[PATCH] net: rswitch: Do not register disabled ports as ethernet devices
In case an rswitch port is described as disabled in DT, do not register it as ethernet device in U-Boot. This way, such ports cannot be accessed from U-Boot command line.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Enric Balletbo i Serra eballetb@redhat.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org Cc: Ramon Fried rfried.dev@gmail.com Cc: Tom Rini trini@konsulko.com Cc: u-boot@lists.denx.de --- drivers/net/rswitch.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/net/rswitch.c b/drivers/net/rswitch.c index 97b5d1b75c1..57eff748c90 100644 --- a/drivers/net/rswitch.c +++ b/drivers/net/rswitch.c @@ -1113,6 +1113,9 @@ static int rswitch_bind(struct udevice *parent) return -ENOENT;
ofnode_for_each_subnode(node, ports_np) { + if (!ofnode_is_enabled(node)) + continue; + ret = device_bind_with_driver_data(parent, drv, ofnode_get_name(node), (ulong)priv, node, &dev);
