous = true; + ixEthAccMacState[portId].joinAll = false; + ixEthAccMacState[portId].initDone = false; + ixEthAccMacState[portId].macInitialised = true;
/* initialize MIB stats mutexes */ ixOsalMutexInit(&ixEthAccMacState[portId].ackMIBStatsLock); @@ -2417,7 +2417,7 @@ ixEthAccMacStateUpdate(IxEthAccPortId portId) { UINT32 regval;
- if ( ixEthAccMacState[portId].enabled == FALSE ) + if ( ixEthAccMacState[portId].enabled == false ) { /* Just disable both the transmitter and reciver in the MAC. */ REG_READ(ixEthAccMacBase[portId], @@ -2480,7 +2480,7 @@ ixEthAccMacStateUpdate(IxEthAccPortId portId) ixEthAccPortPromiscuousModeClearPriv(portId); }
- if ( ixEthAccMacState[portId].enabled == TRUE ) + if ( ixEthAccMacState[portId].enabled == true ) { /* Enable both the transmitter and reciver in the MAC. */ REG_READ(ixEthAccMacBase[portId], @@ -2509,10 +2509,10 @@ ixEthAccMacEqual(IxEthAccMacAddr *macAddr1, { if(macAddr1->macAddress[i] != macAddr2->macAddress[i]) { - return FALSE; + return false; } } - return TRUE; + return true; }
PRIVATE void @@ -2554,7 +2554,7 @@ ixEthAccMulticastAddressSet(IxEthAccPortId portId) * are set in the result */
- if (ixEthAccMacState[portId].promiscuous == TRUE) + if (ixEthAccMacState[portId].promiscuous == true) { /* Promiscuous Mode is set, and filtering * allow all packets, and enable the mcast and @@ -2569,7 +2569,7 @@ ixEthAccMulticastAddressSet(IxEthAccPortId portId) } else { - if(ixEthAccMacState[portId].joinAll == TRUE) + if(ixEthAccMacState[portId].joinAll == true) { /* Join all is set. The mask and address are * the multicast settings. diff --git a/drivers/net/npe/IxEthDBAPI.c b/drivers/net/npe/IxEthDBAPI.c index b2bfb72..d46c47c 100644 --- a/drivers/net/npe/IxEthDBAPI.c +++ b/drivers/net/npe/IxEthDBAPI.c @@ -60,7 +60,7 @@ IxEthDBStatus ixEthDBFilteringStaticEntryProvision(IxEthDBPortId portID, IxEthDB
IX_ETH_DB_CHECK_FEATURE(portID, IX_ETH_DB_LEARNING);
- return ixEthDBTriggerAddPortUpdate(macAddr, portID, TRUE); + return ixEthDBTriggerAddPortUpdate(macAddr, portID, true); }
IX_ETH_DB_PUBLIC @@ -74,7 +74,7 @@ IxEthDBStatus ixEthDBFilteringDynamicEntryProvision(IxEthDBPortId portID, IxEthD
- return ixEthDBTriggerAddPortUpdate(macAddr, portID, FALSE); + return ixEthDBTriggerAddPortUpdate(macAddr, portID, false); }
IX_ETH_DB_PUBLIC @@ -102,7 +102,7 @@ void ixEthDBDatabaseMaintenance() { HashIterator iterator; UINT32 portIndex; - BOOL agingRequired = FALSE; + BOOL agingRequired = false;
/* ports who will have deleted records and therefore will need updating */ IxEthDBPortMap triggerPorts; @@ -120,7 +120,7 @@ void ixEthDBDatabaseMaintenance() { if (ixEthDBPortInfo[portIndex].agingEnabled && ixEthDBPortInfo[portIndex].enabled) { - agingRequired = TRUE; + agingRequired = true; } }
@@ -152,9 +152,9 @@ void ixEthDBDatabaseMaintenance() } else { - ixEthDBPortInfo[portIndex].agingEnabled = FALSE; - ixEthDBPortInfo[portIndex].updateMethod.updateEnabled = FALSE; - ixEthDBPortInfo[portIndex].updateMethod.userControlled = TRUE; + ixEthDBPortInfo[portIndex].agingEnabled = false; + ixEthDBPortInfo[portIndex].updateMethod.updateEnabled = false; + ixEthDBPortInfo[portIndex].updateMethod.userControlled = true;
ixOsalLog(IX_OSAL_LOG_LVL_FATAL, IX_OSAL_LOG_DEV_STDOUT, @@ -173,7 +173,7 @@ void ixEthDBDatabaseMaintenance() { MacDescriptor *descriptor = (MacDescriptor *) iterator.node->data; UINT32 *age = NULL; - BOOL staticEntry = TRUE; + BOOL staticEntry = true;
if (descriptor->type == IX_ETH_DB_FILTERING_RECORD) { @@ -187,10 +187,10 @@ void ixEthDBDatabaseMaintenance() } else { - staticEntry = TRUE; + staticEntry = true; }
- if (ixEthDBPortInfo[descriptor->portID].agingEnabled && (staticEntry == FALSE)) + if (ixEthDBPortInfo[descriptor->portID].agingEnabled && (staticEntry == false)) { /* manually increment the age if the port has no such capability */ if ((ixEthDBPortDefinitions[descriptor->portID].capabilities & IX_ETH_ENTRY_AGING) == 0) @@ -341,7 +341,7 @@ IxEthDBStatus ixEthDBPortAgingDisable(IxEthDBPortId portID)
- ixEthDBPortInfo[portID].agingEnabled = FALSE; + ixEthDBPortInfo[portID].agingEnabled = false;
return IX_ETH_DB_SUCCESS; } @@ -355,7 +355,7 @@ IxEthDBStatus ixEthDBPortAgingEnable(IxEthDBPortId portID)
- ixEthDBPortInfo[portID].agingEnabled = TRUE; + ixEthDBPortInfo[portID].agingEnabled = true;
return IX_ETH_DB_SUCCESS; } @@ -442,7 +442,7 @@ IxEthDBStatus ixEthDBPortUpdateEnableSet(IxEthDBPortId portID, BOOL enableUpdate IX_ETH_DB_CHECK_FEATURE(portID, IX_ETH_DB_FILTERING);
ixEthDBPortInfo[portID].updateMethod.updateEnabled = enableUpdate; - ixEthDBPortInfo[portID].updateMethod.userControlled = TRUE; + ixEthDBPortInfo[portID].updateMethod.userControlled = true;
return IX_ETH_DB_SUCCESS; } diff --git a/drivers/net/npe/IxEthDBAPISupport.c b/drivers/net/npe/IxEthDBAPISupport.c index 36bc200..1facb89 100644 --- a/drivers/net/npe/IxEthDBAPISupport.c +++ b/drivers/net/npe/IxEthDBAPISupport.c @@ -128,18 +128,18 @@ void ixEthDBPortInit(IxEthDBPortId portID) SET_DEPENDENCY_MAP(portInfo->dependencyPortMap, portID);
/* default values */ - portInfo->agingEnabled = FALSE; - portInfo->enabled = FALSE; - portInfo->macAddressUploaded = FALSE; + portInfo->agingEnabled = false; + portInfo->enabled = false; + portInfo->macAddressUploaded = false; portInfo->maxRxFrameSize = IX_ETHDB_DEFAULT_FRAME_SIZE; portInfo->maxTxFrameSize = IX_ETHDB_DEFAULT_FRAME_SIZE;
/* default update control values */ portInfo->updateMethod.searchTree = NULL; - portInfo->updateMethod.searchTreePendingWrite = FALSE; - portInfo->updateMethod.treeInitialized = FALSE; - portInfo->updateMethod.updateEnabled = FALSE; - portInfo->updateMethod.userControlled = FALSE; + portInfo->updateMethod.searchTreePendingWrite = false; + portInfo->updateMethod.treeInitialized = false; + portInfo->updateMethod.updateEnabled = false; + portInfo->updateMethod.userControlled = false;
/* default WiFi parameters */ memset(portInfo->bbsid, 0, sizeof (portInfo->bbsid)); @@ -153,9 +153,9 @@ void ixEthDBPortInit(IxEthDBPortId portID) }
/* initialize state save */ - ixEthDBPortState[portID].saved = FALSE; + ixEthDBPortState[portID].saved = false;
- portInfo->initialized = TRUE; + portInfo->initialized = true; }
/** @@ -190,7 +190,7 @@ IxEthDBStatus ixEthDBPortEnable(IxEthDBPortId portID) SET_DEPENDENCY_MAP(triggerPorts, portID);
/* mark as enabled */ - portInfo->enabled = TRUE; + portInfo->enabled = true;
/* Operation stops here when Ethernet Learning is not enabled */ if(IX_FEATURE_CTRL_SWCONFIG_DISABLED == @@ -214,7 +214,7 @@ IxEthDBStatus ixEthDBPortEnable(IxEthDBPortId portID) if (!portInfo->updateMethod.userControlled && ((portInfo->featureCapability & IX_ETH_DB_FILTERING) != 0)) { - portInfo->updateMethod.updateEnabled = TRUE; + portInfo->updateMethod.updateEnabled = true; }
/* if this is first time initialization then we already have @@ -227,7 +227,7 @@ IxEthDBStatus ixEthDBPortEnable(IxEthDBPortId portID) ixEthDBUpdatePortLearningTrees(triggerPorts);
/* mark tree as being initialized */ - portInfo->updateMethod.treeInitialized = TRUE; + portInfo->updateMethod.treeInitialized = true; } }
@@ -262,7 +262,7 @@ IxEthDBStatus ixEthDBPortEnable(IxEthDBPortId portID) ixEthDBFilteringPortMaximumTxFrameSizeSet(portID, ixEthDBPortState[portID].maxTxFrameSize);
/* discard previous save */ - ixEthDBPortState[portID].saved = FALSE; + ixEthDBPortState[portID].saved = false; }
IX_ETH_DB_SUPPORT_TRACE("DB: (Support) Enabling succeeded for port %d\n", portID); @@ -321,7 +321,7 @@ IxEthDBStatus ixEthDBPortDisable(IxEthDBPortId portID) memcpy(ixEthDBPortState[portID].transmitTaggingInfo, portInfo->transmitTaggingInfo, sizeof (IxEthDBVlanSet)); memcpy(ixEthDBPortState[portID].priorityTable, portInfo->priorityTable, sizeof (IxEthDBPriorityTable));
- ixEthDBPortState[portID].saved = TRUE; + ixEthDBPortState[portID].saved = true;
/* now turn off all EthDB filtering features on the port */
