[U-Boot] [PATCH 4/4] Exynos5420: DMC: Add software read leveling
Sometimes Read DQ and DQS are not in phase. Since, this phase shift differs from board to board, we need to calibrate it at DRAM init phase, that's read DQ calibration. This patch adds SW Read DQ calibration routine to compensate this skew.
Signed-off-by: Alim Akhtar alim.akhtar@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com --- arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c | 244 +++++++++++++++++++++++++++++- arch/arm/cpu/armv7/exynos/exynos5_setup.h | 5 +- arch/arm/include/asm/arch-exynos/dmc.h | 3 + arch/arm/include/asm/arch-exynos/power.h | 4 +- 4 files changed, 252 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c b/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c index 0654c6a..a4f6099 100644 --- a/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c +++ b/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c @@ -6,6 +6,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#include <common.h> #include <config.h> #include <asm/io.h> #include <asm/arch/clock.h> @@ -16,7 +17,12 @@ #include "exynos5_setup.h" #include "clock_init.h"
-#define TIMEOUT 10000 +#define TIMEOUT 10000 +#define NUM_BYTE_LANES 4 +#define DEFAULT_DQS 8 +#define DEFAULT_DQS_X4 0x08080808 +#define FALSE 0 +#define TRUE 1
#ifdef CONFIG_EXYNOS5250 static void reset_phy_ctrl(void) @@ -222,6 +228,219 @@ int ddr3_mem_ctrl_init(int reset) #endif
#ifdef CONFIG_EXYNOS5420 +/* + * RAM address to use in the test. + * + * We'll use 4 words at this address and 4 at this address + 0x80 (Ares + * interleaves channels every 128 bytes). This will allow us to evaluate all of + * the chips in a 1 chip per channel (2GB) system and half the chips in a 2 + * chip per channel (4GB) system. We can't test the 2nd chip since we need to + * do tests before the 2nd chip is enabled. Looking at the 2nd chip isn't + * critical because the 1st and 2nd chip have very similar timings (they'd + * better have similar timings, since there's only a single adjustment that is + * shared by both chips). + */ +const unsigned int test_addr = 0x20000000; + +/* Test pattern with which RAM will be tested */ +static const unsigned int test_pattern[] = { + 0x5A5A5A5A, + 0xA5A5A5A5, + 0xF0F0F0F0, + 0x0F0F0F0F, +}; + +/* + * This function is a test vector for sw read leveling, + * it compares the read data with the written data. + * + * @param ch DMC channel number + * @param byte_lane which DQS byte offset, + * possible values are 0,1,2,3 + * @returns TRUE if memory was good, FALSE if not. + */ +static int dmc_valid_window_test_vector(int ch, int byte_lane) +{ + unsigned int read_data; + unsigned int mask; + int i; + + mask = 0xFF << (8 * byte_lane); + + for (i = 0; i < ARRAY_SIZE(test_pattern); i++) { + read_data = readl(test_addr + i*4 + ch*0x80); + if ((read_data & mask) != (test_pattern[i] & mask)) + return FALSE; + } + + return TRUE; +} + +/* + * This function returns current read offset value. + * + * @param phy_ctrl pointer to the current phy controller + */ +static unsigned int dmc_get_read_offset_value(struct exynos5420_phy_control + *phy_ctrl) +{ + return readl(&phy_ctrl->phy_con4); +} + +/* + * This function performs resync, so that slave DLL is updated. + * + * @param phy_ctrl pointer to the current phy controller + */ +static void ddr_phy_set_do_resync(struct exynos5420_phy_control *phy_ctrl) +{ + setbits_le32(&phy_ctrl->phy_con10, PHY_CON10_CTRL_OFFSETR3); + clrbits_le32(&phy_ctrl->phy_con10, PHY_CON10_CTRL_OFFSETR3); +} + +/* + * This function sets read offset value register with 'offset'. + * + * ...we also call call ddr_phy_set_do_resync(). + * + * @param phy_ctrl pointer to the current phy controller + * @param offset offset to read DQS + */ +static void dmc_set_read_offset_value(struct exynos5420_phy_control *phy_ctrl, + unsigned