[U-Boot] [PATCH 1/2] am33xx: add a pulldown macro to pinmux config
Signed-off-by: Lars Poeschel poeschel@lemonage.de --- arch/arm/include/asm/arch-am33xx/mux.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-am33xx/mux.h b/arch/arm/include/asm/arch-am33xx/mux.h index aed6b00..460ac1c 100644 --- a/arch/arm/include/asm/arch-am33xx/mux.h +++ b/arch/arm/include/asm/arch-am33xx/mux.h @@ -25,7 +25,8 @@ /* PAD Control Fields */ #define SLEWCTRL (0x1 << 6) #define RXACTIVE (0x1 << 5) -#define PULLUP_EN (0x1 << 4) /* Pull UP Selection */ +#define PULLDOWN_EN (0x0 << 4) /* Pull Down Selection */ +#define PULLUP_EN (0x1 << 4) /* Pull Up Selection */ #define PULLUDEN (0x0 << 3) /* Pull up enabled */ #define PULLUDDIS (0x1 << 3) /* Pull up disabled */ #define MODE(val) val /* used for Readability */
The board is named pcm051 and has this hardware: SOC: TI AM3359 DDR3-RAM: 2x MT41J256M8HX-15EIT:D 512MiB ETH 1: LAN8710AI SPI-Flash: W25Q64BVSSIG RTC: RV-4162-C7 I2C-EEPROM: CAT32WC32 NAND: MT29F4G08_VFPGA63 PMIC: TPS65910A3 LCD
Supported: UART 1 MMC/SD ETH 1 USB I2C SPI
Not yet supported: NAND RTC LCD
Signed-off-by: Lars Poeschel poeschel@lemonage.de --- arch/arm/include/asm/arch-am33xx/ddr_defs.h | 18 ++ board/phytec/pcm051/Makefile | 46 ++++ board/phytec/pcm051/board.c | 271 +++++++++++++++++++++++ board/phytec/pcm051/board.h | 33 +++ board/phytec/pcm051/mux.c | 133 ++++++++++++ boards.cfg | 1 + include/configs/pcm051.h | 308 +++++++++++++++++++++++++++ 7 files changed, 810 insertions(+) create mode 100644 board/phytec/pcm051/Makefile create mode 100644 board/phytec/pcm051/board.c create mode 100644 board/phytec/pcm051/board.h create mode 100644 board/phytec/pcm051/mux.c create mode 100644 include/configs/pcm051.h
diff --git a/arch/arm/include/asm/arch-am33xx/ddr_defs.h b/arch/arm/include/asm/arch-am33xx/ddr_defs.h index 8e69fb6..f95b332 100644 --- a/arch/arm/include/asm/arch-am33xx/ddr_defs.h +++ b/arch/arm/include/asm/arch-am33xx/ddr_defs.h @@ -65,6 +65,24 @@ #define MT41J128MJT125_PHY_FIFO_WE 0x100 #define MT41J128MJT125_IOCTRL_VALUE 0x18B
+/* Micron MT41J256M8HX-15E */ +#define MT41J256M8HX15E_EMIF_READ_LATENCY 0x06 +#define MT41J256M8HX15E_EMIF_TIM1 0x0888A39B +#define MT41J256M8HX15E_EMIF_TIM2 0x26337FDA +#define MT41J256M8HX15E_EMIF_TIM3 0x501F830F +#define MT41J256M8HX15E_EMIF_SDCFG 0x61C04B32 +#define MT41J256M8HX15E_EMIF_SDREF 0x0000093B +#define MT41J256M8HX15E_ZQ_CFG 0x50074BE4 +#define MT41J256M8HX15E_DLL_LOCK_DIFF 0x1 +#define MT41J256M8HX15E_RATIO 0x40 +#define MT41J256M8HX15E_INVERT_CLKOUT 0x1 +#define MT41J256M8HX15E_RD_DQS 0x3B +#define MT41J256M8HX15E_WR_DQS 0x85 +#define MT41J256M8HX15E_PHY_WR_DATA 0xC1 +#define MT41J256M8HX15E_PHY_FIFO_WE 0x100 +#define MT41J256M8HX15E_IOCTRL_VALUE 0x18B + + /** * Configure SDRAM */ diff --git a/board/phytec/pcm051/Makefile b/board/phytec/pcm051/Makefile new file mode 100644 index 0000000..67a87a1 --- /dev/null +++ b/board/phytec/pcm051/Makefile @@ -0,0 +1,46 @@ +# +# Makefile +# +# Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed "as is" WITHOUT ANY WARRANTY of any +# kind, whether express or implied; without even the implied warranty +# of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +ifdef CONFIG_SPL_BUILD +COBJS := mux.o +endif + +COBJS += board.o +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/phytec/pcm051/board.c b/board/phytec/pcm051/board.c new file mode 100644 index 0000000..d2fb60d --- /dev/null +++ b/board/phytec/pcm051/board.c @@ -0,0 +1,271 @@ +/* + * board.c + * + * Board functions for Phytec phyCORE-AM335x (pcm051) based boards + * + * Copyright (C) 2013 Lemonage Software GmbH + * Author Lars Poeschel poeschel@lemonage.de + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <errno.h> +#include <spl.h> +#include <asm/arch/cpu.h> +#include <asm/arch/hardware.h> +#include <asm/arch/omap.h> +#include <asm/arch/ddr_defs.h> +#include <asm/arch/clock.h> +#include <asm/arch/gpio.h> +#include <asm/arch/mmc_host_def.h> +#include <asm/arch/sys_proto.h> +#include <asm/io.h> +#include <asm/emif.h> +#include <asm/gpio.h> +#include <i2c.h> +#include <miiphy.h> +#include <cpsw.h> +#include "board.h" + +DECLARE_GLOBAL_DATA_PTR; + +static struct wd_timer *wdtimer = (struct wd_timer *)WDT_BASE; +#ifdef CONFIG_SPL_BUILD +static struct uart_sys *uart_base = (struct uart_sys *)DEFAULT_UART_BASE; +#endif + +/* MII mode defines */ +#define MII_MODE_ENABLE 0x0 +#define RGMII_MODE_ENABLE 0xA +#define RMII_RGMII2_MODE_ENABLE 0x49 + +static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE; + +/* UART defines */ +#ifdef CONFIG_SPL_BUILD +#define UART_RESET (0x1 << 1) +#define UART_CLK_RUNNING_MASK 0x1 +#define UART_SMART_IDLE_EN (0x1 << 0x3) + +/* DDR RAM defines */ +#define DDR_CLK_MHZ 303 + +static void rtc32k_enable(void) +{ + struct rtc_regs *rtc = (struct rtc_regs *)AM335X_RTC_BASE; + + /* + * Unlock the RTC's registers. For more details please see the + * RTC_SS section of the TRM. In order to unlock we need to + * write these specific values (keys) in this order. + */ + writel(0x83e70b13, &rtc->kick0r); + writel(0x95a4f1e0, &rtc->kick1r); + + /* Enable the RTC 32K OSC by setting bits 3 and 6. */ + writel((1 << 3) | (1 << 6), &rtc->osc); +} + +static const struct ddr_data ddr3_data = { + .datardsratio0 = MT41J256M8HX15E_RD_DQS, + .datawdsratio0 = MT41J256M8HX15E_WR_DQS, + .datafwsratio0 = MT41J256M8HX15E_PHY_FIFO_WE, + .datawrsratio0 = MT41J256M8HX15E_PHY_WR_DATA, + .datadldiff0 = PHY_DLL_LOCK_DIFF, +}; + +static const struct cmd_control ddr3_cmd_ctrl_data = { + .cmd0csratio = MT41J256M8HX15E_RATIO, + .cmd0dldiff = MT41J256M8HX15E_DLL_LOCK_DIFF, + .cmd0iclkout = MT41J256M8HX15E_INVERT_CLKOUT, + + .cmd1csratio = MT41J256M8HX15E_RATIO, + .cmd1dldiff = MT41J256M8HX15E_DLL_LOCK_DIFF, + .cmd1iclkout = MT41J256M8HX15E_INVERT_CLKOUT, + + .cmd2csratio = MT41J256M8HX15E_RATIO, + .cmd2dldiff = MT41J256M8HX15E_DLL_LOCK_DIFF, + .cmd2iclkout = MT41J256M8HX15E_INVERT_CLKOUT, +}; + +static struct emif_regs ddr3_emif_reg_data = { + .sdram_config = MT41J256M8HX15E_EMIF_SDCFG, + .ref_ctrl = MT41J256M8HX15E_EMIF_SDREF, + .sdram_tim1 = MT41J256M8HX15E_EMIF_TIM1, + .sdram_tim2 = MT41J256M8HX15E_EMIF_TIM2, + .sdram_tim3 = MT41J256M8HX15E_EMIF_TIM3, + .zq_config = MT41J256M8HX15E_ZQ_CFG, + .emif_ddr_phy_ctlr_1 = MT41J256M8HX15E_EMIF_READ_LATENCY, +}; +#endif + +/* + * early system init of muxing and clocks. + */ +void s_init(void) +{ + /* WDT1 is already running when the bootloader gets control + * Disable it to avoid "random" resets + */ + writel(0xAAAA, &wdtimer->wdtwspr); + while (readl(&wdtimer->wdtwwps) != 0x0) + ; + writel(0x5555, &wdtimer->wdtwspr); + while (readl(&wdtimer->wdtwwps) != 0x0) + ; + +#ifdef CONFIG_SPL_BUILD + /* Setup the PLLs and the clocks for the peripherals */ + pll_init(); + + /* Enable RTC32K clock */ + rtc32k_enable(); + + /* UART softreset */ + u32 regval; + + enable_uart0_pin_mux(); + + regval = readl(&uart_base->uartsyscfg); + regval |= UART_RESET; + writel(regval, &uart_base->uartsyscfg); + while ((readl(&uart_base->uartsyssts) & + UART_CLK_RUNNING_MASK) != UART_CLK_RUNNING_MASK) + ; + + /* Disable smart idle */ + regval = readl(&uart_base->uartsyscfg); + regval |= UART_SMART_IDLE_EN; + writel(regval, &uart_base->uartsyscfg); + + gd = &gdata; + + preloader_console_init(); + + /* Initalize the board header */ + enable_i2c0_pin_mux(); + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + + enable_board_pin_mux(); + + config_ddr(DDR_CLK_MHZ, MT41J256M8HX15E_IOCTRL_VALUE, &ddr3_data, + &ddr3_cmd_ctrl_data, &ddr3_emif_reg_data); +#endif +} + +/* + * Basic board specific setup. Pinmux has been handled already. + */ +int board_init(void) +{ + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + + gd->bd->bi_boot_params = PHYS_DRAM_1 + 0x100; + + return 0; +} + +#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) +{ + return 0; +} +#endif + +#ifdef CONFIG_DRIVER_TI_CPSW +static void cpsw_control(int enabled) +{ + /* VTP can be added here */ + + return; +} + +static struct cpsw_slave_data cpsw_slaves[] = { + { + .slave_reg_ofs = 0x208, + .sliver_reg_ofs = 0xd80, + .phy_id = 0, + .phy_if = PHY_INTERFACE_MODE_RGMII, + }, + { + .slave_reg_ofs = 0x308, + .sliver_reg_ofs = 0xdc0, + .phy_id = 1, + .phy_if = PHY_INTERFACE_MODE_RGMII, + }, +}; + +static struct cpsw_platform_data cpsw_data = { + .mdio_base = AM335X_CPSW_MDIO_BASE, + .cpsw_base = AM335X_CPSW_BASE, + .mdio_div = 0xff, + .channels = 8, + .cpdma_reg_ofs = 0x800, + .slaves = 1, + .slave_data = cpsw_slaves, + .ale_reg_ofs = 0xd00, + .ale_entries = 1024, + .host_port_reg_ofs = 0x108, + .hw_stats_reg_ofs = 0x900, + .mac_control = (1 << 5), + .control = cpsw_control, + .host_port_num = 0, + .version = CPSW_CTRL_VERSION_2, +}; +#endif + +#if defined(CONFIG_DRIVER_TI_CPSW) || \ + (defined(CONFIG_USB_ETHER) && defined(CONFIG_MUSB_GADGET)) +int board_eth_init(bd_t *bis) +{ + int rv, n = 0; +#ifdef CONFIG_DRIVER_TI_CPSW + uint8_t mac_addr[6]; + uint32_t mac_hi, mac_lo; + + if (!eth_getenv_enetaddr("ethaddr", mac_addr)) { + debug("<ethaddr> not set. Reading from E-fuse\n"); + /* try reading mac address from efuse */ + mac_lo = readl(&cdev->macid0l); + mac_hi = readl(&cdev->macid0h); + mac_addr[0] = mac_hi & 0xFF; + mac_addr[1] = (mac_hi & 0xFF00) >> 8; + mac_addr[2] = (mac_hi & 0xFF0000) >> 16; + mac_addr[3] = (mac_hi & 0xFF000000) >> 24; + mac_addr[4] = mac_lo & 0xFF; + mac_addr[5] = (mac_lo & 0xFF00) >> 8; + + if (is_valid_ether_addr(mac_addr)) + eth_setenv_enetaddr("ethaddr", mac_addr); + else + goto try_usbether; + } + + writel(RMII_RGMII2_MODE_ENABLE, &cdev->miisel); + + rv = cpsw_register(&cpsw_data); + if (rv < 0) + printf("Error %d registering CPSW switch\n", rv); + else + n += rv; +#endif +try_usbether: +#if defined(CONFIG_USB_ETHER) && !defined(CONFIG_SPL_BUILD) + rv = usb_eth_initialize(bis); + if (rv < 0) + printf("Error %d registering USB_ETHER\n", rv); + else + n += rv; +#endif + return n; +} +#endif diff --git a/board/phytec/pcm051/board.h b/board/phytec/pcm051/board.h new file mode 100644 index 0000000..c2630d7 --- /dev/null +++ b/board/phytec/pcm051/board.h @@ -0,0 +1,33 @@ +/* + * board.h + * + * Phytec phyCORE-AM335x (pcm051) boards information header + * + * Copyright (C) 2013, Lemonage Software GmbH + * Author Lars Poeschel poeschel@lemonage.de + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _BOARD_H_ +#define _BOARD_H_ + +/* + * We have three pin mux functions that must exist. We must be able to enable + * uart0, for initial output and i2c0 to read the main EEPROM. We then have a + * main pinmux function that can be overridden to enable all other pinmux that + * is required on the board. + */ +void enable_uart0_pin_mux(void); +void enable_i2c0_pin_mux(void); +void