@@ -330,7 +330,7 @@ IxEthDBStatus ixEthDBPortDisable(IxEthDBPortId portID) if ((portInfo->featureCapability & IX_ETH_DB_VLAN_QOS) != 0) { ixEthDBPortVlanMembershipRangeAdd((IxEthDBPortId) portID, 0, IX_ETH_DB_802_1Q_MAX_VLAN_ID); - ixEthDBEgressVlanRangeTaggingEnabledSet((IxEthDBPortId) portID, 0, IX_ETH_DB_802_1Q_MAX_VLAN_ID, FALSE); + ixEthDBEgressVlanRangeTaggingEnabledSet((IxEthDBPortId) portID, 0, IX_ETH_DB_802_1Q_MAX_VLAN_ID, false); ixEthDBAcceptableFrameTypeSet((IxEthDBPortId) portID, IX_ETH_DB_ACCEPT_ALL_FRAMES); ixEthDBIngressVlanTaggingEnabledSet((IxEthDBPortId) portID, IX_ETH_DB_PASS_THROUGH);
@@ -342,7 +342,7 @@ IxEthDBStatus ixEthDBPortDisable(IxEthDBPortId portID) /* STP */ if ((portInfo->featureCapability & IX_ETH_DB_SPANNING_TREE_PROTOCOL) != 0) { - ixEthDBSpanningTreeBlockingStateSet((IxEthDBPortId) portID, FALSE); + ixEthDBSpanningTreeBlockingStateSet((IxEthDBPortId) portID, false); }
/* Firewall */ @@ -350,7 +350,7 @@ IxEthDBStatus ixEthDBPortDisable(IxEthDBPortId portID) { ixEthDBFirewallModeSet((IxEthDBPortId) portID, IX_ETH_DB_FIREWALL_BLACK_LIST); ixEthDBFirewallTableDownload((IxEthDBPortId) portID); - ixEthDBFirewallInvalidAddressFilterEnable((IxEthDBPortId) portID, FALSE); + ixEthDBFirewallInvalidAddressFilterEnable((IxEthDBPortId) portID, false); }
/* Frame size filter */ @@ -413,18 +413,18 @@ IxEthDBStatus ixEthDBPortDisable(IxEthDBPortId portID) }
/* mark as disabled */ - portInfo->enabled = FALSE; + portInfo->enabled = false;
/* disable updates unless the user has specifically altered the default behavior */ if (ixEthDBPortDefinitions[portID].type == IX_ETH_NPE) { if (!portInfo->updateMethod.userControlled) { - portInfo->updateMethod.updateEnabled = FALSE; + portInfo->updateMethod.updateEnabled = false; }
/* make sure we re-initialize the NPE learning tree when the port is re-enabled */ - portInfo->updateMethod.treeInitialized = FALSE; + portInfo->updateMethod.treeInitialized = false; }
ixEthDBUpdateUnlock(); @@ -668,7 +668,7 @@ IxEthDBStatus ixEthDBPortAddressSet(IxEthDBPortId portID, IxEthDBMacAddr *macAdd
if (result == IX_SUCCESS) { - ixEthDBPortInfo[portID].macAddressUploaded = TRUE; + ixEthDBPortInfo[portID].macAddressUploaded = true; }
return result; diff --git a/drivers/net/npe/IxEthDBCore.c b/drivers/net/npe/IxEthDBCore.c index 25b7cbb..8b3c1d9 100644 --- a/drivers/net/npe/IxEthDBCore.c +++ b/drivers/net/npe/IxEthDBCore.c @@ -51,7 +51,7 @@ IX_ETH_DB_PUBLIC BOOL ixEthDBPortUpdateRequired[IX_ETH_DB_MAX_RECORD_TYPE_INDEX IX_ETH_DB_PUBLIC UINT32 ixEthDBKeyType[IX_ETH_DB_MAX_RECORD_TYPE_INDEX + 1];
/* private initialization flag */ -IX_ETH_DB_PRIVATE BOOL ethDBInitializationComplete = FALSE; +IX_ETH_DB_PRIVATE BOOL ethDBInitializationComplete = false;
/** * @brief initializes EthDB @@ -124,7 +124,7 @@ IxEthDBStatus ixEthDBInit(void) ixEthDBFeatureCapabilityScan(); }
- ethDBInitializationComplete = TRUE; + ethDBInitializationComplete = true;
return result; } @@ -179,7 +179,7 @@ IxEthDBStatus ixEthDBUnload(void) ixOsalMutexDestroy(&ixEthDBPortInfo[portIndex].npeAckLock); }
- ixEthDBPortInfo[portIndex].initialized = FALSE; + ixEthDBPortInfo[portIndex].initialized = false; }
/* shutdown event processor */ @@ -188,7 +188,7 @@ IxEthDBStatus ixEthDBUnload(void) /* deallocate NPE update zones */ ixEthDBNPEUpdateAreasUnload();
- ethDBInitializationComplete = FALSE; + ethDBInitializationComplete = false;
return IX_ETH_DB_SUCCESS; } diff --git a/drivers/net/npe/IxEthDBEvents.c b/drivers/net/npe/IxEthDBEvents.c index 4d44e03..529063d 100644 --- a/drivers/net/npe/IxEthDBEvents.c +++ b/drivers/net/npe/IxEthDBEvents.c @@ -61,8 +61,8 @@ IX_ETH_DB_PRIVATE PortEventQueue eventQueue; IX_ETH_DB_PRIVATE IxOsalMutex eventQueueLock; IX_ETH_DB_PRIVATE IxOsalMutex portUpdateLock;
-IX_ETH_DB_PRIVATE BOOL ixEthDBLearningShutdown = FALSE; -IX_ETH_DB_PRIVATE BOOL ixEthDBEventProcessorRunning = FALSE; +IX_ETH_DB_PRIVATE BOOL ixEthDBLearningShutdown = false; +IX_ETH_DB_PRIVATE BOOL ixEthDBEventProcessorRunning = false;
/* imported data */ extern HashTable dbHashtable; @@ -143,7 +143,7 @@ IxEthDBStatus ixEthDBStartLearningFunction(void) return IX_ETH_DB_FAIL; }
- ixEthDBLearningShutdown = FALSE; + ixEthDBLearningShutdown = false;
/* create processor loop thread */ if (ixOsalThreadCreate(&eventProcessorThread, &threadAttr, ixEthDBEventProcessorLoop, NULL) != IX_SUCCESS) @@ -173,7 +173,7 @@ IxEthDBStatus ixEthDBStartLearningFunction(void) IX_ETH_DB_PUBLIC IxEthDBStatus ixEthDBStopLearningFunction(void) { - ixEthDBLearningShutdown = TRUE; + ixEthDBLearningShutdown = true;
/* wake up event processing loop to actually process the shutdown event */ ixOsalSemaphorePost(&eventQueueSemaphore); @@ -253,13 +253,13 @@ void ixEthDBEventProcessorLoop(void *unused1) IxEthDBPortMap triggerPorts; IxEthDBPortId portIndex;
- ixEthDBEventProcessorRunning = TRUE; + ixEthDBEventProcessorRunning = true;
IX_ETH_DB_EVENTS_TRACE("DB: (Events) Event processor loop was started\n");
while (!ixEthDBLearningShutdown) { - BOOL keepProcessing = TRUE; + BOOL keepProcessing = true; UINT32 processedEvents = 0;
IX_ETH_DB_EVENTS_VERBOSE_TRACE("DB: (Events) Waiting for new learning event...\n"); @@ -302,7 +302,7 @@ void ixEthDBEventProcessorLoop(void *unused1) if (processedEvents > EVENT_PROCESSING_LIMIT /* maximum burst reached? */ || ixOsalSemaphoreTryWait(&eventQueueSemaphore) != IX_SUCCESS) /* or empty queue? */ { - keepProcessing = FALSE; + keepProcessing = false; } }
@@ -313,10 +313,10 @@ void ixEthDBEventProcessorLoop(void *unused1) /* turn off automatic updates */ for (portIndex = 0 ; portIndex < IX_ETH_DB_NUMBER_OF_PORTS ; portIndex++) { - ixEthDBPortInfo[portIndex].updateMethod.updateEnabled = FALSE; + ixEthDBPortInfo[portIndex].updateMethod.updateEnabled = false; }
- ixEthDBEventProcessorRunning = FALSE; + ixEthDBEventProcessorRunning = false; }
/** @@ -381,7 +381,7 @@ void ixEthDBProcessEvent(PortEvent *local_event, IxEthDBPortMap triggerPorts) * * @param macAddr MAC address of the new record * @param portID port ID of the new record - * @param staticEntry TRUE if record is static, FALSE if dynamic + * @param staticEntry true if record is static, false if dynamic * * @return IX_ETH_DB_SUCCESS if the event creation was * successfull or IX_ETH_DB_BUSY if the event queue is full @@ -430,7 +430,7 @@ IxEthDBStatus ixEthDBTriggerRemovePortUpdate(IxEthDBMacAddr *macAddr, IxEthDBPor { if (ixEthDBPeek(macAddr, IX_ETH_DB_ALL_FILTERING_RECORDS) != IX_ETH_DB_NO_SUCH_ADDR) { - return ixEthDBTriggerPortUpdate(IX_ETH_DB_REMOVE_FILTERING_RECORD, macAddr, portID, FALSE); + return ixEthDBTriggerPortUpdate(IX_ETH_DB_REMOVE_FILTERING_RECORD, macAddr, portID, false); } else { diff --git a/drivers/net/npe/IxEthDBFeatures.c b/drivers/net/npe/IxEthDBFeatures.c index 7a58d26..faf4f93 100644 --- a/drivers/net/npe/IxEthDBFeatures.c +++ b/drivers/net/npe/IxEthDBFeatures.c @@ -169,7 +169,7 @@ void ixEthDBFeatureCapabilityScan(void) /* enable port, VLAN and Firewall feature bits to initialize QoS/VLAN/Firewall configuration */ portInfo->featureStatus |= IX_ETH_DB_VLAN_QOS; portInfo->featureStatus |= IX_ETH_DB_FIREWALL; - portInfo->enabled = TRUE; + portInfo->enabled = true;
#define CONFIG_WITH_VLAN /* test-only: VLAN support not included to save space!!! */ #ifdef CONFIG_WITH_VLAN /* test-only: VLAN support not included to save space!!! */ @@ -195,7 +195,7 @@ void ixEthDBFeatureCapabilityScan(void) ixEthDBPortVlanMembershipRangeRemove(portIndex, 0, IX_ETH_DB_802_1Q_MAX_VLAN_ID);
/* clear TTI table - no VLAN tagged frames will be transmitted */ - ixEthDBEgressVlanRangeTaggingEnabledSet(portIndex, 0, 4094, FALSE); + ixEthDBEgressVlanRangeTaggingEnabledSet(portIndex, 0, 4094, false);
/* set membership on 0, otherwise no Tx or Rx is working */ ixEthDBPortVlanMembershipAdd(portIndex, 0); @@ -221,12 +221,12 @@ void ixEthDBFeatureCapabilityScan(void) #endif
