'bmp display' convert 24bit bmp to 16bit lcd format
Hi:
I had tested 'bmp display' command with 24bits bmp picture, **video_bmp_display** function always convert 24bits picture to RGB555 format if the lcd is 16bits. But most of all lcd controller is RGB565 format. Should we improve this?
Thanks
Hi Qianfan,
+Anatolij Gustschin
On Mon, 20 Dec 2021 at 18:22, qianfan qianfanguijin@qq.com wrote:
Hi:
See also:
https://patchwork.ozlabs.org/project/uboot/patch/20211119202408.1815506-16-s...
在 2021/12/28 16:52, Simon Glass 写道:
Hi Qianfan,
+Anatolij Gustschin
Hi:
See also:
Hi, I read this patch and it is resolved this question. But I don't know if it is a good idea that just replace RGB555 to RGB565.
Maybe somedays after this patch merged, someone will complain about video_bmp_display doesn't support RGB555 mode.
Hi Qianfan,
Hi Qianfan,
+Anatolij Gustschin
Hi:
See also:
Maybe, at which point it should really become an option. But you did say that 565 is more common. The existing BPP enum is not really descriptive enough.
qianfan
