[U-Boot] [PATCH v3 0/2] net: macb: Add remove callback and align the compatibles
Add the remove callback to avoid the failure of mdio_register(), and add the compatibles to align with the kernel.
Changes in v3: - Incorporate [PATCH] net: macb: align the compatibles with kernel. - Rebase on the latest commit (db40c1aa1c10) of master branch of u-boot-net. - Add Acked-by tag.
Changes in v2: - Rebase on v2017.03.
Wenyou Yang (2): net: macb: Add remove callback net: macb: Align the compatibles with kernel
drivers/net/macb.c | 49 +++++++++++++++++++++++++++++++++---------------- 1 file changed, 33 insertions(+), 16 deletions(-)
To avoid the failure of mdio_register(), add the remove callback to unregister the mii_dev when removing the ethernet device.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com Acked-by: Joe Hershberger joe.hershberger@ni.com ---
Changes in v3: None Changes in v2: - Rebase on v2017.03.
drivers/net/macb.c | 45 +++++++++++++++++++++++++++++---------------- 1 file changed, 29 insertions(+), 16 deletions(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 402e866817..a4c6bd0ee6 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -111,6 +111,9 @@ struct macb_device { #endif unsigned short phy_addr; struct mii_dev *bus; +#ifdef CONFIG_PHYLIB + struct phy_device *phydev; +#endif
#ifdef CONFIG_DM_ETH #ifdef CONFIG_CLK @@ -479,9 +482,6 @@ static int macb_phy_init(struct macb_device *macb, const char *name) #ifdef CONFIG_DM_ETH struct macb_device *macb = dev_get_priv(dev); #endif -#ifdef CONFIG_PHYLIB - struct phy_device *phydev; -#endif u32 ncfgr; u16 phy_id, status, adv, lpa; int media, speed, duplex; @@ -503,19 +503,19 @@ static int macb_phy_init(struct macb_device *macb, const char *name)
#ifdef CONFIG_PHYLIB #ifdef CONFIG_DM_ETH - phydev = phy_connect(macb->bus, macb->phy_addr, dev, + macb->phydev = phy_connect(macb->bus, macb->phy_addr, dev, macb->phy_interface); #else /* need to consider other phy interface mode */ - phydev = phy_connect(macb->bus, macb->phy_addr, &macb->netdev, + macb->phydev = phy_connect(macb->bus, macb->phy_addr, &macb->netdev, PHY_INTERFACE_MODE_RGMII); #endif - if (!phydev) { + if (!macb->phydev) { printf("phy_connect failed\n"); return -ENODEV; }
- phy_config(phydev); + phy_config(macb->phydev); #endif
status = macb_mdio_read(macb, MII_BMSR); @@ -1056,23 +1056,35 @@ static int macb_eth_probe(struct udevice *dev) _macb_eth_initialize(macb);
#if defined(CONFIG_CMD_MII) || defined(CONFIG_PHYLIB) - int retval; - struct mii_dev *mdiodev = mdio_alloc(); - if (!mdiodev) + macb->bus = mdio_alloc(); + if (!macb->bus) return -ENOMEM; - strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); - mdiodev->read = macb_miiphy_read; - mdiodev->write = macb_miiphy_write; + strncpy(macb->bus->name, dev->name, MDIO_NAME_LEN); + macb->bus->read = macb_miiphy_read; + macb->bus->write = macb_miiphy_write;
- retval = mdio_register(mdiodev); - if (retval < 0) - return retval; + ret = mdio_register(macb->bus); + if (ret < 0) + return ret; macb->bus = miiphy_get_dev_by_name(dev->name); #endif
return 0; }
+static int macb_eth_remove(struct udevice *dev) +{ + struct macb_device *macb = dev_get_priv(dev); + +#ifdef CONFIG_PHYLIB + free(macb->phydev); +#endif + mdio_unregister(macb->bus); + mdio_free(macb->bus); + + return 0; +} + static int macb_eth_ofdata_to_platdata(struct udevice *dev) { struct eth_pdata *pdata = dev_get_platdata(dev); @@ -1092,6 +1104,7 @@ U_BOOT_DRIVER(eth_macb) = { .of_match = macb_eth_ids, .ofdata_to_platdata = macb_eth_ofdata_to_platdata, .probe = macb_eth_probe, + .remove = macb_eth_remove, .ops = &macb_eth_ops, .priv_auto_alloc_size = sizeof(struct macb_device), .platdata_auto_alloc_size = sizeof(struct eth_pdata),
Applied to u-boot-dm/next, thanks!
Add the compatibles to align with the kernel.
Changes in v2: None
drivers/net/macb.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index a4c6bd0ee6..7d045c90c5 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -1095,6 +1095,10 @@ static int macb_eth_ofdata_to_platdata(struct udevice *dev)
static const struct udevice_id macb_eth_ids[] = { { .compatible = "cdns,macb" }, + { .compatible = "cdns,at91sam9260-macb" }, + { .compatible = "atmel,sama5d2-gem" }, + { .compatible = "atmel,sama5d3-gem" }, + { .compatible = "atmel,sama5d4-gem" }, { } };
Changes in v2: None
sjg@google.com
Wenyou Yang