int offset) +{ + writel(offset, &phy_ctrl->phy_con4); + ddr_phy_set_do_resync(phy_ctrl); +} + +/* + * Convert a 2s complement byte to a byte with a sign bit. + * + * NOTE: you shouldn't use normal math on the number returned by this function. + * As an example, -10 = 0xf6. After this function -10 = 0x8a. If you wanted + * to do math and get the average of 10 and -10 (should be 0): + * 0x8a + 0xa = 0x94 (-108) + * 0x94 / 2 = 0xca (-54) + * ...and 0xca = sign bit plus 0x4a, or -74 + * + * Also note that you lose the ability to represent -128 since there are two + * representations of 0. + * + * @param b The byte to convert in two's complement. + * @returns The 7-bit value + sign bit. + */ + +unsigned char make_signed_byte(signed char b) +{ + if (b < 0) + return 0x80 | -b; + else + return b; +} + +/* + * Test various shifts starting at 'start' and going to 'end'. + * + * For each byte lane, we'll walk through shift starting at 'start' and going + * to 'end' (inclusive). When we are finally able to read the test pattern + * we'll store the value in the results array. + * + * @param phy_ctrl pointer to the current phy controller + * @param ch channel number + * @param start the start shift. -127 to 127 + * @param end the end shift. -127 to 127 + * @param results we'll store results for each byte lane. + */ + +void test_shifts(struct exynos5420_phy_control *phy_ctrl, int ch, + int start, int end, int results[NUM_BYTE_LANES]) +{ + int incr = (start < end) ? 1 : -1; + int byte_lane; + + for (byte_lane = 0; byte_lane < NUM_BYTE_LANES; byte_lane++) { + int shift; + + dmc_set_read_offset_value(phy_ctrl, DEFAULT_DQS_X4); + results[byte_lane] = DEFAULT_DQS; + + for (shift = start; shift != (end + incr); shift += incr) { + unsigned int byte_offsetr; + unsigned int offsetr; + + byte_offsetr = make_signed_byte(shift); + + offsetr = dmc_get_read_offset_value(phy_ctrl); + offsetr &= ~(0xFF << (8 * byte_lane)); + offsetr |= (byte_offsetr << (8 * byte_lane)); + dmc_set_read_offset_value(phy_ctrl, offsetr); + + if (dmc_valid_window_test_vector(ch, byte_lane)) { + results[byte_lane] = shift; + break; + } + } + } +} + +/* + * This function performs SW read leveling to compensate DQ-DQS skew at + * receiver it first finds the optimal read offset value on each DQS + * then applies the value to PHY. + * + * Read offset value has its min margin and max margin. If read offset + * value exceeds its min or max margin, read data will have corruption. + * To avoid this we are doing sw read leveling. + * + * SW read leveling is: + * 1> Finding offset value's left_limit and right_limit + * 2> and calculate its center value + * 3> finally programs that center value to PHY + * 4> then PHY gets its optimal offset value. + * + * @param phy_ctrl pointer to the current phy controller + * @param ch channel number + * @param coarse_lock_val The coarse lock value read from PHY_CON13. + * (0 - 0x7f) + */ +static void software_find_read_offset(struct exynos5420_phy_control *phy_ctrl, + int ch, unsigned int coarse_lock_val) +{ + unsigned int offsetr_cent; + int byte_lane; + int left_limit; + int right_limit; + int left[NUM_BYTE_LANES]; + int right[NUM_BYTE_LANES]; + int i; + + /* Fill the memory with test patterns */ + for (i = 0; i < ARRAY_SIZE(test_pattern); i++) + writel(test_pattern[i], test_addr + i*4 + ch*0x80); + + /* Figure out the limits we'll test with; keep -127 < limit < 127 */ + left_limit = DEFAULT_DQS - coarse_lock_val; + right_limit = DEFAULT_DQS + coarse_lock_val; + if (right_limit > 127) + right_limit = 127; + + /* Fill in the location where reads were OK from left and right */ + test_shifts(phy_ctrl, ch, left_limit, right_limit, left); + test_shifts(phy_ctrl, ch, right_limit, left_limit, right); + + /* Make a final value by taking the center between the left and right */ + offsetr_cent = 0; + for (byte_lane = 0; byte_lane < NUM_BYTE_LANES; byte_lane++) { + int temp_center; + unsigned int vmwc; + + temp_center = (left[byte_lane] + right[byte_lane]) / 2; + vmwc = make_signed_byte(temp_center); + offsetr_cent |= vmwc << (8 * byte_lane); + } + dmc_set_read_offset_value(phy_ctrl, offsetr_cent); +} + int ddr3_mem_ctrl_init(int reset) { struct exynos5420_clock *clk = @@ -231,6 +450,7 @@ int ddr3_mem_ctrl_init(int reset) struct exynos5420_phy_control *phy0_ctrl, *phy1_ctrl; struct exynos5420_dmc *drex0, *drex1; struct exynos5420_tzasc *tzasc0, *tzasc1; + struct exynos5_power *pmu; struct mem_timings *mem; uint32_t val, n_lock_r, n_lock_w_phy0, n_lock_w_phy1; uint32_t lock0_info, lock1_info; @@ -247,6 +467,7 @@ int ddr3_mem_ctrl_init(int reset) tzasc1 = (struct exynos5420_tzasc *)(samsung_get_base_dmc_tzasc() + DMC_OFFSET); mem = clock_get_mem_timings(); + pmu = (struct exynos5_power *)EXYNOS5420_POWER_BASE;
/* Enable PAUSE for DREX */ setbits_le32(&clk->pause, ENABLE_BIT); @@ -566,6 +787,27 @@ int ddr3_mem_ctrl_init(int reset) setbits_le32(&phy1_ctrl->phy_con2, DLL_DESKEW_EN); }
+ /* + * Do software read leveling + * + * Do this before we turn on auto refresh since the auto refresh can + * be in conflict with the resync operation that's part of setting + * read leveling. + */ + if (!reset) { + /* restore calibrated value after resume */ + dmc_set_read_offset_value(phy0_ctrl, readl(&pmu->pmu_spare1)); + dmc_set_read_offset_value(phy1_ctrl, readl(&pmu->pmu_spare2)); + } else { + software_find_read_offset(phy0_ctrl, 0, + CTRL_LOCK_COARSE(lock0_info)); + software_find_read_offset(phy1_ctrl, 1, + CTRL_LOCK_COARSE(lock1_info)); + /* save calibrated value to restore after resume */ + writel(dmc_get_read_offset_value(phy0_ctrl), &pmu->pmu_spare1); + writel(dmc_get_read_offset_value(phy1_ctrl), &pmu->pmu_spare2); + } + /* Send PALL command */ dmc_config_prech(mem, &drex0->directcmd); dmc_config_prech(mem, &drex1->directcmd); diff --git a/arch/arm/cpu/armv7/exynos/exynos5_setup.h b/arch/arm/cpu/armv7/exynos/exynos5_setup.h index 1cf9caf..f4ee2a2 100644 --- a/arch/arm/cpu/armv7/exynos/exynos5_setup.h +++ b/arch/arm/cpu/armv7/exynos/exynos5_setup.h @@ -282,8 +282,11 @@ #define PHY_CON12_VAL 0x10107F50 #define CTRL_START (1 << 6) #define CTRL_DLL_ON (1 << 5) +#define CTRL_LOCK_COARSE_OFFSET (10) +#define CTRL_LOCK_COARSE_MASK (0x7F << CTRL_LOCK_COARSE_OFFSET) +#define CTRL_LOCK_COARSE(x) (((x) & CTRL_LOCK_COARSE_MASK) >> \ + CTRL_LOCK_COARSE_OFFSET) #define CTRL_FORCE_MASK (0x7F << 8) -#define CTRL_LOCK_COARSE_MASK (0x7F << 10) #define CTRL_FINE_LOCKED 0x7
#define CTRL_OFFSETD_RESET_VAL 0x8 diff --git a/arch/arm/include/asm/arch-exynos/dmc.h b/arch/arm/include/asm/arch-exynos/dmc.h index d78536d..ec3f9b6 100644 --- a/arch/arm/include/asm/arch-exynos/dmc.h +++ b/arch/arm/include/asm/arch-exynos/dmc.h @@ -467,6 +467,9 @@ enum mem_manuf { /* PHY_CON1 register fields */ #define PHY_CON1_RDLVL_RDDATA_ADJ_SHIFT 0
+/* PHY_CON4 rgister fields */ +#define PHY_CON10_CTRL_OFFSETR3 (1 << 24) + /* PHY_CON12 register fields */ #define PHY_CON12_CTRL_START_POINT_SHIFT 24 #define PHY_CON12_CTRL_INC_SHIFT 16 diff --git a/arch/arm/include/asm/arch-exynos/power.h b/arch/arm/include/asm/arch-exynos/power.h index c9609a2..bcef43f 100644 --- a/arch/arm/include/asm/arch-exynos/power.h +++ b/arch/arm/include/asm/arch-exynos/power.h @@ -906,8 +906,8 @@ struct exynos5420_power { unsigned int sysip_dat3; unsigned char res11[0xe0]; unsigned int pmu_spare0; - unsigned int pmu_spare1; - unsigned int pmu_spare2; + unsigned int pmu_spare1; /* Store PHY0_CON4 for read leveling */ + unsigned int pmu_spare2; /* Store PHY1_CON4 for read leveling */ unsigned int pmu_spare3; unsigned char res12[0x4]; unsigned int cg_status0;
Hi Akshay,
The English could be a bit better here - also suggest formatting to 72 columns or more.
