[U-Boot] [PATCH] cmd: pxe: Display splashscreen from extlinux.conf input
The objective is to provide a simple way to retrieve a BMP file, and display it as splashscreen, from extlinux.conf file input.
For this, we take example on https://www.syslinux.org/wiki/ index.php?title=Menu#The_advanced_menu_system and more particularly on MENU BACKGROUND chapter. For this, add "menu background" support in pxe command.
As example, extlinux.conf content will look like:
# Generic Distro Configuration file generated by OpenEmbedded menu title Select the boot mode TIMEOUT 20 menu background ../splash.bmp DEFAULT stm32mp157c-ev1-sdcard LABEL stm32mp157c-ev1-sdcard KERNEL /uImage FDT /stm32mp157c-ev1.dtb APPEND root=/dev/mmcblk0p6 rootwait rw earlyprintk console=ttySTM0,115200
Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
cmd/pxe.c | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+)
diff --git a/cmd/pxe.c b/cmd/pxe.c index 274555319ba8..e77770237cb1 100644 --- a/cmd/pxe.c +++ b/cmd/pxe.c @@ -8,11 +8,13 @@ #include <command.h> #include <malloc.h> #include <mapmem.h> +#include <lcd.h> #include <linux/string.h> #include <linux/ctype.h> #include <errno.h> #include <linux/list.h> #include <fs.h> +#include <splash.h> #include <asm/io.h>
#include "menu.h" @@ -488,6 +490,7 @@ struct pxe_label { * * title - the name of the menu as given by a 'menu title' line. * default_label - the name of the default label, if any. + * bmp - the bmp file name which is displayed in background * timeout - time in tenths of a second to wait for a user key-press before * booting the default label. * prompt - if 0, don't prompt for a choice unless the timeout period is @@ -498,6 +501,7 @@ struct pxe_label { struct pxe_menu { char *title; char *default_label; + char *bmp; int timeout; int prompt; struct list_head labels; @@ -850,6 +854,7 @@ enum token_type { T_FDTDIR, T_ONTIMEOUT, T_IPAPPEND, + T_BACKGROUND, T_INVALID };
@@ -883,6 +888,7 @@ static const struct token keywords[] = { {"fdtdir", T_FDTDIR}, {"ontimeout", T_ONTIMEOUT,}, {"ipappend", T_IPAPPEND,}, + {"background", T_BACKGROUND,}, {NULL, T_INVALID} };
@@ -1160,6 +1166,10 @@ static int parse_menu(cmd_tbl_t *cmdtp, char **c, struct pxe_menu *cfg, nest_level + 1); break;
+ case T_BACKGROUND: + err = parse_sliteral(c, &cfg->bmp); + break; + default: printf("Ignoring malformed menu command: %.*s\n", (int)(*c - s), s); @@ -1574,6 +1584,20 @@ static void handle_pxe_menu(cmd_tbl_t *cmdtp, struct pxe_menu *cfg) struct menu *m; int err;
+#ifdef CONFIG_CMD_BMP + /* display BMP if available */ + if (cfg->bmp) { + if (get_relfile(cmdtp, cfg->bmp, load_addr)) { + run_command("cls", 0); + bmp_display(load_addr, + BMP_ALIGN_CENTER, BMP_ALIGN_CENTER); + } else { + printf("Skipping background bmp %s for failure\n", + cfg->bmp); + } + } +#endif + m = pxe_menu_to_menu(cfg); if (!m) return;
Patrice Chotard