/* by default we turn off invalid source MAC address filtering */ - ixEthDBFirewallInvalidAddressFilterEnable(portIndex, FALSE); + ixEthDBFirewallInvalidAddressFilterEnable(portIndex, false);
/* disable port, VLAN, Firewall feature bits */ portInfo->featureStatus &= ~IX_ETH_DB_VLAN_QOS; portInfo->featureStatus &= ~IX_ETH_DB_FIREWALL; - portInfo->enabled = FALSE; + portInfo->enabled = false;
/* enable filtering by default if present */ if ((portInfo->featureCapability & IX_ETH_DB_FILTERING) != 0) @@ -333,7 +333,7 @@ IxEthDBStatus ixEthDBFeatureEnable(IxEthDBPortId portID, IxEthDBFeature feature, }
/* force port enabled */ - portInfo->enabled = TRUE; + portInfo->enabled = true;
if (enable) { @@ -399,7 +399,7 @@ IxEthDBStatus ixEthDBFeatureEnable(IxEthDBPortId portID, IxEthDBFeature feature, /* enable TPID port extraction */ if (status == IX_ETH_DB_SUCCESS) { - status = ixEthDBVlanPortExtractionEnable(portID, TRUE); + status = ixEthDBVlanPortExtractionEnable(portID, true); } } else if (feature == IX_ETH_DB_FIREWALL) @@ -414,7 +414,7 @@ IxEthDBStatus ixEthDBFeatureEnable(IxEthDBPortId portID, IxEthDBFeature feature,
if (status == IX_ETH_DB_SUCCESS) { - status = ixEthDBFirewallInvalidAddressFilterEnable(portID, FALSE); + status = ixEthDBFirewallInvalidAddressFilterEnable(portID, false); } } } @@ -445,7 +445,7 @@ IxEthDBStatus ixEthDBFeatureEnable(IxEthDBPortId portID, IxEthDBFeature feature,
if (status == IX_ETH_DB_SUCCESS) @@ -515,7 +515,7 @@ IxEthDBStatus ixEthDBFeatureEnable(IxEthDBPortId portID, IxEthDBFeature feature, /* disable TPID port extraction */ if (status == IX_ETH_DB_SUCCESS) { - status = ixEthDBVlanPortExtractionEnable(portID, FALSE); + status = ixEthDBVlanPortExtractionEnable(portID, false); } } #endif diff --git a/drivers/net/npe/IxEthDBFirewall.c b/drivers/net/npe/IxEthDBFirewall.c index eb46174..24fb82e 100644 --- a/drivers/net/npe/IxEthDBFirewall.c +++ b/drivers/net/npe/IxEthDBFirewall.c @@ -72,7 +72,7 @@ IxEthDBStatus ixEthDBFirewallUpdate(IxEthDBPortId portID, void *address, UINT32 UINT32 mode = 0; PortInfo *portInfo = &ixEthDBPortInfo[portID];
- mode = (portInfo->srcAddressFilterEnabled != FALSE) << 1 | (portInfo->firewallMode == IX_ETH_DB_FIREWALL_WHITE_LIST); + mode = (portInfo->srcAddressFilterEnabled != false) << 1 | (portInfo->firewallMode == IX_ETH_DB_FIREWALL_WHITE_LIST);
FILL_SETFIREWALLMODE_MSG(message, IX_ETH_DB_PORT_ID_TO_NPE_LOGICAL_ID(portID), diff --git a/drivers/net/npe/IxEthDBNPEAdaptor.c b/drivers/net/npe/IxEthDBNPEAdaptor.c index 112a46c..d47ffec 100644 --- a/drivers/net/npe/IxEthDBNPEAdaptor.c +++ b/drivers/net/npe/IxEthDBNPEAdaptor.c @@ -203,7 +203,7 @@ void ixEthDBNPESyncScan(IxEthDBPortId portID, void *eltBaseAddress, UINT32 eltSi /* debug */ IX_ETH_DB_NPE_VERBOSE_TRACE("DB: (NPEAdaptor) checking node at offset %d...\n", eltEntryOffset / ELT_ENTRY_SIZE);
- if (IX_EDB_NPE_NODE_VALID(eltNodeAddress) != TRUE) + if (IX_EDB_NPE_NODE_VALID(eltNodeAddress) != true) { IX_ETH_DB_NPE_VERBOSE_TRACE("\t... node is empty\n"); } diff --git a/drivers/net/npe/IxEthDBPortUpdate.c b/drivers/net/npe/IxEthDBPortUpdate.c index cdf114b..813e4ee 100644 --- a/drivers/net/npe/IxEthDBPortUpdate.c +++ b/drivers/net/npe/IxEthDBPortUpdate.c @@ -60,7 +60,7 @@ extern HashTable dbHashtable; * * @param typeArray array indexed on record types, each * element indicating whether the record type requires an - * automatic update (TRUE) or not (FALSE) + * automatic update (true) or not (false) * * Automatic updates are done for registered record types * upon adding, updating (that is, updating the record portID) @@ -70,7 +70,7 @@ extern HashTable dbHashtable; * * It is assumed that the typeArray parameter is allocated large * enough to hold all the user defined types. Also, the type - * array should be initialized to FALSE as this function only + * array should be initialized to false as this function only * caters for types which do require automatic updates. * * Note that this function should be called by the component @@ -84,8 +84,8 @@ extern HashTable dbHashtable; IX_ETH_DB_PUBLIC UINT32 ixEthDBUpdateTypeRegister(BOOL *typeArray) { - typeArray[IX_ETH_DB_FILTERING_RECORD] = TRUE; - typeArray[IX_ETH_DB_FILTERING_VLAN_RECORD] = TRUE; + typeArray[IX_ETH_DB_FILTERING_RECORD] = true; + typeArray[IX_ETH_DB_FILTERING_VLAN_RECORD] = true;
return 2; } @@ -174,7 +174,7 @@ void ixEthDBCreateTrees(IxEthDBPortMap updatePorts) { UINT32 portIndex; BOOL result; - BOOL portsLeft = TRUE; + BOOL portsLeft = true;
while (portsLeft) { @@ -305,11 +305,11 @@ void ixEthDBCreateTrees(IxEthDBPortMap updatePorts) }
/* mark tree as valid */ - port->updateMethod.searchTreePendingWrite = TRUE; + port->updateMethod.searchTreePendingWrite = true; } else { - portsLeft = FALSE; + portsLeft = false;
IX_ETH_DB_UPDATE_TRACE("DB: (Update) No trees to create this round\n"); } @@ -374,7 +374,7 @@ IxEthDBStatus ixEthDBNPEUpdateHandler(IxEthDBPortId portID, IxEthDBRecordType ty
/* forget last used search tree */ port->updateMethod.searchTree = NULL; - port->updateMethod.searchTreePendingWrite = FALSE; + port->updateMethod.searchTreePendingWrite = false;
/* dependending on the update type we do different things */ if (type == IX_ETH_DB_FILTERING_RECORD || type == IX_ETH_DB_WIFI_RECORD) @@ -393,9 +393,9 @@ IxEthDBStatus ixEthDBNPEUpdateHandler(IxEthDBPortId portID, IxEthDBRecordType ty } else { - ixEthDBPortInfo[portID].agingEnabled = FALSE; - ixEthDBPortInfo[portID].updateMethod.updateEnabled = FALSE; - ixEthDBPortInfo[portID].updateMethod.userControlled = TRUE; + ixEthDBPortInfo[portID].agingEnabled = false; + ixEthDBPortInfo[portID].updateMethod.updateEnabled = false; + ixEthDBPortInfo[portID].updateMethod.userControlled = true;
ERROR_LOG("EthDB: (PortUpdate) disabling aging and updates on port %d (assumed dead)\n", portID);
diff --git a/drivers/net/npe/IxEthDBReports.c b/drivers/net/npe/IxEthDBReports.c index 9c7ae1c..912e608 100644 --- a/drivers/net/npe/IxEthDBReports.c +++ b/drivers/net/npe/IxEthDBReports.c @@ -62,7 +62,7 @@ IX_ETH_DB_PUBLIC IxEthDBStatus ixEthDBDependencyPortMapShow(IxEthDBPortId portID, IxEthDBPortMap map) { UINT32 portIndex; - BOOL mapSelf = TRUE, mapNone = TRUE, firstPort = TRUE; + BOOL mapSelf = true, mapNone = true, firstPort = true;
/* dependency port maps */ printf("Dependency port map: "); @@ -72,22 +72,22 @@ IxEthDBStatus ixEthDBDependencyPortMapShow(IxEthDBPortId portID, IxEthDBPortMap { if (IS_PORT_INCLUDED(portIndex, map)) { - mapNone = FALSE; + mapNone = false;
if (portIndex != portID) { - mapSelf = FALSE; + mapSelf = false; }
printf("%s%d", firstPort ? "{" : ", ", portIndex);
- firstPort = FALSE; + firstPort = false; } }
if (mapNone) { - mapSelf = FALSE; + mapSelf = false; }
printf("%s (%s)\n", firstPort ? "" : "}", mapSelf ? "self" : mapNone ? "none" : "group"); diff --git a/drivers/net/npe/IxEthDBSearch.c b/drivers/net/npe/IxEthDBSearch.c index 4a10878..75fdebe 100644 --- a/drivers/net/npe/IxEthDBSearch.c +++ b/drivers/net/npe/IxEthDBSearch.c @@ -50,7 +50,7 @@ extern HashTable dbHashtable; * @param untypedReference record to match against * @param untypedEntry record to match * - * @return TRUE if the match is successful or FALSE otherwise + * @return true if the match is successful or false otherwise * * @internal */ @@ -61,7 +61,7 @@ BOOL ixEthDBAddressRecordMatch(void *untypedReference, void *untypedEntry) MacDescriptor *reference = (MacDescriptor *) untypedReference;
/* check accepted record types */ - if ((entry->type & reference->type) == 0) return FALSE; + if ((entry->type & reference->type) == 0) return false;
return (ixEthDBAddressCompare((UINT8 *) entry->macAddress, (UINT8 *) reference->macAddress) == 0); } @@ -73,7 +73,7 @@ BOOL ixEthDBAddressRecordMatch(void *untypedReference, void *untypedEntry) * @param untypedReference record to match against * @param untypedEntry record to match * - * @return TRUE if the match is successful or FALSE otherwise + * @return true if the match is successful or false otherwise * * @internal */ @@ -84,7 +84,7 @@ BOOL ixEthDBVlanRecordMatch(void *untypedReference, void *untypedEntry) MacDescriptor *reference = (MacDescriptor *) untypedReference;
