[U-Boot] Keystone 2 sram scratch address?
Hey folks,
So as part of Simon's patch[1] to move CONFIG_SPL_TEXT_BASE to Kconfig I've run into a problem on Keystone 2 platforms, specifically the HS variants. What keystone does is define the SRAM scratch address relative to the end of our regular SRAM usage for SPL. This is I think in part due to the large variation in the SRAM size on these parts contain and a desire to be able to more easily support the larger sizes. This is fine on the non-HS parts where we enable and build SPL so can play these games. But on the HS parts (or at least k2l_hs_evm k2e_hs_evm k2hk_hs_evm k2g_hs_evm) we don't use SPL, so once moving CONFIG_SPL_TEXT_BASE to Kconfig we don't have it defined and a few places fall apart. Can we find some constant we could use for CONFIG_SYS_INIT_SP_ADDR and then for the EEPROM copy we make on K2G? Thanks!
[1]: https://patchwork.ozlabs.org/patch/976918/
Hi Tom,
On 10/7/2018 7:29 PM, Tom Rini wrote:
Hey folks,
I guess we can use the same constant as SPL_TEXT_BASE for all the platforms?
diff --git a/include/configs/k2hk_evm.h b/include/configs/k2hk_evm.h index 0b909a1bf6..0ffbc464cc 100644 --- a/include/configs/k2hk_evm.h +++ b/include/configs/k2hk_evm.h @@ -40,8 +40,7 @@
#include <configs/ti_armv7_keystone2.h>
-/* SPL SPI Loader Configuration */ -#define CONFIG_SPL_TEXT_BASE 0x0c200000 +#define CONFIG_SYS_INIT_SP_ADDR 0x0c200000
#define SPI_MTD_PARTS KEYSTONE_SPI0_MTD_PARTS
Thanks and regards, Lokesh
On Mon, Oct 08, 2018 at 10:47:06AM +0530, Lokesh Vutla wrote:
Hi Tom,
Hey folks,
If there's not a constant we can use for all K2 platforms then, OK, I'll work-something up based on that idea. Thanks!
Lokesh Vutla
