[U-Boot] [PATCH] rockchip: rk3328: fix syscon id table
syscon id table need a dummy member as NULL ending, or else system will panic while try to match a compatible in this table as a list.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/mach-rockchip/rk3328/syscon_rk3328.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-rockchip/rk3328/syscon_rk3328.c b/arch/arm/mach-rockchip/rk3328/syscon_rk3328.c index a1a368f..9a2c88d 100644 --- a/arch/arm/mach-rockchip/rk3328/syscon_rk3328.c +++ b/arch/arm/mach-rockchip/rk3328/syscon_rk3328.c @@ -11,6 +11,7 @@
static const struct udevice_id rk3328_syscon_ids[] = { { .compatible = "rockchip,rk3328-grf", .data = ROCKCHIP_SYSCON_GRF }, + { } };
U_BOOT_DRIVER(syscon_rk3328) = {
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Applied to u-boot-rockchip, thanks!
Kever Yang
Philipp Tomsich
