[U-Boot] [PATCH 4/7] JFFS2: Improve error checking
Check the return value when we do malloc.
Signed-off-by: Baidu Liu liucai.lfn@gmail.com --- fs/jffs2/jffs2_1pass.c | 12 ++++++++++-- fs/jffs2/jffs2_nand_1pass.c | 5 ++++- 2 files changed, 14 insertions(+), 3 deletions(-)
diff --git a/fs/jffs2/jffs2_1pass.c b/fs/jffs2/jffs2_1pass.c index be6ac78..b3d94af 100644 --- a/fs/jffs2/jffs2_1pass.c +++ b/fs/jffs2/jffs2_1pass.c @@ -662,7 +662,8 @@ jffs2_free_cache(struct part_info *part) pL = (struct b_lists *)part->jffs2_priv; free_nodes(&pL->frag); free_nodes(&pL->dir); - free(pL->readbuf); + if(pL->readbuf) + free(pL->readbuf); free(pL); } } @@ -1470,9 +1471,16 @@ jffs2_1pass_build_lists(struct part_info * part) /* lcd_off(); */
/* if we are building a list we need to refresh the cache. */ - jffs_init_1pass_list(part); + if(! jffs_init_1pass_list(part)) + return 0; + pL = (struct b_lists *)part->jffs2_priv; buf = malloc(buf_size); + if (!buf) { + printf("jffs2_1pass_build_lists: malloc failed\n"); + return 0; + } + puts ("Scanning JFFS2 FS: ");
/* start at the beginning of the partition */ diff --git a/fs/jffs2/jffs2_nand_1pass.c b/fs/jffs2/jffs2_nand_1pass.c index 9bad690..885fa3c 100644 --- a/fs/jffs2/jffs2_nand_1pass.c +++ b/fs/jffs2/jffs2_nand_1pass.c @@ -251,6 +251,7 @@ jffs_init_1pass_list(struct part_info *part) pL->dir.listCompare = compare_dirents; pL->frag.listCompare = compare_inodes; #endif + return 1; } return 0; } @@ -806,7 +807,9 @@ jffs2_1pass_build_lists(struct part_info * part) nand = nand_info + id->num;
/* if we are building a list we need to refresh the cache. */ - jffs_init_1pass_list(part); + if(! jffs_init_1pass_list(part)) + return 0; + pL = (struct b_lists *)part->jffs2_priv; pL->partOffset = part->offset; puts ("Scanning JFFS2 FS: ");
Hi Baidu,
free(pL->readbuf);
if(pL->readbuf)
free(pL); }free(pL->readbuf);
This looks ok.
- if(! jffs_init_1pass_list(part))
This is strange. We now check for an error of jffs2_init_1pass_list, which currently always returns 0, so let's see where you change that. Ah, you don't (it's in line 671 in this file). It's only in jffs2_nand_1pass that you do a change, but even there we have a problem:
return 1;
When malloc fails, we get no error output.
And the caller fails also, so the user in this case will see no error message and no output. Not good.
Cheers Detlev
Hi, Detlev
Yes, we check the return value of function jffs_init_1pass_list(). Also we add the check in nand flash. I do not konw what you are talking about.
- return 1;
You are too strict. Search the malloc in uboot. There are many places which do not even check the return value.
Hi Baidu,
Hi, Detlev
The function 'jffs_init_1pass_list' is implemented in two files, i.e. in fs/jffs2/jffs2_1pass.c and in fs/jffs2/jffs2_nand_1pass.c. Your patch inserts the actual malloc error checking only in the latter file, whereas the check for return code is done in both files. Just look at your changes - how could your new test in jffs2_1pass ever fail as you did not change the called function?
This is _plain inconsistent_ - you missed to do the same error checking for the NOR flash case.
- return 1;
This is getting more and more ridiculous. When writing new code, we always have to conform to our own standards. Now you insert an error check but if it fails, you do not inform the user that he ran out of memory but simply provide empty output? So there is _no way_ of telling a failed malloc from an empty directory? And to argument for this broken behavious you point to other places that do no error checking?
Sorry, you are loosing my interest of reviewing your code.
Best wishes Detlev
Baidu Liu
Detlev Zundel
