[U-Boot] [PATCH] common: fdt_support: Remove check for mtdparts in fdt_fixup_mtdparts
fdt_fixup_mtdparts currently does nothing when partitin info is runtime generated or compiled-in defaults are used.
Signed-off-by: Ladislav Michl ladis@linux-mips.org --- common/fdt_support.c | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index c9f7019e38..a57a5759e4 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -903,14 +903,9 @@ void fdt_fixup_mtdparts(void *blob, void *node_info, int node_info_size) { struct node_info *ni = node_info; struct mtd_device *dev; - char *parts; int i, idx; int noff;
- parts = getenv("mtdparts"); - if (!parts) - return; - if (mtdparts_init() != 0) return;
Fixed commit message nits and
Applied to u-boot-dm, thanks!
Ladislav Michl
