[U-Boot] [PATCH 1/2] ls1046ardb: Add CONFIG_ENV_ADDR to init env in qspi boot
Signed-off-by: Pankit Garg pankit.garg@nxp.com --- Changes for v2: - add NXP copyright
include/configs/ls1046ardb.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index f22e863..fa90953 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* * Copyright 2016 Freescale Semiconductor + * Copyright 2019 NXP */
#ifndef __LS1046ARDB_H__ @@ -162,6 +163,8 @@ #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x500000 /* 5MB */ #define CONFIG_ENV_SECT_SIZE 0x40000 /* 256KB */ +#define CONFIG_SYS_FSL_QSPI_BASE 0x40000000 +#define CONFIG_ENV_ADDR CONFIG_SYS_FSL_QSPI_BASE + CONFIG_ENV_OFFSET #else #if defined(CONFIG_SD_BOOT) #define CONFIG_SYS_MMC_ENV_DEV 0
Change bootcmd update logic when CONFIG_ENV_ADDR is not defined
arch/arm/cpu/armv8/fsl-layerscape/soc.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index aeaf7b8..a4b6faf 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2014-2015 Freescale Semiconductor + * Copyright 2019 NXP */
#include <common.h> @@ -874,7 +875,11 @@ int board_late_init(void) * check if gd->env_addr is default_environment; then setenv bootcmd * and mcinitcmd. */ +#if !defined(CONFIG_ENV_ADDR) || defined(ENV_IS_EMBEDDED) + if (gd->env_addr == (ulong)&default_environment[0]) { +#else if (gd->env_addr + gd->reloc_off == (ulong)&default_environment[0]) { +#endif fsl_setenv_bootcmd(); fsl_setenv_mcinitcmd(); }
-----Original Message----- From: Pankit Garg Sent: Thursday, May 30, 2019 5:34 PM To: u-boot@lists.denx.de Cc: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com Subject: [PATCH 2/2] armv8: fsl-layerscape: Change bootcmd update logic
This patch has been applied to fsl-qoriq master, awaiting upstream.
--pk
-----Original Message----- From: Pankit Garg Sent: Thursday, May 30, 2019 5:34 PM To: u-boot@lists.denx.de Cc: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com Subject: [PATCH 1/2] ls1046ardb: Add CONFIG_ENV_ADDR to init env in qspi boot
--pk
Pankit Garg
Prabhakar Kushwaha