enable_board_pin_mux(void); +void enable_cbmux_pin_mux(void); +#endif diff --git a/board/phytec/pcm051/mux.c b/board/phytec/pcm051/mux.c new file mode 100644 index 0000000..2cda331 --- /dev/null +++ b/board/phytec/pcm051/mux.c @@ -0,0 +1,133 @@ +/* + * mux.c + * + * Copyright (C) 2013 Lemonage Software GmbH + * Author Lars Poeschel poeschel@lemonage.de + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation version 2. + * + * This program is distributed "as is" WITHOUT ANY WARRANTY of any + * kind, whether express or implied; without even the implied warranty + * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/hardware.h> +#include <asm/arch/mux.h> +#include <asm/io.h> +#include "board.h" + +static struct module_pin_mux uart0_pin_mux[] = { + {OFFSET(uart0_rxd), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* UART0_RXD */ + {OFFSET(uart0_txd), (MODE(0) | PULLUDEN)}, /* UART0_TXD */ + {-1}, +}; + +#ifdef CONFIG_MMC +static struct module_pin_mux mmc0_pin_mux[] = { + {OFFSET(mmc0_dat3), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT3 */ + {OFFSET(mmc0_dat2), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT2 */ + {OFFSET(mmc0_dat1), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT1 */ + {OFFSET(mmc0_dat0), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT0 */ + {OFFSET(mmc0_clk), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CLK */ + {OFFSET(mmc0_cmd), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CMD */ + {OFFSET(mcasp0_aclkr), (MODE(4) | RXACTIVE)}, /* MMC0_WP */ + {OFFSET(spi0_cs1), (MODE(5) | RXACTIVE | PULLUP_EN)}, /* MMC0_CD */ + {-1}, +}; +#endif + +#ifdef CONFIG_I2C +static struct module_pin_mux i2c0_pin_mux[] = { + {OFFSET(i2c0_sda), (MODE(0) | RXACTIVE | + PULLUDEN | SLEWCTRL)}, /* I2C_DATA */ + {OFFSET(i2c0_scl), (MODE(0) | RXACTIVE | + PULLUDEN | SLEWCTRL)}, /* I2C_SCLK */ + {-1}, +}; +#endif + +#ifdef CONFIG_SPI +static struct module_pin_mux spi0_pin_mux[] = { + {OFFSET(spi0_sclk), (MODE(0) | RXACTIVE | PULLUDEN)}, /* SPI0_SCLK */ + {OFFSET(spi0_d0), (MODE(0) | RXACTIVE | + PULLUDEN | PULLUP_EN)}, /* SPI0_D0 */ + {OFFSET(spi0_d1), (MODE(0) | RXACTIVE | PULLUDEN)}, /* SPI0_D1 */ + {OFFSET(spi0_cs0), (MODE(0) | RXACTIVE | + PULLUDEN | PULLUP_EN)}, /* SPI0_CS0 */ + {-1}, +}; +#endif + +static struct module_pin_mux gpio0_7_pin_mux[] = { + {OFFSET(ecap0_in_pwm0_out), (MODE(7) | PULLUDEN)}, /* GPIO0_7 */ + {-1}, +}; + +static struct module_pin_mux rmii1_pin_mux[] = { + {OFFSET(mii1_crs), MODE(1) | RXACTIVE}, /* RMII1_CRS */ + {OFFSET(mii1_rxerr), MODE(1) | RXACTIVE}, /* RMII1_RXERR */ + {OFFSET(mii1_txen), MODE(1)}, /* RMII1_TXEN */ + {OFFSET(mii1_txd1), MODE(1)}, /* RMII1_TXD1 */ + {OFFSET(mii1_txd0), MODE(1)}, /* RMII1_TXD0 */ + {OFFSET(mii1_rxd1), MODE(1) | RXACTIVE}, /* RMII1_RXD1 */ + {OFFSET(mii1_rxd0), MODE(1) | RXACTIVE}, /* RMII1_RXD0 */ + {OFFSET(mdio_data), MODE(0) | RXACTIVE | PULLUP_EN}, /* MDIO_DATA */ + {OFFSET(mdio_clk), MODE(0) | PULLUP_EN}, /* MDIO_CLK */ + {OFFSET(rmii1_refclk), MODE(0) | RXACTIVE}, /* RMII1_REFCLK */ + {-1}, +}; + +static struct module_pin_mux cbmux_pin_mux[] = { + {OFFSET(uart0_ctsn), MODE(7) | RXACTIVE | PULLDOWN_EN}, /* JP3 */ + {OFFSET(uart0_rtsn), MODE(7) | RXACTIVE | PULLUP_EN}, /* JP4 */ + {-1}, +}; + +#ifdef CONFIG_NAND +static struct module_pin_mux nand_pin_mux[] = { + {OFFSET(gpmc_ad0), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD0 */ + {OFFSET(gpmc_ad1), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD1 */ + {OFFSET(gpmc_ad2), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD2 */ + {OFFSET(gpmc_ad3), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD3 */ + {OFFSET(gpmc_ad4), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD4 */ + {OFFSET(gpmc_ad5), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD5 */ + {OFFSET(gpmc_ad6), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD6 */ + {OFFSET(gpmc_ad7), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD7 */ + {OFFSET(gpmc_wait0), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* NAND WAIT */ + {OFFSET(gpmc_wpn), (MODE(7) | PULLUP_EN | RXACTIVE)}, /* NAND_WPN */ + {OFFSET(gpmc_csn0), (MODE(0) | PULLUDEN)}, /* NAND_CS0 */ + {OFFSET(gpmc_advn_ale), (MODE(0) | PULLUDEN)}, /* NAND_ADV_ALE */ + {OFFSET(gpmc_oen_ren), (MODE(0) | PULLUDEN)}, /* NAND_OE */ + {OFFSET(gpmc_wen), (MODE(0) | PULLUDEN)}, /* NAND_WEN */ + {OFFSET(gpmc_be0n_cle), (MODE(0) | PULLUDEN)}, /* NAND_BE_CLE */ + {-1}, +}; +#endif + +void enable_uart0_pin_mux(void) +{ + configure_module_pin_mux(uart0_pin_mux); +} + +void enable_i2c0_pin_mux(void) +{ + configure_module_pin_mux(i2c0_pin_mux); +} + +void enable_board_pin_mux() +{ + configure_module_pin_mux(rmii1_pin_mux); + configure_module_pin_mux(mmc0_pin_mux); + configure_module_pin_mux(cbmux_pin_mux); +#ifdef CONFIG_NAND + configure_module_pin_mux(nand_pin_mux); +#endif +#ifdef CONFIG_SPI + configure_module_pin_mux(spi0_pin_mux); +#endif +} diff --git a/boards.cfg b/boards.cfg index 91504c0..f471556 100644 --- a/boards.cfg +++ b/boards.cfg @@ -234,6 +234,7 @@ am335x_evm_uart2 arm armv7 am335x ti am335x_evm_uart3 arm armv7 am335x ti am33xx am335x_evm:SERIAL4,CONS_INDEX=4 am335x_evm_uart4 arm armv7 am335x ti am33xx am335x_evm:SERIAL5,CONS_INDEX=5 am335x_evm_uart5 arm armv7 am335x ti am33xx am335x_evm:SERIAL6,CONS_INDEX=6 +pcm051 arm armv7 pcm051 phytec am33xx pcm051 highbank arm armv7 highbank - highbank mx51_efikamx arm armv7 mx51_efikamx genesi mx5 mx51_efikamx:MACH_TYPE=MACH_TYPE_MX51_EFIKAMX,IMX_CONFIG=board/genesi/mx51_efikamx/imximage_mx.cfg mx51_efikasb arm armv7 mx51_efikamx genesi mx5 mx51_efikamx:MACH_TYPE=MACH_TYPE_MX51_EFIKASB,IMX_CONFIG=board/genesi/mx51_efikamx/imximage_sb.cfg diff --git a/include/configs/pcm051.h b/include/configs/pcm051.h new file mode 100644 index 0000000..96becad --- /dev/null +++ b/include/configs/pcm051.h @@ -0,0 +1,308 @@ +/* + * pcm051.h + * + * Phytec phyCORE-AM335x (pcm051) boards information header + * + * Copyright (C) 2013 Lemonage Software GmbH + * Author Lars Poeschel poeschel@lemonage.de + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation version 2. + * + * This program is distributed "as is" WITHOUT ANY WARRANTY of any + * kind, whether express or implied; without even the implied warranty + * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef __CONFIG_PCM051_H +#define __CONFIG_PCM051_H + +#define CONFIG_AM33XX + +#include <asm/arch/cpu.h> +#include <asm/arch/hardware.h> + +#define CONFIG_DMA_COHERENT +#define CONFIG_DMA_COHERENT_SIZE (1 << 20) + +#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ +#define CONFIG_SYS_MALLOC_LEN (1024 << 10) +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT "U-Boot# " +#define CONFIG_BOARD_LATE_INIT +#define CONFIG_SYS_NO_FLASH +#define MACH_TYPE_PCM051 4144 /* Until the next sync */ +#define CONFIG_MACH_TYPE MACH_TYPE_PCM051 + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG + +/* commands to include */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_VERSION_VARIABLE + +/* set to negative value for no autoboot */ +#define CONFIG_BOOTDELAY 1 +#define CONFIG_ENV_VARS_UBOOT_CONFIG +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x80200000\0" \ + "fdtaddr=0x80F80000\0" \ + "rdaddr=0x81000000\0" \ + "bootfile=/boot/uImage\0" \ + "fdtfile=\0" \ + "console=ttyO0,115200n8\0" \ + "optargs=\0" \ + "mmcdev=0\0" \ + "mmcroot=/dev/mmcblk0p2 ro\0" \ + "mmcrootfstype=ext4 rootwait\0" \ + "ramroot=/dev/ram0 rw ramdisk_size=65536 initrd=${rdaddr},64M\0" \ + "ramrootfstype=ext2\0" \ + "mmcargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "root=${mmcroot} " \ + "rootfstype=${mmcrootfstype}\0" \ + "bootenv=uEnv.txt\0" \ + "loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenv}\0" \ + "importbootenv=echo Importing environment from mmc ...; " \ + "env import -t $loadaddr $filesize\0" \ + "ramargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "root=${ramroot} " \ + "rootfstype=${ramrootfstype}\0" \ + "loadramdisk=fatload mmc ${mmcdev} ${rdaddr} ramdisk.gz\0" \ + "loaduimagefat=fatload mmc ${mmcdev} ${loadaddr} ${bootfile}\0" \ + "loaduimage=ext2load mmc ${mmcdev}:2 ${loadaddr} ${bootfile}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootm ${loadaddr}\0" \ + "ramboot=echo Booting from ramdisk ...; " \ + "run ramargs; " \ + "bootm ${loadaddr}\0" \ + "findfdt="\ + "if test $board_name = A335BONE; then " \ + "setenv fdtfile am335x-bone.dtb; fi; " \ + "if test $board_name = A33515BB; then " \ + "setenv fdtfile am335x-evm.dtb; fi; " \ + "if test $board_name = A335X_SK; then " \ + "setenv fdtfile am335x-evmsk.dtb; fi\0" \ + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "echo SD/MMC found on device ${mmcdev};" \ + "if run loadbootenv; then " \ + "echo Loaded environment from ${bootenv};" \ + "run importbootenv;" \ + "fi;" \ + "if test -n $uenvcmd; then " \ + "echo Running uenvcmd ...;" \ + "run uenvcmd;" \ + "fi;" \ + "if run loaduimage; then " \ + "run mmcboot;" \ + "fi;" \ + "fi;" \ + +/* Clock Defines */ +#define V_OSCK 25000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK) + +#define CONFIG_CMD_ECHO + +/* max number of command args */ +#define CONFIG_SYS_MAXARGS 16 + +/* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 512 + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ + + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* + * memtest works on 8 MB in DRAM after skipping 32MB from + * start addr of ram disk + */ +#define CONFIG_SYS_MEMTEST_START (PHYS_DRAM_1 + (64 * 1024 * 1024)) +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START \ + + (8 * 1024 * 1024)) + +#define CONFIG_SYS_LOAD_ADDR 0x81000000 /* Default load address */ +#define CONFIG_SYS_HZ 1000 /* 1ms clock */ + +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_OMAP_HSMMC +#define CONFIG_CMD_MMC +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 + +#define CONFIG_SPI +#define CONFIG_OMAP3_SPI +#define CONFIG_MTD_DEVICE +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_WINBOND +#define CONFIG_CMD_SF +#define CONFIG_SF_DEFAULT_SPEED 24000000 + + /* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ +#define PHYS_DRAM_1 0x80000000 /* DRAM Bank #1 */ +#define CONFIG_MAX_RAM_BANK_SIZE (1024 << 20) /* 1GB */ + +#define CONFIG_SYS_SDRAM_BASE PHYS_DRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (NON_SECURE_SRAM_END - \ + GENERATED_GBL_DATA_SIZE) + /* Platform/Board specific defs */ +#define CONFIG_SYS_TIMERBASE 0x48040000 /* Use Timer2 */ +#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_CONS_INDEX 1 +/* NS16550 Configuration */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SERIAL_MULTI +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK (48000000) +#define CONFIG_SYS_NS16550_COM1 0x44e09000 /* Base EVM has