Pull request efi-2024-01-rc2
Dear Tom,
The following changes since commit 5cab3515f8c9796015739c1750b8933291c816be:
Merge tag 'u-boot-rockchip-20231024' of https://source.denx.de/u-boot/custodians/u-boot-rockchip (2023-10-24 09:39:52 -0400)
https://source.denx.de/u-boot/custodians/u-boot-efi.git tags/efi-2024-01-rc2
for you to fetch changes up to 916dad34af0e53181dfe21f5764d3a787cb24bdc:
efi_loader: fix EFI_ENTRY point on get_active_pcr_banks (2023-10-24 23:56:43 +0200)
Gitlab CI showed no issues: https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/18293
---------------------------------------------------------------- Pull request efi-2024-01-rc2
Documentation:
* Bump urllib3 version * Replace references to dm_dump_all() with dm_dump_tree() * Update description of build dependencies for Alpine Linux * Fix typo in gpt example * Fix ordering of shell commands
UEFI:
* Fix build failure without network * Expose the device-tree file name as UEFI variable * Move misplace EFI_ENTRY macro.
---------------------------------------------------------------- Dylan Corrales (1): doc: Replace dm_dump_all() with dm_dump_tree()
Heinrich Schuchardt (2): efi_loader: fix efi_dp_from_eth efi_loader: expose the device-tree file name
Ilias Apalodimas (1): efi_loader: fix EFI_ENTRY point on get_active_pcr_banks
Milan P. Stanić (1): doc: build: update description of build dependencies for Alpine Linux
Tom Fitzhenry (2): doc: gpt: fix example of echoing variable doc: usage: fix ordering of shell commands
Tom Rini (1): sphinx: Bump urllib3 version
doc/build/gcc.rst | 10 ++++++++-- doc/develop/driver-model/debugging.rst | 2 +- doc/develop/uefi/uefi.rst | 14 ++++++++++++++ doc/sphinx/requirements.txt | 2 +- doc/usage/cmd/gpt.rst | 5 +++-- doc/usage/index.rst | 8 ++++---- include/efi_loader.h | 5 +++++ lib/efi_loader/efi_device_path.c | 5 ++++- lib/efi_loader/efi_setup.c | 30 ++++++++++++++++++++++++++++++ lib/efi_loader/efi_tcg2.c | 3 ++- 10 files changed, 72 insertions(+), 12 deletions(-)
On Wed, Oct 25, 2023 at 04:20:06AM +0200, Heinrich Schuchardt wrote:
Dear Tom,
So, there's not been enough time for "efi_loader: expose the device-tree file name" as there's still comments on how to word things there (and I'm fine taking this eventually for the release, we don't need it today). And since we're here anyways, "efi_loader: fix efi_dp_from_eth" isn't needed as with "sandbox: eliminate unused functions from binaries" we can build sandbox with EFI_LOADER=y NET=n LTO=n (and CMDLINE=n with the rest of my v4 + an unrelated to this fix for fastboot) and since I'm asking for changes anyhow, lets just drop this. Thanks.
Dear Tom,
You and Ilias marked this patch as reviewed.
Which comments should I look at?
I am fine with dropping the patch. Will you be moving that sandbox patch?
Best regards
Heinrich
Dear Tom,
Well, Simons that you replied to now, and my follow-up.
As yes, I did RB it, but I also didn't expect it to be merged a day after posting since it's not a critical security fix. Most changes should sit on the list for a few days at least, to give people a chance to read and comment. I thought it was good enough at first but on reading what Simon said (and this is a thing I will do as I read a longer thread I hadn't seen at first) I changed my mind a bit, and noticed something else too.
Yes, the gc-sections patch will be merged, Simon and I talked off-list about it more.