return (IX_ETH_DB_GET_VLAN_ID(entry->recordData.filteringVlanData.ieee802_1qTag) == IX_ETH_DB_GET_VLAN_ID(reference->recordData.filteringVlanData.ieee802_1qTag)) && @@ -98,7 +98,7 @@ BOOL ixEthDBVlanRecordMatch(void *untypedReference, void *untypedEntry) * @param untypedReference record to match against * @param untypedEntry record to match * - * @return TRUE if the match is successful or FALSE otherwise + * @return true if the match is successful or false otherwise * * @internal */ @@ -109,7 +109,7 @@ BOOL ixEthDBPortRecordMatch(void *untypedReference, void *untypedEntry) MacDescriptor *reference = (MacDescriptor *) untypedReference;
return (entry->portID == reference->portID) && (ixEthDBAddressCompare(entry->macAddress, reference->macAddress) == 0); @@ -125,7 +125,7 @@ BOOL ixEthDBPortRecordMatch(void *untypedReference, void *untypedEntry) * array on invalid types. Calling it will display an * error message, indicating an error in the component logic. * - * @return FALSE + * @return false * * @internal */ @@ -137,7 +137,7 @@ BOOL ixEthDBNullMatch(void *reference, void *entry) ixOsalLog(IX_OSAL_LOG_LVL_WARNING, IX_OSAL_LOG_DEV_STDOUT, "DB: (Search) The NullMatch function was called, wrong key type?\n", 0, 0, 0, 0, 0, 0);
/** diff --git a/drivers/net/npe/IxEthDBUtil.c b/drivers/net/npe/IxEthDBUtil.c index e708bf1..24acc24 100644 --- a/drivers/net/npe/IxEthDBUtil.c +++ b/drivers/net/npe/IxEthDBUtil.c @@ -94,13 +94,13 @@ BOOL ixEthDBCheckSingleBitValue(UINT32 value) while (value != 0) { - if (value == 1) return TRUE; - else if ((value & 1) == 1) return FALSE; + if (value == 1) return true; + else if ((value & 1) == 1) return false;
value >>= 1; }
#endif } diff --git a/drivers/net/npe/IxEthMii.c b/drivers/net/npe/IxEthMii.c index 4d92f17..4667749 100644 --- a/drivers/net/npe/IxEthMii.c +++ b/drivers/net/npe/IxEthMii.c @@ -89,7 +89,7 @@ ixEthMiiPhyScan(BOOL phyPresent[], UINT32 maxPhyCount) i<IXP425_ETH_ACC_MII_MAX_ADDR; i++) { - phyPresent[i] = FALSE; + phyPresent[i] = false; }
/* iterate through the PHY addresses */ @@ -119,7 +119,7 @@ ixEthMiiPhyScan(BOOL phyPresent[], UINT32 maxPhyCount) ) { /* supported phy */ - phyPresent[i] = TRUE; + phyPresent[i] = true; } /* end of if(ixEthMiiPhyId) */ else { @@ -131,7 +131,7 @@ ixEthMiiPhyScan(BOOL phyPresent[], UINT32 maxPhyCount) "ixEthMiiPhyScan : unexpected Mii PHY ID %8.8x\n", ixEthMiiPhyId[i], 2, 3, 4, 5, 6); ixEthMiiPhyId[i] = IX_ETH_MII_UNKNOWN_PHY_ID; - phyPresent[i] = TRUE; + phyPresent[i] = true; } } } @@ -347,10 +347,10 @@ ixEthMiiLinkStatus(UINT32 phyAddr, return IX_FAIL; }
- *linkUp = FALSE; - *speed100 = FALSE; - *fullDuplex = FALSE; - *autoneg = FALSE; + *linkUp = false; + *speed100 = false; + *fullDuplex = false; + *autoneg = false;
if ((phyAddr < IXP425_ETH_ACC_MII_MAX_ADDR) && (ixEthMiiPhyId[phyAddr] != IX_ETH_MII_INVALID_PHY_ID)) @@ -406,20 +406,20 @@ ixEthMiiLinkStatus(UINT32 phyAddr, if ((regval & IX_ETH_MII_SR_TX_FULL_DPX) != 0) { /* 100 Base X full dplx */ - *speed100 = TRUE; - *fullDuplex = TRUE; + *speed100 = true; + *fullDuplex = true; return IX_SUCCESS; } if ((regval & IX_ETH_MII_SR_TX_HALF_DPX) != 0) { /* 100 Base X half dplx */ - *speed100 = TRUE; + *speed100 = true; return IX_SUCCESS; } if ((regval & IX_ETH_MII_SR_10T_FULL_DPX) != 0) { /* 10 mb full dplx */ - *fullDuplex = TRUE; + *fullDuplex = true; return IX_SUCCESS; } if ((regval & IX_ETH_MII_SR_10T_HALF_DPX) != 0) diff --git a/drivers/net/npe/IxFeatureCtrl.c b/drivers/net/npe/IxFeatureCtrl.c index 2e196a1..b6728e4 100644 --- a/drivers/net/npe/IxFeatureCtrl.c +++ b/drivers/net/npe/IxFeatureCtrl.c @@ -72,7 +72,7 @@ IX_OSAL_WRITE_LONG(ixFeatureCtrlRegister, (value)); \
/* Boolean to mark the fact that the EXP_CONFIG address space was mapped */ -PRIVATE BOOL ixFeatureCtrlExpCfgRegionMapped = FALSE; +PRIVATE BOOL ixFeatureCtrlExpCfgRegionMapped = false;
/* Pointer holding the virtual address of the Feature Control Register */ PRIVATE VUINT32 *ixFeatureCtrlRegister = NULL; @@ -81,7 +81,7 @@ PRIVATE VUINT32 *ixFeatureCtrlRegister = NULL; PRIVATE BOOL swConfiguration[IX_FEATURECTRL_SWCONFIG_MAX];
/* Flag to control swConfiguration[] is initialized once */ -PRIVATE BOOL swConfigurationFlag = FALSE ; +PRIVATE BOOL swConfigurationFlag = false ;
/* Array containing component mask values */ #ifdef __ixp42X @@ -158,7 +158,7 @@ void ixFeatureCtrlExpMap(void)
/* If the EXP Configuration space has already been mapped then * return */ - if (ixFeatureCtrlExpCfgRegionMapped == TRUE) + if (ixFeatureCtrlExpCfgRegionMapped == true) { return; } @@ -176,7 +176,7 @@ void ixFeatureCtrlExpMap(void) (VUINT32 *) (expCfgBaseAddress + IX_FEATURE_CTRL_REG_OFFSET);
/* Mark the fact that the EXP_CONFIG space has already been mapped */ - ixFeatureCtrlExpCfgRegionMapped = TRUE; + ixFeatureCtrlExpCfgRegionMapped = true; }
/** @@ -186,15 +186,15 @@ void ixFeatureCtrlExpMap(void) PRIVATE void ixFeatureCtrlSwConfigurationInit(void) { UINT32 i; - if (FALSE == swConfigurationFlag) + if (false == swConfigurationFlag) { for (i=0; i<IX_FEATURECTRL_SWCONFIG_MAX ; i++) { /* By default, all software configuration are enabled */ - swConfiguration[i]= TRUE ; + swConfiguration[i]= true ; } /*Make sure this function only initializes swConfiguration[] once*/ - swConfigurationFlag = TRUE ; + swConfigurationFlag = true ; } }
@@ -326,7 +326,7 @@ ixFeatureCtrlProductIdRead () extern IxFeatureCtrlProductId AsmixFeatureCtrlProductIdRead();
#ifndef IN_KERNEL - mode = SetKMode(TRUE); + mode = SetKMode(true); #endif pdId = AsmixFeatureCtrlProductIdRead(); #ifndef IN_KERNEL @@ -372,7 +372,7 @@ ixFeatureCtrlSwConfigurationCheck (IxFeatureCtrlSwConfig swConfigType) ixFeatureCtrlSwConfigurationInit();
/* Check and return software configuration */ - return ((swConfiguration[(UINT32)swConfigType] == TRUE) ? IX_FEATURE_CTRL_SWCONFIG_ENABLED: IX_FEATURE_CTRL_SWCONFIG_DISABLED); + return ((swConfiguration[(UINT32)swConfigType] == true) ? IX_FEATURE_CTRL_SWCONFIG_ENABLED: IX_FEATURE_CTRL_SWCONFIG_DISABLED); }
/** diff --git a/drivers/net/npe/IxNpeDl.c b/drivers/net/npe/IxNpeDl.c index 3738337..bfeac87 100644 --- a/drivers/net/npe/IxNpeDl.c +++ b/drivers/net/npe/IxNpeDl.c @@ -89,9 +89,9 @@ typedef struct */ static IxNpeDlNpeState ixNpeDlNpeState[IX_NPEDL_NPEID_MAX] = { - {FALSE, {IX_NPEDL_NPEID_MAX, 0, 0, 0}}, - {FALSE, {IX_NPEDL_NPEID_MAX, 0, 0, 0}}, - {FALSE, {IX_NPEDL_NPEID_MAX, 0, 0, 0}} + {false, {IX_NPEDL_NPEID_MAX, 0, 0, 0}}, + {false, {IX_NPEDL_NPEID_MAX, 0, 0, 0}}, + {false, {IX_NPEDL_NPEID_MAX, 0, 0, 0}} };
static IxNpeDlStats ixNpeDlStats; @@ -99,7 +99,7 @@ static IxNpeDlStats ixNpeDlStats; /* * Software guard to prevent NPE from being started multiple times. */ -static BOOL ixNpeDlNpeStarted[IX_NPEDL_NPEID_MAX] ={FALSE, FALSE, FALSE} ; +static BOOL ixNpeDlNpeStarted[IX_NPEDL_NPEID_MAX] ={false, false, false} ;
/* @@ -195,7 +195,7 @@ ixNpeDlImageDownload (IxNpeDlImageId *imageIdPtr, if (IX_SUCCESS == status) { ixNpeDlNpeState[npeId].imageId = *imageIdPtr; - ixNpeDlNpeState[npeId].validImage = TRUE; + ixNpeDlNpeState[npeId].validImage = true; ixNpeDlStats.successfulDownloads++;
status = ixNpeDlNpeExecutionStart (npeId); @@ -204,7 +204,7 @@ ixNpeDlImageDownload (IxNpeDlImageId *imageIdPtr, (status == IX_NPEDL_CRITICAL_MICROCODE_ERR)) { ixNpeDlNpeState[npeId].imageId = *imageIdPtr; - ixNpeDlNpeState[npeId].validImage = FALSE; + ixNpeDlNpeState[npeId].validImage = false; ixNpeDlStats.criticalFailDownloads++; } } /* end of if(IX_SUCCESS) */ /* condition: image located successfully in microcode image */ @@ -507,7 +507,7 @@ ixNpeDlNpeStopAndReset (IxNpeDlNpeId npeId) if (IX_SUCCESS == status) { /* Indicate NPE has been stopped */ - ixNpeDlNpeStarted[npeId] = FALSE ; + ixNpeDlNpeStarted[npeId] = false ; }
