[U-Boot] [PATCH v2 0/2] power: pmic: Add support for LP87565 family of PMICs
The series adds support for LP87565 family of PMICs. Implements functions to configure regulators. Enable/Disable Get/Set voltages of regulators.
Keerthy (2): power: pmic: lp87565: Add the basic pmic support power: regulator: lp87565: add regulator support
drivers/power/pmic/Kconfig | 7 + drivers/power/pmic/Makefile | 1 + drivers/power/pmic/lp87565.c | 85 ++++++++++++ drivers/power/regulator/Kconfig | 10 ++ drivers/power/regulator/Makefile | 1 + drivers/power/regulator/lp87565_regulator.c | 199 ++++++++++++++++++++++++++++ include/power/lp87565.h | 12 ++ 7 files changed, 315 insertions(+) create mode 100644 drivers/power/pmic/lp87565.c create mode 100644 drivers/power/regulator/lp87565_regulator.c create mode 100644 include/power/lp87565.h
Add support to bind the regulators/child nodes with the pmic.
Signed-off-by: Keerthy j-keerthy@ti.com ---
Changes in v2:
* Used dev_read_subnode function to fetch the regulators node.
drivers/power/pmic/Kconfig | 7 ++++ drivers/power/pmic/Makefile | 1 + drivers/power/pmic/lp87565.c | 85 ++++++++++++++++++++++++++++++++++++++++++++ include/power/lp87565.h | 12 +++++++ 4 files changed, 105 insertions(+) create mode 100644 drivers/power/pmic/lp87565.c create mode 100644 include/power/lp87565.h
diff --git a/drivers/power/pmic/Kconfig b/drivers/power/pmic/Kconfig index 3f50c12..e3f9e4d 100644 --- a/drivers/power/pmic/Kconfig +++ b/drivers/power/pmic/Kconfig @@ -188,6 +188,13 @@ config PMIC_LP873X The LP873X is a PMIC containing couple of LDOs and couple of SMPS. This driver binds the pmic children.
+config PMIC_LP87565 + bool "Enable driver for Texas Instruments LP87565 PMIC" + depends on DM_PMIC + ---help--- + The LP87565 is a PMIC containing a bunch of SMPS. + This driver binds the pmic children. + config POWER_MC34VR500 bool "Enable driver for Freescale MC34VR500 PMIC" ---help--- diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index f409e3a..f488799 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -21,6 +21,7 @@ obj-$(CONFIG_PMIC_TPS65090) += tps65090.o obj-$(CONFIG_PMIC_S5M8767) += s5m8767.o obj-$(CONFIG_$(SPL_)PMIC_PALMAS) += palmas.o obj-$(CONFIG_$(SPL_)PMIC_LP873X) += lp873x.o +obj-$(CONFIG_$(SPL_)PMIC_LP87565) += lp87565.o
obj-$(CONFIG_POWER_LTC3676) += pmic_ltc3676.o obj-$(CONFIG_POWER_MAX77696) += pmic_max77696.o diff --git a/drivers/power/pmic/lp87565.c b/drivers/power/pmic/lp87565.c new file mode 100644 index 0000000..9803bf9 --- /dev/null +++ b/drivers/power/pmic/lp87565.c @@ -0,0 +1,85 @@ +/* + * (C) Copyright 2017 Texas Instruments Incorporated, <www.ti.com> + * Keerthy j-keerthy@ti.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fdtdec.h> +#include <errno.h> +#include <dm.h> +#include <i2c.h> +#include <power/pmic.h> +#include <power/regulator.h> +#include <power/lp87565.h> +#include <dm/device.