[U-Boot] [PATCH v3] ls1043ardb: SPL size reduction in case of non-xip boot
Using changes in this patch we were able to reduce approx 10k size of u-boot-spl.bin image. Following is breif description of changes to reduce SPL size: 1. Changes in board/freescale/ls1043ardb/Makefile to remove compilation of eth.c and cpld.c in case of SPL build. 2. Changes in board/freescale/ls1043ardb/ls1043ardb.c to keep only ddr_init and board_early_init_f funcations in case of SPL build. 3. Changes in ls1043a_common.h & ls1043ardb.h to remove driver specific macros due to which static data was being compiled in case of SPL build. 4. Disable MMC driver from bieng compiled in case of SPL NAND build and NAND driver from bieng compiled in case of SPL MMC build. 5. Remove I2C driver support from SPL in case of LS1043ARDB.
Signed-off-by: Vinitha Pillai vinitha.pillai@nxp.com Signed-off-by: Sumit Garg sumit.garg@nxp.com ---
Changes in v3: Reorganised way to remove driver macros in ls1043a_common.h & ls1043ardb.h files for easy maintainability.
Changes in v2: Rebased and fixed compilation warning on ls1043aqds.
board/freescale/ls1043aqds/Makefile | 2 ++ board/freescale/ls1043ardb/Makefile | 4 +++- board/freescale/ls1043ardb/ls1043ardb.c | 18 +++++++++++------- configs/ls1043ardb_sdcard_defconfig | 1 - include/configs/ls1043a_common.h | 29 +++++++++++++++++++++++++++++ include/configs/ls1043ardb.h | 27 +++++++++++++++++++++++++++ 6 files changed, 72 insertions(+), 9 deletions(-)
diff --git a/board/freescale/ls1043aqds/Makefile b/board/freescale/ls1043aqds/Makefile index f727bfd..49d8d7d 100644 --- a/board/freescale/ls1043aqds/Makefile +++ b/board/freescale/ls1043aqds/Makefile @@ -5,5 +5,7 @@ #
obj-y += ddr.o +ifndef CONFIG_SPL_BUILD obj-y += eth.o +endif obj-y += ls1043aqds.o diff --git a/board/freescale/ls1043ardb/Makefile b/board/freescale/ls1043ardb/Makefile index 5fe1cc9..2a4452e 100644 --- a/board/freescale/ls1043ardb/Makefile +++ b/board/freescale/ls1043ardb/Makefile @@ -4,7 +4,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += cpld.o obj-y += ddr.o obj-y += ls1043ardb.o +ifndef CONFIG_SPL_BUILD obj-$(CONFIG_SYS_DPAA_FMAN) += eth.o +obj-y += cpld.o +endif diff --git a/board/freescale/ls1043ardb/ls1043ardb.c b/board/freescale/ls1043ardb/ls1043ardb.c index 2333843..6de7f9a 100644 --- a/board/freescale/ls1043ardb/ls1043ardb.c +++ b/board/freescale/ls1043ardb/ls1043ardb.c @@ -29,6 +29,15 @@
DECLARE_GLOBAL_DATA_PTR;
+int board_early_init_f(void) +{ + fsl_lsch2_early_init_f(); + + return 0; +} + +#ifndef CONFIG_SPL_BUILD + int checkboard(void) { static const char *freq[2] = {"100.00MHZ", "156.25MHZ"}; @@ -67,13 +76,6 @@ int checkboard(void) return 0; }
-int board_early_init_f(void) -{ - fsl_lsch2_early_init_f(); - - return 0; -} - int board_init(void) { struct ccsr_scfg *scfg = (struct ccsr_scfg *)CONFIG_SYS_FSL_SCFG_ADDR; @@ -215,3 +217,5 @@ u16 flash_read16(void *addr)
return (((val) >> 8) & 0x00ff) | (((val) << 8) & 0xff00); } + +#endif diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index e57c42b..6bebbd9 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -17,7 +17,6 @@ CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 CONFIG_SPL_ENV_SUPPORT=y -CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GPT=y diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 5a5f951..19a808a 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -7,6 +7,21 @@ #ifndef __LS1043A_COMMON_H #define __LS1043A_COMMON_H
+/* SPL build */ +#ifndef CONFIG_SPL_BUILD +#define FMAN_UCODE +#define DSPI +#define PCIE +#define CMD_ENV +#define MISC +#endif +#if !(defined(CONFIG_SPL_BUILD) && defined(CONFIG_NAND_BOOT)) +#define MMC +#endif +#if !(defined(CONFIG_SPL_BUILD) && defined(CONFIG_SD_BOOT)) +#define IFC +#endif + #define CONFIG_REMAKE_ELF #define CONFIG_FSL_LAYERSCAPE #define CONFIG_LS1043A @@ -82,6 +97,7 @@ #endif
