[U-Boot] [PATCH] net: phy/cortina: Add four phy addresses support
Before CORTINA driver only supports two phy addresses. This patch adds the four phy addresses support for CORTINA PHY module.
Signed-off-by: Chunhe Lan Chunhe.Lan@freescale.com --- drivers/net/phy/cortina.c | 28 ++++++++++++++++++++++------ 1 files changed, 22 insertions(+), 6 deletions(-)
diff --git a/drivers/net/phy/cortina.c b/drivers/net/phy/cortina.c index 7e46679..1b9434f 100644 --- a/drivers/net/phy/cortina.c +++ b/drivers/net/phy/cortina.c @@ -289,25 +289,41 @@ int phy_cortina_init(void) int get_phy_id(struct mii_dev *bus, int addr, int devad, u32 *phy_id) { int phy_reg; + bool cortina_phy = false; + + switch (addr) { +#ifdef CORTINA_PHY_ADDR1 + case CORTINA_PHY_ADDR1: +#endif +#ifdef CORTINA_PHY_ADDR2 + case CORTINA_PHY_ADDR2: +#endif +#ifdef CORTINA_PHY_ADDR3 + case CORTINA_PHY_ADDR3: +#endif +#ifdef CORTINA_PHY_ADDR4 + case CORTINA_PHY_ADDR4: +#endif + cortina_phy = true; + break; + default: + break; + }
-#if defined(CORTINA_PHY_ADDR1) || defined(CORTINA_PHY_ADDR2) /* Cortina PHY has non-standard offset of PHY ID registers */ - if (addr == CORTINA_PHY_ADDR1 || addr == CORTINA_PHY_ADDR2) + if (cortina_phy) phy_reg = bus->read(bus, addr, 0, VILLA_GLOBAL_CHIP_ID_LSB); else -#endif phy_reg = bus->read(bus, addr, devad, MII_PHYSID1);
if (phy_reg < 0) return -EIO;
*phy_id = (phy_reg & 0xffff) << 16; -#if defined(CORTINA_PHY_ADDR1) || defined(CORTINA_PHY_ADDR2) /* Cortina PHY has non-standard offset of PHY ID registers */ - if (addr == CORTINA_PHY_ADDR1 || addr == CORTINA_PHY_ADDR2) + if (cortina_phy) phy_reg = bus->read(bus, addr, 0, VILLA_GLOBAL_CHIP_ID_MSB); else -#endif phy_reg = bus->read(bus, addr, devad, MII_PHYSID2);
if (phy_reg < 0)
Chunhe,
Does this patch depend on other patches? I don't see cortina.c file.
York
Chunhe,
Looks like you have this patch consolidated into this one http://patchwork.ozlabs.org/patch/350162/.
Please confirm so we can drop this.
York
Chunhe Lan
York Sun