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct pmic_child_info pmic_children_info[] = { + { .prefix = "buck", .driver = LP87565_BUCK_DRIVER }, + { }, +}; + +static int lp87565_write(struct udevice *dev, uint reg, const uint8_t *buff, + int len) +{ + if (dm_i2c_write(dev, reg, buff, len)) { + error("write error to device: %p register: %#x!", dev, reg); + return -EIO; + } + + return 0; +} + +static int lp87565_read(struct udevice *dev, uint reg, uint8_t *buff, int len) +{ + if (dm_i2c_read(dev, reg, buff, len)) { + error("read error from device: %p register: %#x!", dev, reg); + return -EIO; + } + + return 0; +} + +static int lp87565_bind(struct udevice *dev) +{ + ofnode regulators_node; + int children; + + regulators_node = dev_read_subnode(dev, "regulators"); + if (!ofnode_valid(regulators_node)) { + debug("%s: %s regulators subnode not found!", __func__, + dev->name); + return -ENXIO; + } + + debug("%s: '%s' - found regulators subnode\n", __func__, dev->name); + + children = pmic_bind_children(dev, regulators_node, pmic_children_info); + if (!children) + printf("%s: %s - no child found\n", __func__, dev->name); + + /* Always return success for this device */ + return 0; +} + +static struct dm_pmic_ops lp87565_ops = { + .read = lp87565_read, + .write = lp87565_write, +}; + +static const struct udevice_id lp87565_ids[] = { + { .compatible = "ti,lp87565", .data = LP87565 }, + { .compatible = "ti,lp87565-q1", .data = LP87565_Q1 }, + { } +}; + +U_BOOT_DRIVER(pmic_lp87565) = { + .name = "lp87565_pmic", + .id = UCLASS_PMIC, + .of_match = lp87565_ids, + .bind = lp87565_bind, + .ops = &lp87565_ops, +}; diff --git a/include/power/lp87565.h b/include/power/lp87565.h new file mode 100644 index 0000000..5160f5d --- /dev/null +++ b/include/power/lp87565.h @@ -0,0 +1,12 @@ +#define LP87565 0x0 +#define LP87565_Q1 0x1 + +#define LP87565_BUCK_NUM 6 + +/* Drivers name */ +#define LP87565_BUCK_DRIVER "lp87565_buck" + +#define LP87565_BUCK_VOLT_MASK 0xFF +#define LP87565_BUCK_VOLT_MAX_HEX 0xFF +#define LP87565_BUCK_VOLT_MAX 3360000 +#define LP87565_BUCK_MODE_MASK 0x80
Hi Keerthy,
Changes in v2:
- Used dev_read_subnode function to fetch the regulators node.
- bool "Enable driver for Texas Instruments LP87565 PMIC"
- depends on DM_PMIC
- ---help---
- The LP87565 is a PMIC containing a bunch of SMPS.
- This driver binds the pmic children.
- (C) Copyright 2017 Texas Instruments Incorporated, <www.ti.com>
- Keerthy j-keerthy@ti.com
- { .prefix = "buck", .driver = LP87565_BUCK_DRIVER },
int len)
- if (dm_i2c_write(dev, reg, buff, len)) {
I think you referred to the other file.. :)
dm_i2c_write() can be returned the other error number.. I think the below code is better than now..I will modify the other files like below
ret = dm_i2c_read() if (ret) error();
return ret;
return -EIO;
- if (dm_i2c_read(dev, reg, buff, len)) {
return -EIO;
- ofnode regulators_node;
- int children;
- regulators_node = dev_read_subnode(dev, "regulators");
- if (!ofnode_valid(regulators_node)) {
dev->name);
return -ENXIO;
- debug("%s: '%s' - found regulators subnode\n", __func__, dev->name);
- children = pmic_bind_children(dev, regulators_node, pmic_children_info);
- if (!children)
- /* Always return success for this device */
- .read = lp87565_read,
- .write = lp87565_write,
- { .compatible = "ti,lp87565", .data = LP87565 },
- { .compatible = "ti,lp87565-q1", .data = LP87565_Q1 },
- .name = "lp87565_pmic",
- .id = UCLASS_PMIC,
- .of_match = lp87565_ids,
- .bind = lp87565_bind,
- .ops = &lp87565_ops,
On Wednesday 07 June 2017 06:28 PM, Jaehoon Chung wrote:
Hi Keerthy,
Changes in v2:
- ---help---
int len)
return ret;
Jaehoon,
yes makes sense. So both dm_i2c_write and dm_i2c_read can return different values. I will change like how you have suggested and post v3.
