[PATCH] misc: fs_loader: Fix alignment of fs_loader driver
DM_DRIVER_GET will redeclare the fs_loader driver without the correct alignment. This causes GCC to use the default section alignment of 32 bytes. This in turn creates a gap in the linker list due to the padding required to achieve the correct alignment, corrupting all further entries. Use DM_DRIVER_REF instead, which doesn't redeclare anything.
Fixes: 0998a20cfc6 ("misc: fs_loader: Add function to get the chosen loader") Signed-off-by: Sean Anderson seanga2@gmail.com ---
drivers/misc/fs_loader.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/misc/fs_loader.c b/drivers/misc/fs_loader.c index ccf5c7a8037..1ffc199ba1e 100644 --- a/drivers/misc/fs_loader.c +++ b/drivers/misc/fs_loader.c @@ -316,7 +316,7 @@ int get_fs_loader(struct udevice **dev) return ret;
/* Just create a new device */ - ret = device_bind(dm_root(), DM_DRIVER_GET(fs_loader), "default-loader", + ret = device_bind(dm_root(), DM_DRIVER_REF(fs_loader), "default-loader", &default_plat, ofnode_null(), dev); if (ret) return ret;
doc/api/linker_lists.rst describes this problem.
We are using DM_DRIVER_GET() a lot and DM_DRIVER_REF() rarely.
I have seen that ll_entry_get exists since 2012 when Marek introduced linker lists into U-Boot and ll_entry_ref since 2021.
In which use cases are ll_entry_get() and DM_DRIVER_GET() really needed? Or can they both be completely replaced by ll_entry_ref() and DM_DRIVER_REF().
Best regards
Heinrich
- ret = device_bind(dm_root(), DM_DRIVER_REF(fs_loader), "default-loader", &default_plat, ofnode_null(), dev); if (ret) return ret;
Sean Anderson
