[U-Boot] [PATCH] 85xx: Remove unused CONFIG_ASSUME_AMD_FLASH from config files
A bunch of the 85xx boards have this cruft in them - it's not used anywhere. Delete it.
Signed-off-by: Becky Bruce beckyb@kernel.crashing.org --- include/configs/MPC8536DS.h | 7 ------- include/configs/MPC8541CDS.h | 7 ------- include/configs/MPC8544DS.h | 7 ------- include/configs/MPC8548CDS.h | 7 ------- include/configs/MPC8555CDS.h | 7 ------- include/configs/MPC8568MDS.h | 7 ------- include/configs/MPC8569MDS.h | 7 ------- include/configs/MPC8572DS.h | 7 ------- include/configs/P2020DS.h | 7 ------- 9 files changed, 0 insertions(+), 63 deletions(-)
diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index a847275..46d6e9d 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -70,13 +70,6 @@ #define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_ENV_OVERWRITE
-/* - * When initializing flash, if we cannot find the manufacturer ID, - * assume this is the AMD flash associated with the CDS board. - * This allows booting from a promjet. - */ -#define CONFIG_ASSUME_AMD_FLASH - #ifndef __ASSEMBLY__ extern unsigned long get_board_sys_clk(unsigned long dummy); extern unsigned long get_board_ddr_clk(unsigned long dummy); diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index a8f206f..f41fe30 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -46,13 +46,6 @@
#define CONFIG_FSL_VIA
-/* - * When initializing flash, if we cannot find the manufacturer ID, - * assume this is the AMD flash associated with the CDS board. - * This allows booting from a promjet. - */ -#define CONFIG_ASSUME_AMD_FLASH - #ifndef __ASSEMBLY__ extern unsigned long get_clock_freq(void); #endif diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index 0caf456..b7d3553 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -50,13 +50,6 @@ #define CONFIG_ENV_OVERWRITE #define CONFIG_INTERRUPTS /* enable pci, srio, ddr interrupts */
-/* - * When initializing flash, if we cannot find the manufacturer ID, - * assume this is the AMD flash associated with the CDS board. - * This allows booting from a promjet. - */ -#define CONFIG_ASSUME_AMD_FLASH - #ifndef __ASSEMBLY__ extern unsigned long get_board_sys_clk(unsigned long dummy); #endif diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index e69ba90..53de56d 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -52,13 +52,6 @@
-/* - * When initializing flash, if we cannot find the manufacturer ID, - * assume this is the AMD flash associated with the CDS board. - * This allows booting from a promjet. - */ -#define CONFIG_ASSUME_AMD_FLASH - #ifndef __ASSEMBLY__ extern unsigned long get_clock_freq(void); #endif diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index 94952dc..abbfd47 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -46,13 +46,6 @@ #define CONFIG_FSL_VIA
-/* - * When initializing flash, if we cannot find the manufacturer ID, - * assume this is the AMD flash associated with the CDS board. - * This allows booting from a promjet. - */ -#define CONFIG_ASSUME_AMD_FLASH - #ifndef __ASSEMBLY__ extern unsigned long get_clock_freq(void); #endif diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index 7b8c6c7..426b933 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -44,13 +44,6 @@ #define CONFIG_ENV_OVERWRITE #define CONFIG_FSL_LAW 1 /* Use common FSL init code */
-/* - * When initializing flash, if we cannot find the manufacturer ID, - * assume this is the AMD flash associated with the MDS board. - * This allows booting from a promjet. - */ -#define CONFIG_ASSUME_AMD_FLASH - #ifndef __ASSEMBLY__ extern unsigned long get_clock_freq(void); #endif /*Replace a call to get_clock_freq (after it is implemented)*/ diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index 17ea3bb..b87f375 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -44,13 +44,6 @@ #define CONFIG_ENV_OVERWRITE #define CONFIG_FSL_LAW 1 /* Use common FSL init code */
-/* - * When initializing flash, if we cannot find the manufacturer ID, - * assume this is the AMD flash associated with the MDS board. - * This allows booting from a promjet. - */ -#define CONFIG_ASSUME_AMD_FLASH - #ifndef __ASSEMBLY__ extern unsigned long get_clock_freq(void); #endif diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 000f8f6..0e7745c 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -53,13 +53,6 @@ #define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_ENV_OVERWRITE
-/* - * When initializing flash, if we cannot find the manufacturer ID, - * assume this is the AMD flash associated with the CDS board. - * This allows booting from a promjet. - */ -#define CONFIG_ASSUME_AMD_FLASH - #ifndef __ASSEMBLY__ extern unsigned long get_board_sys_clk(unsigned long dummy); extern unsigned long get_board_ddr_clk(unsigned long dummy); diff --git a/include/configs/P2020DS.h b/include/configs/P2020DS.h index b48c199..9574fca 100644 --- a/include/configs/P2020DS.h +++ b/include/configs/P2020DS.h @@ -54,13 +54,6 @@ #define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_ENV_OVERWRITE
-/* - * When initializing flash, if we cannot find the manufacturer ID, - * assume this is the AMD flash associated with the CDS board. - * This allows booting from a promjet. - */ -#define CONFIG_ASSUME_AMD_FLASH - #ifndef __ASSEMBLY__ extern unsigned long calculate_board_sys_clk(unsigned long dummy); extern unsigned long calculate_board_ddr_clk(unsigned long dummy);
applied to 85xx next branch.
- k
Dear Becky Bruce,
In message 1257381008-18020-1-git-send-email-beckyb@kernel.crashing.org you wrote:
Applied, thanks.
Andy/Kumar: I hope it's OK with you that I take this directky.
On Dec 2, 2009, at 3:58 PM, Wolfgang Denk wrote:
Dear Becky Bruce,
In message <1257381008-18020-1-git-send-email-beckyb@kernel.crashing.org
you wrote: A bunch of the 85xx boards have this cruft in them - it's not used anywhere. Delete it.
Applied, thanks.
no issue, will drop it from my 'next' branch.
- k
Dear Kumar Gala,
In message BAE42E61-5B62-49D6-BC87-0054CA198125@kernel.crashing.org you wrote:
You don't really have to - git will sort this out.
Becky Bruce
Kumar Gala
