[U-Boot] [PATCH] doc: Fix statements on case sensitivity for regulator prefix
The regulator bindings state that regulator prefixes are allowd to be in upper or lower case. However pmic_bind_children from pmic_uclass uses strncmp to compare DT node name against prefix. This comparison is case sensitive hence the regulator driver prefix case matters.
Signed-off-by: Felix Brack fb@ltec.ch ---
doc/device-tree-bindings/regulator/regulator.txt | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/doc/device-tree-bindings/regulator/regulator.txt b/doc/device-tree-bindings/regulator/regulator.txt index 2cf4b9d..918711e 100644 --- a/doc/device-tree-bindings/regulator/regulator.txt +++ b/doc/device-tree-bindings/regulator/regulator.txt @@ -10,10 +10,10 @@ pmic: drivers/power/pmic/max77686.c regulator: drivers/power/regulator/max77686.c
For the node name e.g.: "prefix[:alpha:]num { ... }": -- the driver prefix should be: "prefix" or "PREFIX" - case insensitive +- the driver prefix should be: "prefix" - case sensitive - the node name's "num" is set as "dev->driver_data" on bind
-Example the prefix "ldo" will pass for: "ldo1", "ldo@1", "LDO1", "LDOREG@1"... +Example the prefix "ldo" will pass for: "ldo1", "ldo@1", "ldoreg@1, ...
Optional properties: - regulator-name: a string, required by the regulator uclass
Felix Brack
