[U-Boot] [PATCH REPOST] usb: create common header virtual root hub descriptors
Many USB host controller drivers contain almost identical copies of the same virtual root hub descriptors. Put these into a common file to avoid duplication.
Note that there were some very minor differences between the descriptors in the various files, such as:
- USB 1.0 vs. USB 1.1 - Manufacturer/Device ID - Max packet size - String content
I assume these aren't relevant.
Cc: Thomas Lange thomas@corelatus.se Cc: Shinya Kuribayashi skuribay@pobox.com Cc: Gary Jennejohn garyj@denx.de Cc: Wolfgang Denk wd@denx.de Cc: Eric Millbrandt emillbrandt@coldhaus.com Cc: Pierre Aubert p.aubert@staubli.com Cc: Stefan Roese sr@denx.de Cc: Daniel Hellstrom daniel@gaisler.com Cc: Denis Peter d.peter@mpl.ch Cc: Rodolfo Giometti giometti@linux.it Cc: Zhang Wei wei.zhang@freescale.com Cc: Mateusz Zalega m.zalega@samsung.com Cc: Remy Bohmer linux@bohmer.net Cc: Markus Klotzbuecher mk@denx.de Cc: Minkyu Kang mk7.kang@samsung.com Cc: Gary Jennejohn garyj@denx.de Cc: C Nauman cnauman@diagraph.com Cc: David Müller d.mueller@elsoft.ch Cc: Yoshihiro Shimoda shimoda.yoshihiro@renesas.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org Cc: Thomas Abraham t-abraham@ti.com Cc: Tom Rini trini@ti.com Cc: Andrew Murray amurray@embedded-bits.co.uk Cc: Matej Frančeškin matej.franceskin@comtrade.com Cc: Cliff Cai cliff.cai@analog.com Cc: Bryan Wu cooloney@gmail.com Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- Repost: Marek asked me to resend this Cc to the maintainers of the various edited files. If you're CC'd, could you please check that the minor differences in the descriptor content between the new header and your driver isn't going to be an issue. It's pretty unclear who the maintainer is for many of the files, so I've had to cast a fairly wide net... --- arch/mips/cpu/mips32/au1x00/au1x00_usb_ohci.c | 99 +------------------- arch/powerpc/cpu/mpc5xxx/usb_ohci.c | 99 +------------------- arch/powerpc/cpu/ppc4xx/usb_ohci.c | 99 +------------------- arch/sparc/cpu/leon3/usb_uhci.c | 107 +-------------------- board/mpl/common/usb_uhci.c | 115 +---------------------- drivers/usb/host/isp116x-hcd.c | 100 +------------------- drivers/usb/host/ohci-hcd.c | 98 +------------------ drivers/usb/host/ohci-s3c24xx.c | 95 +------------------ drivers/usb/host/r8a66597-hcd.c | 104 +-------------------- drivers/usb/musb/musb_hcd.c | 93 +------------------ include/usbroothubdes.h | 129 ++++++++++++++++++++++++++ 11 files changed, 143 insertions(+), 995 deletions(-) create mode 100644 include/usbroothubdes.h
diff --git a/arch/mips/cpu/mips32/au1x00/au1x00_usb_ohci.c b/arch/mips/cpu/mips32/au1x00/au1x00_usb_ohci.c index fd0ec65..a3dac70 100644 --- a/arch/mips/cpu/mips32/au1x00/au1x00_usb_ohci.c +++ b/arch/mips/cpu/mips32/au1x00/au1x00_usb_ohci.c @@ -839,104 +839,7 @@ static int dl_done_list (ohci_t *ohci, td_t *td_list) * Virtual Root Hub *-------------------------------------------------------------------------*/
-/* Device descriptor */ -static __u8 root_hub_dev_des[] = -{ - 0x12, /* __u8 bLength; */ - 0x01, /* __u8 bDescriptorType; Device */ - 0x10, /* __u16 bcdUSB; v1.1 */ - 0x01, - 0x09, /* __u8 bDeviceClass; HUB_CLASSCODE */ - 0x00, /* __u8 bDeviceSubClass; */ - 0x00, /* __u8 bDeviceProtocol; */ - 0x08, /* __u8 bMaxPacketSize0; 8 Bytes */ - 0x00, /* __u16 idVendor; */ - 0x00, - 0x00, /* __u16 idProduct; */ - 0x00, - 0x00, /* __u16 bcdDevice; */ - 0x00, - 0x00, /* __u8 iManufacturer; */ - 0x01, /* __u8 iProduct; */ - 0x00, /* __u8 iSerialNumber; */ - 0x01 /* __u8 bNumConfigurations; */ -}; - - -/* Configuration descriptor */ -static __u8 root_hub_config_des[] = -{ - 0x09, /* __u8 bLength; */ - 0x02, /* __u8 bDescriptorType; Configuration */ - 0x19, /* __u16 wTotalLength; */ - 0x00, - 0x01, /* __u8 bNumInterfaces; */ - 0x01, /* __u8 bConfigurationValue; */ - 0x00, /* __u8 iConfiguration; */ - 0x40, /* __u8 bmAttributes; - Bit 7: Bus-powered, 6: Self-powered, 5 Remote-wakwup, 4..0: resvd */ - 0x00, /* __u8 MaxPower; */ - - /* interface */ - 0x09, /* __u8 if_bLength; */ - 0x04, /* __u8 if_bDescriptorType; Interface */ - 0x00, /* __u8 if_bInterfaceNumber; */ - 0x00, /* __u8 if_bAlternateSetting; */ - 0x01, /* __u8 if_bNumEndpoints; */ - 0x09, /* __u8 if_bInterfaceClass; HUB_CLASSCODE */ - 0x00, /* __u8 if_bInterfaceSubClass; */ - 0x00, /* __u8 if_bInterfaceProtocol; */ - 0x00, /* __u8 if_iInterface; */ - - /* endpoint */ - 0x07, /* __u8 ep_bLength; */ - 0x05, /* __u8 ep_bDescriptorType; Endpoint */ - 0x81, /* __u8 ep_bEndpointAddress; IN Endpoint 1 */ - 0x03, /* __u8 ep_bmAttributes; Interrupt */ - 0x02, /* __u16 ep_wMaxPacketSize; ((MAX_ROOT_PORTS + 1) / 8 */ - 0x00, - 0xff /* __u8 ep_bInterval; 255 ms */ -}; - -static unsigned char root_hub_str_index0[] = -{ - 0x04, /* __u8 bLength; */ - 0x03, /* __u8 bDescriptorType; String-descriptor */ - 0x09, /* __u8 lang ID */ - 0x04, /* __u8 lang ID */ -}; - -static unsigned char root_hub_str_index1[] = -{ - 28, /* __u8 bLength; */ - 0x03, /* __u8 bDescriptorType; String-descriptor */ - 'O', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'H', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'C', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'I', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - ' ', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'R', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'o', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'o', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 't', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - ' ', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'H', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'u', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'b', /* __u8 Unicode */ - 0, /* __u8 Unicode */ -}; +#include <usbroothubdes.h>
/* Hub class-specific descriptor is constructed dynamically */
diff --git a/arch/powerpc/cpu/mpc5xxx/usb_ohci.c b/arch/powerpc/cpu/mpc5xxx/usb_ohci.c index a68f9d6..3c8b2d9 100644 --- a/arch/powerpc/cpu/mpc5xxx/usb_ohci.c +++ b/arch/powerpc/cpu/mpc5xxx/usb_ohci.c @@ -842,104 +842,7 @@ static int dl_done_list (ohci_t *ohci, td_t *td_list) * Virtual Root Hub *-------------------------------------------------------------------------*/
diff --git a/arch/powerpc/cpu/ppc4xx/usb_ohci.c b/arch/powerpc/cpu/ppc4xx/usb_ohci.c index fafc15e..d1e78f6 100644 --- a/arch/powerpc/cpu/ppc4xx/usb_ohci.c +++ b/arch/powerpc/cpu/ppc4xx/usb_ohci.c @@ -847,104 +847,7 @@ static int dl_done_list (ohci_t *ohci, td_t *td_list) * Virtual Root Hub *-------------------------------------------------------------------------*/
diff --git a/arch/sparc/cpu/leon3/usb_uhci.c b/arch/sparc/cpu/leon3/usb_uhci.c index c411ded..ca7d6e8 100644 --- a/arch/sparc/cpu/leon3/usb_uhci.c +++ b/arch/sparc/cpu/leon3/usb_uhci.c @@ -757,110 +757,9 @@ static void usb_display_Req(unsigned short req) } #endif
-static unsigned char root_hub_dev_des[] = { - 0x12, /* __u8 bLength; */ - 0x01, /* __u8 bDescriptorType; Device */ - 0x00, /* __u16 bcdUSB; v1.0 */ - 0x01, - 0x09, /* __u8 bDeviceClass; HUB_CLASSCODE */ - 0x00, /* __u8 bDeviceSubClass; */ - 0x00, /* __u8 bDeviceProtocol; */ - 0x08, /* __u8 bMaxPacketSize0; 8 Bytes */ - 0x00, /* __u16 idVendor; */ - 0x00, - 0x00, /* __u16 idProduct; */ - 0x00, - 0x00, /* __u16 bcdDevice; */ - 0x00, - 0x01, /* __u8 iManufacturer; */ - 0x00, /* __u8 iProduct; */ - 0x00, /* __u8 iSerialNumber; */ - 0x01 /* __u8 bNumConfigurations; */ -}; - -/* Configuration descriptor */ -static unsigned char root_hub_config_des[] = { - 0x09, /* __u8 bLength; */ - 0x02, /* __u8 bDescriptorType; Configuration */ - 0x19, /* __u16 wTotalLength; */ - 0x00, - 0x01, /* __u8 bNumInterfaces; */ - 0x01, /* __u8 bConfigurationValue; */ - 0x00, /* __u8 iConfiguration; */ - 0x40, /* __u8 bmAttributes; - Bit 7: Bus-powered, 6: Self-powered, 5 Remote-wakwup, 4..0: resvd */ - 0x00, /* __u8 MaxPower; */ - - /* interface */ - 0x09, /* __u8 if_bLength; */ - 0x04, /* __u8 if_bDescriptorType; Interface */ - 0x00, /* __u8 if_bInterfaceNumber; */ - 0x00, /* __u8 if_bAlternateSetting; */ - 0x01, /* __u8 if_bNumEndpoints; */ - 0x09, /* __u8 if_bInterfaceClass; HUB_CLASSCODE */ - 0x00, /* __u8 if_bInterfaceSubClass; */ - 0x00, /* __u8 if_bInterfaceProtocol; */ - 0x00, /* __u8 if_iInterface; */ - - /* endpoint */ - 0x07, /* __u8 ep_bLength; */ - 0x05, /* __u8 ep_bDescriptorType; Endpoint */ - 0x81, /* __u8 ep_bEndpointAddress; IN Endpoint 1 */ - 0x03, /* __u8 ep_bmAttributes; Interrupt */ - 0x08, /* __u16 ep_wMaxPacketSize; 8 Bytes */ - 0x00, - 0xff /* __u8 ep_bInterval; 255 ms */ -}; - -static unsigned char root_hub_hub_des[] = { - 0x09, /* __u8 bLength; */ - 0x29, /* __u8 