return status; @@ -573,7 +573,7 @@ ixNpeDlNpeExecutionStart (IxNpeDlNpeId npeId) } /* end of if-else(IX_NPEDL_NPEID_NPEC) */ } /* end of if not IXP42x-A0 Silicon */
- if (TRUE == ixNpeDlNpeStarted[npeId]) + if (true == ixNpeDlNpeStarted[npeId]) { /* NPE has been started. */ return IX_SUCCESS ; @@ -588,7 +588,7 @@ ixNpeDlNpeExecutionStart (IxNpeDlNpeId npeId) if (IX_SUCCESS == status) { /* Indicate NPE has started */ - ixNpeDlNpeStarted[npeId] = TRUE ; + ixNpeDlNpeStarted[npeId] = true ; }
IX_NPEDL_TRACE1 (IX_NPEDL_FN_ENTRY_EXIT, @@ -674,7 +674,7 @@ ixNpeDlNpeExecutionStop (IxNpeDlNpeId npeId) if (IX_SUCCESS == status) { /* Indicate NPE has been stopped */ - ixNpeDlNpeStarted[npeId] = FALSE ; + ixNpeDlNpeStarted[npeId] = false ; }
return status; @@ -840,10 +840,10 @@ ixNpeDlNpeInitAndStartInternal (UINT32 *imageLibrary, * currently loaded images. If a critical error occured * during download, record that the NPE has an invalid image */ - status = ixNpeDlNpeMgrImageLoad (npeId, imageCodePtr, TRUE); + status = ixNpeDlNpeMgrImageLoad (npeId, imageCodePtr, true); if (IX_SUCCESS == status) { - ixNpeDlNpeState[npeId].validImage = TRUE; + ixNpeDlNpeState[npeId].validImage = true; ixNpeDlStats.successfulDownloads++;
status = ixNpeDlNpeExecutionStart (npeId); @@ -851,7 +851,7 @@ ixNpeDlNpeInitAndStartInternal (UINT32 *imageLibrary, else if ((status == IX_NPEDL_CRITICAL_NPE_ERR) || (status == IX_NPEDL_CRITICAL_MICROCODE_ERR)) { - ixNpeDlNpeState[npeId].validImage = FALSE; + ixNpeDlNpeState[npeId].validImage = false; ixNpeDlStats.criticalFailDownloads++; }
diff --git a/drivers/net/npe/IxNpeDlImageMgr.c b/drivers/net/npe/IxNpeDlImageMgr.c index 9bcdc9c..0484483 100644 --- a/drivers/net/npe/IxNpeDlImageMgr.c +++ b/drivers/net/npe/IxNpeDlImageMgr.c @@ -414,11 +414,11 @@ ixNpeDlImageMgrSignatureCheck (UINT32 *microCodeImageLibrary) { IxNpeDlImageMgrImageLibraryHeader *header = (IxNpeDlImageMgrImageLibraryHeader *) microCodeImageLibrary; - BOOL result = TRUE; + BOOL result = true;
if (!header || header->signature != IX_NPEDL_IMAGEMGR_SIGNATURE) { - result = FALSE; + result = false; ixNpeDlImageMgrStats.invalidSignature++; }
@@ -469,11 +469,11 @@ ixNpeDlImageMgrImageIdCompare ( (imageIdA->major == imageIdB->major) && (imageIdA->minor == imageIdB->minor)) { - return TRUE; + return true; } else { - return FALSE; + return false; } }
@@ -491,11 +491,11 @@ ixNpeDlImageMgrNpeFunctionIdCompare ( if ((imageIdA->npeId == imageIdB->npeId) && (imageIdA->functionalityId == imageIdB->functionalityId)) { - return TRUE; + return true; } else { - return FALSE; + return false; } }
@@ -550,7 +550,7 @@ ixNpeDlImageMgrImageFind_legacy ( UINT32 imageCount = 0; IX_STATUS status = IX_FAIL; IxNpeDlImageMgrImageLibraryHeader *header; - BOOL imageFound = FALSE; + BOOL imageFound = false;
IX_NPEDL_TRACE0 (IX_NPEDL_FN_ENTRY_EXIT, "Entering ixNpeDlImageMgrImageFind\n"); @@ -584,7 +584,7 @@ ixNpeDlImageMgrImageFind_legacy ( /* get the image size */ *imageSize = header->entry[imageCount].image.size; status = IX_SUCCESS; - imageFound = TRUE; + imageFound = true; } imageCount++; } diff --git a/drivers/net/npe/IxNpeDlNpeMgr.c b/drivers/net/npe/IxNpeDlNpeMgr.c index a9ea8bc..aaffeeb 100644 --- a/drivers/net/npe/IxNpeDlNpeMgr.c +++ b/drivers/net/npe/IxNpeDlNpeMgr.c @@ -229,7 +229,7 @@ static IxNpeDlEcsRegResetValue ixNpeDlEcsRegResetValues[] = static IxNpeDlNpeMgrStats ixNpeDlNpeMgrStats;
/* Set when NPE register memory has been mapped */ -static BOOL ixNpeDlMemInitialised = FALSE; +static BOOL ixNpeDlMemInitialised = false;
/* @@ -290,7 +290,7 @@ ixNpeDlNpeMgrInit (void) IX_OSAL_ASSERT(virtAddr); ixNpeDlNpeInfo[IX_NPEDL_NPEID_NPEC].baseAddress = virtAddr;
- ixNpeDlMemInitialised = TRUE; + ixNpeDlMemInitialised = true; } }
@@ -314,7 +314,7 @@ ixNpeDlNpeMgrUninit (void) ixNpeDlNpeInfo[IX_NPEDL_NPEID_NPEB].baseAddress = 0; ixNpeDlNpeInfo[IX_NPEDL_NPEID_NPEC].baseAddress = 0;
- ixNpeDlMemInitialised = FALSE; + ixNpeDlMemInitialised = false;
return IX_SUCCESS; } @@ -662,7 +662,7 @@ ixNpeDlNpeMgrNpeReset ( { /* for each physical register in the NPE reg file, write 0 : */ status = ixNpeDlNpeMgrPhysicalRegWrite (npeBaseAddress, regAddr, - 0, TRUE); + 0, true); if (status != IX_SUCCESS) { return status; /* abort reset */ @@ -684,7 +684,7 @@ ixNpeDlNpeMgrNpeReset ( { regVal = ixNpeDlCtxtRegResetValues[ctxtReg]; status = ixNpeDlNpeMgrCtxtRegWrite (npeBaseAddress, ctxtNum, - ctxtReg, regVal, TRUE); + ctxtReg, regVal, true); if (status != IX_SUCCESS) { return status; /* abort reset */ diff --git a/drivers/net/npe/IxNpeMh.c b/drivers/net/npe/IxNpeMh.c index 8703def..2870ff7 100644 --- a/drivers/net/npe/IxNpeMh.c +++ b/drivers/net/npe/IxNpeMh.c @@ -79,7 +79,7 @@ * static variables. */
-PRIVATE BOOL ixNpeMhInitialized = FALSE; +PRIVATE BOOL ixNpeMhInitialized = false;
/* * Extern function prototypes. @@ -128,7 +128,7 @@ PUBLIC IX_STATUS ixNpeMhInitialize ( */ ixNpeMhConfigInitialize (npeInterrupts);
- ixNpeMhInitialized = TRUE; + ixNpeMhInitialized = true;
IX_NPEMH_TRACE0 (IX_NPEMH_FN_ENTRY_EXIT, "Exiting " "ixNpeMhInitialize\n"); @@ -153,7 +153,7 @@ PUBLIC IX_STATUS ixNpeMhUnload (void) /* Uninitialize the Configuration module */ ixNpeMhConfigUninit ();
- ixNpeMhInitialized = FALSE; + ixNpeMhInitialized = false;
IX_NPEMH_TRACE0 (IX_NPEMH_FN_ENTRY_EXIT, "Exiting " "ixNpeMhUnload\n"); diff --git a/drivers/net/npe/IxNpeMhConfig.c b/drivers/net/npe/IxNpeMhConfig.c index 50c8f21..092d480 100644 --- a/drivers/net/npe/IxNpeMhConfig.c +++ b/drivers/net/npe/IxNpeMhConfig.c @@ -105,7 +105,7 @@ IxNpeMhConfigNpeInfo ixNpeMhConfigNpeInfo[IX_NPEMH_NUM_NPES] = 0, 0, NULL, - FALSE + false }, { 0, @@ -116,7 +116,7 @@ IxNpeMhConfigNpeInfo ixNpeMhConfigNpeInfo[IX_NPEMH_NUM_NPES] = 0, 0, NULL, - FALSE + false }, { 0, @@ -127,7 +127,7 @@ IxNpeMhConfigNpeInfo ixNpeMhConfigNpeInfo[IX_NPEMH_NUM_NPES] = 0, 0, NULL, - FALSE + false } };
diff --git a/drivers/net/npe/IxNpeMhSend.c b/drivers/net/npe/IxNpeMhSend.c index 318913a..27bc9b7 100644 --- a/drivers/net/npe/IxNpeMhSend.c +++ b/drivers/net/npe/IxNpeMhSend.c @@ -124,7 +124,7 @@ BOOL ixNpeMhSendInFifoIsFull( IxNpeMhNpeId npeId, UINT32 maxSendRetries) { - BOOL isFull = FALSE; + BOOL isFull = false; UINT32 numRetries = 0;
/* check the NPE's inFIFO */ diff --git a/drivers/net/npe/IxOsalOsSemaphore.c b/drivers/net/npe/IxOsalOsSemaphore.c index 443aefd..672bec1 100644 --- a/drivers/net/npe/IxOsalOsSemaphore.c +++ b/drivers/net/npe/IxOsalOsSemaphore.c @@ -135,10 +135,10 @@ static void drv_mutex_destroy(IxOsalMutex *mutex)
static int drv_mutex_trylock(IxOsalMutex *mutex) { - int result = TRUE; + int result = true;
if (*mutex == 1) - result = FALSE; + result = false;
return result; } diff --git a/drivers/net/npe/IxQMgrDispatcher.c b/drivers/net/npe/IxQMgrDispatcher.c index 9cb1439..25a3e85 100644 --- a/drivers/net/npe/IxQMgrDispatcher.c +++ b/drivers/net/npe/IxQMgrDispatcher.c @@ -160,7 +160,7 @@ static IxQMgrQId priorityTable[IX_QMGR_MAX_NUM_QUEUES]; /* * This flag indicates to the dispatcher that the priority table needs to be rebuilt. */ -static BOOL rebuildTable = FALSE; +static BOOL rebuildTable = false;
/* Dispatcher statistics */ static IxQMgrDispatcherStats dispatcherStats; @@ -197,7 +197,7 @@ ixQMgrDispatcherInit (void) int i; IxFeatureCtrlProductId productId = 0; IxFeatureCtrlDeviceId deviceId = 0; - BOOL stickyIntSilicon = TRUE; + BOOL stickyIntSilicon = true;
/* Set default priorities */ for (i=0; i< IX_QMGR_MAX_NUM_QUEUES; i++) @@ -226,7 +226,7 @@ ixQMgrDispatcherInit (void) dispatcherStats.queueStats[i].priorityChangeCnt = 0; dispatcherStats.queueStats[i].intNoCallbackCnt = 0; dispatcherStats.queueStats[i].intLostCallbackCnt = 0; - dispatcherStats.queueStats[i].notificationEnabled = FALSE; + dispatcherStats.queueStats[i].notificationEnabled = false; dispatcherStats.queueStats[i].srcSel = 0;
