[U-Boot] [PATCH v2 1/5] armv8: ls2088a: The ls2088a platform supports the I2C driver model.
DM_I2C_COMPAT is a compatibility layer that allows using the non-DM I2C API when DM_I2C is used.When DM_I2C_COMPAT is not enabled for compilation, a compilation error will be generated. This patch solves the problem that the i2c-related api of the ls2088a platform does not support dm.
Signed-off-by: Chuanhua Han chuanhua.han@nxp.com --- depends on: - http://patchwork.ozlabs.org/project/uboot/list/?series=109459 - http://patchwork.ozlabs.org/project/uboot/list/?series=113103
Change in v2: - No change.
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 4 ---- board/freescale/ls2080ardb/ls2080ardb.c | 9 +++++++++ include/configs/ls2080a_common.h | 3 --- include/configs/ls2080ardb.h | 1 - 4 files changed, 9 insertions(+), 8 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index ffda02a..8a69af4 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -205,10 +205,6 @@ config ARCH_LS2080A select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F select SYS_I2C_MXC - select SYS_I2C_MXC_I2C1 - select SYS_I2C_MXC_I2C2 - select SYS_I2C_MXC_I2C3 - select SYS_I2C_MXC_I2C4 imply DISTRO_DEFAULTS imply PANIC_HANG
diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index ce419df..8833ed3 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -163,7 +163,16 @@ int select_i2c_ch_pca9547(u8 ch) { int ret;
+#ifndef CONFIG_DM_I2C ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); +#else + struct udevice *dev; + + ret = i2c_get_chip_for_busnum(0, I2C_MUX_PCA_ADDR_PRI, 1, &dev); + if (!ret) + ret = dm_i2c_write(dev, 0, &ch, 1); +#endif + if (ret) { puts("PCA: failed to select proper channel\n"); return ret; diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index c7d8a3b..e776b5c 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -74,9 +74,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2048 * 1024)
-/* I2C */ -#define CONFIG_SYS_I2C - /* Serial Port */ #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index bfb54be..db22f59 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -13,7 +13,6 @@ #ifdef CONFIG_TARGET_LS2081ARDB #define CONFIG_QIXIS_I2C_ACCESS #endif -#define CONFIG_SYS_I2C_EARLY_INIT #endif
#define I2C_MUX_CH_VOL_MONITOR 0xa
As no gpio.h is defined for this architecture, to avoid compilation failure, do not include <asm/arch/gpio.h> for arch ls2080a.
arch/arm/include/asm/gpio.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/arm/include/asm/gpio.h b/arch/arm/include/asm/gpio.h index f78b976..292adfa 100644 --- a/arch/arm/include/asm/gpio.h +++ b/arch/arm/include/asm/gpio.h @@ -1,7 +1,7 @@ #if !defined(CONFIG_ARCH_UNIPHIER) && !defined(CONFIG_ARCH_STI) && \ !defined(CONFIG_ARCH_K3) && !defined(CONFIG_ARCH_BCM6858) && \ !defined(CONFIG_ARCH_BCM63158) && !defined(CONFIG_ARCH_ROCKCHIP) && \ - !defined(CONFIG_ARCH_LX2160A) + !defined(CONFIG_ARCH_LX2160A) && !defined(CONFIG_ARCH_LS2080A) #include <asm/arch/gpio.h> #endif #include <asm-generic/gpio.h>
Enable related configs to support rtc DM feature for ls2088ardb board.
configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 7 ++++++- configs/ls2088ardb_tfa_defconfig | 7 ++++++- 2 files changed, 12 insertions(+), 2 deletions(-)
diff --git a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig index d3312c6..abc608f 100644 --- a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080ARDB=y +CONFIG_SYS_MALLOC_F_LEN=0x6000 CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SECURE_BOOT=y CONFIG_QSPI_AHB_INIT=y @@ -8,7 +9,6 @@ CONFIG_NR_DRAM_BANKS=3 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y -# CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y @@ -69,3 +69,8 @@ CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_DM_I2C=y +CONFIG_DM_GPIO=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_DM_RTC=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index 1aa8dd9..c273a75 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080ARDB=y +CONFIG_SYS_MALLOC_F_LEN=0x6000 CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_QSPI_AHB_INIT=y CONFIG_TFABOOT=y @@ -7,7 +8,6 @@ CONFIG_NR_DRAM_BANKS=3 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y -# CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y @@ -70,3 +70,8 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_DM_I2C=y +CONFIG_DM_GPIO=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_DM_RTC=y
One ls2088a, there is four I2C controllers. This patch is to add I2C node for ls2088a.
arch/arm/dts/fsl-ls2080a.dtsi | 36 ++++++++++++++++++++++++++++++++++++ 1 files changed, 36 insertions(+), 0 deletions(-)
diff --git a/arch/arm/dts/fsl-ls2080a.dtsi b/arch/arm/dts/fsl-ls2080a.dtsi index 5c0769b..99ed33a 100644 --- a/arch/arm/dts/fsl-ls2080a.dtsi +++ b/arch/arm/dts/fsl-ls2080a.dtsi @@ -56,6 +56,42 @@ <0x00000000 0x08340000 0 0x40000>; /* MC control reg */ };
+ i2c0: i2c@2000000 { + status = "disabled"; + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2000000 0x0 0x10000>; + interrupts = <0 34 0x4>; /* Level high type */ + }; + + i2c1: i2c@2010000 { + status = "disabled"; + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2010000 0x0 0x10000>; + interrupts = <0 34 0x4>; /* Level high type */ + }; + + i2c2: i2c@2020000 { + status = "disabled"; + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2020000 0x0 0x10000>; + interrupts = <0 35 0x4>; /* Level high type */ + }; + + i2c3: i2c@2030000 { + status = "disabled"; + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2030000 0x0 0x10000>; + interrupts = <0 35 0x4>; /* Level high type */ + }; + dspi: dspi@2100000 { compatible = "fsl,vf610-dspi"; #address-cells = <1>;
This patch adds some slave nodes to support the i2c dm on the device side under the i2c0 controller.
Change in v2: - Delete unnecessary i2c slave nodes.
arch/arm/dts/fsl-ls2088a-rdb-qspi.dts | 22 ++++++++++++++++++++++ 1 files changed, 22 insertions(+), 0 deletions(-)
diff --git a/arch/arm/dts/fsl-ls2088a-rdb-qspi.dts b/arch/arm/dts/fsl-ls2088a-rdb-qspi.dts index bf97d13..72b2177 100644 --- a/arch/arm/dts/fsl-ls2088a-rdb-qspi.dts +++ b/arch/arm/dts/fsl-ls2088a-rdb-qspi.dts @@ -57,6 +57,28 @@ }; };
+&i2c0 { + status = "okay"; + u-boot,dm-pre-reloc; + + pca9547@75 { + compatible = "nxp,pca9547"; + reg = <0x75>; + #address-cells = <1>; + #size-cells = <0>; + + i2c@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x01>; + rtc@68 { + compatible = "dallas,ds3232"; + reg = <0x68>; + }; + }; + }; +}; + &sata { status = "okay"; };
Chuanhua Han