bDescriptorType; Hub-descriptor */ - 0x02, /* __u8 bNbrPorts; */ - 0x00, /* __u16 wHubCharacteristics; */ - 0x00, - 0x01, /* __u8 bPwrOn2pwrGood; 2ms */ - 0x00, /* __u8 bHubContrCurrent; 0 mA */ - 0x00, /* __u8 DeviceRemovable; *** 7 Ports max *** */ - 0xff /* __u8 PortPwrCtrlMask; *** 7 ports max *** */ -}; - -static unsigned char root_hub_str_index0[] = { - 0x04, /* __u8 bLength; */ - 0x03, /* __u8 bDescriptorType; String-descriptor */ - 0x09, /* __u8 lang ID */ - 0x04, /* __u8 lang ID */ -}; - -static unsigned char root_hub_str_index1[] = { - 28, /* __u8 bLength; */ - 0x03, /* __u8 bDescriptorType; String-descriptor */ - 'U', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'H', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'C', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'I', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - ' ', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'R', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'o', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'o', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 't', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - ' ', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'H', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'u', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'b', /* __u8 Unicode */ - 0, /* __u8 Unicode */ -}; +#define WANT_USB_ROOT_HUB_HUB_DES +#include <usbroothubdes.h> +#undef WANT_USB_ROOT_HUB_HUB_DES
/* * Root Hub Control Pipe (interrupt Pipes are not supported) diff --git a/board/mpl/common/usb_uhci.c b/board/mpl/common/usb_uhci.c index 6bbb527..5590be1 100644 --- a/board/mpl/common/usb_uhci.c +++ b/board/mpl/common/usb_uhci.c @@ -640,118 +640,9 @@ static void usb_display_wValue(unsigned short wValue,unsigned short wIndex) {} static void usb_display_Req(unsigned short req) {} #endif
-static unsigned char root_hub_dev_des[] = -{ - 0x12, /* __u8 bLength; */ - 0x01, /* __u8 bDescriptorType; Device */ - 0x00, /* __u16 bcdUSB; v1.0 */ - 0x01, - 0x09, /* __u8 bDeviceClass; HUB_CLASSCODE */ - 0x00, /* __u8 bDeviceSubClass; */ - 0x00, /* __u8 bDeviceProtocol; */ - 0x08, /* __u8 bMaxPacketSize0; 8 Bytes */ - 0x00, /* __u16 idVendor; */ - 0x00, - 0x00, /* __u16 idProduct; */ - 0x00, - 0x00, /* __u16 bcdDevice; */ - 0x00, - 0x01, /* __u8 iManufacturer; */ - 0x00, /* __u8 iProduct; */ - 0x00, /* __u8 iSerialNumber; */ - 0x01 /* __u8 bNumConfigurations; */ -}; - - -/* Configuration descriptor */ -static unsigned char root_hub_config_des[] = -{ - 0x09, /* __u8 bLength; */ - 0x02, /* __u8 bDescriptorType; Configuration */ - 0x19, /* __u16 wTotalLength; */ - 0x00, - 0x01, /* __u8 bNumInterfaces; */ - 0x01, /* __u8 bConfigurationValue; */ - 0x00, /* __u8 iConfiguration; */ - 0x40, /* __u8 bmAttributes; - Bit 7: Bus-powered, 6: Self-powered, 5 Remote-wakwup, 4..0: resvd */ - 0x00, /* __u8 MaxPower; */ - - /* interface */ - 0x09, /* __u8 if_bLength; */ - 0x04, /* __u8 if_bDescriptorType; Interface */ - 0x00, /* __u8 if_bInterfaceNumber; */ - 0x00, /* __u8 if_bAlternateSetting; */ - 0x01, /* __u8 if_bNumEndpoints; */ - 0x09, /* __u8 if_bInterfaceClass; HUB_CLASSCODE */ - 0x00, /* __u8 if_bInterfaceSubClass; */ - 0x00, /* __u8 if_bInterfaceProtocol; */ - 0x00, /* __u8 if_iInterface; */ - - /* endpoint */ - 0x07, /* __u8 ep_bLength; */ - 0x05, /* __u8 ep_bDescriptorType; Endpoint */ - 0x81, /* __u8 ep_bEndpointAddress; IN Endpoint 1 */ - 0x03, /* __u8 ep_bmAttributes; Interrupt */ - 0x08, /* __u16 ep_wMaxPacketSize; 8 Bytes */ - 0x00, - 0xff /* __u8 ep_bInterval; 255 ms */ -}; - - -static unsigned char root_hub_hub_des[] = -{ - 0x09, /* __u8 bLength; */ - 0x29, /* __u8 bDescriptorType; Hub-descriptor */ - 0x02, /* __u8 bNbrPorts; */ - 0x00, /* __u16 wHubCharacteristics; */ - 0x00, - 0x01, /* __u8 bPwrOn2pwrGood; 2ms */ - 0x00, /* __u8 bHubContrCurrent; 0 mA */ - 0x00, /* __u8 DeviceRemovable; *** 7 Ports max *** */ - 0xff /* __u8 PortPwrCtrlMask; *** 7 ports max *** */ -}; - -static unsigned char root_hub_str_index0[] = -{ - 0x04, /* __u8 bLength; */ - 0x03, /* __u8 bDescriptorType; String-descriptor */ - 0x09, /* __u8 lang ID */ - 0x04, /* __u8 lang ID */ -}; - -static unsigned char root_hub_str_index1[] = -{ - 28, /* __u8 bLength; */ - 0x03, /* __u8 bDescriptorType; String-descriptor */ - 