[U-Boot] [PATCH] ARM: zynq: Disable net for cse nor/nand
There is no need to waste 6k if none needs it.
zynq_cse_nand : all -6486 bss -20 data -136 rodata -606 text -5724 zynq_cse_nor : all -6486 bss -20 data -136 rodata -606 text -5724
configs/zynq_cse_nand_defconfig | 2 +- configs/zynq_cse_nor_defconfig | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/configs/zynq_cse_nand_defconfig b/configs/zynq_cse_nand_defconfig index 9bb02add2d07..608619e40c3e 100644 --- a/configs/zynq_cse_nand_defconfig +++ b/configs/zynq_cse_nand_defconfig @@ -40,11 +40,11 @@ CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NET is not set # CONFIG_CMD_MISC is not set # CONFIG_PARTITIONS is not set CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-nand" +# CONFIG_NET is not set # CONFIG_DM_WARN is not set # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/zynq_cse_nor_defconfig b/configs/zynq_cse_nor_defconfig index 44329971b67e..b4f1e313b1dd 100644 --- a/configs/zynq_cse_nor_defconfig +++ b/configs/zynq_cse_nor_defconfig @@ -39,11 +39,11 @@ CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NET is not set # CONFIG_CMD_MISC is not set # CONFIG_PARTITIONS is not set CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-nor" +# CONFIG_NET is not set # CONFIG_DM_WARN is not set # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_SPL_DM_SEQ_ALIAS=y
Michal Simek
