[U-Boot] [PATCH] omap3/mem.c: remove unused defines
These GPMC_CS defines are a leftover from prior gpmc_init(). Commit 187af954 removed the need for these definitions but missed to remove them.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com Cc: Tom Rini trini@ti.com --- arch/arm/cpu/armv7/omap3/mem.c | 14 -------------- 1 file changed, 14 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap3/mem.c b/arch/arm/cpu/armv7/omap3/mem.c index 2fe5ac7..1ca37a9 100644 --- a/arch/arm/cpu/armv7/omap3/mem.c +++ b/arch/arm/cpu/armv7/omap3/mem.c @@ -42,13 +42,6 @@ static const u32 gpmc_m_nand[GPMC_MAX_REG] = { M_NAND_GPMC_CONFIG5, M_NAND_GPMC_CONFIG6, 0 }; - -#if defined(CONFIG_ENV_IS_IN_NAND) -#define GPMC_CS 0 -#else -#define GPMC_CS 1 -#endif - #endif
#if defined(CONFIG_CMD_ONENAND) @@ -60,13 +53,6 @@ static const u32 gpmc_onenand[GPMC_MAX_REG] = { ONENAND_GPMC_CONFIG5, ONENAND_GPMC_CONFIG6, 0 }; - -#if defined(CONFIG_ENV_IS_IN_ONENAND) -#define GPMC_CS 0 -#else -#define GPMC_CS 1 -#endif - #endif
Signed-off-by: Andreas Bie??mann andreas.devel@googlemail.com Cc: Tom Rini trini@ti.com
Applied to u-boot-ti/master, thanks!
Andreas Bießmann
