[U-Boot-Users] [PATCH] Fix building with CRAMFS but no JFFS2 support
Hi!
Fix building with CRAMFS but not JFFS2 support
Signed-off-by: Harald Welte laforge@openmoko.org
Index: u-boot/fs/cramfs/cramfs.c =================================================================== --- u-boot.orig/fs/cramfs/cramfs.c 2007-02-17 11:46:26.000000000 +0100 +++ u-boot/fs/cramfs/cramfs.c 2007-02-17 11:54:36.000000000 +0100 @@ -27,7 +27,7 @@ #include <common.h> #include <malloc.h>
-#if defined(CONFIG_CMD_JFFS2) +#if defined(CONFIG_CMD_CRAMFS)
#include <asm/byteorder.h> #include <linux/stat.h> Index: u-boot/common/cmd_jffs2.c =================================================================== --- u-boot.orig/common/cmd_jffs2.c 2007-02-17 11:47:51.000000000 +0100 +++ u-boot/common/cmd_jffs2.c 2007-02-17 14:08:25.000000000 +0100 @@ -170,10 +170,19 @@ static struct mtd_device *current_dev = NULL; static u8 current_partnum = 0;
+#if defined(CONFIG_CMD_CRAMFS) extern int cramfs_check (struct part_info *info); extern int cramfs_load (char *loadoffset, struct part_info *info, char *filename); extern int cramfs_ls (struct part_info *info, char *filename); extern int cramfs_info (struct part_info *info); +#else +/* defining empty macros for function names is ugly but avoids ifdef clutter + * all over the code */ +#define cramfs_check(x) (0) +#define cramfs_load(x,y,z) (-1) +#define cramfs_ls(x,y) (0) +#define cramfs_info(x) (0) +#endif
static struct part_info* jffs2_part_info(struct mtd_device *dev, unsigned int part_num);
Applied, thanks.
Harald Welte