Is this in milliseconds? If so TIMEOUT_MS, or maybe microseconds, TIMEOUT _US
What does this mean?
You can just use true and false in U-Boot now (the bool type).
- RAM address to use in the test.
- We'll use 4 words at this address and 4 at this address + 0x80 (Ares
- interleaves channels every 128 bytes). This will allow us to evaluate all of
- the chips in a 1 chip per channel (2GB) system and half the chips in a 2
- chip per channel (4GB) system. We can't test the 2nd chip since we need to
- do tests before the 2nd chip is enabled. Looking at the 2nd chip isn't
- critical because the 1st and 2nd chip have very similar timings (they'd
- better have similar timings, since there's only a single adjustment that is
- shared by both chips).
Isn't this CONFIG_SYS_SDRAM_BASE?
0x5A5A5A5A,
0xA5A5A5A5,
0xF0F0F0F0,
0x0F0F0F0F,
Lower case hex throughout?
Should fix for each function.
- This function is a test vector for sw read leveling,
- it compares the read data with the written data.
- @param ch DMC channel number
- @param byte_lane which DQS byte offset,
- @returns TRUE if memory was good, FALSE if not.
@return
unsigned int mask;
int i;
Spaces around * operators
return FALSE;
return TRUE;
- This function returns current read offset value.
- @param phy_ctrl pointer to the current phy controller
*phy_ctrl)
- This function performs resync, so that slave DLL is updated.
- This function sets read offset value register with 'offset'.
- ...we also call call ddr_phy_set_do_resync().
- @param offset offset to read DQS
- Convert a 2s complement byte to a byte with a sign bit.
- NOTE: you shouldn't use normal math on the number returned by this function.
- As an example, -10 = 0xf6. After this function -10 = 0x8a. If you wanted
- to do math and get the average of 10 and -10 (should be 0):
- ...and 0xca = sign bit plus 0x4a, or -74
- Also note that you lose the ability to represent -128 since there are two
- representations of 0.
- @param b The byte to convert in two's complement.
- @returns The 7-bit value + sign bit.
if (b < 0)
return 0x80 | -b;
else
return b;
- Test various shifts starting at 'start' and going to 'end'.
- For each byte lane, we'll walk through shift starting at 'start' and going
- to 'end' (inclusive). When we are finally able to read the test pattern
- we'll store the value in the results array.
- @param ch channel number
- @param start the start shift. -127 to 127
- @param end the end shift. -127 to 127
- @param results we'll store results for each byte lane.
int byte_lane;
int shift;
break;
- This function performs SW read leveling to compensate DQ-DQS skew at
- receiver it first finds the optimal read offset value on each DQS
- then applies the value to PHY.
- Read offset value has its min margin and max margin. If read offset
- value exceeds its min or max margin, read data will have corruption.
- To avoid this we are doing sw read leveling.
- SW read leveling is:
- 1> Finding offset value's left_limit and right_limit
- 2> and calculate its center value
- 3> finally programs that center value to PHY
- 4> then PHY gets its optimal offset value.
- @param coarse_lock_val The coarse lock value read from PHY_CON13.
(0 - 0x7f)
int byte_lane;
int left_limit;
int right_limit;
int i;
right_limit = 127;
offsetr_cent = 0;
int temp_center;
unsigned int vmwc;
pmu = (struct exynos5_power *)EXYNOS5420_POWER_BASE; /* Enable PAUSE for DREX */ setbits_le32(&clk->pause, ENABLE_BIT);
* read leveling.
if (!reset) {
} else {
Don't need ()
-- 1.8.3.2
Akshay Saraswat