UART0 */ +#define CONFIG_SYS_NS16550_COM2 0x48022000 /* UART1 */ +#define CONFIG_SYS_NS16550_COM3 0x48024000 /* UART2 */ +#define CONFIG_SYS_NS16550_COM4 0x481a6000 /* UART3 */ +#define CONFIG_SYS_NS16550_COM5 0x481a8000 /* UART4 */ +#define CONFIG_SYS_NS16550_COM6 0x481aa000 /* UART5 */ + +/* I2C Configuration */ +#define CONFIG_I2C +#define CONFIG_CMD_I2C +#define CONFIG_HARD_I2C +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_DRIVER_OMAP24XX_I2C +#define CONFIG_CMD_EEPROM +#define CONFIG_ENV_EEPROM_IS_ON_I2C +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* Main EEPROM */ +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_I2C_MULTI_EEPROMS + +#define CONFIG_OMAP_GPIO + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 110, 300, 600, 1200, 2400, \ +4800, 9600, 14400, 19200, 28800, 38400, 56000, 57600, 115200 } + +#define CONFIG_ENV_OVERWRITE 1 +#define CONFIG_SYS_CONSOLE_INFO_QUIET + +#define CONFIG_ENV_IS_NOWHERE + +/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_TEXT_BASE 0x402F0400 +#define CONFIG_SPL_MAX_SIZE (101 * 1024) +#define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR + +#define CONFIG_SPL_BSS_START_ADDR 0x80000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ + +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 +#define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img" +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_GPIO_SUPPORT +#define CONFIG_SPL_YMODEM_SUPPORT +#define CONFIG_SPL_NET_SUPPORT +#define CONFIG_SPL_NET_VCI_STRING "AM335x U-Boot SPL" +#define CONFIG_SPL_ETH_SUPPORT +#define CONFIG_SPL_SPI_SUPPORT +#define CONFIG_SPL_SPI_FLASH_SUPPORT +#define CONFIG_SPL_SPI_LOAD +#define CONFIG_SPL_SPI_BUS 0 +#define CONFIG_SPL_SPI_CS 0 +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 +#define CONFIG_SYS_SPI_U_BOOT_SIZE 0x40000 +#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds" + +/* + * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM + * 64 bytes before this address should be set aside for u-boot.img's + * header. That is 0x800FFFC0--0x80100000 should not be used for any + * other needs. + */ +#define CONFIG_SYS_TEXT_BASE 0x80800000 +#define CONFIG_SYS_SPL_MALLOC_START 0x80208000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 + +/* Since SPL did pll and ddr initialization for us, + * we don't need to do it twice. + */ +#ifndef CONFIG_SPL_BUILD +#define CONFIG_SKIP_LOWLEVEL_INIT +#endif + +/* + * USB configuration + */ +#define CONFIG_USB_MUSB_DSPS +#define CONFIG_ARCH_MISC_INIT +#define CONFIG_MUSB_GADGET +#define CONFIG_MUSB_PIO_ONLY +#define CONFIG_USB_GADGET_DUALSPEED +#define CONFIG_MUSB_HOST +#define CONFIG_AM335X_USB0 +#define CONFIG_AM335X_USB0_MODE MUSB_PERIPHERAL +#define CONFIG_AM335X_USB1 +#define CONFIG_AM335X_USB1_MODE MUSB_HOST + +#ifdef CONFIG_MUSB_HOST +#define CONFIG_CMD_USB +#define CONFIG_USB_STORAGE +#endif + +#ifdef CONFIG_MUSB_GADGET +#define CONFIG_USB_ETHER +#define CONFIG_USB_ETH_RNDIS +#endif /* CONFIG_MUSB_GADGET */ + +/* Unsupported features */ +#undef CONFIG_USE_IRQ + +#define CONFIG_CMD_NET +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_DRIVER_TI_CPSW +#define CONFIG_MII +#define CONFIG_BOOTP_DEFAULT +#define CONFIG_BOOTP_DNS +#define CONFIG_BOOTP_DNS2 +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_SUBNETMASK +#define CONFIG_NET_RETRY_COUNT 10 +#define CONFIG_NET_MULTI +#define CONFIG_PHY_GIGE +#define CONFIG_PHYLIB +#define CONFIG_PHY_SMSC + +#endif /* ! __CONFIG_PCM051_H */
Dear Lars,
In message 1357663926-15937-2-git-send-email-larsi@wh2.tu-dresden.de you wrote: ...