'U', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'H', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'C', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'I', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - ' ', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'R', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'o', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'o', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 't', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - ' ', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'H', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'u', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'b', /* __u8 Unicode */ - 0, /* __u8 Unicode */ -}; - +#define WANT_USB_ROOT_HUB_HUB_DES +#include <usbroothubdes.h> +#undef WANT_USB_ROOT_HUB_HUB_DES
/* * Root Hub Control Pipe (interrupt Pipes are not supported) diff --git a/drivers/usb/host/isp116x-hcd.c b/drivers/usb/host/isp116x-hcd.c index 5aa190b..46e4cee 100644 --- a/drivers/usb/host/isp116x-hcd.c +++ b/drivers/usb/host/isp116x-hcd.c @@ -254,105 +254,7 @@ static inline void dump_ptd_data(struct ptd *ptd, u8 * buf, int type)
/* --- Virtual Root Hub ---------------------------------------------------- */
-/* Device descriptor */ -static __u8 root_hub_dev_des[] = { - 0x12, /* __u8 bLength; */ - 0x01, /* __u8 bDescriptorType; Device */ - 0x10, /* __u16 bcdUSB; v1.1 */ - 0x01, - 0x09, /* __u8 bDeviceClass; HUB_CLASSCODE */ - 0x00, /* __u8 bDeviceSubClass; */ - 0x00, /* __u8 bDeviceProtocol; */ - 0x08, /* __u8 bMaxPacketSize0; 8 Bytes */ - 0x00, /* __u16 idVendor; */ - 0x00, - 0x00, /* __u16 idProduct; */ - 0x00, - 0x00, /* __u16 bcdDevice; */ - 0x00, - 0x00, /* __u8 iManufacturer; */ - 0x01, /* __u8 iProduct; */ - 0x00, /* __u8 iSerialNumber; */ - 0x01 /* __u8 bNumConfigurations; */ -}; - -/* Configuration descriptor */ -static __u8 root_hub_config_des[] = { - 0x09, /* __u8 bLength; */ - 0x02, /* __u8 bDescriptorType; Configuration */ - 0x19, /* __u16 wTotalLength; */ - 0x00, - 0x01, /* __u8 bNumInterfaces; */ - 0x01, /* __u8 bConfigurationValue; */ - 0x00, /* __u8 iConfiguration; */ - 0x40, /* __u8 bmAttributes; - Bit 7: Bus-powered, 6: Self-powered, 5 Remote-wakwup, 4..0: resvd */ - 0x00, /* __u8 MaxPower; */ - - /* interface */ - 0x09, /* __u8 if_bLength; */ - 0x04, /* __u8 if_bDescriptorType; Interface */ - 0x00, /* __u8 if_bInterfaceNumber; */ - 0x00, /* __u8 if_bAlternateSetting; */ - 0x01, /* __u8 if_bNumEndpoints; */ - 0x09, /* __u8 if_bInterfaceClass; HUB_CLASSCODE */ - 0x00, /* __u8 if_bInterfaceSubClass; */ - 0x00, /* __u8 if_bInterfaceProtocol; */ - 0x00, /* __u8 if_iInterface; */ - - /* endpoint */ - 0x07, /* __u8 ep_bLength; */ - 0x05, /* __u8 ep_bDescriptorType; Endpoint */ - 0x81, /* __u8 ep_bEndpointAddress; IN Endpoint 1 */ - 0x03, /* __u8 ep_bmAttributes; Interrupt */ - 0x00, /* __u16 ep_wMaxPacketSize; ((MAX_ROOT_PORTS + 1) / 8 */ - 0x02, - 0xff /* __u8 ep_bInterval; 255 ms */ -}; - -static unsigned char root_hub_str_index0[] = { - 0x04, /* __u8 bLength; */ - 0x03, /* __u8 bDescriptorType; String-descriptor */ - 0x09, /* __u8 lang ID */ - 0x04, /* __u8 lang ID */ -}; - -static unsigned char root_hub_str_index1[] = { - 0x22, /* __u8 bLength; */ - 0x03, /* __u8 bDescriptorType; String-descriptor */ - 'I', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'S', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'P', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - '1', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - '1', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - '6', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'x', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - ' ', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'R', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'o', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'o', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 't', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - ' ', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'H', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'u', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'b', /* __u8 Unicode */ - 0, /* __u8 Unicode */ -}; +#include <usbroothubdes.h>