Thanks, Keerthy
return -EIO;
return -EIO;
- int children;
dev->name);
return -ENXIO;
- if (!children)
The driver provides regulator set/get voltage enable/disable functions for lp87565 family of PMICs.
Changes in v2:
* updated Kconfig description. * Used -EINVAL instead of hardcoded -1. * removed couple of unwanted braces. * Changed volt2hex to volt2val and hex2volt to val2volt.
drivers/power/regulator/Kconfig | 10 ++ drivers/power/regulator/Makefile | 1 + drivers/power/regulator/lp87565_regulator.c | 199 ++++++++++++++++++++++++++++ 3 files changed, 210 insertions(+) create mode 100644 drivers/power/regulator/lp87565_regulator.c
diff --git a/drivers/power/regulator/Kconfig b/drivers/power/regulator/Kconfig index ef057e0..f213487 100644 --- a/drivers/power/regulator/Kconfig +++ b/drivers/power/regulator/Kconfig @@ -149,3 +149,13 @@ config DM_REGULATOR_LP873X This enables implementation of driver-model regulator uclass features for REGULATOR LP873X and the family of LP873X PMICs. The driver implements get/set api for: value and enable. + +config DM_REGULATOR_LP87565 + bool "Enable driver for LP87565 PMIC regulators" + depends on PMIC_LP87565 + ---help--- + This enables implementation of driver-model regulator uclass + features for REGULATOR LP87565 and the family of LP87565 PMICs. + LP87565 series of PMICs have 4 single phase BUCKs that can also + be configured in multi phase modes. The driver implements + get/set api for value and enable. diff --git a/drivers/power/regulator/Makefile b/drivers/power/regulator/Makefile index 3e01021..ce14d08 100644 --- a/drivers/power/regulator/Makefile +++ b/drivers/power/regulator/Makefile @@ -18,3 +18,4 @@ obj-$(CONFIG_DM_REGULATOR_SANDBOX) += sandbox.o obj-$(CONFIG_REGULATOR_TPS65090) += tps65090_regulator.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_PALMAS) += palmas_regulator.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_LP873X) += lp873x_regulator.o +obj-$(CONFIG_$(SPL_)DM_REGULATOR_LP87565) += lp87565_regulator.o diff --git a/drivers/power/regulator/lp87565_regulator.c b/drivers/power/regulator/lp87565_regulator.c new file mode 100644 index 0000000..3811396 --- /dev/null +++ b/drivers/power/regulator/lp87565_regulator.c @@ -0,0 +1,199 @@ +/* + * (C) Copyright 2017 + * Texas Instruments Incorporated, <www.ti.com> + * + * Keerthy j-keerthy@ti.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fdtdec.h> +#include <errno.h> +#include <dm.h> +#include <i2c.h> +#include <power/pmic.h> +#include <power/regulator.h> +#include <power/lp87565.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const char lp87565_buck_ctrl1[LP87565_BUCK_NUM] = {0x2, 0x4, 0x6, 0x8, 0x2, 0x6}; +static const char lp87565_buck_vout[LP87565_BUCK_NUM] = {0xA, 0xC, 0xE, 0x10, 0xA, 0xE }; + +static int lp87565_buck_enable(struct udevice *dev, int op, bool *enable) +{ + int ret; + unsigned int adr; + struct dm_regulator_uclass_platdata *uc_pdata; + + uc_pdata = dev_get_uclass_platdata(dev); + adr = uc_pdata->ctrl_reg; + + ret = pmic_reg_read(dev->parent, adr); + if (ret < 0) + return ret; + + if (op == PMIC_OP_GET) { + ret &= LP87565_BUCK_MODE_MASK; + + if (ret) + *enable = true; + else + *enable = false; + + return 0; + } else if (op == PMIC_OP_SET) { + if (*enable) + ret |= LP87565_BUCK_MODE_MASK; + else + ret &= ~LP87565_BUCK_MODE_MASK; + ret = pmic_reg_write(dev->parent, adr, ret); + if (ret) + return ret; + } + + return 0; +} + +static int lp87565_buck_volt2val(int uV) +{ + if (uV > LP87565_BUCK_VOLT_MAX) + return -EINVAL; + else if (uV > 1400000) + return (uV - 1420000) / 20000 + 0x9E; + else if (uV > 730000) + return (uV - 735000) / 5000 + 0x18; + else if (uV >= 500000) + return (uV - 500000) / 10000; + else + return -EINVAL; +} + +static int lp87565_buck_val2volt(int val) +{ + if (val > LP87565_BUCK_VOLT_MAX_HEX) + return -EINVAL; + else if (val > 0x9D) + return 1400000 + (val - 0x9D) * 20000; + else if (val > 0x17) + return 730000 + (val - 0x17) * 5000; + else if (val >= 0x0) + return 500000 + val * 10000; + else + return -EINVAL; +} + +static int lp87565_buck_val(struct udevice *dev, int op, int *uV) +{ + unsigned int hex, adr; + int ret; + struct dm_regulator_uclass_platdata *uc_pdata; + + uc_pdata = dev_get_uclass_platdata(dev); + + if (op == PMIC_OP_GET) + *uV = 0; + + adr = uc_pdata->volt_reg; + + ret = pmic_reg_read(dev->parent, adr); + if (ret < 0) + return ret; + + if (op == PMIC_OP_GET) { + ret &= LP87565_BUCK_VOLT_MASK; + ret = lp87565_buck_val2volt(ret); + if (ret < 0) + return ret; + *uV = ret; + + return 0; + } + + hex = lp87565_buck_volt2val(*uV); + if (hex < 0) + return hex; + + ret &= 0x0; + ret = hex; + + ret = pmic_reg_write(dev->parent, adr, ret); + + return ret; +} + +static int lp87565_buck_probe(struct udevice *dev) +{ + struct dm_regulator_uclass_platdata *uc_pdata; + int idx; + + uc_pdata = dev_get_uclass_platdata(dev); + uc_pdata->type = REGULATOR_TYPE_BUCK; + + idx = dev->driver_data; + if (idx == 0 || idx == 1 || idx == 2 || idx == 3) { + debug("Single phase regulator\n"); + } else if (idx == 23) { + idx = 5; + } else if (idx == 10) { + idx = 4; + } else { + printf("Wrong ID for regulator\n"); + return -EINVAL; + } + + uc_pdata->ctrl_reg = lp87565_buck_ctrl1[idx]; + uc_pdata->volt_reg = lp87565_buck_vout[idx]; + + return 0; +} + +static int buck_get_value(struct udevice *dev) +{ + int uV; + int ret; + + ret = lp87565_buck_val(dev, PMIC_OP_GET, &uV); + if (ret) + return ret; + + return uV; +} + +static int buck_set_value(struct udevice *dev, int uV) +{ + return lp87565_buck_val(dev, PMIC_OP_SET, &uV); +} + +static bool buck_get_enable(struct udevice *dev) +{ + bool enable = false; + int ret; + + + ret = lp87565_buck_enable(dev, PMIC_OP_GET, &enable); + if (ret) + return ret; + + return enable; +} + +static int buck_set_enable(struct udevice *dev, bool enable) +{ + return lp87565_buck_enable(dev, PMIC_OP_SET, &enable); +} + +static const struct dm_regulator_ops lp87565_buck_ops = { + .get_value = buck_get_value, + .set_value = buck_set_value, + .get_enable = buck_get_enable, + .set_enable = buck_set_enable, +}; + +U_BOOT_DRIVER(lp87565_buck) = { + .name = LP87565_BUCK_DRIVER, + .id = UCLASS_REGULATOR, + .ops = &lp87565_buck_ops, + .probe = lp87565_buck_probe, +};
Jaehoon Chung
Keerthy
