[U-Boot] [PATCH] imx: mx6q_4x_mt41j128.cfg: Setup CCM_CCOSR register
Setup CCM_CCOSR register to provide a CKO1 clock frequency of 16.5 MHz.
CKO1 drives sgtl5000 codec clock on mx6qsabrelite and doing this setup in the bootloader will allow us to remove a lot of code in arch/arm/mach-imx/mach-imx6q.c from the mainline kernel.
mx6q_4x_mt41j128.cfg is also used by mx6qsabresd, and it is safe to use it for this board as well.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg b/board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg index f4cae5e..4661775 100644 --- a/board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg +++ b/board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg @@ -172,3 +172,14 @@ DATA 4 0x020e0010 0xF00000CF /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ DATA 4 0x020e0018 0x007F007F DATA 4 0x020e001c 0x007F007F + +/* + * Setup CCM_CCOSR register as follows: + * + * cko1_en = 1 --> CKO1 enabled + * cko1_div = 111 --> divide by 8 + * cko1_sel = 1011 --> ahb_clk_root + * + * This sets CKO1 at ahb_clk_root/8 = 132/8 = 16.5 MHz + */ +DATA 4 0x020c4060 0x000000fb
Thanks Fabio,
More importantly than eliminating code in the mainline kernel, enabling the clock will remove squeal after an ungraceful reboot (watchdog) if hooked up to speakers. I believe you can see this under Android by issuing a 'reboot' command.
We've been meaning to push a patch for this for a while.
We did it in two parts.
1.) Add routine to enable the clock: https://github.com/boundarydevices/u-boot-imx6/commit/7087d645ea1ad476825ea9...
2.) Enable it on each of SABRE Lite, Nitrogen6X and one of our custom boards. https://github.com/boundarydevices/u-boot-imx6/commit/44b1015f69b52c0a7d7b93...
Does wandboard also use SGTL5000 connected up to CKO1?
- Setup CCM_CCOSR register as follows:
- cko1_en = 1 --> CKO1 enabled
- cko1_div = 111 --> divide by 8
- cko1_sel = 1011 --> ahb_clk_root
- This sets CKO1 at ahb_clk_root/8 = 132/8 = 16.5 MHz
Hi Eric,
On Wed, Apr 17, 2013 at 3:57 PM, Eric Nelson eric.nelson@boundarydevices.com wrote:
Ok, great. I was not aware of this problem. Glad to know that it also fixes it.
I can send this same change to nitrogen and wandboard.
Yes, it does.
I started to adding audio support to wandboard in the mainline kernel, then I saw all the code that mx6qsabrelite uses to configure the cko1, and I preferred not to repeat it again.
It is much simpler to let the bootloader take care of it, as it is a simple register write.
Regards,
Fabio Estevam
Hi all,
I am working on IMX6Q-SabreLite Board.in that board we have sgtl5000 codec.so I would like to add (sgtl5000) codec support in *u-boot level*.There is no code available in u-boot level for this codec.Can you please help me How to initialize this audio codec and how to test this one in UBOOT level.
It will be very helpful if you send any u-boot level patch for this codec(sgtl5000).
Thanks Prem.
On Thu, Apr 18, 2013 at 12:52 AM, Fabio Estevam festevam@gmail.com wrote:
Hi Eric,
Yes, it does.
Regards,
Fabio Estevam _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
On Thu, Apr 18, 2013 at 2:27 AM, prem s prem441@gmail.com wrote:
Hi all,
I am working on IMX6Q-SabreLite Board.in that board we have sgtl5000 codec.so I would like to add (sgtl5000) codec support in u-boot level.There is no code available in u-boot level for this codec.Can you please help me How to initialize this audio codec and how to test this one in UBOOT level.
I don't have plans to adding audio support into U-boot for imx.
Maybe you could try to use the OBDS code from Freescale, which provides standalone code for setting up various peripherals and then you can use it as a reference for adding audio support in U-boot.
Just curious: what is your requirement in terms of providing the user with an audio response?
Would booting the kernel fast and providing the audio response in the kernel meet your goal?
Regards,
Fabio Estevam
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Eric Nelson
Fabio Estevam
prem s
Stefano Babic