/* * Hub class-specific descriptor is constructed dynamically diff --git a/drivers/usb/host/ohci-hcd.c b/drivers/usb/host/ohci-hcd.c index 219d182..dc0a4e3 100644 --- a/drivers/usb/host/ohci-hcd.c +++ b/drivers/usb/host/ohci-hcd.c @@ -1094,103 +1094,7 @@ static int dl_done_list(ohci_t *ohci) * Virtual Root Hub *-------------------------------------------------------------------------*/
-/* Device descriptor */ -static __u8 root_hub_dev_des[] = -{ - 0x12, /* __u8 bLength; */ - 0x01, /* __u8 bDescriptorType; Device */ - 0x10, /* __u16 bcdUSB; v1.1 */ - 0x01, - 0x09, /* __u8 bDeviceClass; HUB_CLASSCODE */ - 0x00, /* __u8 bDeviceSubClass; */ - 0x00, /* __u8 bDeviceProtocol; */ - 0x08, /* __u8 bMaxPacketSize0; 8 Bytes */ - 0x00, /* __u16 idVendor; */ - 0x00, - 0x00, /* __u16 idProduct; */ - 0x00, - 0x00, /* __u16 bcdDevice; */ - 0x00, - 0x00, /* __u8 iManufacturer; */ - 0x01, /* __u8 iProduct; */ - 0x00, /* __u8 iSerialNumber; */ - 0x01 /* __u8 bNumConfigurations; */ -}; - -/* Configuration descriptor */ -static __u8 root_hub_config_des[] = -{ - 0x09, /* __u8 bLength; */ - 0x02, /* __u8 bDescriptorType; Configuration */ - 0x19, /* __u16 wTotalLength; */ - 0x00, - 0x01, /* __u8 bNumInterfaces; */ - 0x01, /* __u8 bConfigurationValue; */ - 0x00, /* __u8 iConfiguration; */ - 0x40, /* __u8 bmAttributes; - Bit 7: Bus-powered, 6: Self-powered, 5 Remote-wakwup, 4..0: resvd */ - 0x00, /* __u8 MaxPower; */ - - /* interface */ - 0x09, /* __u8 if_bLength; */ - 0x04, /* __u8 if_bDescriptorType; Interface */ - 0x00, /* __u8 if_bInterfaceNumber; */ - 0x00, /* __u8 if_bAlternateSetting; */ - 0x01, /* __u8 if_bNumEndpoints; */ - 0x09, /* __u8 if_bInterfaceClass; HUB_CLASSCODE */ - 0x00, /* __u8 if_bInterfaceSubClass; */ - 0x00, /* __u8 if_bInterfaceProtocol; */ - 0x00, /* __u8 if_iInterface; */ - - /* endpoint */ - 0x07, /* __u8 ep_bLength; */ - 0x05, /* __u8 ep_bDescriptorType; Endpoint */ - 0x81, /* __u8 ep_bEndpointAddress; IN Endpoint 1 */ - 0x03, /* __u8 ep_bmAttributes; Interrupt */ - 0x02, /* __u16 ep_wMaxPacketSize; ((MAX_ROOT_PORTS + 1) / 8 */ - 0x00, - 0xff /* __u8 ep_bInterval; 255 ms */ -}; - -static unsigned char root_hub_str_index0[] = -{ - 0x04, /* __u8 bLength; */ - 0x03, /* __u8 bDescriptorType; String-descriptor */ - 0x09, /* __u8 lang ID */ - 0x04, /* __u8 lang ID */ -}; - -static unsigned char root_hub_str_index1[] = -{ - 28, /* __u8 bLength; */ - 0x03, /* __u8 bDescriptorType; String-descriptor */ - 'O', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'H', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'C', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'I', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - ' ', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'R', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'o', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'o', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 't', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - ' ', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'H', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'u', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'b', /* __u8 Unicode */ - 0, /* __u8 Unicode */ -}; +#include <usbroothubdes.h>
diff --git a/drivers/usb/host/ohci-s3c24xx.c b/drivers/usb/host/ohci-s3c24xx.c index 42e564e..3c659c6 100644 --- a/drivers/usb/host/ohci-s3c24xx.c +++ b/drivers/usb/host/ohci-s3c24xx.c @@ -873,100 +873,7 @@ static int dl_done_list(struct ohci *ohci, struct td *td_list) * Virtual Root Hub *-------------------------------------------------------------------------*/
-/* Device descriptor */ -static __u8 root_hub_dev_des[] = { - 0x12, /* __u8 bLength; */ - 0x01, /* __u8 bDescriptorType; Device */ - 0x10, /* __u16 bcdUSB; v1.1 */ - 0x01, - 0x09, /* __u8 bDeviceClass; HUB_CLASSCODE */ - 0x00, /* __u8 bDeviceSubClass; */ - 0x00, /* __u8 bDeviceProtocol; */ - 0x08, /* __u8 bMaxPacketSize0; 8 Bytes */ - 0x00, /* __u16 idVendor; */ - 0x00, - 0x00, /* __u16 idProduct; */ - 0x00, - 0x00, /* __u16 bcdDevice; */ - 0x00, - 0x00, /* __u8 iManufacturer; */ - 0x01, /* __u8 iProduct; */ - 0x00, /* __u8 iSerialNumber; */ - 0x01 /* __u8 bNumConfigurations; */ -}; - -/* Configuration descriptor */ -static __u8 root_hub_config_des[] = { - 0x09, /* __u8 bLength; */ - 0x02, /* __u8 bDescriptorType; Configuration */ - 0x19, /* __u16 wTotalLength; */ - 0x00, - 0x01, /* __u8 bNumInterfaces; */ - 0x01, /* __u8 bConfigurationValue; */ - 0x00, /* __u8 iConfiguration; */ - 0x40, /* __u8 bmAttributes; - Bit 