[PATCH] arm64: xilinx: Enable EFI_HTTP_BOOT by default
Enable EFI_HTTP_BOOT to be able to booting OS via http. In case of that dhcp server is not providing dns server IP set it up via setenv dnsip <ip addr>.
Signed-off-by: Michal Simek michal.simek@amd.com ---
I am ignoring defconfig sync because it needs to done because of cda3f81b06f5 ("cmd/flash: Make this default y for CFI and NOR only") anyway that's why I will just enable feature and Tom will run resync at some point to remove automatically selected options. --- configs/xilinx_versal_net_virt_defconfig | 1 + configs/xilinx_versal_virt_defconfig | 1 + configs/xilinx_zynqmp_kria_defconfig | 1 + configs/xilinx_zynqmp_virt_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/xilinx_versal_net_virt_defconfig b/configs/xilinx_versal_net_virt_defconfig index 371d14eb89b7..0f1d990936f3 100644 --- a/configs/xilinx_versal_net_virt_defconfig +++ b/configs/xilinx_versal_net_virt_defconfig @@ -146,3 +146,4 @@ CONFIG_VIRTIO_MMIO=y CONFIG_VIRTIO_NET=y CONFIG_VIRTIO_BLK=y CONFIG_TPM=y +CONFIG_EFI_HTTP_BOOT=y diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index 5f76a305ab32..3c55dd8dcde9 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -153,3 +153,4 @@ CONFIG_VIRTIO_MMIO=y CONFIG_VIRTIO_NET=y CONFIG_VIRTIO_BLK=y CONFIG_TPM=y +CONFIG_EFI_HTTP_BOOT=y diff --git a/configs/xilinx_zynqmp_kria_defconfig b/configs/xilinx_zynqmp_kria_defconfig index 0dc6c5b6877f..28b28f68411f 100644 --- a/configs/xilinx_zynqmp_kria_defconfig +++ b/configs/xilinx_zynqmp_kria_defconfig @@ -224,3 +224,4 @@ CONFIG_EFI_SET_TIME=y CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y +CONFIG_EFI_HTTP_BOOT=y diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 2742e38b599e..1fcae45e95db 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -242,3 +242,4 @@ CONFIG_EFI_SET_TIME=y CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y +CONFIG_EFI_HTTP_BOOT=y
Applied. M
Michal Simek