} @@ -258,7 +258,7 @@ ixQMgrDispatcherInit (void) (IX_FEATURE_CTRL_SILICON_TYPE_A0 == (IX_FEATURE_CTRL_SILICON_STEPPING_MASK & productId))) { - stickyIntSilicon = FALSE; + stickyIntSilicon = false; }
/* @@ -293,7 +293,7 @@ ixQMgrDispatcherPrioritySet (IxQMgrQId qId, /* Change priority */ dispatchQInfo[qId].priority = priority; /* Set flag */ - rebuildTable = TRUE; + rebuildTable = true;
ixOsalIrqUnlock(ixQMgrLockKey);
@@ -364,7 +364,7 @@ ixQMgrNotificationEnable (IxQMgrQId qId, #endif
#ifndef NDEBUG - dispatcherStats.queueStats[qId].notificationEnabled = TRUE; + dispatcherStats.queueStats[qId].notificationEnabled = true; dispatcherStats.queueStats[qId].srcSel = srcSel; #endif
@@ -428,7 +428,7 @@ ixQMgrNotificationDisable (IxQMgrQId qId) * so need critical section */ #ifndef NDEBUG - dispatcherStats.queueStats[qId].notificationEnabled = FALSE; + dispatcherStats.queueStats[qId].notificationEnabled = false; #endif
ixQMgrLockKey = ixOsalIrqLock(); @@ -593,7 +593,7 @@ ixQMgrDispatcherLoopRunA0 (IxQMgrDispatchGroup group) qIndex += IX_QMGR_MIN_QUEUPP_QID; }
- if (statusChangeFlag == FALSE) + if (statusChangeFlag == false) { /* check if the interrupt register contains * only 1 bit set (happy day scenario) @@ -800,7 +800,7 @@ ixQMgrDispatcherLoopRunB0 (IxQMgrDispatchGroup group) * For example: * intRegVal = 0x0010 * currDispatchQInfo->intRegCheckMask = 0x0010 - * intRegVal == currDispatchQInfo->intRegCheckMask is TRUE. + * intRegVal == currDispatchQInfo->intRegCheckMask is true. */ currDispatchQInfo = &dispatchQInfo[qIndex]; if (intRegVal == currDispatchQInfo->intRegCheckMask) @@ -955,7 +955,7 @@ ixQMgrDispatcherLoopRunB0LLP (IxQMgrDispatchGroup group) * For example: * intRegVal = 0x0010 * currDispatchQInfo->intRegCheckMask = 0x0010 - * intRegVal == currDispatchQInfo->intRegCheckMask is TRUE. + * intRegVal == currDispatchQInfo->intRegCheckMask is true. */ currDispatchQInfo = &dispatchQInfo[qIndex]; if (intRegVal == currDispatchQInfo->intRegCheckMask) @@ -1118,7 +1118,7 @@ ixQMgrDispatcherReBuildPriorityTable (void) int uppQuePriorityTableIndex = IX_QMGR_MIN_UPP_QUE_PRIORITY_TABLE_INDEX;
/* Reset the rebuild flag */ - rebuildTable = FALSE; + rebuildTable = false;
/* initialize the mak used to identify the queues in the first half * of the priority table @@ -1266,7 +1266,7 @@ ixQMgrPeriodicDone (void) * Update statistics */ dispatcherStats.queueStats[i].enableCount++; - dispatcherStats.queueStats[i].notificationEnabled = TRUE; + dispatcherStats.queueStats[i].notificationEnabled = true; #endif } } diff --git a/drivers/net/npe/IxQMgrInit.c b/drivers/net/npe/IxQMgrInit.c index b00c22d..61ca96c 100644 --- a/drivers/net/npe/IxQMgrInit.c +++ b/drivers/net/npe/IxQMgrInit.c @@ -66,7 +66,7 @@ * Set to true if initialized * N.B. global so integration/unit tests can reinitialize */ -BOOL qMgrIsInitialized = FALSE; +BOOL qMgrIsInitialized = false;
/* * Function definitions. @@ -90,7 +90,7 @@ ixQMgrInit (void) ixQMgrQAccessInit ();
/* Initialization complete */ - qMgrIsInitialized = TRUE; + qMgrIsInitialized = true;
return IX_SUCCESS; } @@ -107,7 +107,7 @@ ixQMgrUnload (void) ixQMgrQCfgUninit ();
/* Uninitialization complete */ - qMgrIsInitialized = FALSE; + qMgrIsInitialized = false;
return IX_SUCCESS; } diff --git a/drivers/net/npe/IxQMgrQCfg.c b/drivers/net/npe/IxQMgrQCfg.c index ec7d837..be12708 100644 --- a/drivers/net/npe/IxQMgrQCfg.c +++ b/drivers/net/npe/IxQMgrQCfg.c @@ -120,7 +120,7 @@ static UINT32 freeSramAddress=0; /* 4 words of zeroed memory for inline access */ static UINT32 zeroedPlaceHolder[4] = { 0, 0, 0, 0 };
-static BOOL cfgInitialized = FALSE; +static BOOL cfgInitialized = false;
static IxOsalMutex ixQMgrQCfgMutex;
@@ -177,10 +177,10 @@ ixQMgrQCfgInit (void) strcpy (cfgQueueInfo[loopIndex].qName, ""); cfgQueueInfo[loopIndex].qSizeInWords = 0; cfgQueueInfo[loopIndex].qEntrySizeInWords = 0; - cfgQueueInfo[loopIndex].isConfigured = FALSE; + cfgQueueInfo[loopIndex].isConfigured = false;
/* Statistics */ - stats.qStats[loopIndex].isConfigured = FALSE; + stats.qStats[loopIndex].isConfigured = false; stats.qStats[loopIndex].qName = cfgQueueInfo[loopIndex].qName; }
@@ -191,13 +191,13 @@ ixQMgrQCfgInit (void)
ixOsalMutexInit(&ixQMgrQCfgMutex);
- cfgInitialized = TRUE; + cfgInitialized = true; }
void ixQMgrQCfgUninit (void) { - cfgInitialized = FALSE; + cfgInitialized = false;
/* Uninitialise the AqmIf component */ ixQMgrAqmIfUninit (); @@ -281,13 +281,13 @@ ixQMgrQConfig (char *qName, IX_QMGR_QUE_BUFFER_SPACE_SIZE);
/* The queue is now configured */ - cfgQueueInfo[qId].isConfigured = TRUE; + cfgQueueInfo[qId].isConfigured = true;
ixOsalMutexUnlock(&ixQMgrQCfgMutex);
#ifndef NDEBUG /* Update statistics */ - stats.qStats[qId].isConfigured = TRUE; + stats.qStats[qId].isConfigured = true; stats.qStats[qId].qName = cfgQueueInfo[qId].qName; #endif return IX_SUCCESS; @@ -417,7 +417,7 @@ ixQMgrQIsConfigured (IxQMgrQId qId) { if (!IX_QMGR_QID_IS_VALID(qId)) { - return FALSE; + return false; }
return cfgQueueInfo[qId].isConfigured; @@ -487,7 +487,7 @@ watermarkLevelIsOk (IxQMgrQId qId, IxQMgrWMLevel level) case IX_QMGR_Q_WM_LEVEL64: break; default: - return FALSE; + return false; }
/* Check watermark is not bigger than the qSizeInEntries */ @@ -495,10 +495,10 @@ watermarkLevelIsOk (IxQMgrQId qId, IxQMgrWMLevel level)
if ((unsigned)level > qSizeInEntries) { - return FALSE; + return false; }
PRIVATE BOOL @@ -512,10 +512,10 @@ qSizeInWordsIsOk (IxQMgrQSizeInWords qSize) case IX_QMGR_Q_SIZE32: case IX_QMGR_Q_SIZE64: case IX_QMGR_Q_SIZE128: - status = TRUE; + status = true; break; default: - status = FALSE; + status = false; break; }
@@ -532,10 +532,10 @@ qEntrySizeInWordsIsOk (IxQMgrQEntrySizeInWords entrySize) case IX_QMGR_Q_ENTRY_SIZE1: case IX_QMGR_Q_ENTRY_SIZE2: case IX_QMGR_Q_ENTRY_SIZE4: - status = TRUE; + status = true; break; default: - status = FALSE; + status = false; break; }
diff --git a/drivers/net/npe/include/IxEthAcc_p.h b/drivers/net/npe/include/IxEthAcc_p.h index 4e0de82..eda3e30 100644 --- a/drivers/net/npe/include/IxEthAcc_p.h +++ b/drivers/net/npe/include/IxEthAcc_p.h @@ -92,7 +92,7 @@ #define IX_ETH_ACC_PUBLIC
-#define IX_ETH_ACC_IS_PORT_VALID(port) ((port) < IX_ETH_ACC_NUMBER_OF_PORTS ? TRUE : FALSE ) +#define IX_ETH_ACC_IS_PORT_VALID(port) ((port) < IX_ETH_ACC_NUMBER_OF_PORTS ? true : false )
@@ -286,7 +286,7 @@ extern IxEthAccPortDataInfo ixEthAccPortData[]; #define IX_ETH_IS_PORT_INITIALIZED(port) (ixEthAccPortData[port].portInitialized)
extern BOOL ixEthAccServiceInit; -#define IX_ETH_ACC_IS_SERVICE_INITIALIZED() (ixEthAccServiceInit == TRUE ) +#define IX_ETH_ACC_IS_SERVICE_INITIALIZED() (ixEthAccServiceInit == true )
/* * Maximum number of frames to consume from the Rx Frame Q. diff --git a/drivers/net/npe/include/IxEthDB_p.h b/drivers/net/npe/include/IxEthDB_p.h index ccec7ea..e86ba88 100644 --- a/drivers/net/npe/include/IxEthDB_p.h +++ b/drivers/net/npe/include/IxEthDB_p.h @@ -169,9 +169,9 @@ extern int overflowEvent; #define TREE_POOL_SIZE (4000) /**< number of MacTreeNode objects; each entry has 16 bytes */
/* retry policies */ -#define BUSY_RETRY_ENABLED (TRUE) /**< if set to TRUE the API will retry automatically calls returning BUSY */ -#define FOREVER_RETRY (TRUE) /**< if set to TRUE the API will retry forever BUSY calls */ -#define MAX_RETRIES (400) /**< upper retry limit - used only when FOREVER_RETRY is FALSE */ +#define BUSY_RETRY_ENABLED (true) /**< if set to true the API will retry automatically calls returning BUSY */ +#define FOREVER_RETRY (true) /**< if set to true the API will retry forever BUSY calls */ +#define MAX_RETRIES (400) /**< upper retry limit - used only when FOREVER_RETRY is false */ #define BUSY_RETRY_YIELD (5) /**< ticks to yield for every failed retry */
/* event management */ @@ -179,8 +179,8 @@ extern int overflowEvent; #define EVENT_PROCESSING_LIMIT (100) /**< batch processing control size (how many events are extracted from the queue at once) */