7: Bus-powered, 6: Self-powered, - 5 Remote-wakwup, 4..0: resvd */ - 0x00, /* __u8 MaxPower; */ - - /* interface */ - 0x09, /* __u8 if_bLength; */ - 0x04, /* __u8 if_bDescriptorType; Interface */ - 0x00, /* __u8 if_bInterfaceNumber; */ - 0x00, /* __u8 if_bAlternateSetting; */ - 0x01, /* __u8 if_bNumEndpoints; */ - 0x09, /* __u8 if_bInterfaceClass; HUB_CLASSCODE */ - 0x00, /* __u8 if_bInterfaceSubClass; */ - 0x00, /* __u8 if_bInterfaceProtocol; */ - 0x00, /* __u8 if_iInterface; */ - - /* endpoint */ - 0x07, /* __u8 ep_bLength; */ - 0x05, /* __u8 ep_bDescriptorType; Endpoint */ - 0x81, /* __u8 ep_bEndpointAddress; IN Endpoint 1 */ - 0x03, /* __u8 ep_bmAttributes; Interrupt */ - 0x02, /* __u16 ep_wMaxPacketSize; ((MAX_ROOT_PORTS + 1) / 8 */ - 0x00, - 0xff /* __u8 ep_bInterval; 255 ms */ -}; - -static unsigned char root_hub_str_index0[] = { - 0x04, /* __u8 bLength; */ - 0x03, /* __u8 bDescriptorType; String-descriptor */ - 0x09, /* __u8 lang ID */ - 0x04, /* __u8 lang ID */ -}; - -static unsigned char root_hub_str_index1[] = { - 28, /* __u8 bLength; */ - 0x03, /* __u8 bDescriptorType; String-descriptor */ - 'O', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'H', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'C', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'I', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - ' ', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'R', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'o', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'o', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 't', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - ' ', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'H', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'u', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'b', /* __u8 Unicode */ - 0, /* __u8 Unicode */ -}; +#include <usbroothubdes.h>
diff --git a/drivers/usb/host/r8a66597-hcd.c b/drivers/usb/host/r8a66597-hcd.c index fd30d67..dfe5423 100644 --- a/drivers/usb/host/r8a66597-hcd.c +++ b/drivers/usb/host/r8a66597-hcd.c @@ -557,109 +557,7 @@ static int check_usb_device_connecting(struct r8a66597 *r8a66597) * Virtual Root Hub *-------------------------------------------------------------------------*/
-/* Device descriptor */ -static __u8 root_hub_dev_des[] = -{ - 0x12, /* __u8 bLength; */ - 0x01, /* __u8 bDescriptorType; Device */ - 0x10, /* __u16 bcdUSB; v1.1 */ - 0x01, - 0x09, /* __u8 bDeviceClass; HUB_CLASSCODE */ - 0x00, /* __u8 bDeviceSubClass; */ - 0x00, /* __u8 bDeviceProtocol; */ - 0x08, /* __u8 bMaxPacketSize0; 8 Bytes */ - 0x00, /* __u16 idVendor; */ - 0x00, - 0x00, /* __u16 idProduct; */ - 0x00, - 0x00, /* __u16 bcdDevice; */ - 0x00, - 0x00, /* __u8 iManufacturer; */ - 0x01, /* __u8 iProduct; */ - 0x00, /* __u8 iSerialNumber; */ - 0x01 /* __u8 bNumConfigurations; */ -}; - -/* Configuration descriptor */ -static __u8 root_hub_config_des[] = -{ - 0x09, /* __u8 bLength; */ - 0x02, /* __u8 bDescriptorType; Configuration */ - 0x19, /* __u16 wTotalLength; */ - 0x00, - 0x01, /* __u8 bNumInterfaces; */ - 0x01, /* __u8 bConfigurationValue; */ - 0x00, /* __u8 iConfiguration; */ - 0x40, /* __u8 bmAttributes; */ - - 0x00, /* __u8 MaxPower; */ - - /* interface */ - 0x09, /* __u8 if_bLength; */ - 0x04, /* __u8 if_bDescriptorType; Interface */ - 0x00, /* __u8 if_bInterfaceNumber; */ - 0x00, /* __u8 if_bAlternateSetting; */ - 0x01, /* __u8 if_bNumEndpoints; */ - 0x09, /* __u8 if_bInterfaceClass; HUB_CLASSCODE */ - 0x00, /* __u8 if_bInterfaceSubClass; */ - 0x00, /* __u8 if_bInterfaceProtocol; */ - 0x00, /* __u8 if_iInterface; */ - - /* endpoint */ - 0x07, /* __u8 ep_bLength; */ - 0x05, /* __u8 ep_bDescriptorType; Endpoint */ - 0x81, /* __u8 ep_bEndpointAddress; IN Endpoint 1 */ - 0x03, /* __u8 ep_bmAttributes; Interrupt */ - 0x02, /* __u16 ep_wMaxPacketSize; ((MAX_ROOT_PORTS + 1) / 8 */ - 0x00, - 0xff /* __u8 ep_bInterval; 255 ms */ -}; - -static unsigned char root_hub_str_index0[] = -{ - 0x04, /* __u8 bLength; */ - 0x03, /* __u8 bDescriptorType; String-descriptor */ - 0x09, /* __u8 lang ID */ - 0x04, /* __u8 lang ID */ -}; - -static unsigned char root_hub_str_index1[] = -{ - 34, /* __u8 bLength; */ - 0x03, /* __u8 bDescriptorType; String-descriptor */ - 