[U-Boot] [PATCH] sunxi: fix build error on non-ARM64 boards
The previous commit which disables Pine64 detection logic on non-Pine64 board has an error and prevents non-ARM64 boards from building.
Fix the build error on non-ARM64 boards by adjusting the position of a '}'.
Fixes: 6b92e01dca4b ("sunxi: disable Pine A64 model detection code on other boards") Signed-off-by: Icenowy Zheng icenowy@aosc.io --- board/sunxi/board.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 65ae0c4219..b196d48674 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -877,5 +877,5 @@ int board_fit_config_name_match(const char *name) } #endif return strcmp(name, cmp_str); -#endif } +#endif
Acked-by: Maxime Ripard maxime.ripard@bootlin.com
Maxime
I would have run buildman, it my bad. anyway I squashed it, thanks!
Icenowy Zheng
Jagan Teki
Maxime Ripard