/* MAC descriptors */ -#define STATIC_ENTRY (TRUE) -#define DYNAMIC_ENTRY (FALSE) +#define STATIC_ENTRY (true) +#define DYNAMIC_ENTRY (false)
/* age reset on next maintenance - incrementing by 1 will reset to 0 */ #define AGE_RESET (0xFFFFFFFF) @@ -270,7 +270,7 @@ extern int overflowEvent; /* gives an empty dependency map */ #define SET_EMPTY_DEPENDENCY_MAP(map) { int i = 0; for (; i < 32 ; i++) map[i] = 0; }
-#define IS_EMPTY_DEPENDENCY_MAP(result, map) { int i = 0 ; result = TRUE; for (; i < 32 ; i++) if (map[i] != 0) { result = FALSE; break; }} +#define IS_EMPTY_DEPENDENCY_MAP(result, map) { int i = 0 ; result = true; for (; i < 32 ; i++) if (map[i] != 0) { result = false; break; }}
/** * gives a map consisting only of 'portID' @@ -293,12 +293,12 @@ extern int overflowEvent; #define EXCLUDE_PORT_FROM_MAP(map, portID) { map[portID >> 3] &= ~(1 << (portID & 0x7); }
/** - * returns TRUE if map1 is a subset of map2 and FALSE otherwise + * returns true if map1 is a subset of map2 and false otherwise */ -#define IS_MAP_SUBSET(result, map1, map2) { int i = 0; result = TRUE; for (; i < 32 ; i++) if ((map1[i] | map2[i]) != map2[i]) result = FALSE; } +#define IS_MAP_SUBSET(result, map1, map2) { int i = 0; result = true; for (; i < 32 ; i++) if ((map1[i] | map2[i]) != map2[i]) result = false; }
/** - * returns TRUE is portID is part of map and FALSE otherwise + * returns true is portID is part of map and false otherwise */ #define IS_PORT_INCLUDED(portID, map) ((map[portID >> 3] & (1 << (portID & 0x7))) != 0)
@@ -308,9 +308,9 @@ extern int overflowEvent; #define DIFF_MAPS(map, map1, map2) { int i = 0; for (; i < 32 ; i++) map[i] = map1[i] ^ (map1[i] & map2[i]); }
/** - * returns TRUE if the maps collide (have at least one port in common) and FALSE otherwise + * returns true if the maps collide (have at least one port in common) and false otherwise */ -#define MAPS_COLLIDE(result, map1, map2) { int i = 0; result = FALSE; for (; i < 32 ; i++) if ((map1[i] & map2[i]) != 0) result = TRUE; } +#define MAPS_COLLIDE(result, map1, map2) { int i = 0; result = false; for (; i < 32 ; i++) if ((map1[i] & map2[i]) != 0) result = true; }
/* size (number of ports) of a dependency map */ #define GET_MAP_SIZE(map, size) { int i = 0, b = 0; size = 0; for (; i < 32 ; i++) { char y = map[i]; for (; b < 8 && (y >>= 1); b++) size += (y & 1); }} diff --git a/drivers/net/npe/include/IxOsalTypes.h b/drivers/net/npe/include/IxOsalTypes.h index a190a70..06e71de 100644 --- a/drivers/net/npe/include/IxOsalTypes.h +++ b/drivers/net/npe/include/IxOsalTypes.h @@ -107,22 +107,6 @@ typedef volatile INT32 VINT32; */ #define IX_OSAL_BILLION (1000000000)
-#ifndef TRUE -#define TRUE 1L -#endif - -#if TRUE != 1 -#error TRUE is not defined to 1 -#endif - -#ifndef FALSE -#define FALSE 0L -#endif - -#if FALSE != 0 -#error FALSE is not defined to 0 -#endif - #ifndef NULL #define NULL 0L #endif diff --git a/drivers/net/npe/include/IxQMgrAqmIf_p.h b/drivers/net/npe/include/IxQMgrAqmIf_p.h index 4f0f64d..b63c4a9 100644 --- a/drivers/net/npe/include/IxQMgrAqmIf_p.h +++ b/drivers/net/npe/include/IxQMgrAqmIf_p.h @@ -606,10 +606,10 @@ ixQMgrAqmIfQStatusCheck (UINT32 *oldQStatusWords, (newQStatusWords[statusWordOffset] & mask)) && ((newQStatusWords[statusWordOffset] & mask) == checkValue)) { - return TRUE; + return true; }
/* @@ -665,7 +665,7 @@ ixQMgrAqmIfQInterruptEnableRegRead (IxQMgrDispatchGroup group,
/* * This inline function will read the status bit of a queue - * specified by qId. If reset is TRUE the bit is cleared. + * specified by qId. If reset is true the bit is cleared. */ IX_QMGR_AQMIF_INLINE BOOL ixQMgrAqmIfRegisterBitCheck (IxQMgrQId qId, @@ -707,11 +707,11 @@ ixQMgrAqmIfRegisterBitCheck (IxQMgrQId qId, { ixQMgrAqmIfWordWrite (registerAddress, registerWord & (~actualBitOffset)); } - return TRUE; + return true; }
/* Bit not set */ - return FALSE; + return false; }
@@ -733,12 +733,12 @@ ixQMgrAqmIfUnderflowCheck (IxQMgrQId qId) IX_QMGR_QUEUOSTAT0_OFFSET, IX_QMGR_QUEUOSTAT_NUM_QUE_PER_WORD, IX_QMGR_UNDERFLOW_BIT_OFFSET, - TRUE/*reset*/)); + true/*reset*/)); } else { /* Qs 32-63 have no underflow status */ - return FALSE; + return false; } }
@@ -755,12 +755,12 @@ ixQMgrAqmIfOverflowCheck (IxQMgrQId qId) IX_QMGR_QUEUOSTAT0_OFFSET, IX_QMGR_QUEUOSTAT_NUM_QUE_PER_WORD, IX_QMGR_OVERFLOW_BIT_OFFSET, - TRUE/*reset*/)); + true/*reset*/)); } else { /* Qs 32-63 have no overflow status */ - return FALSE; + return false; } }
@@ -870,7 +870,7 @@ ixQMgrAqmIfQueUppStatRead (IxQMgrQId qId, IX_QMGR_QUEUPPSTAT0_OFFSET, IX_QMGR_QUEUPPSTAT_NUM_QUE_PER_WORD, 0/*relativeBitOffset*/, - FALSE/*!reset*/)) + false/*!reset*/)) { *status |= IX_QMGR_Q_STATUS_NE_BIT_MASK; } @@ -884,7 +884,7 @@ ixQMgrAqmIfQueUppStatRead (IxQMgrQId qId, IX_QMGR_QUEUPPSTAT1_OFFSET, IX_QMGR_QUEUPPSTAT_NUM_QUE_PER_WORD, 0/*relativeBitOffset*/, - FALSE/*!reset*/)) + false/*!reset*/)) { *status |= IX_QMGR_Q_STATUS_F_BIT_MASK; } diff --git a/drivers/net/npe/npe.c b/drivers/net/npe/npe.c index 1fe3a95..6fc9f86 100644 --- a/drivers/net/npe/npe.c +++ b/drivers/net/npe/npe.c @@ -322,7 +322,7 @@ static int npe_csr_load(void) }
/* don't need this for U-Boot */ - ixFeatureCtrlSwConfigurationWrite(IX_FEATURECTRL_ETH_LEARNING, FALSE); + ixFeatureCtrlSwConfigurationWrite(IX_FEATURECTRL_ETH_LEARNING, false);
if (ixEthAccInit() != IX_ETH_ACC_SUCCESS) { printf("Error initialising Ethernet access driver!\n"); @@ -647,29 +647,29 @@ int npe_initialize(bd_t * bis) */ if (ixFeatureCtrlComponentCheck(IX_FEATURECTRL_ETH0) == IX_FEATURE_CTRL_COMPONENT_ENABLED) - npe_exists[IX_ETH_PORT_1] = TRUE; + npe_exists[IX_ETH_PORT_1] = true;
if (ixFeatureCtrlComponentCheck(IX_FEATURECTRL_ETH1) == IX_FEATURE_CTRL_COMPONENT_ENABLED) - npe_exists[IX_ETH_PORT_2] = TRUE; + npe_exists[IX_ETH_PORT_2] = true; break; case IX_FEATURE_CTRL_SILICON_TYPE_A0: /* * If it is A0 Silicon, we enable both as both Eth Coprocessors * are available. */ - npe_exists[IX_ETH_PORT_1] = TRUE; - npe_exists[IX_ETH_PORT_2] = TRUE; + npe_exists[IX_ETH_PORT_1] = true; + npe_exists[IX_ETH_PORT_2] = true; break; } } else if (ixFeatureCtrlDeviceRead() == IX_FEATURE_CTRL_DEVICE_TYPE_IXP46X) { if (ixFeatureCtrlComponentCheck(IX_FEATURECTRL_ETH0) == IX_FEATURE_CTRL_COMPONENT_ENABLED) - npe_exists[IX_ETH_PORT_1] = TRUE; + npe_exists[IX_ETH_PORT_1] = true;
if (ixFeatureCtrlComponentCheck(IX_FEATURECTRL_ETH1) == IX_FEATURE_CTRL_COMPONENT_ENABLED) - npe_exists[IX_ETH_PORT_2] = TRUE; + npe_exists[IX_ETH_PORT_2] = true; }
npe_used[IX_ETH_PORT_1] = 1; diff --git a/drivers/rtc/ds1374.c b/drivers/rtc/ds1374.c index d61a228..ec04ec8 100644 --- a/drivers/rtc/ds1374.c +++ b/drivers/rtc/ds1374.c @@ -84,15 +84,6 @@ #define RTC_SR_BIT_AF 0x01 /* Bit 0 = Alarm Flag */ #define RTC_SR_BIT_OSF 0x80 /* Bit 7 - Osc Stop Flag */
-typedef unsigned char boolean_t; - -#ifndef TRUE -#define TRUE ((boolean_t)(0==0)) -#endif -#ifndef FALSE -#define FALSE (!TRUE) -#endif - const char RtcTodAddr[] = { RTC_TOD_CNT_BYTE0_ADDR, RTC_TOD_CNT_BYTE1_ADDR, @@ -101,7 +92,7 @@ const char RtcTodAddr[] = { };
static uchar rtc_read (uchar reg); -static void rtc_write (uchar reg, uchar val, boolean_t set); +static void rtc_write(uchar reg, uchar val, bool set); static void rtc_write_raw (uchar reg, uchar val);
/* @@ -185,7 +176,7 @@ int rtc_set (struct rtc_time *tmp){ }
/* Start clock */ - rtc_write(RTC_CTL_ADDR, RTC_CTL_BIT_EN_OSC, FALSE); + rtc_write(RTC_CTL_ADDR, RTC_CTL_BIT_EN_OSC, false);
return 0; } @@ -202,18 +193,18 @@ void rtc_reset (void){ struct rtc_time tmp;
/* clear status flags */ - rtc_write (RTC_SR_ADDR, (RTC_SR_BIT_AF|RTC_SR_BIT_OSF), FALSE); /* clearing OSF and AF */ + rtc_write(RTC_SR_ADDR, (RTC_SR_BIT_AF|RTC_SR_BIT_OSF), false); /* clearing OSF and AF */