'R', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - '8', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'A', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - '6', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - '6', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - '5', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - '9', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - '7', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - ' ', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'R', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'o', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'o', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 't', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'H', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'u', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'b', /* __u8 Unicode */ - 0, /* __u8 Unicode */ -}; +#include <usbroothubdes.h>
static int r8a66597_submit_rh_msg(struct usb_device *dev, unsigned long pipe, void *buffer, int transfer_len, struct devrequest *cmd) diff --git a/drivers/usb/musb/musb_hcd.c b/drivers/usb/musb/musb_hcd.c index 799bd30..f0ba8aa 100644 --- a/drivers/usb/musb/musb_hcd.c +++ b/drivers/usb/musb/musb_hcd.c @@ -28,99 +28,8 @@ static const struct musb_epinfo epinfo[3] = { static int rh_devnum; static u32 port_status;
-/* Device descriptor */ -static const u8 root_hub_dev_des[] = { - 0x12, /* __u8 bLength; */ - 0x01, /* __u8 bDescriptorType; Device */ - 0x00, /* __u16 bcdUSB; v1.1 */ - 0x02, - 0x09, /* __u8 bDeviceClass; HUB_CLASSCODE */ - 0x00, /* __u8 bDeviceSubClass; */ - 0x00, /* __u8 bDeviceProtocol; */ - 0x08, /* __u8 bMaxPacketSize0; 8 Bytes */ - 0x00, /* __u16 idVendor; */ - 0x00, - 0x00, /* __u16 idProduct; */ - 0x00, - 0x00, /* __u16 bcdDevice; */ - 0x00, - 0x00, /* __u8 iManufacturer; */ - 0x01, /* __u8 iProduct; */ - 0x00, /* __u8 iSerialNumber; */ - 0x01 /* __u8 bNumConfigurations; */ -}; - -/* Configuration descriptor */ -static const u8 root_hub_config_des[] = { - 0x09, /* __u8 bLength; */ - 0x02, /* __u8 bDescriptorType; Configuration */ - 0x19, /* __u16 wTotalLength; */ - 0x00, - 0x01, /* __u8 bNumInterfaces; */ - 0x01, /* __u8 bConfigurationValue; */ - 0x00, /* __u8 iConfiguration; */ - 0x40, /* __u8 bmAttributes; - Bit 7: Bus-powered, 6: Self-powered, 5 Remote-wakwup, 4..0: resvd */ - 0x00, /* __u8 MaxPower; */ - - /* interface */ - 0x09, /* __u8 if_bLength; */ - 0x04, /* __u8 if_bDescriptorType; Interface */ - 0x00, /* __u8 if_bInterfaceNumber; */ - 0x00, /* __u8 if_bAlternateSetting; */ - 0x01, /* __u8 if_bNumEndpoints; */ - 0x09, /* __u8 if_bInterfaceClass; HUB_CLASSCODE */ - 0x00, /* __u8 if_bInterfaceSubClass; */ - 0x00, /* __u8 if_bInterfaceProtocol; */ - 0x00, /* __u8 if_iInterface; */ - - /* endpoint */ - 0x07, /* __u8 ep_bLength; */ - 0x05, /* __u8 ep_bDescriptorType; Endpoint */ - 0x81, /* __u8 ep_bEndpointAddress; IN Endpoint 1 */ - 0x03, /* __u8 ep_bmAttributes; Interrupt */ - 0x00, /* __u16 ep_wMaxPacketSize; ((MAX_ROOT_PORTS + 1) / 8 */ - 0x02, - 0xff /* __u8 ep_bInterval; 255 ms */ -}; +#include <usbroothubdes.h>
-static const unsigned char root_hub_str_index0[] = { - 0x04, /* __u8 bLength; */ - 0x03, /* __u8 bDescriptorType; String-descriptor */ - 0x09, /* __u8 lang ID */ - 0x04, /* __u8 lang ID */ -}; - -static const unsigned char root_hub_str_index1[] = { - 0x1c, /* __u8 bLength; */ - 0x03, /* __u8 bDescriptorType; String-descriptor */ - 'M', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'U', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'S', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'B', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - ' ', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'R', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'o', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'o', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 't', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - ' ', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'H', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'u', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'b', /* __u8 Unicode */ - 0, /* __u8 Unicode */ -}; #endif
