[U-Boot] [PATCH][v2] driver/nand: Add support of 16K SRAM for IFC 2.0
Internal SRAM has been incresed from 8KB to 16KB for IFC cotroller ver 2.0.
Update the page offset calculation logic to support the same.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Changes for v2: rebased the patch
drivers/mtd/nand/fsl_ifc_nand.c | 25 +++++++++++++++++++++++++ 1 file changed, 25 insertions(+)
diff --git a/drivers/mtd/nand/fsl_ifc_nand.c b/drivers/mtd/nand/fsl_ifc_nand.c index 280e14e..fd5f536 100644 --- a/drivers/mtd/nand/fsl_ifc_nand.c +++ b/drivers/mtd/nand/fsl_ifc_nand.c @@ -24,6 +24,7 @@ #endif
#define FSL_IFC_V1_1_0 0x01010000 +#define FSL_IFC_V2_0_0 0x02000000 #define MAX_BANKS CONFIG_SYS_FSL_IFC_BANK_COUNT #define ERR_BYTE 0xFF /* Value returned for read bytes when read failed */ @@ -1040,6 +1041,30 @@ static int fsl_ifc_chip_init(int devnum, u8 *addr) if (ret) return ret;
+ if (ver >= FSL_IFC_V2_0_0) { + switch (csor & CSOR_NAND_PGS_MASK) { + case CSOR_NAND_PGS_512: + priv->bufnum_mask = 31; + break; + + case CSOR_NAND_PGS_2K: + priv->bufnum_mask = 7; + break; + + case CSOR_NAND_PGS_4K: + priv->bufnum_mask = 3; + break; + + case CSOR_NAND_PGS_8K: + priv->bufnum_mask = 1; + break; + + default: + printf("ifc nand: bad csor %#x: bad page size\n", csor); + return -ENODEV; + } + } + ret = nand_scan_ident(mtd, 1, NULL); if (ret) return ret;
- if (ver >= FSL_IFC_V2_0_0) {
break;
break;
break;
break;
Whitespace
Instead of this, how about:
if (ver >= FSL_IFC_V2_0_0) priv->bufnum_mask = (priv->bufnum_mask * 2) + 1;
-Scott
Prabhakar Kushwaha
Scott Wood