/* Initialise DS1374 oriented to MPC8349E-ADS */ rtc_write (RTC_CTL_ADDR, (RTC_CTL_BIT_EN_OSC |RTC_CTL_BIT_WACE - |RTC_CTL_BIT_AIE), FALSE);/* start osc, disable WACE, clear AIE + |RTC_CTL_BIT_AIE), false);/* start osc, disable WACE, clear AIE - set to 0 */ rtc_write (RTC_CTL_ADDR, (RTC_CTL_BIT_WD_ALM |RTC_CTL_BIT_WDSTR |RTC_CTL_BIT_RS1 |RTC_CTL_BIT_RS2 - |RTC_CTL_BIT_BBSQW), TRUE);/* disable WD/ALM, WDSTR set to INT-pin, + |RTC_CTL_BIT_BBSQW), true);/* disable WD/ALM, WDSTR set to INT-pin, set BBSQW and SQW to 32k - set to 1 */ tmp.tm_year = 1970; @@ -229,9 +220,9 @@ void rtc_reset (void){ tmp.tm_year, tmp.tm_mon, tmp.tm_mday, tmp.tm_hour, tmp.tm_min, tmp.tm_sec);
- rtc_write(RTC_WD_ALM_CNT_BYTE2_ADDR,0xAC, TRUE); - rtc_write(RTC_WD_ALM_CNT_BYTE1_ADDR,0xDE, TRUE); - rtc_write(RTC_WD_ALM_CNT_BYTE2_ADDR,0xAD, TRUE); + rtc_write(RTC_WD_ALM_CNT_BYTE2_ADDR, 0xAC, true); + rtc_write(RTC_WD_ALM_CNT_BYTE1_ADDR, 0xDE, true); + rtc_write(RTC_WD_ALM_CNT_BYTE2_ADDR, 0xAD, true); }
/* @@ -242,9 +233,9 @@ static uchar rtc_read (uchar reg) return (i2c_reg_read (CONFIG_SYS_I2C_RTC_ADDR, reg)); }
-static void rtc_write (uchar reg, uchar val, boolean_t set) +static void rtc_write(uchar reg, uchar val, bool set) { - if (set == TRUE) { + if (set == true) { val |= i2c_reg_read (CONFIG_SYS_I2C_RTC_ADDR, reg); i2c_reg_write (CONFIG_SYS_I2C_RTC_ADDR, reg, val); } else { diff --git a/drivers/usb/musb-new/linux-compat.h b/drivers/usb/musb-new/linux-compat.h index 5c126ef..72c8c2b 100644 --- a/drivers/usb/musb-new/linux-compat.h +++ b/drivers/usb/musb-new/linux-compat.h @@ -12,8 +12,6 @@ #define __iomem #define __deprecated
-typedef enum { false = 0, true = 1 } bool; - struct unused {}; typedef struct unused unused_t;
diff --git a/fs/ext4/ext4_common.h b/fs/ext4/ext4_common.h index 87cab16..72cd020 100644 --- a/fs/ext4/ext4_common.h +++ b/fs/ext4/ext4_common.h @@ -44,8 +44,6 @@
#define YES 1 #define NO 0 -#define TRUE 1 -#define FALSE 0 #define RECOVER 1 #define SCAN 0
diff --git a/fs/ext4/ext4_journal.c b/fs/ext4/ext4_journal.c index 9f01708..ba4a7bb 100644 --- a/fs/ext4/ext4_journal.c +++ b/fs/ext4/ext4_journal.c @@ -37,7 +37,7 @@
static struct revoke_blk_list *revk_blk_list; static struct revoke_blk_list *prev_node; -static int first_node = TRUE; +static int first_node = true;
int gindex; int gd_index; @@ -268,10 +268,10 @@ void ext4fs_push_revoke_blk(char *buffer) return; memcpy(node->content, buffer, fs->blksz);
- if (first_node == TRUE) { + if (first_node == true) { revk_blk_list = node; prev_node = node; - first_node = FALSE; + first_node = false; } else { prev_node->next = node; prev_node = node; @@ -298,7 +298,7 @@ void ext4fs_free_revoke_blks(void)
revk_blk_list = NULL; prev_node = NULL; - first_node = TRUE; + first_node = true; }
int check_blknr_for_revoke(long int blknr, int sequence_no) diff --git a/include/at91rm9200_net.h b/include/at91rm9200_net.h index f799206..804105f 100644 --- a/include/at91rm9200_net.h +++ b/include/at91rm9200_net.h @@ -23,10 +23,6 @@ #include <asm/io.h> #include <asm/arch/hardware.h>
-#define FALSE 0 -#define TRUE 1 - - #define ETHERNET_ADDRESS_SIZE 6
typedef unsigned char UCHAR; diff --git a/include/bedbug/ppc.h b/include/bedbug/ppc.h index 46bf8db..76d86fd 100644 --- a/include/bedbug/ppc.h +++ b/include/bedbug/ppc.h @@ -296,11 +296,6 @@ struct operand { ((rc) & 0x1)) #define MDS_MASK MDS_OPCODE(0x3f,0xf,0x1)
-#ifndef FALSE -#define FALSE 0 -#define TRUE (!FALSE) -#endif - #define INSTRUCTION( memaddr ) ntohl(*(unsigned long *)(memaddr))
#define MAX_OPERANDS 8 diff --git a/include/fpga.h b/include/fpga.h index e0b1fe7..30a4e6a 100644 --- a/include/fpga.h +++ b/include/fpga.h @@ -31,14 +31,6 @@ #define CONFIG_MAX_FPGA_DEVICES 5 #endif
-/* these probably belong somewhere else */ -#ifndef FALSE -#define FALSE (0) -#endif -#ifndef TRUE -#define TRUE (!FALSE) -#endif - /* CONFIG_FPGA bit assignments */ #define CONFIG_SYS_FPGA_MAN(x) (x) #define CONFIG_SYS_FPGA_DEV(x) ((x) << 8 ) diff --git a/include/galileo/core.h b/include/galileo/core.h index c277509..faf4962 100644 --- a/include/galileo/core.h +++ b/include/galileo/core.h @@ -110,11 +110,6 @@ extern unsigned int INTERNAL_REG_BASE_ADDR; #define _1G 0x40000000 #define _2G 0x80000000
-#ifndef BOOL_WAS_DEFINED -#define BOOL_WAS_DEFINED -typedef enum _bool{false,true} bool; -#endif - /* Little to Big endian conversion macros */
#ifdef LE /* Little Endian */ diff --git a/include/linux/types.h b/include/linux/types.h index 1b0b4a4..f07ba41 100644 --- a/include/linux/types.h +++ b/include/linux/types.h @@ -7,6 +7,7 @@
#include <linux/posix_types.h> #include <asm/types.h> +#include <stdbool.h>
#ifndef __KERNEL_STRICT_NAMES
diff --git a/include/scsi.h b/include/scsi.h index 9da764b..c764e15 100644 --- a/include/scsi.h +++ b/include/scsi.h @@ -204,12 +204,4 @@ int scsi_get_disk_count(void);
#define SCSI_INT_STATE 0x00010000 /* unknown Interrupt number is stored in 16 LSB */
- -#ifndef TRUE -#define TRUE 1 -#endif -#ifndef FALSE -#define FALSE 0 -#endif - #endif /* _SCSI_H */ diff --git a/include/sym53c8xx.h b/include/sym53c8xx.h index 7d3ded5..9696db0 100644 --- a/include/sym53c8xx.h +++ b/include/sym53c8xx.h @@ -568,11 +568,4 @@
#define SCSI_IDENTIFY 0xC0
-#ifndef TRUE -#define TRUE 1 -#endif -#ifndef FALSE -#define FALSE 0 -#endif - #endif diff --git a/include/xyzModem.h b/include/xyzModem.h index f437bbd..a3ea768 100644 --- a/include/xyzModem.h +++ b/include/xyzModem.h @@ -97,14 +97,6 @@ typedef struct { #endif } connection_info_t;
-#ifndef BOOL_WAS_DEFINED -#define BOOL_WAS_DEFINED -typedef unsigned int bool; -#endif - -#define false 0 -#define true 1 - #endif
On Thu, Jan 24, 2013 at 03:12:17PM -0800, York Sun wrote:
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99.
All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0.
Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files.
Signed-off-by: York Sun yorksun@freescale.com
Change since v1: Move 'false' and 'true' to the common header file.
Change since v2: Use stdbool.h Consolidate all TRUE, FALSE, True, False, true, false
Change since v3: Fix boolean_t which was missed in v2.
Change since v4: Replace FALSE, False with false. Replace TRUE, True with true.
Change since v5: Revert changes for *.py, *.php, lib/* files. Revert change to type conversions. Revert comment-only changes. (Not sure about if we should replace the comments). Fix many coding style issues but left drivers/net/npe alone (way too many issues).
This patch doesn't address the white space issue where TRUE/FALSE is repalced.
Need help to test on all ARCHs with differnt toolchains as well as USE_PRIVATE_LIBGCC.
I think you can drop the RFC from your patch at this point.
Built on all tegra20 and tegra30 devices with USE_PRIVATE_LIBGCC. Tested on seaboard (tegra20).
I've also submitted your patch to my build regression script which will build all 1100+ boards against your patch and tell if there are any build regressions. I'll let you know the results tomorrow.
-Allen
Allen,
Is any change needed?
York
Allen,
Hi York, sorry I forgot to get back to you. I ran your patch through all boards and so no warning or error build regressions. Looking at the logs it looks like I ran it on version 5 not version 6 of your patch though. I'll do another run tonight on version 6 and let you know the results. I don't anticipate any problems though as it looks like the only differences are dropping the python files and whitespace changes.
-Allen
Allen,
Allen,
Your help is greatly appreciated.
York
Allen,
Allen,
York
Compiled against all boards, no warning or error regressions detected. Tested on tegra20 trimslice and tegra30 cardhu.
Acked-by: Allen Martin amartin@nvidia.com
Allen,
Allen,
York
Thanks a lot, Allen. I will send v7 with RFC removed from subject and add your ack.
York
Allen,
Allen,
York
York
Thank you for taking on such a monster of a patch!
Also, either my blackfin toolchain is broken, or every blackfin board doesn't compile (even without this patch). You may want to have someone who has a known working blackfin build check the patch too.
-Allen
Allen Martin
York Sun