/* diff --git a/include/usbroothubdes.h b/include/usbroothubdes.h new file mode 100644 index 0000000..adb70cd --- /dev/null +++ b/include/usbroothubdes.h @@ -0,0 +1,129 @@ +/* + * USB virtual root hub descriptors + * + * (C) Copyright 2014 + * Stephen Warren swarren@wwwdotorg.org + * + * Based on ohci-hcd.c + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __USBROOTHUBDES_H__ +#define __USBROOTHUBDES_H__ + +/* Device descriptor */ +static __u8 root_hub_dev_des[] = { + 0x12, /* __u8 bLength; */ + 0x01, /* __u8 bDescriptorType; Device */ + 0x10, /* __u16 bcdUSB; v1.1 */ + 0x01, + 0x09, /* __u8 bDeviceClass; HUB_CLASSCODE */ + 0x00, /* __u8 bDeviceSubClass; */ + 0x00, /* __u8 bDeviceProtocol; */ + 0x08, /* __u8 bMaxPacketSize0; 8 Bytes */ + 0x00, /* __u16 idVendor; */ + 0x00, + 0x00, /* __u16 idProduct; */ + 0x00, + 0x00, /* __u16 bcdDevice; */ + 0x00, + 0x00, /* __u8 iManufacturer; */ + 0x01, /* __u8 iProduct; */ + 0x00, /* __u8 iSerialNumber; */ + 0x01, /* __u8 bNumConfigurations; */ +}; + +/* Configuration descriptor */ +static __u8 root_hub_config_des[] = { + 0x09, /* __u8 bLength; */ + 0x02, /* __u8 bDescriptorType; Configuration */ + 0x19, /* __u16 wTotalLength; */ + 0x00, + 0x01, /* __u8 bNumInterfaces; */ + 0x01, /* __u8 bConfigurationValue; */ + 0x00, /* __u8 iConfiguration; */ + 0x40, /* __u8 bmAttributes; + * Bit 7: Bus-powered + * 6: Self-powered, + * 5 Remote-wakwup, + * 4..0: resvd + */ + 0x00, /* __u8 MaxPower; */ + /* interface */ + 0x09, /* __u8 if_bLength; */ + 0x04, /* __u8 if_bDescriptorType; Interface */ + 0x00, /* __u8 if_bInterfaceNumber; */ + 0x00, /* __u8 if_bAlternateSetting; */ + 0x01, /* __u8 if_bNumEndpoints; */ + 0x09, /* __u8 if_bInterfaceClass; HUB_CLASSCODE */ + 0x00, /* __u8 if_bInterfaceSubClass; */ + 0x00, /* __u8 if_bInterfaceProtocol; */ + 0x00, /* __u8 if_iInterface; */ + /* endpoint */ + 0x07, /* __u8 ep_bLength; */ + 0x05, /* __u8 ep_bDescriptorType; Endpoint */ + 0x81, /* __u8 ep_bEndpointAddress; IN Endpoint 1 */ + 0x03, /* __u8 ep_bmAttributes; Interrupt */ + 0x02, /* __u16 ep_wMaxPacketSize; ((MAX_ROOT_PORTS + 1) / 8 */ + 0x00, + 0xff, /* __u8 ep_bInterval; 255 ms */ +}; + +#ifdef WANT_USB_ROOT_HUB_HUB_DES +static unsigned char root_hub_hub_des[] = { + 0x09, /* __u8 bLength; */ + 0x29, /* __u8 bDescriptorType; Hub-descriptor */ + 0x02, /* __u8 bNbrPorts; */ + 0x00, /* __u16 wHubCharacteristics; */ + 0x00, + 0x01, /* __u8 bPwrOn2pwrGood; 2ms */ + 0x00, /* __u8 bHubContrCurrent; 0 mA */ + 0x00, /* __u8 DeviceRemovable; *** 7 Ports max *** */ + 0xff, /* __u8 PortPwrCtrlMask; *** 7 ports max *** */ +}; +#endif + +static unsigned char root_hub_str_index0[] = { + 0x04, /* __u8 bLength; */ + 0x03, /* __u8 bDescriptorType; String-descriptor */ + 0x09, /* __u8 lang ID */ + 0x04, /* __u8 lang ID */ +}; + +static unsigned char root_hub_str_index1[] = { + 32, /* __u8 bLength; */ + 0x03, /* __u8 bDescriptorType; String-descriptor */ + 'U', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + '-', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'B', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'o', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'o', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 't', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + ' ', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'R', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'o', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'o', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 't', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + ' ', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'H', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'u', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'b', /* __u8 Unicode */ + 0, /* __u8 Unicode */ +}; + +#endif
- Max packet size
- String content
Looks good for ppc4xx, so:
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
- Max packet size
- String content
Marek, how long do you think we should wait for acks/naks from the CC'd people?
- Max packet size
- String content
Stephen, I guess I'm not the right person to Ack/Nak this patch now, since I haven't played this for a long time. Also it's the same for Cliff Cai and his email is dead.
Thanks, -Bryan
- Max packet size
- String content
Well, I'm picking this up now.
Best regards, Marek Vasut
Hello Stephen,
Sorry for the delay, I wasn't connected during 2 weeks. I can't comment your patch because I no longer have an MPC5200-based board.
Best regards
- Max packet size
- String content
participants (5)
Bryan Wu
Pierre AUBERT
Stefan Roese
Stephen Warren
