[U-Boot] [PATCH] itest: fix result of string compares
The implementation of the string compare function of the "itest" command was weird, as only the length of the shortest argument was included in the compare, with the result that something like "itest.s abd == abddef" would return TRUE. Fix this.
Signed-off-by: Wolfgang Denk wd@denx.de --- common/cmd_itest.c | 7 ++----- 1 files changed, 2 insertions(+), 5 deletions(-)
diff --git a/common/cmd_itest.c b/common/cmd_itest.c index fa6a0c3..2a238a4 100644 --- a/common/cmd_itest.c +++ b/common/cmd_itest.c @@ -94,16 +94,13 @@ static char * evalstr(char *s)
static int stringcomp(char *s, char *t, int op) { - int n, p; + int p; char *l, *r;
l = evalstr(s); r = evalstr(t);
- /* we'll do a compare based on the length of the shortest string */ - n = min(strlen(l), strlen(r)); - - p = strncmp(l, r, n); + p = strcmp(l, r); switch (op) { case EQ: return (p == 0); case NE: return (p != 0);
Hi Wolfgang,
Acked-by: Detlev Zundel dzu@denx.de
Cheers Detlev
Dear Wolfgang Denk,
Applied.
Detlev Zundel
