[PATCH] configs: omap3x_logic: Enable LTO on more LogicPD OMAP3 boards
There are five omap3 based boards from LogicPD. Two of them have added LTO support. Add the remaining three to use LTO.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index 9ff5929b96..d359e32a36 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -12,6 +12,7 @@ CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set CONFIG_SPL=y CONFIG_DEFAULT_DEVICE_TREE="logicpd-torpedo-35xx-devkit" +CONFIG_LTO=y CONFIG_DISTRO_DEFAULTS=y CONFIG_ANDROID_BOOT_IMAGE=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index 2cc7060de5..d221ace735 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -12,6 +12,7 @@ CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set CONFIG_SPL=y CONFIG_DEFAULT_DEVICE_TREE="logicpd-som-lv-35xx-devkit" +CONFIG_LTO=y CONFIG_DISTRO_DEFAULTS=y CONFIG_ANDROID_BOOT_IMAGE=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index 90c670cee2..e2b71c5ab6 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -12,6 +12,7 @@ CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set CONFIG_SPL=y CONFIG_DEFAULT_DEVICE_TREE="logicpd-som-lv-37xx-devkit" +CONFIG_LTO=y CONFIG_DISTRO_DEFAULTS=y CONFIG_ANDROID_BOOT_IMAGE=y # CONFIG_USE_BOOTCOMMAND is not set
There are many merge conflicts with this patch. Can you rebase on top of latest master and repost?
Thanks and regards, Lokesh
Adam Ford
Lokesh Vutla
