[U-Boot] [PATCH 1/1] efi_loader: fix typos in efi_boottime.c
Fix numerous typos.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_boottime.c | 42 +++++++++++++++++------------------ 1 file changed, 21 insertions(+), 21 deletions(-)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index f9f59b93f9..dfddcb5aa5 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -106,8 +106,8 @@ void efi_save_gd(void)
/* * Special case handler for error/abort that just forces things back to u-boot - * world so we can dump out an abort msg, without any care about returning back - * to UEFI world. + * world so we can dump out an abort message, without any care about returning + * back to UEFI world. */ void efi_restore_gd(void) { @@ -184,7 +184,7 @@ static void efi_queue_event(struct efi_event *event, bool check_tpl) * is_valid_tpl() - check if the task priority level is valid * * @tpl: TPL level to check - * ReturnValue: status code + * Return: status code */ efi_status_t is_valid_tpl(efi_uintn_t tpl) { @@ -627,7 +627,7 @@ efi_status_t efi_create_event(uint32_t type, efi_uintn_t notify_tpl, evt->notify_function = notify_function; evt->notify_context = notify_context; evt->group = group; - /* Disable timers on bootup */ + /* Disable timers on boot up */ evt->trigger_next = -1ULL; evt->is_queued = false; evt->is_signaled = false; @@ -733,7 +733,7 @@ void efi_timer_check(void) * efi_set_timer() - set the trigger time for a timer event or stop the event * @event: event for which the timer is set * @type: type of the timer - * @trigger_time: trigger period in multiples of 100ns + * @trigger_time: trigger period in multiples of 100 ns * * This is the function for internal usage in U-Boot. For the API function * implementing the SetTimer service see efi_set_timer_ext. @@ -748,8 +748,8 @@ efi_status_t efi_set_timer(struct efi_event *event, enum efi_timer_delay type, return EFI_INVALID_PARAMETER;
/* - * The parameter defines a multiple of 100ns. - * We use multiples of 1000ns. So divide by 10. + * The parameter defines a multiple of 100 ns. + * We use multiples of 1000 ns. So divide by 10. */ do_div(trigger_time, 10);
@@ -775,7 +775,7 @@ efi_status_t efi_set_timer(struct efi_event *event, enum efi_timer_delay type, * event * @event: event for which the timer is set * @type: type of the timer - * @trigger_time: trigger period in multiples of 100ns + * @trigger_time: trigger period in multiples of 100 ns * * This function implements the SetTimer service. * @@ -1062,7 +1062,7 @@ out: /** * efi_get_drivers() - get all drivers associated to a controller * @efiobj: handle of the controller - * @protocol: protocol guid (optional) + * @protocol: protocol GUID (optional) * @number_of_drivers: number of child controllers * @driver_handle_buffer: handles of the the drivers * @@ -1127,7 +1127,7 @@ static efi_status_t efi_get_drivers(struct efi_object *efiobj, /** * efi_disconnect_all_drivers() - disconnect all drivers from a controller * @efiobj: handle of the controller - * @protocol: protocol guid (optional) + * @protocol: protocol GUID (optional) * @child_handle: handle of the child to destroy * * This function implements the DisconnectController service. @@ -1409,7 +1409,7 @@ efi_status_t efi_install_configuration_table(const efi_guid_t *guid, if (!guid) return EFI_INVALID_PARAMETER;
- /* Check for guid override */ + /* Check for GUID override */ for (i = 0; i < systab.nr_tables; i++) { if (!guidcmp(guid, &systab.tables[i].guid)) { if (table) @@ -1433,7 +1433,7 @@ efi_status_t efi_install_configuration_table(const efi_guid_t *guid, systab.nr_tables = i + 1;
out: - /* systab.nr_tables may have changed. So we need to update the crc32 */ + /* systab.nr_tables may have changed. So we need to update the CRC32 */ efi_update_table_header_crc32(&systab.hdr);
/* Notify that the configuration table was changed */ @@ -1655,7 +1655,7 @@ static efi_status_t EFIAPI efi_load_image(bool boot_policy, if (ret != EFI_SUCCESS) goto failure; } else { - /* In this case, file_path is the "device" path, ie. + /* In this case, file_path is the "device" path, i.e. * something like a HARDWARE_DEVICE:MEMORY_MAPPED */ ret = efi_setup_loaded_image(info, obj, file_path, NULL); @@ -1679,7 +1679,7 @@ error: }
/** - * efi_start_image() - dall the entry point of an image + * efi_start_image() - call the entry point of an image * @image_handle: handle of the image * @exit_data_size: size of the buffer * @exit_data: buffer to receive the exit data of the called image @@ -1738,7 +1738,7 @@ static efi_status_t EFIAPI efi_start_image(efi_handle_t image_handle,
/* * Usually UEFI applications call Exit() instead of returning. - * But because the world doesn not consist of ponies and unicorns, + * But because the world doesn't consist of ponies and unicorns, * we're happy to emulate that behavior on behalf of a payload * that forgot. */ @@ -1882,7 +1882,7 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, } }
- /* TODO Should persist EFI variables here */ + /* TODO: Should persist EFI variables here */
board_quiesce_devices();
@@ -1892,7 +1892,7 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, /* This stops all lingering devices */ bootm_disable_interrupts();
- /* Disable boottime services */ + /* Disable boot time services */ systab.con_in_handle = NULL; systab.con_in = NULL; systab.con_out_handle = NULL; @@ -2126,7 +2126,7 @@ static efi_status_t EFIAPI efi_protocols_per_handle( ++*protocol_buffer_count; }
- /* Copy guids */ + /* Copy GUIDs */ if (*protocol_buffer_count) { size_t j = 0;
@@ -2717,7 +2717,7 @@ static efi_status_t efi_bind_controller( * efi_connect_single_controller() - connect a single driver to a controller * @controller_handle: controller * @driver_image_handle: driver - * @remain_device_path: remainting path + * @remain_device_path: remaining path * * Return: status code */ @@ -2798,7 +2798,7 @@ static efi_status_t efi_connect_single_controller( * details. * * First all driver binding protocol handles are tried for binding drivers. - * Afterwards all handles that have openened a protocol of the controller + * Afterwards all handles that have opened a protocol of the controller * with EFI_OPEN_PROTOCOL_BY_CHILD_CONTROLLER are connected to drivers. * * Return: status code @@ -3143,7 +3143,7 @@ efi_status_t efi_initialize_system_table(void) sizeof(struct efi_configuration_table), (void **)&systab.tables);
- /* Set crc32 field in table headers */ + /* Set CRC32 field in table headers */ efi_update_table_header_crc32(&systab.hdr); efi_update_table_header_crc32(&efi_runtime_services.hdr); efi_update_table_header_crc32(&efi_boot_services.hdr);
