[U-Boot-Users] Re: [patch] add support for AMD Alchemy Pb1x00 boards to u-boot-1.1.2
In message 1106244186.8838.23.camel@kronenbourg.scs.ch you wrote:
Here's a patch to support AMD's Pb1x00 eval board, based on the Dbau1x00 support. I've tested it by loading it into the board SDRAM.
Added, thanks.
I've also fixed the mii and usb commands which can dereference a null pointer when called without arguments.
No, this is not possible. The command definition requires always at least one argument. This part rejected.
Furthermore, I added mii routines to the au1x00 ethernet driver.
Added, thanks.
And I had to add the objects as explicit target in the examples makefile, to avoid the use of a builtin make rule that goes directly from source to executable without going through the object files.
Fixed in the meantime.
Note that the usb ohci driver doesn't yet work for me. Root hub seems to work, but any data transfer from a device fails. On the other hand, current linux mips 2.6 hangs when I load the ohci driver, so it doesn't work there too.
Added as is. I understand you will fix this eventually?
Btw, it seems to me that the Dbau1x00 port sets up the auxilliary PLL way too fast.
Please read the Conding Style guidelines. Your patch violates several of the rules (indentation, trailing white space, // comments).
I beg to differ - I've seen this problem also. The code in main.c:run_command() checks for more than more than a maximum but never checks a minimum number of arguments, so entering mii<CR> makes cmd_mii get called with argv[0] = 'mii' and argc = 1. main.c:parse_line() sets argv[1] to NULL.
The code in cmd_mii.c assumes there will be a valid argv[1], but never checks argc before using argv[1]. This leads to an exception on machines where 0 is not a valid address (like MIPS).
-- Hardware, n.: The parts of a computer system that can be kicked.
Andrew Dyer