Please add an entry to the MAINTAINERS file.
Also, please run your patch through checkpatch - it complains about a number of style errors:
WARNING: Whitespace before semicolon
Is this really correct? 303 ??
- struct rtc_regs *rtc = (struct rtc_regs *)AM335X_RTC_BASE;
- writel(0x83e70b13, &rtc->kick0r);
- writel(0x95a4f1e0, &rtc->kick1r);
These magic numbers should probbly be moved to some header file ?
- /* WDT1 is already running when the bootloader gets control
Incorrect multiline comment style.
- writel(0xAAAA, &wdtimer->wdtwspr);
More hard-wired magic values?
- while (readl(&wdtimer->wdtwwps) != 0x0)
No timeout?
- writel(0x5555, &wdtimer->wdtwspr);
No timeout?
- while ((readl(&uart_base->uartsyssts) &
Braces needed for multiline statement.
+} +#endif
Do you plan to use this? Otherwise please just omit such dead code.
- /* VTP can be added here */
- return;
Ditto...
- if (!eth_getenv_enetaddr("ethaddr", mac_addr)) {
This should be a printf(). Any such automatic changes are always worth to be told explicitly.
goto try_usbether;
Did you ever try building without CONFIG_DRIVER_TI_CPSW set? I bet this causes a few compiler warnings. [Hint: You define a label, but don't use it anywhere.]
Does this really make sense? I doubt you will ever need more than 10% of this size - so you are just wasting a lot of time for checksumming unused memory...
Please do not define values for logical variables like this one; please fix globally.
Really?
Thanks!
Hello Wolfgang,
thank you for your fast review!
I am quite sure, I read this in a datasheet, but I can not find it anymore. I set this to 333 now. mtest still works.
- return;
Ditto...
The cpsw driver needs a control function, otherwise the board crashes when network initializes. On my board this is empty like on am335x_evm.
Fix globally ? Do you mean, I have to fix that for EVERY board that is in u- boot, that defines CONFIG_ENV_OVERWRITE with a value to get my patch in? There are a number of boards doing this wrong!
Really?
Uuhm. Yes. At the moment I use this uEnv.txt file on sd-card, as I am not able to use the NAND yet. The env should go to nand later.
Thanks for the other hints you gave. I will address this and send a version 2 soon.
Regards, Lars
On Tue, Jan 08, 2013 at 07:58:37PM +0100, Wolfgang Denk wrote:
Dear Lars,
Yes, it's really correct.
This is a copy/paste from the am335x board.c file. I specifically did a long comment to explain what / where these values come from because that (to me) is more helpful than #define AM33X_RTC_KICK0R_KEY 0x... #define AM33X_RTC_KICK1R_KEY 0x...
[snip]
No timeout?
No. I argued with Marek about some of these before too. In short, if we don't suceed here, there's a catastrophic failure of the hardware.
This is the normal case of asking the hardware what MAC it shipped with. Why do we want to tell the user the expected has happened?
goto try_usbether;
It's a valid question if this board uses the CPSW eth or not, yes.
ENV stored in NAND with page size of 128KiB is probably the reason for this.
Really?
Until they add NAND (which just now hit mainline), yes.
Hi Wolfgang, hi Tom,
as I almost have the changes requested by Wolfgang in place, you two can choose, which version I should resubmit. ;)
Am 09.01.2013 um 20:34 schrieb Tom Rini:
davinci does it this way. I would prefer Tom's variant having the values right in place.
Here I'd prefer the printf variant, because for a common user it is not obivous, that it is reading the MAC from efuse. So this message is helpful.
goto try_usbether;
Yes, the board uses CPSW, but here I would prefer having the try_usbether label inside the ifdef.
Really?
This is a very valuable information, thanks!
Regards, Lars
[snip]
OK, please also patch board/ti/am335x/board.c to also printf here then. Other than that, yes, I'd be happy to see you make the other changes you said. Just partially trying to help explain the SoC to Wolfgang :)
Lars Poeschel
Lars Poeschel
