[U-Boot] [PATCH] mmc: Poll for broken card detection case
Poll for broken card detection case instead of return no card detected.
Signed-off-by: Jun Nie jun.nie@linaro.org --- drivers/mmc/Kconfig | 5 +++++ drivers/mmc/mmc.c | 4 ++++ 2 files changed, 9 insertions(+)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 8fbeaa7..ed194a3 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -10,6 +10,11 @@ config MMC If you want MMC/SD/SDIO support, you should say Y here and also to your specific host controller driver.
+config MMC_BROKEN_CD + bool "Poll for broken card detection case" + help + If card detection feature is broken, just poll to detect. + config DM_MMC bool "Enable MMC controllers using Driver Model" depends on DM diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 38d2e07..13c5bf5 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -1650,8 +1650,12 @@ int mmc_start_init(struct mmc *mmc) bool no_card; int err;
+#if !defined(CONFIG_MMC_BROKEN_CD) /* we pretend there's no card when init is NULL */ no_card = mmc_getcd(mmc) == 0; +#else + no_card = 0; +#endif #if !CONFIG_IS_ENABLED(DM_MMC) no_card = no_card || (mmc->cfg->ops->init == NULL); #endif
Sorry for late. i didn't see this patch in my mailbox.
Does it need to add the new config?
Best Regards, Jaehoon Chung
- bool "Poll for broken card detection case"
- help
- no_card = 0;
2018-01-22 13:03 GMT+08:00 Jaehoon Chung jh80.chung@samsung.com:
Yes, a new config, CONFIG_MMC_BROKEN_CD is needed for board that does not support card detection pin. Not sure whether you mean this. Without this config, the logic is not changed so no board is impacted by this config.
Jun
help
no_card = 0;
Right, there is no impacted by this config. In Kernel, there is "broken-cd" property. So how about using 'broken-cd' property instead of adding config?
Jun
help
no_card = 0;
2018-01-23 10:00 GMT+08:00 Jaehoon Chung jh80.chung@samsung.com:
Some platforms, if not all, do not support DTB in SPL. So a config is better than dt node property.
Jun
Jun
help
no_card = 0;
Ok. It make sense...Will apply this patch to u-boot-mmc. Thanks!
Jun
Jun
help
no_card = 0;
Applied to u-boot-mmc.
Jun
Jun
help
no_card = 0;
Jaehoon Chung
Jun Nie