/* IFC */ +#ifdef IFC #if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_FSL_IFC /* @@ -102,6 +118,7 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ #endif #endif +#endif
/* I2C */ #define CONFIG_SYS_I2C @@ -112,6 +129,7 @@ #define CONFIG_SYS_I2C_MXC_I2C4
/* PCIe */ +#ifdef PCIE #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE2 /* PCIE controller 2 */ #define CONFIG_PCIE3 /* PCIE controller 3 */ @@ -121,17 +139,23 @@ #define CONFIG_PCI_SCAN_SHOW #define CONFIG_CMD_PCI #endif +#endif
/* Command line configuration */ +#ifdef CMD_ENV #define CONFIG_CMD_ENV +#endif
/* MMC */ +#ifdef MMC #ifdef CONFIG_MMC #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #endif +#endif
/* DSPI */ +#ifdef DSPI #define CONFIG_FSL_DSPI #ifdef CONFIG_FSL_DSPI #define CONFIG_DM_SPI_FLASH @@ -143,8 +167,10 @@ #define CONFIG_SF_DEFAULT_CS 0 #endif #endif +#endif
/* FMan ucode */ +#ifdef FMAN_UCODE #define CONFIG_SYS_DPAA_FMAN #ifdef CONFIG_SYS_DPAA_FMAN #define CONFIG_SYS_FM_MURAM_SIZE 0x60000 @@ -176,6 +202,7 @@ #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) #endif +#endif
/* Miscellaneous configurable options */ #define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000) @@ -183,6 +210,7 @@ #define CONFIG_HWCONFIG #define HWCONFIG_BUFFER_SIZE 128
+#ifdef MISC #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define MTDPARTS_DEFAULT "mtdparts=spi0.0:1m(uboot)," \ "5m(kernel),1m(dtb),9m(file_system)" @@ -221,6 +249,7 @@ #define CONFIG_BOOTCOMMAND "cp.b $kernel_start $kernel_load " \ "$kernel_size && bootm $kernel_load" #endif +#endif
/* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index f185380..e7d1f99 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -9,6 +9,19 @@
#include "ls1043a_common.h"
+/* SPL build */ +#ifndef CONFIG_SPL_BUILD +#define FMAN +#define USB +#define SATA +#define QE +#define EEPROM +#define ENV +#endif +#if !(defined(CONFIG_SPL_BUILD) && defined(CONFIG_SD_BOOT)) +#define NAND_IFC +#endif + #if defined(CONFIG_NAND_BOOT) || defined(CONFIG_SD_BOOT) #define CONFIG_SYS_TEXT_BASE 0x82000000 #else @@ -90,7 +103,9 @@ /* * NAND Flash Definitions */ +#ifdef NAND_IFC #define CONFIG_NAND_FSL_IFC +#endif
#define CONFIG_SYS_NAND_BASE 0x7e800000 #define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE @@ -213,6 +228,7 @@ #define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_CPLD_FTIM3
/* EEPROM */ +#ifdef EEPROM #define CONFIG_ID_EEPROM #define CONFIG_SYS_I2C_EEPROM_NXID #define CONFIG_SYS_EEPROM_BUS_NUM 0 @@ -220,11 +236,14 @@ #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 +#endif
/* * Environment */ +#ifdef ENV #define CONFIG_ENV_OVERWRITE +#endif
#if defined(CONFIG_NAND_BOOT) #define CONFIG_ENV_IS_IN_NAND @@ -243,6 +262,7 @@ #endif
/* FMan */ +#ifdef FMAN #ifdef CONFIG_SYS_DPAA_FMAN #define CONFIG_FMAN_ENET #define CONFIG_PHYLIB @@ -266,23 +286,29 @@
#define CONFIG_ETHPRIME "FM1@DTSEC3" #endif +#endif
/* QE */ +#ifdef QE #if !defined(CONFIG_SD_BOOT) && !defined(CONFIG_NAND_BOOT) && \ !defined(CONFIG_QSPI_BOOT) #define CONFIG_U_QE #endif #define CONFIG_SYS_QE_FW_ADDR 0x60600000 +#endif
/* USB */ +#ifdef USB #define CONFIG_HAS_FSL_XHCI_USB #ifdef CONFIG_HAS_FSL_XHCI_USB #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 3 #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #endif +#endif
/* SATA */ +#ifdef SATA #define CONFIG_LIBATA #define CONFIG_SCSI_AHCI #define CONFIG_CMD_SCSI @@ -299,6 +325,7 @@ #define SCSI_VEND_ID 0x1b4b #define SCSI_DEV_ID 0x9170 #define CONFIG_SCSI_DEV_LIST {SCSI_VEND_ID, SCSI_DEV_ID} +#endif
#include <asm/fsl_secure_boot.h>
Sumit Garg
